    4. RPI2 Monitor wirft Fehlermeldung raus.
      Beowolf last edited by
      ich wollte den RPI2 Adapter installieren.
      Die Adapterinstallation endet mit diesem LOG Hinweis.
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.8.2
      2 info using node@v20.18.1
      3 silly config load:file:/usr/lib/node_modules/npm/npmrc
      4 silly config load:file:/opt/iobroker/.npmrc
      5 silly config load:file:/home/iobroker/.npmrc
      6 silly config load:file:/usr/etc/npmrc
      7 verbose title npm install iobroker-community-adapters/ioBroker.rpi2
      8 verbose argv "install" "iobroker-community-adapters/ioBroker.rpi2" "--foreground-scripts"
      9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-11-21T09_11_38_148Z-
      10 verbose logfile /home/iobroker/.npm/_logs/2024-11-21T09_11_38_148Z-debug-0.log
      11 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
      12 silly logfile start cleaning logs, removing 1 files
      13 silly logfile done cleaning log files
      14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      15 silly idealTree buildDeps
      16 silly fetch manifest iobroker.rpi2@iobroker-community-adapters/ioBroker.rpi2
      17 silly placeDep ROOT iobroker.rpi2@2.2.2 OK for: iobroker.inst@3.0.0 want: iobroker-community-adapters/ioBroker.rpi2
      18 silly fetch manifest opengpio@^1.0.16
      19 silly packumentCache full:https://registry.npmjs.org/opengpio cache-miss
      20 silly fetch manifest ci@^2.3.0
      21 silly packumentCache full:https://registry.npmjs.org/ci cache-miss
      22 silly fetch manifest node-dht-sensor@^0.4.3
      23 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor cache-miss
      24 http fetch GET 200 https://registry.npmjs.org/opengpio 20ms (cache hit)
      25 silly packumentCache full:https://registry.npmjs.org/opengpio set size:29380 disposed:false
      26 http fetch GET 200 https://registry.npmjs.org/ci 22ms (cache hit)
      27 silly packumentCache full:https://registry.npmjs.org/ci set size:22895 disposed:false
      28 http fetch GET 200 https://registry.npmjs.org/node-dht-sensor 22ms (cache hit)
      29 silly packumentCache full:https://registry.npmjs.org/node-dht-sensor set size:72767 disposed:false
      30 silly placeDep ROOT ci@2.3.0 OK for: iobroker.rpi2@2.2.2 want: ^2.3.0
      31 silly placeDep ROOT node-dht-sensor@0.4.3 OK for: iobroker.rpi2@2.2.2 want: ^0.4.3
      32 silly placeDep ROOT opengpio@1.0.16 OK for: iobroker.rpi2@2.2.2 want: ^1.0.16
      33 silly fetch manifest node-addon-api@^1.6.3
      34 silly packumentCache full:https://registry.npmjs.org/node-addon-api cache-miss
      35 silly fetch manifest debug@^4.3.4
      36 silly packumentCache full:https://registry.npmjs.org/debug cache-miss
      37 http fetch GET 200 https://registry.npmjs.org/node-addon-api 15ms (cache hit)
      38 silly packumentCache full:https://registry.npmjs.org/node-addon-api set size:290718 disposed:false
      39 http fetch GET 200 https://registry.npmjs.org/debug 21ms (cache hit)
      40 silly packumentCache full:https://registry.npmjs.org/debug set size:188929 disposed:false
      41 silly placeDep node_modules/node-dht-sensor node-addon-api@1.7.2 OK for: node-dht-sensor@0.4.3 want: ^1.6.3
      42 silly placeDep node_modules/opengpio debug@4.3.7 OK for: opengpio@1.0.16 want: ^4.3.4
      43 silly fetch manifest ms@^2.1.3
      44 silly packumentCache full:https://registry.npmjs.org/ms cache-miss
      45 http fetch GET 200 https://registry.npmjs.org/ms 17ms (cache hit)
      46 silly packumentCache full:https://registry.npmjs.org/ms set size:84885 disposed:false
      47 silly placeDep node_modules/opengpio ms@2.1.3 OK for: debug@4.3.7 want: ^2.1.3
      48 silly reify moves {}
      49 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-win32-x64-msvc
      50 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-win32-x64-msvc' ]
      51 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-win32-ia32-msvc
      52 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-win32-ia32-msvc' ]
      53 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-win32-arm64-msvc
      54 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-win32-arm64-msvc' ]
      55 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-linux-x64-musl
      56 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-linux-x64-musl' ]
      57 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-linux-x64-gnu
      58 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-linux-x64-gnu' ]
      59 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-linux-arm-gnueabihf
      60 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-linux-arm-gnueabihf' ]
      61 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-darwin-x64
      62 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-darwin-x64' ]
      63 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-darwin-universal
      64 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-darwin-universal' ]
      65 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-darwin-arm64
      66 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-darwin-arm64' ]
      67 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-android-arm64
      68 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-android-arm64' ]
      69 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto-android-arm-eabi
      70 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto-android-arm-eabi' ]
      71 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
      72 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
      73 http fetch GET 200 https://codeload.github.com/iobroker-community-adapters/ioBroker.rpi2/tar.gz/1e17dad080e6908c84cc0a8e3386881d3847943e 295ms (cache revalidated)
      74 verbose stack Error: git dep preparation failed
      74 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
      74 verbose stack     at module.exports (/usr/lib/node_modules/npm/node_modules/pacote/lib/util/npm.js:13:10)
      74 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/git.js:183:14
      74 verbose stack     at async withTempDir (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/with-temp-dir.js:21:14)
      75 error code 1
      76 error git dep preparation failed
      77 error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
      78 error > node-dht-sensor@0.4.3 install
      78 error > node-gyp configure
      78 error
      78 error
      78 error
      78 error > opengpio@1.0.16 install
      78 error > node-gyp rebuild
      78 error
      78 error
      78 error make: Entering directory '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio/build'
      78 error   CXX(target) Release/obj.target/opengpio/cpp/opengpio.o
      78 error make: Leaving directory '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio/build'
      79 error npm warn using --force Recommended protections disabled.
      79 error npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      79 error npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array instead
      79 error npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
      79 error npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.
      79 error gyp info it worked if it ends with ok
      79 error gyp info using node-gyp@10.1.0
      79 error gyp info using node@20.18.1 | linux | arm64
      79 error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
      79 error gyp info spawn /usr/bin/python3
      79 error gyp info spawn args [
      79 error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
      79 error gyp info spawn args 'binding.gyp',
      79 error gyp info spawn args '-f',
      79 error gyp info spawn args 'make',
      79 error gyp info spawn args '-I',
      79 error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/node-dht-sensor/build/config.gypi',
      79 error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
      79 error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.18.1/include/node/common.gypi',
      79 error gyp info spawn args '-Dlibrary=shared_library',
      79 error gyp info spawn args '-Dvisibility=default',
      79 error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.18.1',
      79 error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
      79 error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.18.1/<(target_arch)/node.lib',
      79 error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/node-dht-sensor',
      79 error gyp info spawn args '-Dnode_engine=v8',
      79 error gyp info spawn args '--depth=.',
      79 error gyp info spawn args '--no-parallel',
      79 error gyp info spawn args '--generator-output',
      79 error gyp info spawn args 'build',
      79 error gyp info spawn args '-Goutput_dir=.'
      79 error gyp info spawn args ]
      79 error gyp info ok
      79 error gyp info spawn args '/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio/build/config.gypi',
      79 error gyp info spawn args '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio',
      79 error gyp info spawn make
      79 error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      79 error ../cpp/opengpio.cpp:3:10: fatal error: gpiod.hpp: No such file or directory
      79 error     3 | #include <gpiod.hpp>
      79 error       |          ^~~~~~~~~~~
      79 error compilation terminated.
      79 error make: *** [opengpio.target.mk:106: Release/obj.target/opengpio/cpp/opengpio.o] Error 1
      79 error gyp ERR! build error
      79 error gyp ERR! stack Error: `make` failed with exit code: 2
      79 error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
      79 error gyp ERR! System Linux 6.6.51+rpt-rpi-2712
      79 error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      79 error gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio
      79 error gyp ERR! node -v v20.18.1
      79 error gyp ERR! node-gyp -v v10.1.0
      79 error gyp ERR! not ok
      79 error npm error code 1
      79 error npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneacjvzW/node_modules/opengpio
      79 error npm error command failed
      79 error npm error command sh -c node-gyp rebuild
      79 error npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-21T09_11_41_279Z-debug-0.log
      80 silly unfinished npm timer reify 1732180298438
      81 silly unfinished npm timer reify:unpack 1732180300842
      82 silly unfinished npm timer reifyNode:node_modules/iobroker.rpi2 1732180300842
      83 verbose cwd /opt/iobroker
      84 verbose os Linux 6.6.51+rpt-rpi-2712
      85 verbose node v20.18.1
      86 verbose npm  v10.8.2
      87 verbose exit 1
      88 verbose code 1
      89 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-11-21T09_11_38_148Z-debug-0.log
      Was läuft da wo falsch?
        Beowolf last edited by Beowolf
        Hat sich erledigt.
        Habe alles was ich finden konnte upgedatet. Nun läuft die Installation durch.
          Thomas Braun Most Active @Beowolf last edited by
          @beowolf sagte in RPI2 Monitor wirft Fehlermeldung raus.:
          Da kann opengpio nicht gebaut werden. Ist das Paket
          libgpiod-dev
          installiert?
          sudo apt update
          apt policy libgpiod-dev
            Das ist ohnehin eine Grundvoraussetzung für ein rundes System.
            Updates immer zeitnah einspielen.
              Trotzdem Danke für die Info.
