    4. Zigbee2MQTT auf LNX mit zyklischen Warnings
      tklein last edited by tklein
      folgende Meldungen kommen zyklisch auf meinem LNX Proxmox IOB-System:
      zigbee2mqtt.0 	2024-11-18 18:30:21.496	info	Connect to Zigbee2MQTT over websocket connection.
      mqtt.0 	2024-11-18 18:30:21.035	info	Client [mqttjs_d5ac25e0] publishOnSubscribe send all known states
      mqtt.0	2024-11-18 18:30:20.835	info	Client [mqttjs_d5ac25e0] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
      mqtt.0	2024-11-18 18:30:20.835	info	Client [mqttjs_d5ac25e0] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
      mqtt.0	2024-11-18 18:30:20.806	info	Client [mqttjs_d5ac25e0] connected with secret 1731951020801_3346
      zigbee2mqtt.0	2024-11-18 18:30:20.493	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:19.492	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:18.491	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:17.491	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:16.489	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:15.488	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:14.487	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:13.486	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:12.485	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:11.484	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:10.483	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:09.483	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:08.483	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:07.482	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:06.481	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:05.479	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:04.478	warn	Start try again in 1 seconds...
      zigbee2mqtt.0	2024-11-18 18:30:03.477	warn	Start try again in 1 seconds...
      mqtt.0	2024-11-18 18:30:02.477	info	Client [mqttjs_2077511c] connection closed: disconnected
      Im Log von der Zigbee2MQTT GUI steht nur folgendes:
      info 2024-11-18 18:32:28z2m: Successfully changed options
      info 2024-11-18 18:32:28z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/options', payload '{"data":{"restart_required":false},"status":"ok","transaction":"t5a97-1"}'
      Der Status vom Dienst/Service:
      Als Coordinator nutze ich den SLZB-06M mit
      • Aktuelle Kern-Firmware-Version: v2.5.8
      • Zigbee Firmware-Revision: 20231030
      MQTT und Zigbee2MQTT Adapter sind grün. System und Adapter sind aktuell.
      Was kann ich tun, damit die Warnungen nicht mehr auftreten?
      Thomas
        für mich sieht es so aus, als wenn der Z2M Dienst alle ca 30 sek sich verabschiedet:
        root@iobroker:~# sudo service zigbee2mqtt status
        * zigbee2mqtt.service - zigbee2mqtt
             Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
             Active: activating (auto-restart) (Result: timeout) since Mon 2024-11-18 19:08:43 CET; 1s ago
            Process: 5331 ExecStart=/usr/bin/node index.js (code=exited, status=1/FAILURE)
           Main PID: 5331 (code=exited, status=1/FAILURE)
                CPU: 2.278s
             Active: activating (start) since Mon 2024-11-18 19:08:53 CET; 2s ago
           Main PID: 5367 (node)
              Tasks: 11 (limit: 18931)
             Memory: 98.0M
                CPU: 1.498s
             CGroup: /system.slice/zigbee2mqtt.service
                     `-5367 /usr/bin/node index.js
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> ACK  (5)
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> [8520dd7e]
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: <-- ACK (2): 4a0bb1a96b2a164fa674eb04aaa76d499db3d8fbe5ce67b2307e
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: Unexpected packet sequence 2 | 0
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: Skipping the packet as repeated (5)
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: <-- Error c20251a8bd7e
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: Uart reseting
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> Write reset
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> [1ac038bc7e]
        Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: -?- waiting reset
        root@iobroker:~# ^C
        root@iobroker:~#
          was ich komisch finde ist, dass es eine Pause in den Logs gibt: 22:37 - 07:20 Uhr:
            kein plan was der da macht...
            kannst du mal zigbee2mqtt manuell starten über konsole
            zuerst service stoppen
            in dem zigbee2mqtt Ordner wechseln und dann
            npm start
            und dann gucken was da kommt..
              tklein @arteck last edited by
              @arteck
              hier mal der anfang von der ausgabe:
              root@iobroker:/opt/zigbee2mqtt# npm start
              > zigbee2mqtt@1.40.1 start
              > node index.js
              Starting Zigbee2MQTT without watchdog.
              [2024-11-19 10:28:48] info:     z2m: Logging to console, file (filename: log.log)
              [2024-11-19 10:28:48] debug:    z2m: Loaded state from file /opt/zigbee2mqtt/data/state.json
              [2024-11-19 10:28:48] info:     z2m: Starting Zigbee2MQTT version 1.40.1 (commit #403d3c0)
              [2024-11-19 10:28:48] info:     z2m: Starting zigbee-herdsman (0.57.3)
              [2024-11-19 10:28:48] debug:    z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":1748,\"extendedPanID\":[106,111,32,69,142,92,130,83],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/opt/zigbee2mqtt/data/database.db\",\"databaseBackupPath\":\"/opt/zigbee2mqtt/data/database.db.backup\",\"backupPath\":\"/opt/zigbee2mqtt/data/coordinator_backup.json\",\"serialPort\":{\"baudRate\":115200,\"path\":\"tcp://192.168.0.33:6638\",\"adapter\":\"ezsp\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
              [2024-11-19 10:28:48] debug:    zh:ezsp: Adapter concurrent: 8
              [2024-11-19 10:28:48] debug:    zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":1748,"extendedPanID":[106,111,32,69,142,92,130,83],"channelList":[11]},"serialPort":{"baudRate":115200,"path":"tcp://192.168.0.33:6638","adapter":"ezsp"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/opt/zigbee2mqtt/data/database.db","databaseBackupPath":"/opt/zigbee2mqtt/data/database.db.backup","backupPath":"/opt/zigbee2mqtt/data/coordinator_backup.json"}'
              [2024-11-19 10:28:48] warning:  zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Opening TCP socket with 192.168.0.33:6638
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket connected
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket ready
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Uart reseting
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> Write reset
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [1ac038bc7e]
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: -?- waiting reset
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- [2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3203b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67e70e7e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357ec20251a8bd7e4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e]
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: reject condition
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [a0547d3a7e]
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,1): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: packet replay
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (3)
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [83401b7e]
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected packet sequence 2 | 0
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (3)
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,0): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (4)
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [8430fc7e]
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
              [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== Frame: 4190013f0006fcff00001f00000000000000ffff0000
              [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== 0x1: {"_cls_":"getLibraryStatus","_id_":1,"_isRequest_":false,"status":63}
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 4: packet replay
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,1): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (4)
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- Error c20251a8bd7e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (4,2,0): 4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e
              [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 4 | 0: reject condition
              [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- [c1020b0a527e]
              [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- RSTACK c1020b0a527e
              [2024-11-19 10:28:49] debug:    zh:ezsp:uart: RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
              [2024-11-19 10:28:49] debug:    zh:ezsp:uart: -+- waiting reset success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":4}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":4}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 00000004
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004221a850ed2c7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (1)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0142a1a8582805c1ae247e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0142a1a8582805c1ae247e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (1)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8160597e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0142a1a8582805c1ae247e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0080000c021073
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x0: {"_cls_":"version","_id_":0,"_isRequest_":false,"protocolVersion":12,"stackType":2,"stackVersion":29456}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (1) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Switching to eszp version 12
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":12}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":12}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 01000100000c
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314321a9542a1989fb7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (2)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1243a1a9542a19b049e7e2dc7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1243a1a9542a19b049e7e2dc7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (2)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [82503a7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1243a1a9542a19b049e7e2dc7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 01800100000c021073
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (2) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S = 90
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":56,"value":90}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":56,"value":90}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0200015300385a00
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224021a9072a2de8595e057e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (3)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2340a1a9072a159ab77e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2340a1a9072a159ab77e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (3)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [83401b7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2340a1a9072a159ab77e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 028001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x53: {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (3) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE = 2
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":25,"value":2}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":25,"value":2}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0300015300190200
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334121a9072a0cb05997eb7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (4)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3441a1a9072a15f1287e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3441a1a9072a15f1287e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (4)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8430fc7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3441a1a9072a15f1287e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 038001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (4) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_DELAY_MS = 50
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":29,"value":50}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":29,"value":50}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 04000153001d3200
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444621a9072a08805993d67e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (5)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4546a1a9072a1505697e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4546a1a9072a1505697e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (5)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8520dd7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4546a1a9072a1505697e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 048001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (5) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD = 2
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":34,"value":2}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":34,"value":2}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0500015300220200
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554721a9072a37b05980d97e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (6)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5647a1a9072a15af307e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5647a1a9072a15af307e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (6)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8610be7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5647a1a9072a15af307e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 058001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (6) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS = 3
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":42,"value":3}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":42,"value":3}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 06000153002a0300
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664421a9072a3fb1590b7a7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (7)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6744a1a9072a15803c7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6744a1a9072a15803c7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (7)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [87009f7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6744a1a9072a15803c7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 068001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (7) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT = 7680
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":18,"value":7680}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":18,"value":7680}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 070001530012001e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774521a9072a07b2473edc7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (0)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7045a1a9072a15eba37e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 7045a1a9072a15eba37e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (0)
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8070787e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 7045a1a9072a15eba37e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 078001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (0) success
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT = 14
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":19,"value":14}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":19,"value":14}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 0800015300130e00
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004a21a9072a06bc597d3aae7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [014aa1a9072a1512a07e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 014aa1a9072a1512a07e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 014aa1a9072a1512a07e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 088001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_SECURITY_LEVEL = 5
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":13,"value":5}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":13,"value":5}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 09000153000d0500
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314b21a9072a7d38b75961387e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [124ba1a9072a15b8f97e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 124ba1a9072a15b8f97e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 124ba1a9072a15b8f97e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 098001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_STACK_PROFILE = 2
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":12,"value":2}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":12,"value":2}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0a000153000c0200
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224821a9072a19b059deac7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2348a1a9072a1597f57e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2348a1a9072a1597f57e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2348a1a9072a1597f57e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0a8001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_WINDOW_SIZE = 1
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":28,"value":1}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":28,"value":1}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0b000153001c0100
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334921a9072a09b35937927e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3449a1a9072a15fc6a7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3449a1a9072a15fc6a7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3449a1a9072a15fc6a7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0b8001530000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.APP_KEY_REQUEST_POLICY = 96
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":6,"decisionId":96}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":6,"decisionId":96}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 0c00015500066000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444e21a9012a7d33d2599bc67e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [454ea1a9012a15ba8b7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 454ea1a9012a15ba8b7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 454ea1a9012a15ba8b7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0c8001550000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x55: {"_cls_":"setPolicy","_id_":85,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TC_KEY_REQUEST_POLICY = 81
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":5,"decisionId":81}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":5,"decisionId":81}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0d00015500055100
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554f21a9012a10e3590b3c7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [564fa1a9012a1510d27e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 564fa1a9012a1510d27e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 564fa1a9012a1510d27e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0d8001550000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TRUST_CENTER_POLICY = 3
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":0,"decisionId":3}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":0,"decisionId":3}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 0e00015500000300
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664c21a9012a15b15999227e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [674ca1a9012a153fde7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 674ca1a9012a153fde7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 674ca1a9012a153fde7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0e8001550000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_END_DEVICE_KEEP_ALIVE_SUPPORT_MODE = 3
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":63,"value":3}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":63,"value":3}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 0f0001ab003f0003
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774d21a9ff2a2ab25a7d3a767e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [704da1a9ff2a15ac127e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 704da1a9ff2a15ac127e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 704da1a9ff2a15ac127e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0f8001ab0000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xab: {"_cls_":"setValue","_id_":171,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_CCA_THRESHOLD = 0
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":21,"value":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":21,"value":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 100001ab00150000
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [005221a9ff2a00b25995147e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0152a1a9ff2a154f957e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0152a1a9ff2a154f957e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0152a1a9ff2a154f957e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 108001ab0000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConcentrator: {"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConcentrator","_id_":16,"_isRequest_":true,"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 110001100001f9ff0a005a00040300
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d315321a9442a144ba69e4a7faa519149699e7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1253a1a9442a15ebc27e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1253a1a9442a15ebc27e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1253a1a9442a15ebc27e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 118001100000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x10: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set concentrator type: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setSourceRouteDiscoveryMode: {"mode":1}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":true,"mode":1}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 1200015a0001
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [225021a90e2a1494327e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2350a1a90e2a3db2599476767e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2350a1a90e2a3db2599476767e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2350a1a90e2a3db2599476767e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 1280015a0028000000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x5a: {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":false,"remainingTime":40}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 1300010200010401efbe0007140000030006000a0019001a0000030000030004000500060008002000000300040204050406040005010b030b040b0207001001fc02fc
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [335121a9562a14b6587bf425ad4192499f4e21abe7ce7d5e8be7c6638afc7d5e3ca7efcddb6f89ffcfdbf5d2698f4627abe8733fa3ee758740934f2d17bae277380c0ffbb91990397e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3451a1a9562a1582527e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3451a1a9562a1582527e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3451a1a9562a1582527e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 138001020000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x2: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Ezsp adding endpoint: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 1400010200f2e0a161000000012100
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [445621a9562ae752f8f54a25aa54b349844e7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4556a1a9562a15767d337e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4556a1a9562a1576137e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4556a1a9562a1576137e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 148001020000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Get EzspValueId.VALUE_VERSION_INFO
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getValue: {"valueId":17}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getValue","_id_":170,"_isRequest_":true,"valueId":17}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 150001aa0011
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [555721a9fe2a0430357e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5657a1a9fe2a15b5e9944d26ab5538abde7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5657a1a9fe2a15b5e9944d26ab5538abde7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5657a1a9fe2a15b5e9944d26ab5538abde7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 158001aa000007b00007030100aa
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xaa: {"_cls_":"getValue","_id_":170,"_isRequest_":false,"status":0,"value":{"type":"Buffer","data":[176,0,7,3,1,0,170]}}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Got EzspValueId.VALUE_VERSION_INFO = ��
              [2024-11-19 10:28:52] debug:    zh:ezsp:driv: EmberZNet version: 7.3.1.0 build 176
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkInit: undefined
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkInit","_id_":23,"_isRequest_":true}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 1600011700
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [665421a9432aff9d7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6754a5a9432a15d2d37e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6754a5a9432a15d2d37e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6754a5a9432a15d2d37e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 168401170000
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x17: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Network init result: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7754b1a94d2a85f04c7e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,7,0): 7754b1a94d2a85f04c7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 7754b1a94d2a85f04c7e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 169001190090
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x19: {"_cls_":"stackStatusHandler","_id_":25,"_isRequest_":false,"status":144}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,0,0): 1700012800
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [705521a97c2ad7027e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0055a1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e37627e]
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,0,0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 178001280000016a6f20458e5c8253d406050b0000000000f8ff07
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
              [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Current Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkState: undefined
              [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkState","_id_":24,"_isRequest_":true}
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,1,0): 1800011800
              [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [015a21a94c2ab7527e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [7d315aa1a94c2a17f2417e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,1,0): 115aa1a94c2a17f2417e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (2)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [82503a7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (1): 115aa1a94c2a17f2417e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 188001180002
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x18: {"_cls_":"networkState","_id_":24,"_isRequest_":false,"status":2}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (1) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network state 2
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (1,2,0): 1900012800
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [125b21a97c2accf27e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (2)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [225ba1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e782a7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (3)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [83401b7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (2): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 198001280000016a6f20458e5c8253d406050b0000000000f8ff07
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (2) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNodeId: undefined
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNodeId","_id_":39,"_isRequest_":true}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (2,3,0): 1a00012700
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [235821a9732a58327e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (3)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [3358a1a9732a15b2038c7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (3,3,0): 3358a1a9732a15b2038c7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (4)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8430fc7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (3): 3358a1a9732a15b2038c7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1a800127000000
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x27: {"_cls_":"getNodeId","_id_":39,"_isRequest_":false,"nodeId":0}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (3) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getEui64: undefined
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getEui64","_id_":38,"_isRequest_":true}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (3,4,0): 1b00012600
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [345921a9722a7d33977e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (4)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [4459a1a9722a6b30e56ab5fe1ed171177e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (4,4,0): 4459a1a9722a6b30e56ab5fe1ed171177e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (5)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8520dd7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (4): 4459a1a9722a6b30e56ab5fe1ed171177e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1b800126007e82bcfeffdbb484
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x26: {"_cls_":"getEui64","_id_":38,"_isRequest_":false,"eui64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (4) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network ready
              [2024-11-19 10:28:53] debug:    zh:ezsp: Device join request received: 0 84b4dbfffebc827e
              [2024-11-19 10:28:53] debug:    zh:ezsp: Requesting 'Node Descriptor' for '0'
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: ZDO Node_Desc_req params: {"dstaddr":0}
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: EZSP nwk=0, IEEE=0x84b4dbfffebc827e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":1}
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":1}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (4,5,0): 1c00016a0001
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [455e21a93e2a147b6a7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (5)
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> sendUnicast: {"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7d5e3fa7ebcdde7d310d4339240e66ed86c57e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (5,5,0): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (6)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8610be7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (5): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1c80016a00001a00017eb22b39b5c0ef47bab0d286a4d9459e0090000000000000007e82bcfeffdbb484
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (5) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"sendUnicast","_id_":52,"_isRequest_":true,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (5,6,0): 1d0001340000000000000200000000010000020303020000
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [565f21a9602a15b259944a27aa5592499d4e27a9eecd658bfd976f7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (6)
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: TRUST_CENTER_LINK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":3}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [665fa1a9602a15f071ef7e765fb5a97d312a15b259964a25aa5593499c0cd8abedce9874fec463893e537e065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (6,6,0): 665fa1a9602a15f071ef7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (7)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [87009f7e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 665fa1a9602a15f071ef7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d800134000042
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x34: {"_cls_":"sendUnicast","_id_":52,"_isRequest_":false,"status":0,"sequence":66}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (7,6,0): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (0)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8070787e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94014500000000020000000001000042ff000000ffff03020000
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp: processMessage: {"messageType":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lqi":255,"rssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (0,6,0): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (1)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8160597e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94013f000000000000020000000001000042030000
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x3f: {"_cls_":"messageSentHandler","_id_":63,"_isRequest_":false,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"status":0,"message":{"type":"Buffer","data":[]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (6) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":3}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (6,1,0): 1e00016a0003
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [615c21a93e2a167f587e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (7)
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [165fb1a97d312a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7d5e7f2826668cef8fbeeb5bd5d270177e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,6,0): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: Unexpected packet sequence 6 | 7
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d90014500000000028000000001000043ff000000ffff110200000000408fcdab528000412c800000
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":67,"clusterId":32770,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp  frame: {"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp parsed: {"_cls_":"nodeDescRsp","_id_":32770,"transId":2,"status":0,"nwkaddr":0,"descriptor":{"byte1":0,"byte2":64,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e]
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,7,0): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (7): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1e80016a0000030003c566ea92aaf677e2140a128084cfbd9201d0db0100000000000000000000000000
              [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
              [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (7) success
              [2024-11-19 10:28:53] debug:    zh:ezsp:driv: CURRENT_NETWORK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
              ^C[2024-11-19 10:28:53] debug:  zh:controller:device: Request Queue (0x84b4dbfffebc827e): default expiration timeout set to 0
              [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffeae693): default expiration timeout set to 0
              [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffec950b): default expiration timeout set to 0
              [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x003c84fffe18aed5): default expiration timeout set to 43200000
              [2024-11-19 10:28:53] debug:    z2m: Saving state to file /opt/zigbee2mqtt/data/state.json
              [2024-11-19 10:28:53] error:    z2m: Not connected to MQTT server!
              [2024-11-19 10:28:53] error:    z2m: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
              [2024-11-19 10:28:53] info:     z2m: Disconnecting from MQTT server
              [2024-11-19 10:28:53] info:     z2m: Stopping zigbee-herdsman...
              [2024-11-19 10:28:53] debug:    zh:controller:database: Writing database to '/opt/zigbee2mqtt/data/database.db'
              [2024-11-19 10:28:53] info:     z2m: Stopped zigbee-herdsman
              [2024-11-19 10:28:53] info:     z2m: Stopped Zigbee2MQTT
                hier mal die mqtt logs:
                mqtt.02024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:31:44.835	info	Client [mqttjs_b6def4ee] connected with secret 1732001504835_6979
                mqtt.0	2024-11-19 08:31:26.479	info	Client [mqttjs_297b7318] connection closed: disconnected
                mqtt.0	2024-11-19 08:30:03.883	info	Client [mqttjs_297b7318] publishOnSubscribe send all known states
                mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:30:03.653	info	Client [mqttjs_297b7318] connected with secret 1732001403653_5414
                mqtt.0	2024-11-19 08:29:45.478	info	Client [mqttjs_3e32c692] connection closed: disconnected
                mqtt.0	2024-11-19 08:28:22.870	info	Client [mqttjs_3e32c692] publishOnSubscribe send all known states
                mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:28:22.640	info	Client [mqttjs_3e32c692] connected with secret 1732001302640_1750
                mqtt.0	2024-11-19 08:28:04.478	info	Client [mqttjs_f14b52fd] connection closed: disconnected
                mqtt.0	2024-11-19 08:26:41.793	info	Client [mqttjs_f14b52fd] publishOnSubscribe send all known states
                mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:26:41.564	info	Client [mqttjs_f14b52fd] connected with secret 1732001201564_9659
                mqtt.0	2024-11-19 08:26:23.478	info	Client [mqttjs_9029bbbb] connection closed: disconnected
                mqtt.0	2024-11-19 08:25:01.034	info	Client [mqttjs_9029bbbb] publishOnSubscribe send all known states
                mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
                mqtt.0	2024-11-19 08:25:00.805	info	Client [mqttjs_9029bbbb] connected with secret 1732001100805_685
                mqtt.0	2024-11-19 08:24:42.478	info	Client [mqttjs_93e5d70e] connection closed: disconnected
                  du musst den schon länger laufen lassen bist der wieder ein
                  anzeigt...
                    @arteck
                    die ausgabe in eine datei ist nicht lange gelaufen. dann kam das:
                    root@iobroker:/opt/zigbee2mqtt# sudo service zigbee2mqtt stop
                    root@iobroker:/opt/zigbee2mqtt# npm start >> zigbee2mqtt_log.txt
                    /opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
                      var er = new ERR_STREAM_WRITE_AFTER_END();
                    Error: write after end
                        at writeAfterEnd (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
                        at DerivedLogger.Writable.write (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
                        at DerivedLogger.log (/opt/zigbee2mqtt/node_modules/winston/lib/winston/logger.js:231:12)
                        at Logger.log (/opt/zigbee2mqtt/lib/util/logger.ts:189:25)
                        at Logger.debug (/opt/zigbee2mqtt/lib/util/logger.ts:210:14)
                        at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                        at Object.onceWrapper (node:events:634:26)
                        at Socket.emit (node:events:531:35)
                        at TCP.<anonymous> (node:net:339:12)
                    Hier die Datei:
                    zigbee2mqtt_log.txt
                      hier noch die configuration.yaml:
                      homeassistant: false
                      frontend: true
                      mqtt:
                        base_topic: zigbee2mqtt
                        server: mqtt://192.168.0.22:1888
                      serial:
                        port: tcp://192.168.0.33:6638
                        baudrate: 115200
                        adapter: ezsp
                      advanced:
                        network_key:
                          - 197
                          - 102
                          - 234
                          - 146
                          - 170
                          - 246
                          - 119
                          - 226
                          - 20
                          - 10
                          - 18
                          - 128
                          - 132
                          - 207
                          - 189
                          - 146
                        pan_id: 1748
                        ext_pan_id:
                          - 106
                          - 111
                          - 32
                          - 69
                          - 142
                          - 92
                          - 130
                          - 83
                        homeassistant_legacy_entity_attributes: false
                        legacy_api: false
                        legacy_availability_payload: false
                        log_level: debug
                      device_options:
                        legacy: false
                      devices:
                        '0x282c02bfffeae693':
                          friendly_name: wassersensor_1
                        '0x282c02bfffec950b':
                          friendly_name: '0x282c02bfffec950b'
                        '0x003c84fffe18aed5':
                          friendly_name: '0x003c84fffe18aed5'
                        mit
                        sudo journalctl -u zigbee2mqtt.service -f
                        kam folgendes:
                        Nov 19 13:23:08 iobroker node[20281]:     at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                        Nov 19 13:23:08 iobroker node[20281]:     at Object.onceWrapper (node:events:634:26)
                        Nov 19 13:23:08 iobroker node[20281]:     at Socket.emit (node:events:531:35)
                        Nov 19 13:23:08 iobroker node[20281]:     at TCP.<anonymous> (node:net:339:12)
                        Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
                        Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Failed with result 'timeout'.
                        Nov 19 13:23:08 iobroker systemd[1]: Failed to start zigbee2mqtt.service - zigbee2mqtt.
                        Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Consumed 2.326s CPU time.
                        Nov 19 13:23:18 iobroker systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart c
                          arteck Developer Most Active @tklein last edited by
                          @tklein haswt du einen mosquitto installiert als mqtt server ??
                            @arteck
                            brauche ich den, wenn der iob mqtt als server läuft?
                              @tklein sagte in Zigbee2MQTT auf LNX mit zyklischen Warnings:
                              @arteck
                              da scheint irgendwas mit dem mqtt nicht zu stimmen...
                              stell mal den adapter so ein
                              und in der yaml von zigbee2mqtt mustt du es auch anpassten
                              server: mqtt://192.168.0.22:1884
                                @arteck jetzt sind die warnings weg 🙂 thx dafür
                                ist das ein normales verhalten?
                                zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m: Zigbee2MQTT started!
                                zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                                zigbee2mqtt.0 2024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                                zigbee2mqtt.0 2024-11-20 09:12:59.274	info	z2m: Started frontend on port 8080
                                zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m: Zigbee2MQTT started!
                                zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                                zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                                zigbee2mqtt.0 2024-11-20 09:11:18.122	info	z2m: Started frontend on port 8080
                                zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Zigbee2MQTT started!
                                zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                                zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                                zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Started frontend on port 8080
                                zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Zigbee2MQTT started!
                                zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                                zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                                zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Started frontend on port 8080
                                zigbee2mqtt.0 2024-11-20 09:06:15.147	info	z2m: Zigbee2MQTT started!
                                hier noch die logs on der gui des coordinators:
                                [09:07:49] taskZB | New client: 192.168.0.22 id: 0
                                [09:09:19] taskZB | Client disconnected, id: 0
                                [09:09:30] taskZB | New client: 192.168.0.22 id: 0
                                [09:11:00] taskZB | Client disconnected, id: 0
                                [09:11:11] taskZB | New client: 192.168.0.22 id: 0
                                [09:12:41] taskZB | Client disconnected, id: 0
                                [09:12:52] taskZB | New client: 192.168.0.22 id: 0
                                [09:14:22] taskZB | Client disconnected, id: 0
                                [09:14:33] taskZB | New client: 192.168.0.22 id: 0
                                [09:16:03] taskZB | Client disconnected, id: 0
                                [09:16:14] taskZB | New client: 192.168.0.22 id: 0
                                495
