    4. harmony - Terminated (UNCAUGHT_EXCEPTION): Without reason
    • Chris0706
      Chris0706 last edited by
      seit ein paar Tagen stützt mein Harmony Adapter immer wieder ab. Mit den Fehlermeldungen im Log kann ich nicht wirklich was anfangen.. Hab im IOBroker und in der Harmony App eigentlich nichts geändert..
      Log - Level Silly
      harmony.0
      2024-11-19 17:07:26.661	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.harmony, node: v20.16.0, js-controller: 6.0.11
      harmony.0
      2024-11-19 17:07:26.688	info	[DISCOVER] Searching for Harmony Hubs on 255.255.255.255
      harmony.0
      2024-11-19 17:07:36.971	info	[DISCOVER] Discovered Wohnzimmer (192.168.2.108) and will try to connect
      harmony.0
      2024-11-19 17:07:36.974	info	[DISCOVER] Discovered Schlafzimmer (192.168.2.114) and will try to connect
      harmony.0
      2024-11-19 17:07:36.987	info	[DISCOVER] Discovered Dachfenster (192.168.2.109) and will try to connect
      harmony.0
      2024-11-19 17:07:37.101	info	[CONNECT] Connecting to Wohnzimmer (192.168.2.108)
      harmony.0
      2024-11-19 17:07:37.122	info	[CONNECT] Connecting to Schlafzimmer (192.168.2.114)
      harmony.0
      2024-11-19 17:07:37.179	info	[CONNECT] Connecting to Dachfenster (192.168.2.109)
      harmony.0
      2024-11-19 17:07:37.200	error	uncaught exception: Unexpected server response: 401
      harmony.0
      2024-11-19 17:07:37.201	error	Error: Unexpected server response: 401 at ClientRequest.<anonymous> (/opt/iobroker/node_modules/harmonyhubws/node_modules/ws/lib/websocket.js:595:7) at ClientRequest.emit (node:events:519:28) at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:698:27) at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17) at Socket.socketOnData (node:_http_client:540:22) at Socket.emit (node:events:519:28) at addChunk (node:internal/streams/readable:559:12) at readableAddChunkPushByteMode (node:internal/streams/readable:510:3) at Readable.push (node:internal/streams/readable:390:5) at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
      harmony.0
      2024-11-19 17:07:37.201	error	Unexpected server response: 401
      harmony.0
      2024-11-19 17:07:37.206	info	[END] Terminating
      harmony.0
      2024-11-19 17:07:37.207	info	terminating
      harmony.0
      2024-11-19 17:07:37.207	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      CPU: 14,2 %
      RAM: 52 %
      Betriebszeit: 72d18h
      Verfügbar: 6.0.11
      Installiert: 6.0.11
      Ereignisse: ⇥21 / ↦13
      Plattform: linux
      Betriebssystem: linux
      Architektur: x64
      CPUs: 2
      Geschwindigkeit: 0 MHz
      Modell: Intel(R) Pentium(R) Gold G5420 CPU @ 3.80GHz
      RAM: 5.7 GB
      System-Betriebszeit: 96 T. 05:26:55
      Node.js: v20.16.0
      time: 1732031459740
      timeOffset: -60
      NPM: 10.8.1
      Adapter-Anzahl: 547
      Datenträgergröße: 36.1 GB
      Freier Festplattenspeicher: 22.2 GB
      Aktive Instanzen: 21
      Pfad: /opt/iobroker/
      Betriebszeit: 72 T. 18:34:08
      Was könnte das sein?
      Christian
      • Meister Mopper
        Meister Mopper @Chris0706 last edited by
        @chris0706
        Da können offenbar die Geräte nicht mit dem Hub kommunizieren.
        Ich würde den Hub mal ein paar Minuten stromlos machen und neu verbinden. Vielleicht ist auch das Netzteil des Hub eines natürlichen Todes gestorben. 🤷‍♀️
        • wendy2702
          wendy2702 last edited by
          Sind die Hubs noch per Ping vom iobroker aus erreichbar?
          Wurde was am Netzwerk geändert?
          • Chris0706
            Hubs sind alle per Harmony App erreichbar und Steuerbar. Aber werde sie mal alle stromlos machen und nach und nach einschalten.
            Habe das Netzwerk um einen Repeater erweitert, da aber alle Hubs erreichbar sind dachte / denke ich nicht das es da dran liegt?
            wendy2702 Samson71 2 Replies Last reply Reply Quote 0
            • wendy2702
              wendy2702 @Chris0706 last edited by
              @chris0706 doch, kann am Repeater liegen.
              Du hast also dein Netzwerk verändert, das wird dann wahrscheinlich doch die Ursache sein.
              • Samson71
                Samson71 Global Moderator @Chris0706 last edited by
                @chris0706
                Gegentest: Repeater wieder aus und nochmal probieren. Wenn es dann (wieder) tut, liegt es an den Dingern.
                Chris0706 1 Reply Last reply Reply Quote 0
                • Chris0706
                  Chris0706 @Samson71 last edited by
                  @samson71 also am Repeater liegts nicht, sondern an einem der drei Harmony Hubs.. Sobald der mit ins Netz geht, stürzt die Harmony Instanz ab.
                  Werde wohl mal den Hub zurücksetzen.
