    4. InfluxDB
    5. 100er von Warnmeldungen, was ist jetzt wieder?
      Accuface last edited by Accuface
      Bekomme seid heute jede Minute Hunterte von diesen Meldungen.
      Ich versteh das so, dass er nicht mehr schreiben/übertragen kann. Ich hab aber doch nix verändert, Einstellungen passen auch noch.
      Wenn ich in die Influx schaue, dann werden aber werte übertragen und auch korrekt beschrieben.
      influxdb.0
      40112	2024-11-17 20:18:05.187	info	Add point that had error for alias.0.KG.Waschkueche.Trockner.Power to buffer again, error-count=7
      influxdb.0
      40112	2024-11-17 20:18:05.187	warn	Error on writePoint("{"value":0,"time":"2024-11-17T19:18:05.019Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.187	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.184	info	Add point that had error for alias.0.Strom_Haus.MT681#1_Total_in to buffer again, error-count=9
      influxdb.0
      40112	2024-11-17 20:18:05.184	warn	Error on writePoint("{"value":114.739,"time":"2024-11-17T19:18:04.954Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.183	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.181	info	Add point that had error for alias.0.Strom_Haus.MT681#1_Power_cur to buffer again, error-count=9
      influxdb.0
      40112	2024-11-17 20:18:05.181	warn	Error on writePoint("{"value":438,"time":"2024-11-17T19:18:04.951Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.181	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.180	info	Discard point that had error for alias.0.Strom_Haus.MT681#2_Power_cur, error-count=10
      influxdb.0
      40112	2024-11-17 20:18:05.180	warn	Error on writePoint("{"value":0,"time":"2024-11-17T19:18:04.957Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.179	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.167	warn	Error on writePoint("{"value":0,"time":"2024-11-17T19:18:05.020Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.167	info	Add point that had error for alias.0.KG.Waschkueche.WM.Power to buffer again, error-count=6
      influxdb.0
      40112	2024-11-17 20:18:05.166	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.165	info	Add point that had error for alias.0.KG.Waschkueche.Trockner.Power to buffer again, error-count=6
      influxdb.0
      40112	2024-11-17 20:18:05.165	warn	Error on writePoint("{"value":0,"time":"2024-11-17T19:18:05.019Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.164	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.163	warn	Error on writePoint("{"value":0,"time":"2024-11-17T19:18:04.957Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.163	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.163	info	Add point that had error for alias.0.Strom_Haus.MT681#2_Power_cur to buffer again, error-count=9
      influxdb.0
      40112	2024-11-17 20:18:05.162	info	Discard point that had error for alias.0.Strom_Haus.MT681#1_Total_out, error-count=10
      influxdb.0
      40112	2024-11-17 20:18:05.161	warn	Error on writePoint("{"value":474.589,"time":"2024-11-17T19:18:04.955Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.161	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.158	info	Add point that had error for alias.0.Strom_Haus.MT681#1_Total_in to buffer again, error-count=8
      influxdb.0
      40112	2024-11-17 20:18:05.158	warn	Error on writePoint("{"value":114.739,"time":"2024-11-17T19:18:04.954Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.158	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.156	info	Add point that had error for alias.0.Strom_Haus.MT681#1_Power_cur to buffer again, error-count=8
      influxdb.0
      40112	2024-11-17 20:18:05.156	warn	Error on writePoint("{"value":438,"time":"2024-11-17T19:18:04.951Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.156	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.154	info	Add point that had error for alias.0.Strom_Haus.MT681#2_Power_cur to buffer again, error-count=8
      influxdb.0
      40112	2024-11-17 20:18:05.154	warn	Error on writePoint("{"value":0,"time":"2024-11-17T19:18:04.957Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.153	warn	Point could not be written to database: TESTONE
      influxdb.0
      40112	2024-11-17 20:18:05.151	info	Add point that had error for alias.0.Strom_Haus.MT681#1_Total_out to buffer again, error-count=9
      influxdb.0
      40112	2024-11-17 20:18:05.150	warn	Error on writePoint("{"value":474.589,"time":"2024-11-17T19:18:04.955Z","from":"system.adapter.influxdb.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
      influxdb.0
      40112	2024-11-17 20:18:05.150	warn	Point could not be written to database: TESTONE
      Verbindung ist ok:
      EDIT:
      Wenn ich im Bucket versuche den Speicherzeitraum zu ändern kommt selbe Fehlermeldung wie im Iobroker:
      Platz ist auch noch genug:
      Nach reboot des Raspi bekomm ich diese meldung beim versuch mich über das Terminal einzuloggen:
      • wendy2702
        wendy2702 @Accuface last edited by wendy2702
        @accuface welchen Pi hast du denn neu gestartet?
        Der auf dem iobroker oder Influx läuft?
        Warum hast du das mit rot unkenntlich gemacht?
        Hängt der Pi direkt im Internet und ist von außen durch Port Freigabe oder so erreichbar?
        OliverIO A 2 Replies Last reply Reply Quote 1
        • OliverIO
          OliverIO @wendy2702 last edited by
          @wendy2702 sagte in 100er von Warnmeldungen, was ist jetzt wieder?:
          Was hast du das mit rot unkenntlich gemacht
          user und ip adressen
          wendy2702 1 Reply Last reply Reply Quote 1
          • wendy2702
            wendy2702 @OliverIO last edited by wendy2702
            @oliverio ja, ich weiß.
            Wollte eher damit ausdrücken „warum“ er dass gemacht hat.
            Edit:
            Gerade gesehen das er aus meinem „Warum“ ein „Was“ gemacht hat. Habe es korrigiert.
              Accuface @wendy2702 last edited by Accuface
              @wendy2702 said in 100er von Warnmeldungen, was ist jetzt wieder?:
              Moin,
              Sorry fürs späte Feedback. bissl viel um die Ohren kurz vor Weihnachten.
              Also, mittlerweile läuft alles wieder. Ich hab keine Ahnung was genau der Auslöser war, aber ich hatte den Pi5 mit dem iob drauf und den pi5 mit Influx drauf für mehrer Stunden oder genauer gesagt über Nacht runtergefahren und vom Strom genommen.
              Danach ging alles wieder. wenn dass natürlich alle paar wochen passiert, tick ich aus.
              Nachdem ich etwas gegoogelt hatte, hab ich nen Post gelesen wo der Fehler wohl von irgendeinem Puffer kommt, der wohl beim verarbeiten der Empfangenen Daten nicht hinterherkommt....oder so ähnlich. Ich hab da keine Ahnung von.
              Um deine restlichen Fragen zu beantworten:
              Weil ich nicht genau weiß mit welchen Daten man Unsinn anstellen KÖNNTE, lieber einmal zuviel zensiert, als dann ärger zu haben. Zudem sind diese Daten nicht relevant für das Problem.
              Hängt der Pi direkt im Internet....
              Nein, nur im Netzwerk
              ........und ist von außen durch Port Freigabe oder so erreichbar?
              Nein, auch nur innerhalb meines Netzwerkes
                Accuface @Accuface last edited by
                tja, zu früh gefreut:
                heute gehts wieder los:
                influxdb.0
                2024-11-22 17:34:21.255	warn	Error on writePoint("{"value":575.907,"time":"2024-11-22T16:34:21.152Z","from":"system.adapter.sonoff.0","q":0,"ack":true}): HttpError: unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error / "unexpected error writing points to database: write /var/lib/influxdb/influxd.bolt: input/output error""
                influxdb.0
                2024-11-22 17:34:21.255	warn	Point could not be written to database: TESTONE
                irgendjemand einen Lösungsansatz. was stimmt da nicht?
                aktuelle Daten sind drin in der DB, wird also definitiv beschrieben
                  Thomas Braun Most Active @Accuface last edited by
                  @accuface
                  IO-Error könnte auch von einem wackeligen Dateisystem kommen.
                    Accuface @Thomas Braun last edited by Accuface
                    @thomas-braun said in 100er von Warnmeldungen, was ist jetzt wieder?:
                    @accuface
                    was bedeutet wackelig? iob und influx sind jeweils auf nem Pi5.
                    influx mit 1TB SSD
                      @accuface
                      Die Frage ist eher, auf welchem Dateisystem. Ich vermute ext4. Schau dir die Ausgabe von
                      dmesg -T
                      an. Da könnte evtl. was drin stehen.
                      A 2 Replies Last reply Reply Quote 0
                        @accuface
                        dmesg -T
                        komm ich nicht drauf:
                        PS C:\Users\bernd> ssh pi@XXXXXXXpi5
                        kex_exchange_identification: read: Connection reset
                        Connection reset by 2001:9e8:29d0:2d00:XXXXXXXXXX port 22
                        die meldung hatte ich das letzte mal auch schon
                          @accuface
                          Auch das kann auf ein ,in den Angeln hängendes' System hindeuten.
                            @accuface
                            der Pi scheint sich aufgehängt zu haben..... der reagiert auf den resetknopf nicht. in die datenbank kann ich mich aber einloggen und benutzen....sehr komisch, bin aber auch kein IT freak
                            • Meister Mopper
                              Meister Mopper @Accuface last edited by
                              @accuface sagte in 100er von Warnmeldungen, was ist jetzt wieder?:
                              @accuface
                              Wo hat denn der Raspberry Pi einen resetknopf?
                                @accuface
                                dmesg -T
                                nachdem ich den Pi für einige Minuten vom Netz genommen habe, konnte ich ihn wieder bedienen
                                dmesg -T
                                [Fri Nov 22 18:52:33 2024] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
                                [Fri Nov 22 18:52:33 2024] Linux version 6.6.51+rpt-rpi-2712 (serge@raspberrypi.com) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08)
                                [Fri Nov 22 18:52:33 2024] KASLR enabled
                                [Fri Nov 22 18:52:33 2024] random: crng init done
                                [Fri Nov 22 18:52:33 2024] Machine model: Raspberry Pi 5 Model B Rev 1.0
                                [Fri Nov 22 18:52:33 2024] efi: UEFI not found.
                                [Fri Nov 22 18:52:33 2024] Reserved memory: created CMA memory pool at 0x0000000002000000, size 320 MiB
                                [Fri Nov 22 18:52:33 2024] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                                [Fri Nov 22 18:52:33 2024] OF: reserved mem: 0x0000000002000000..0x0000000015ffffff (327680 KiB) map reusable linux,cma
                                [Fri Nov 22 18:52:33 2024] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
                                [Fri Nov 22 18:52:33 2024] OF: reserved mem: 0x000000003fd165c0..0x000000003fd165f7 (0 KiB) nomap non-reusable nvram@0
                                [Fri Nov 22 18:52:33 2024] Zone ranges:
                                [Fri Nov 22 18:52:33 2024]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
                                [Fri Nov 22 18:52:33 2024]   DMA32    empty
                                [Fri Nov 22 18:52:33 2024]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
                                [Fri Nov 22 18:52:33 2024] Movable zone start for each node
                                [Fri Nov 22 18:52:33 2024] Early memory node ranges
                                [Fri Nov 22 18:52:33 2024]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
                                [Fri Nov 22 18:52:33 2024]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
                                [Fri Nov 22 18:52:33 2024]   node   0: [mem 0x0000000040000000-0x00000001ffffffff]
                                [Fri Nov 22 18:52:33 2024] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
                                [Fri Nov 22 18:52:33 2024] On node 0, zone DMA: 256 pages in unavailable ranges
                                [Fri Nov 22 18:52:33 2024] psci: probing for conduit method from DT.
                                [Fri Nov 22 18:52:33 2024] psci: PSCIv1.1 detected in firmware.
                                [Fri Nov 22 18:52:33 2024] psci: Using standard PSCI v0.2 function IDs
                                [Fri Nov 22 18:52:33 2024] psci: MIGRATE_INFO_TYPE not supported.
                                [Fri Nov 22 18:52:33 2024] psci: SMC Calling Convention v1.2
                                [Fri Nov 22 18:52:33 2024] percpu: Embedded 14 pages/cpu s183976 r8192 d37208 u229376
                                [Fri Nov 22 18:52:33 2024] pcpu-alloc: s183976 r8192 d37208 u229376 alloc=14*16384
                                [Fri Nov 22 18:52:33 2024] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                                [Fri Nov 22 18:52:33 2024] Detected PIPT I-cache on CPU0
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Virtualization Host Extensions
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Hardware dirty bit management
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Spectre-v4
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Spectre-BHB
                                [Fri Nov 22 18:52:33 2024] CPU features: kernel page table isolation forced ON by KASLR
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Kernel page table isolation (KPTI)
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: SSBS not fully self-synchronizing
                                [Fri Nov 22 18:52:33 2024] alternatives: applying boot alternatives
                                [Fri Nov 22 18:52:33 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:7E:BC:31 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=75a12da1-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                [Fri Nov 22 18:52:33 2024] Dentry cache hash table entries: 1048576 (order: 9, 8388608 bytes, linear)
                                [Fri Nov 22 18:52:33 2024] Inode-cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
                                [Fri Nov 22 18:52:33 2024] Built 1 zonelists, mobility grouping on.  Total pages: 521984
                                [Fri Nov 22 18:52:33 2024] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
                                [Fri Nov 22 18:52:33 2024] software IO TLB: area num 4.
                                [Fri Nov 22 18:52:33 2024] software IO TLB: mapped [mem 0x00000000fbffc000-0x00000000ffffc000] (64MB)
                                [Fri Nov 22 18:52:33 2024] Memory: 7901328K/8384512K available (13440K kernel code, 2224K rwdata, 4304K rodata, 5056K init, 1213K bss, 155504K reserved, 327680K cma-reserved)
                                [Fri Nov 22 18:52:33 2024] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                [Fri Nov 22 18:52:33 2024] ftrace: allocating 43243 entries in 43 pages
                                [Fri Nov 22 18:52:33 2024] ftrace: allocated 43 pages with 4 groups
                                [Fri Nov 22 18:52:33 2024] trace event string verifier disabled
                                [Fri Nov 22 18:52:33 2024] rcu: Preemptible hierarchical RCU implementation.
                                [Fri Nov 22 18:52:33 2024] rcu:         RCU event tracing is enabled.
                                [Fri Nov 22 18:52:33 2024] rcu:         RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
                                [Fri Nov 22 18:52:33 2024]      Trampoline variant of Tasks RCU enabled.
                                [Fri Nov 22 18:52:33 2024]      Rude variant of Tasks RCU enabled.
                                [Fri Nov 22 18:52:33 2024]      Tracing variant of Tasks RCU enabled.
                                [Fri Nov 22 18:52:33 2024] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                                [Fri Nov 22 18:52:33 2024] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                [Fri Nov 22 18:52:33 2024] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                                [Fri Nov 22 18:52:33 2024] Root IRQ handler: gic_handle_irq
                                [Fri Nov 22 18:52:33 2024] GIC: Using split EOI/Deactivate mode
                                [Fri Nov 22 18:52:33 2024] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                [Fri Nov 22 18:52:33 2024] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                                [Fri Nov 22 18:52:33 2024] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                                [Fri Nov 22 18:52:33 2024] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                                [Fri Nov 22 18:52:33 2024] Console: colour dummy device 80x25
                                [Fri Nov 22 18:52:33 2024] printk: console [tty1] enabled
                                [Fri Nov 22 18:52:33 2024] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                                [Fri Nov 22 18:52:33 2024] pid_max: default: 32768 minimum: 301
                                [Fri Nov 22 18:52:33 2024] LSM: initializing lsm=capability,integrity
                                [Fri Nov 22 18:52:33 2024] Mount-cache hash table entries: 16384 (order: 3, 131072 bytes, linear)
                                [Fri Nov 22 18:52:33 2024] Mountpoint-cache hash table entries: 16384 (order: 3, 131072 bytes, linear)
                                [Fri Nov 22 18:52:33 2024] cgroup: Disabling memory control group subsystem
                                [Fri Nov 22 18:52:33 2024] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
                                [Fri Nov 22 18:52:33 2024] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
                                [Fri Nov 22 18:52:33 2024] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
                                [Fri Nov 22 18:52:33 2024] rcu: Hierarchical SRCU implementation.
                                [Fri Nov 22 18:52:33 2024] rcu:         Max phase no-delay instances is 1000.
                                [Fri Nov 22 18:52:33 2024] EFI services will not be available.
                                [Fri Nov 22 18:52:33 2024] smp: Bringing up secondary CPUs ...
                                [Fri Nov 22 18:52:33 2024] Detected PIPT I-cache on CPU1
                                [Fri Nov 22 18:52:33 2024] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
                                [Fri Nov 22 18:52:33 2024] Detected PIPT I-cache on CPU2
                                [Fri Nov 22 18:52:33 2024] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
                                [Fri Nov 22 18:52:33 2024] Detected PIPT I-cache on CPU3
                                [Fri Nov 22 18:52:33 2024] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
                                [Fri Nov 22 18:52:33 2024] smp: Brought up 1 node, 4 CPUs
                                [Fri Nov 22 18:52:33 2024] SMP: Total of 4 processors activated.
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: 32-bit EL0 Support
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Common not Private translations
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: CRC32 instructions
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: RCpc load-acquire (LDAPR)
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: LSE atomic instructions
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Privileged Access Never
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: RAS Extension Support
                                [Fri Nov 22 18:52:33 2024] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
                                [Fri Nov 22 18:52:33 2024] CPU: All CPU(s) started at EL2
                                [Fri Nov 22 18:52:33 2024] alternatives: applying system-wide alternatives
                                [Fri Nov 22 18:52:33 2024] devtmpfs: initialized
                                [Fri Nov 22 18:52:33 2024] Enabled cp15_barrier support
                                [Fri Nov 22 18:52:33 2024] Enabled setend support
                                [Fri Nov 22 18:52:33 2024] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                                [Fri Nov 22 18:52:33 2024] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
                                [Fri Nov 22 18:52:33 2024] pinctrl core: initialized pinctrl subsystem
                                [Fri Nov 22 18:52:33 2024] DMI not present or invalid.
                                [Fri Nov 22 18:52:33 2024] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                [Fri Nov 22 18:52:33 2024] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                                [Fri Nov 22 18:52:33 2024] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                [Fri Nov 22 18:52:33 2024] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                                [Fri Nov 22 18:52:33 2024] audit: initializing netlink subsys (disabled)
                                [Fri Nov 22 18:52:33 2024] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
                                [Fri Nov 22 18:52:33 2024] thermal_sys: Registered thermal governor 'step_wise'
                                [Fri Nov 22 18:52:33 2024] cpuidle: using governor menu
                                [Fri Nov 22 18:52:33 2024] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                                [Fri Nov 22 18:52:33 2024] ASID allocator initialised with 32768 entries
                                [Fri Nov 22 18:52:33 2024] Serial: AMBA PL011 UART driver
                                [Fri Nov 22 18:52:33 2024] bcm2835-mbox 107c013880.mailbox: mailbox enabled
                                [Fri Nov 22 18:52:33 2024] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
                                [Fri Nov 22 18:52:33 2024] printk: console [ttyAMA10] enabled
                                [Fri Nov 22 18:52:33 2024] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-09-23T13:02:56, variant start_cd
                                [Fri Nov 22 18:52:33 2024] raspberrypi-firmware soc:firmware: Firmware hash is 2682625900000000000000000000000000000000
                                [Fri Nov 22 18:52:33 2024] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
                                [Fri Nov 22 18:52:33 2024] Modules: 0 pages in range for non-PLT usage
                                [Fri Nov 22 18:52:33 2024] Modules: 129408 pages in range for PLT usage
                                [Fri Nov 22 18:52:33 2024] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
                                [Fri Nov 22 18:52:33 2024] iommu: Default domain type: Translated
                                [Fri Nov 22 18:52:33 2024] iommu: DMA domain TLB invalidation policy: strict mode
                                [Fri Nov 22 18:52:33 2024] SCSI subsystem initialized
                                [Fri Nov 22 18:52:33 2024] usbcore: registered new interface driver usbfs
                                [Fri Nov 22 18:52:33 2024] usbcore: registered new interface driver hub
                                [Fri Nov 22 18:52:33 2024] usbcore: registered new device driver usb
                                [Fri Nov 22 18:52:33 2024] pps_core: LinuxPPS API ver. 1 registered
                                [Fri Nov 22 18:52:33 2024] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                [Fri Nov 22 18:52:33 2024] PTP clock support registered
                                [Fri Nov 22 18:52:33 2024] vgaarb: loaded
                                [Fri Nov 22 18:52:33 2024] clocksource: Switched to clocksource arch_sys_counter
                                [Fri Nov 22 18:52:34 2024] VFS: Disk quotas dquot_6.6.0
                                [Fri Nov 22 18:52:34 2024] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
                                [Fri Nov 22 18:52:34 2024] FS-Cache: Loaded
                                [Fri Nov 22 18:52:34 2024] CacheFiles: Loaded
                                [Fri Nov 22 18:52:34 2024] NET: Registered PF_INET protocol family
                                [Fri Nov 22 18:52:34 2024] IP idents hash table entries: 131072 (order: 6, 1048576 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] tcp_listen_portaddr_hash hash table entries: 4096 (order: 2, 65536 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] TCP established hash table entries: 65536 (order: 5, 524288 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] TCP bind hash table entries: 65536 (order: 7, 2097152 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] TCP: Hash tables configured (established 65536 bind 65536)
                                [Fri Nov 22 18:52:34 2024] MPTCP token hash table entries: 8192 (order: 3, 196608 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] UDP hash table entries: 4096 (order: 3, 131072 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] UDP-Lite hash table entries: 4096 (order: 3, 131072 bytes, linear)
                                [Fri Nov 22 18:52:34 2024] NET: Registered PF_UNIX/PF_LOCAL protocol family
                                [Fri Nov 22 18:52:34 2024] RPC: Registered named UNIX socket transport module.
                                [Fri Nov 22 18:52:34 2024] RPC: Registered udp transport module.
                                [Fri Nov 22 18:52:34 2024] RPC: Registered tcp transport module.
                                [Fri Nov 22 18:52:34 2024] RPC: Registered tcp-with-tls transport module.
                                [Fri Nov 22 18:52:34 2024] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                [Fri Nov 22 18:52:34 2024] PCI: CLS 0 bytes, default 64
                                [Fri Nov 22 18:52:34 2024] kvm [1]: IPA Size Limit: 40 bits
                                [Fri Nov 22 18:52:34 2024] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
                                [Fri Nov 22 18:52:34 2024] Trying to unpack rootfs image as initramfs...
                                [Fri Nov 22 18:52:34 2024] kvm [1]: vgic interrupt IRQ9
                                [Fri Nov 22 18:52:34 2024] kvm [1]: VHE mode initialized successfully
                                [Fri Nov 22 18:52:34 2024] Initialise system trusted keyrings
                                [Fri Nov 22 18:52:34 2024] workingset: timestamp_bits=46 max_order=19 bucket_order=0
                                [Fri Nov 22 18:52:34 2024] zbud: loaded
                                [Fri Nov 22 18:52:34 2024] NFS: Registering the id_resolver key type
                                [Fri Nov 22 18:52:34 2024] Key type id_resolver registered
                                [Fri Nov 22 18:52:34 2024] Key type id_legacy registered
                                [Fri Nov 22 18:52:34 2024] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                                [Fri Nov 22 18:52:34 2024] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                                [Fri Nov 22 18:52:34 2024] F2FS not supported on PAGE_SIZE(16384) != 4096
                                [Fri Nov 22 18:52:34 2024] Key type asymmetric registered
                                [Fri Nov 22 18:52:34 2024] Asymmetric key parser 'x509' registered
                                [Fri Nov 22 18:52:34 2024] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                                [Fri Nov 22 18:52:34 2024] io scheduler mq-deadline registered
                                [Fri Nov 22 18:52:34 2024] io scheduler kyber registered
                                [Fri Nov 22 18:52:34 2024] io scheduler bfq registered
                                [Fri Nov 22 18:52:34 2024] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
                                [Fri Nov 22 18:52:34 2024] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
                                [Fri Nov 22 18:52:34 2024] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
                                [Fri Nov 22 18:52:34 2024] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
                                [Fri Nov 22 18:52:34 2024] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
                                [Fri Nov 22 18:52:34 2024] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
                                [Fri Nov 22 18:52:34 2024] Freeing initrd memory: 11520K
                                [Fri Nov 22 18:52:34 2024] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                                [Fri Nov 22 18:52:34 2024] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
                                [Fri Nov 22 18:52:34 2024] serial serial0: tty port ttyS0 registered
                                [Fri Nov 22 18:52:34 2024] iproc-rng200 107d208000.rng: hwrng registered
                                [Fri Nov 22 18:52:34 2024] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
                                [Fri Nov 22 18:52:34 2024] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
                                [Fri Nov 22 18:52:34 2024] brd: module loaded
                                [Fri Nov 22 18:52:34 2024] loop: module loaded
                                [Fri Nov 22 18:52:34 2024] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                                [Fri Nov 22 18:52:34 2024] Loading iSCSI transport class v2.0-870.
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new device driver r8152-cfgselector
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new interface driver r8152
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new interface driver lan78xx
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new interface driver smsc95xx
                                [Fri Nov 22 18:52:34 2024] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                                [Fri Nov 22 18:52:34 2024] dwc_otg: FIQ enabled
                                [Fri Nov 22 18:52:34 2024] dwc_otg: NAK holdoff enabled
                                [Fri Nov 22 18:52:34 2024] dwc_otg: FIQ split-transaction FSM enabled
                                [Fri Nov 22 18:52:34 2024] Module dwc_common_port init
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new interface driver uas
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new interface driver usb-storage
                                [Fri Nov 22 18:52:34 2024] mousedev: PS/2 mouse device common for all mice
                                [Fri Nov 22 18:52:34 2024] rpi-rtc soc:rpi_rtc: registered as rtc0
                                [Fri Nov 22 18:52:34 2024] rpi-rtc soc:rpi_rtc: setting system clock to 2024-11-22T17:52:34 UTC (1732297954)
                                [Fri Nov 22 18:52:34 2024] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
                                [Fri Nov 22 18:52:34 2024] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                                [Fri Nov 22 18:52:34 2024] sdhci: Secure Digital Host Controller Interface driver
                                [Fri Nov 22 18:52:34 2024] sdhci: Copyright(c) Pierre Ossman
                                [Fri Nov 22 18:52:34 2024] sdhci-pltfm: SDHCI platform and OF driver helper
                                [Fri Nov 22 18:52:34 2024] ledtrig-cpu: registered to indicate activity on CPUs
                                [Fri Nov 22 18:52:34 2024] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
                                [Fri Nov 22 18:52:34 2024] hid: raw HID events driver (C) Jiri Kosina
                                [Fri Nov 22 18:52:34 2024] usbcore: registered new interface driver usbhid
                                [Fri Nov 22 18:52:34 2024] usbhid: USB HID core driver
                                [Fri Nov 22 18:52:34 2024] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
                                [Fri Nov 22 18:52:34 2024] NET: Registered PF_PACKET protocol family
                                [Fri Nov 22 18:52:34 2024] Key type dns_resolver registered
                                [Fri Nov 22 18:52:34 2024] registered taskstats version 1
                                [Fri Nov 22 18:52:34 2024] Loading compiled-in X.509 certificates
                                [Fri Nov 22 18:52:34 2024] Key type .fscrypt registered
                                [Fri Nov 22 18:52:34 2024] Key type fscrypt-provisioning registered
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie: host bridge /axi/pcie@110000 ranges:
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie:   No bus range found for /axi/pcie@110000, using [bus 00-ff]
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie:      MEM 0x1b80000000..0x1bffffffff -> 0x0080000000
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie:      MEM 0x1800000000..0x1b7fffffff -> 0x0400000000
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie: Forcing gen 2
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie: PCI host bridge to bus 0000:00
                                [Fri Nov 22 18:52:34 2024] pci_bus 0000:00: root bus resource [bus 00-ff]
                                [Fri Nov 22 18:52:34 2024] pci_bus 0000:00: root bus resource [mem 0x1b80000000-0x1bffffffff] (bus address [0x80000000-0xffffffff])
                                [Fri Nov 22 18:52:34 2024] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b7fffffff pref] (bus address [0x400000000-0x77fffffff])
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0: PME# supported from D0 D3hot
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
                                [Fri Nov 22 18:52:34 2024] brcm-pcie 1000110000.pcie: link up, 5.0 GT/s PCIe x1 (!SSC)
                                [Fri Nov 22 18:52:34 2024] pci 0000:01:00.0: [2646:5019] type 00 class 0x010802
                                [Fri Nov 22 18:52:34 2024] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
                                [Fri Nov 22 18:52:34 2024] pci 0000:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
                                [Fri Nov 22 18:52:34 2024] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0: BAR 8: assigned [mem 0x1b80000000-0x1b800fffff]
                                [Fri Nov 22 18:52:34 2024] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b80000000-0x1b80003fff 64bit]
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0: PCI bridge to [bus 01]
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0:   bridge window [mem 0x1b80000000-0x1b800fffff]
                                [Fri Nov 22 18:52:34 2024] pci 0000:00:00.0: Max Payload Size set to  512/ 512 (was  128), Max Read Rq  512
                                [Fri Nov 22 18:52:34 2024] pci 0000:01:00.0: Max Payload Size set to  512/ 512 (was  128), Max Read Rq  512
                                [Fri Nov 22 18:52:34 2024] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
                                [Fri Nov 22 18:52:34 2024] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
                                [Fri Nov 22 18:52:34 2024] pcieport 0000:00:00.0: AER: enabled with IRQ 38
                                [Fri Nov 22 18:52:34 2024] nvme nvme0: pci function 0000:01:00.0
                                [Fri Nov 22 18:52:34 2024] nvme 0000:01:00.0: enabling device (0000 -> 0002)
                                [Fri Nov 22 18:52:35 2024] hwmon hwmon1: temp1_input not attached to any thermal zone
                                [Fri Nov 22 18:52:35 2024] hwmon hwmon1: temp2_input not attached to any thermal zone
                                [Fri Nov 22 18:52:35 2024] hwmon hwmon1: temp3_input not attached to any thermal zone
                                [Fri Nov 22 18:52:35 2024] nvme nvme0: allocated 64 MiB host memory buffer.
                                [Fri Nov 22 18:52:35 2024] nvme nvme0: 4/0/0 default/read/poll queues
                                [Fri Nov 22 18:52:35 2024]  nvme0n1: p1 p2
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie: Forcing gen 2
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0001:00
                                [Fri Nov 22 18:52:35 2024] pci_bus 0001:00: root bus resource [bus 00-ff]
                                [Fri Nov 22 18:52:35 2024] pci_bus 0001:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
                                [Fri Nov 22 18:52:35 2024] pci_bus 0001:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0: [14e4:2712] type 01 class 0x060400
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0: PME# supported from D0 D3hot
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
                                [Fri Nov 22 18:52:35 2024] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: [1de4:0001] type 00 class 0x020000
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: supports D1
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: PME# supported from D0 D1 D3hot D3cold
                                [Fri Nov 22 18:52:35 2024] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0: PCI bridge to [bus 01]
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
                                [Fri Nov 22 18:52:35 2024] pci 0001:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
                                [Fri Nov 22 18:52:35 2024] pci 0001:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
                                [Fri Nov 22 18:52:35 2024] pcieport 0001:00:00.0: enabling device (0000 -> 0002)
                                [Fri Nov 22 18:52:35 2024] pcieport 0001:00:00.0: PME: Signaling with IRQ 44
                                [Fri Nov 22 18:52:35 2024] pcieport 0001:00:00.0: AER: enabled with IRQ 44
                                [Fri Nov 22 18:52:35 2024] rp1 0001:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
                                [Fri Nov 22 18:52:35 2024] rp1 0001:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
                                [Fri Nov 22 18:52:35 2024] rp1 0001:01:00.0: enabling device (0000 -> 0002)
                                [Fri Nov 22 18:52:35 2024] rp1 0001:01:00.0: chip_id 0x20001927
                                [Fri Nov 22 18:52:35 2024] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 106
                                [Fri Nov 22 18:52:35 2024] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 112 (2c:cf:67:7e:bc:31)
                                [Fri Nov 22 18:52:35 2024] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.0: xHCI Host Controller
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.0: irq 137, io mem 0x1f00200000
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
                                [Fri Nov 22 18:52:35 2024] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
                                [Fri Nov 22 18:52:35 2024] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                [Fri Nov 22 18:52:35 2024] usb usb1: Product: xHCI Host Controller
                                [Fri Nov 22 18:52:35 2024] usb usb1: Manufacturer: Linux 6.6.51+rpt-rpi-2712 xhci-hcd
                                [Fri Nov 22 18:52:35 2024] usb usb1: SerialNumber: xhci-hcd.0
                                [Fri Nov 22 18:52:35 2024] hub 1-0:1.0: USB hub found
                                [Fri Nov 22 18:52:35 2024] hub 1-0:1.0: 2 ports detected
                                [Fri Nov 22 18:52:35 2024] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
                                [Fri Nov 22 18:52:35 2024] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                [Fri Nov 22 18:52:35 2024] usb usb2: Product: xHCI Host Controller
                                [Fri Nov 22 18:52:35 2024] usb usb2: Manufacturer: Linux 6.6.51+rpt-rpi-2712 xhci-hcd
                                [Fri Nov 22 18:52:35 2024] usb usb2: SerialNumber: xhci-hcd.0
                                [Fri Nov 22 18:52:35 2024] hub 2-0:1.0: USB hub found
                                [Fri Nov 22 18:52:35 2024] hub 2-0:1.0: 1 port detected
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.1: xHCI Host Controller
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.1: irq 142, io mem 0x1f00300000
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
                                [Fri Nov 22 18:52:35 2024] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
                                [Fri Nov 22 18:52:35 2024] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
                                [Fri Nov 22 18:52:35 2024] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                [Fri Nov 22 18:52:35 2024] usb usb3: Product: xHCI Host Controller
                                [Fri Nov 22 18:52:35 2024] usb usb3: Manufacturer: Linux 6.6.51+rpt-rpi-2712 xhci-hcd
                                [Fri Nov 22 18:52:35 2024] usb usb3: SerialNumber: xhci-hcd.1
                                [Fri Nov 22 18:52:35 2024] hub 3-0:1.0: USB hub found
                                [Fri Nov 22 18:52:35 2024] hub 3-0:1.0: 2 ports detected
                                [Fri Nov 22 18:52:35 2024] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
                                [Fri Nov 22 18:52:35 2024] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                [Fri Nov 22 18:52:35 2024] usb usb4: Product: xHCI Host Controller
                                [Fri Nov 22 18:52:35 2024] usb usb4: Manufacturer: Linux 6.6.51+rpt-rpi-2712 xhci-hcd
                                [Fri Nov 22 18:52:35 2024] usb usb4: SerialNumber: xhci-hcd.1
                                [Fri Nov 22 18:52:35 2024] hub 4-0:1.0: USB hub found
                                [Fri Nov 22 18:52:35 2024] hub 4-0:1.0: 1 port detected
                                [Fri Nov 22 18:52:35 2024] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
                                [Fri Nov 22 18:52:35 2024] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:35 2024] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:35 2024] platform 1000800000.codec: Adding to iommu group 0
                                [Fri Nov 22 18:52:35 2024] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:35 2024] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:35 2024] platform 1000880000.pisp_be: Adding to iommu group 0
                                [Fri Nov 22 18:52:35 2024] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:35 2024] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:35 2024] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
                                [Fri Nov 22 18:52:35 2024] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
                                [Fri Nov 22 18:52:35 2024] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
                                [Fri Nov 22 18:52:35 2024] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
                                [Fri Nov 22 18:52:35 2024] platform axi:gpu: Adding to iommu group 1
                                [Fri Nov 22 18:52:35 2024] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
                                [Fri Nov 22 18:52:35 2024] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
                                [Fri Nov 22 18:52:35 2024] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
                                [Fri Nov 22 18:52:35 2024] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
                                [Fri Nov 22 18:52:35 2024] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
                                [Fri Nov 22 18:52:35 2024] mmc1: CQHCI version 5.10
                                [Fri Nov 22 18:52:35 2024] of_cfs_init
                                [Fri Nov 22 18:52:35 2024] of_cfs_init: OK
                                [Fri Nov 22 18:52:35 2024] clk: Disabling unused clocks
                                [Fri Nov 22 18:52:36 2024] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
                                [Fri Nov 22 18:52:36 2024] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
                                [Fri Nov 22 18:52:36 2024] Freeing unused kernel memory: 5056K
                                [Fri Nov 22 18:52:36 2024] Run /init as init process
                                [Fri Nov 22 18:52:36 2024]   with arguments:
                                [Fri Nov 22 18:52:36 2024]     /init
                                [Fri Nov 22 18:52:36 2024]   with environment:
                                [Fri Nov 22 18:52:36 2024]     HOME=/
                                [Fri Nov 22 18:52:36 2024]     TERM=linux
                                [Fri Nov 22 18:52:36 2024] mmc1: new ultra high speed DDR50 SDIO card at address 0001
                                [Fri Nov 22 18:52:36 2024] input: pwr_button as /devices/platform/pwr_button/input/input0
                                [Fri Nov 22 18:52:36 2024] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
                                [Fri Nov 22 18:52:36 2024] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
                                [Fri Nov 22 18:52:37 2024] EXT4-fs (nvme0n1p2): mounted filesystem 3b445224-0aeb-4897-9108-009ed4211fb4 ro with ordered data mode. Quota mode: none.
                                [Fri Nov 22 18:52:37 2024] NET: Registered PF_INET6 protocol family
                                [Fri Nov 22 18:52:37 2024] Segment Routing with IPv6
                                [Fri Nov 22 18:52:37 2024] In-situ OAM (IOAM) with IPv6
                                [Fri Nov 22 18:52:37 2024] systemd[1]: systemd 252.31-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Detected architecture arm64.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Hostname set to <influxpi5>.
                                [Fri Nov 22 18:52:37 2024] uart-pl011 107d001000.serial: no DMA platform data
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Queued start job for default target multi-user.target.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Created slice user.slice - User and Session Slice.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-75a12da1\x2d01.device - /dev/disk/by-partuuid/75a12da1-01...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Reached target paths.target - Path Units.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Reached target slices.target - Slice Units.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Reached target swap.target - Swaps.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
                                [Fri Nov 22 18:52:37 2024] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
                                [Fri Nov 22 18:52:37 2024] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
                                [Fri Nov 22 18:52:37 2024] fuse: init (API version 7.39)
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting systemd-journald.service - Journal Service...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
                                [Fri Nov 22 18:52:37 2024] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
                                [Fri Nov 22 18:52:38 2024] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
                                [Fri Nov 22 18:52:38 2024] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
                                [Fri Nov 22 18:52:38 2024] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
                                [Fri Nov 22 18:52:38 2024] systemd[1]: Started systemd-journald.service - Journal Service.
                                [Fri Nov 22 18:52:38 2024] EXT4-fs (nvme0n1p2): re-mounted 3b445224-0aeb-4897-9108-009ed4211fb4 r/w. Quota mode: none.
                                [Fri Nov 22 18:52:38 2024] systemd-journald[277]: Received client request to flush runtime journal.
                                [Fri Nov 22 18:52:38 2024] mc: Linux media interface: v0.10
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
                                [Fri Nov 22 18:52:38 2024] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
                                [Fri Nov 22 18:52:38 2024] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 0
                                [Fri Nov 22 18:52:38 2024] videodev: Linux video capture interface: v2.00
                                [Fri Nov 22 18:52:38 2024] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:38 2024] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
                                [Fri Nov 22 18:52:38 2024] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
                                [Fri Nov 22 18:52:38 2024] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
                                [Fri Nov 22 18:52:38 2024] rpivid 1000800000.codec: Device registered as /dev/video19
                                [Fri Nov 22 18:52:38 2024] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                                [Fri Nov 22 18:52:38 2024] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
                                [Fri Nov 22 18:52:38 2024] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
                                [Fri Nov 22 18:52:38 2024] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                                [Fri Nov 22 18:52:38 2024] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
                                [Fri Nov 22 18:52:38 2024] Bluetooth: Core ver 2.22
                                [Fri Nov 22 18:52:38 2024] NET: Registered PF_BLUETOOTH protocol family
                                [Fri Nov 22 18:52:38 2024] Bluetooth: HCI device and connection manager initialized
                                [Fri Nov 22 18:52:38 2024] Bluetooth: HCI socket layer initialized
                                [Fri Nov 22 18:52:38 2024] Bluetooth: L2CAP socket layer initialized
                                [Fri Nov 22 18:52:38 2024] Bluetooth: SCO socket layer initialized
                                [Fri Nov 22 18:52:38 2024] Bluetooth: HCI UART driver ver 2.3
                                [Fri Nov 22 18:52:38 2024] Bluetooth: HCI UART protocol H4 registered
                                [Fri Nov 22 18:52:38 2024] Bluetooth: HCI UART protocol Three-wire (H5) registered
                                [Fri Nov 22 18:52:38 2024] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
                                [Fri Nov 22 18:52:38 2024] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
                                [Fri Nov 22 18:52:38 2024] Bluetooth: HCI UART protocol Broadcom registered
                                [Fri Nov 22 18:52:38 2024] brcmfmac: F1 signature read @0x18000000=0x15264345
                                [Fri Nov 22 18:52:38 2024] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] Registered IR keymap rc-cec
                                [Fri Nov 22 18:52:38 2024] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
                                [Fri Nov 22 18:52:38 2024] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
                                [Fri Nov 22 18:52:38 2024] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input2
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
                                [Fri Nov 22 18:52:38 2024] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input3
                                [Fri Nov 22 18:52:38 2024] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input4
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
                                [Fri Nov 22 18:52:38 2024] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 1
                                [Fri Nov 22 18:52:38 2024] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
                                [Fri Nov 22 18:52:38 2024] usbcore: registered new interface driver brcmfmac
                                [Fri Nov 22 18:52:38 2024] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
                                [Fri Nov 22 18:52:38 2024] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM: chip id 107
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM: features 0x2f
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM4345C0
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
                                [Fri Nov 22 18:52:39 2024] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                                [Fri Nov 22 18:52:39 2024] Bluetooth: BNEP filters: protocol multicast
                                [Fri Nov 22 18:52:39 2024] Bluetooth: BNEP socket layer initialized
                                [Fri Nov 22 18:52:39 2024] Adding 204784k swap on /var/swap.  Priority:-2 extents:8 across:1982464k SS
                                [Fri Nov 22 18:52:39 2024] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
                                [Fri Nov 22 18:52:39 2024] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
                                [Fri Nov 22 18:52:39 2024] pps pps0: new PPS source ptp0
                                [Fri Nov 22 18:52:39 2024] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
                                [Fri Nov 22 18:52:39 2024] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
                                [Fri Nov 22 18:52:39 2024] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
                                [Fri Nov 22 18:52:39 2024] Bluetooth: MGMT ver 1.22
                                [Fri Nov 22 18:52:39 2024] NET: Registered PF_ALG protocol family
                                [Fri Nov 22 18:55:52 2024] systemd[829]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
                                code_text
                                  Accuface @Meister Mopper last edited by Accuface
                                  @meister-mopper said in 100er von Warnmeldungen, was ist jetzt wieder?:
                                  Da, das weiße...ist der 5er Pi
                                  • Meister Mopper
                                    Ah, so fortschrittlich bin ich (noch) nicht 😊
                                      gibts glaub auch erst seid dem 5er
                                      A Meister Mopper 2 Replies Last reply Reply Quote 0
                                        Accuface @Accuface last edited by Accuface
                                        df -h
                                        Filesystem      Size  Used Avail Use% Mounted on
                                        udev            3.8G     0  3.8G   0% /dev
                                        tmpfs           806M  5.2M  801M   1% /run
                                        /dev/nvme0n1p2  917G  2.2G  869G   1% /
                                        tmpfs           4.0G     0  4.0G   0% /dev/shm
                                        tmpfs           5.0M   48K  5.0M   1% /run/lock
                                        /dev/nvme0n1p1  510M   64M  447M  13% /boot/firmware
                                        tmpfs           806M     0  806M   0% /run/user/1000
                                        pi@XXXXXXXXXX:~ $ blkid -o list -w /dev/null
                                        device                     fs_type     label        mount point                    UUID
                                        /dev/nvme0n1p1             vfat        bootfs       /boot/firmware                 4C33-xxxx
                                        /dev/nvme0n1p2             ext4        rootfs       /                              3b445224-0aexxxxxx
                                        /dev/ram2                                           (not mounted)
                                        /dev/ram0                                           (not mounted)
                                        /dev/ram9                                           (not mounted)
                                        /dev/ram14                                          (not mounted)
                                        /dev/ram7                                           (not mounted)
                                        /dev/ram12                                          (not mounted)
                                        /dev/ram5                                           (not mounted)
                                        /dev/ram10                                          (not mounted)
                                        /dev/ram3                                           (not mounted)
                                        /dev/ram1                                           (not mounted)
                                        /dev/ram15                                          (not mounted)
                                        /dev/ram8                                           (not mounted)
                                        /dev/ram13                                          (not mounted)
                                        /dev/ram6                                           (not mounted)
                                        /dev/ram11                                          (not mounted)
                                        /dev/ram4                                           (not mounted)
                                        • Meister Mopper
                                          Na ja, bis zum 4er hab ich schon geschafft 😂
                                          917
