    4. Backitup - Influxdb2 Fehler bei Sicherung
      Snopy_16 last edited by
      Ich habe Iobroker in Proxmox auf einer VM
      Influxdb2 in einem eigenen Container
      Backitup erzeugt folgenden Meldung
      20:14:03.439INFOguiBackup gestartet ...
      20:14:03.488DEBUGmountmount activ... umount is started before mount!!
      20:14:03.644DEBUGmountumount successfully completed
      20:14:13.470DEBUGmountnfs-mount command: "sudo mount 192.168.178.10:/Sicherung/iobroker /opt/iobroker/backups"
      20:14:13.545DEBUGmountmount successfully completed
      20:14:13.589DEBUGmountdone
      20:14:14.575DEBUGiobrokerhost.iobroker 196 states saved
      20:14:14.594DEBUGiobrokerhost.iobroker 330 objects saved
      20:14:14.846DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz
      This backup can only be restored with js-controller version up from 4.1
      20:14:15.853DEBUGiobrokerdone
      20:14:16.010DEBUGinfluxDBInfluxDB-Backup started ...
      20:14:16.019DEBUGinfluxDBStart InfluxDB Backup ...
      20:14:16.070DEBUGinfluxDBInfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker" successfully deleted
      20:14:16.148DEBUGinfluxDBdone
      20:14:16.772DEBUGhistoryDBcompress from historyDB started ...
      20:14:16.778DEBUGhistoryDBBackup created: /opt/iobroker/backups/historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz
      20:14:16.817DEBUGhistoryDBdone
      20:14:17.679DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      20:14:17.741DEBUGjavascriptsTry deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      20:14:17.785DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      20:14:17.791DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz
      20:14:17.800DEBUGjavascriptsdone
      20:14:19.449DEBUGonedriveOnedrive: Copy iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz...
      20:14:21.417DEBUGonedrive77% uploaded from iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz
      20:14:22.270DEBUGonedrive100% uploaded from iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz
      20:14:22.284DEBUGonedriveOnedrive: Copy historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz...
      20:14:23.765DEBUGonedrive100% uploaded from historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz
      20:14:23.778DEBUGonedrivehistoryDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz with Id: F9759285BF3AC29!s13ced90a49024e8ca407102f2e0a1f60 saved on Onedrive
      20:14:23.789DEBUGonedriveOnedrive: Copy javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz...
      20:14:25.082DEBUGonedrive100% uploaded from javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz
      20:14:25.126DEBUGonedrivejavascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz with Id: F9759285BF3AC29!s5504a43ce19d44d98a12133ecb3aa421 saved on Onedrive
      20:14:25.138DEBUGonedrivedone
      20:14:25.269DEBUGcifsused copy path: /Sicherung/iobroker
      20:14:25.289DEBUGcifsdone
      20:14:25.689DEBUGgoogledriveGoogle Drive: Copy iobroker_2024_11_22-20_14_12_Proxmox_backupiobroker.tar.gz...
      20:14:28.201ERRORgoogledriveGoogle Drive: File "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker.tar.gz" not found
      20:14:28.311DEBUGgoogledriveGoogle Drive: Copy historyDB_2024_11_22-20_14_15_Proxmox_backupiobroker.tar.gz...
      20:14:30.444DEBUGgoogledriveGoogle Drive: Copy javascripts_2024_11_22-20_14_16_Proxmox_backupiobroker.tar.gz...
      20:14:32.595DEBUGgoogledrivedone
      20:14:32.800ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      20:14:32.808DEBUGcleandone
      20:14:32.899DEBUGhistoryHTMLnew history html values created
      20:14:32.986DEBUGhistoryHTMLdone
      20:14:33.141DEBUGhistoryJSONnew history json values created
      20:14:33.188DEBUGhistoryJSONdone
      20:14:33.297DEBUGumountmount active, umount is started ...
      20:14:38.373DEBUGumountumount successfully completed
      20:14:38.418DEBUGumountdone
      20:14:38.678DEBUGemaildone
      20:14:40.735DEBUGnotificationAdmin notification will be sent
      20:14:40.778DEBUGnotificationdone
      20:14:40.886INFOguiDas Backup wurde erfolgreich erstellt!
      Probleme bei influx eigentlich nicht ersichtbar
      im iobroker log dann dies
      backitup.0
      2024-11-22 20:14:31.666	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      backitup.0
      2024-11-22 20:14:27.079	error	[iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker.tar.gz" not found
      backitup.0
      2024-11-22 20:14:21.154	error	[iobroker/onedrive] Onedrive: File "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker.tar.gz" not found
      backitup.0
      2024-11-22 20:14:14.935	error	[iobroker] Error: Command failed: influx backup --bucket iobroker -t 5GtVXZUdOX6jOnzTpVNscZ6zjRHLUTBxhGqVAhUMxqKdhhU0uAPZL68Z_bynD53ntnns9cBDHEzXb4Un4QqGFQ== "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker"/bin/sh: 1: influx: not found
      backitup.0
      2024-11-22 20:14:14.935	error	[iobroker/influxDB] /bin/sh: 1: influx: not found
      backitup.0
      2024-11-22 20:14:14.935	error	[iobroker/influxDB] Error: Command failed: influx backup --bucket iobroker -t 5GtVXZUdOX6jOnzTpVNscZ6zjRHLUTBxhGqVAhUMxqKdhhU0uAPZL68Z_bynD53ntnns9cBDHEzXb4Un4QqGFQ== "/opt/iobroker/backups/influxDB_2024_11_22-20_14_14_Proxmox_backupiobroker"
      admin.0
      2024-11-22 20:13:45.845	info	==> Connected system.user.admin from ::ffff:192.168.178.93
      Mache ich ein Restore einer noch vom Raspberry erzeugten Sicherung kommt das.
      20:23:11.904INFOguistarting Restore...
      20:23:12.093DEBUGinfluxDBinfluxdb.0 is stopped
      20:23:33.690ERRORinfluxDB/bin/sh: 1: influx: not found
      20:23:33.832DEBUGinfluxDBinfluxdb.0 started
      Ich checks einfach nicht
      Liegt es vielleicht daran dass die Influxdb nicht im selben system wie der iobroker liegt?
      Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Snopy_16 last edited by
        @snopy_16 sagte in Backitup - Influxdb2 Fehler bei Sicherung:
        Richtig, der influxdb-client muss auch lokal installiert werden.
          Snopy_16 @Thomas Braun last edited by
          oje, wie geht den das?
          Können sie mir bitte behilflich sein?
            @snopy_16
            Das hängt davon ab, welche Version von influxdb installiert ist.
            Es könnte z.B.
            sudo apt influxdb-client
            sein
              Snopy_16 @Thomas Braun last edited by Snopy_16
              @Thomas-Braun
              Werds versuchen
                @snopy_16
                Dann dürfte es
                sudo apt update
                sudo apt install influxdb2-cli
                sein.
                • crunchip
                  crunchip Forum Testing Most Active @Snopy_16 last edited by
                  hatte ich dir im anderen Thread geschrieben, Beschreibung von backitup, siehe https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch
                    Snopy_16 @crunchip last edited by
                    @crunchip @Thomas-Braun
                    Ich weiss, dass ich mit meinen Fragen oft nerve.
                    Aber für mich ist das noch alles ein bißchen komplex.🙄
                    Aber mit jedem Schritt lerne ich dazu und verstehe alles ein bisschen besser.
                    Drum danke Euch, die mich unterstützen.👍 😊 👏
                    (Will gar nicht mehr zu meinen Anfängen zurückdenken - stand da wie der Ochs vorm Tor)😠 😧
                      Snopy_16 @crunchip last edited by Snopy_16
                      @crunchip
                      Also, irgendwas mache ich komplett falsch.
                      Beim Restore der influxdb werden keine Datenpunkte zurückgeschrieben.
                      Restore Fehlermeldung.
                      15:00:34.581INFOguistarting Restore...
                      15:00:34.721DEBUGinfluxDBCreated tmp directory
                      15:00:34.736DEBUGinfluxDBStart influxDB Restore ...
                      15:00:57.433ERRORinfluxDBError: API compatibility check failed: Get "http://localhost:8086/health": dial tcp [::1]:8086: connect: connection refused
                      15:00:57.450DEBUGinfluxDBTry deleting the InfluxDB tmp directory
                      15:00:57.557DEBUGinfluxDBinfluxDB Restore completed successfully
                      im log
                      backitup.0
                      2024-11-23 15:00:56.770	error	[influxDB] Error: API compatibility check failed: Get "http://localhost:8086/health": dial tcp [::1]:8086: connect: connection refused
                      backitup.0
                      2024-11-23 15:00:13.312	error	Error: ENOENT: no such file or directory, lstat '/opt/iobroker/backups/influxDB_2024_11_23-14_35_27_backupiobroker.tar.gz'
                      backitup.0
                      2024-11-23 15:00:09.710	error	umount: /opt/iobroker/backups: not mounted.
                      backitup.0
                      2024-11-23 14:59:02.506	error	umount: /opt/iobroker/backups: not mounted.
                      Adapter influxdb vor restore habe ich gestoppt. Alte Influx-Datenbank vor der Wiederherstellung automatisch löschen habe ich auch probiert.
                      Bucket wird angelegt, Measurements werden angelegt. Nur die Historiedaten fehlen.
                      • crunchip
                        Wenn die InfluxDB von einem entfernten Server gesichert werden soll, müssen in der influxdb.conf auf dem entfernten Server die Remote-Rechte für den RPC-Dienst angepasst werden.
                        bind-address = "<InfluxDB-IP>:8088"
                        oder
                        bind-address = "0.0.0.0:8088"
                        Nach dem Änderungen in der Konfiguration muss der InfluxDB-Dienst neugestartet werden.
                        Weitere Informationen zur Datensicherung der InfluxDB sind hier zu finden.
                          @crunchip
                          hab ich aber nur bei influxdb 1 gelesen, ich hab influxdb 2
                          Habs aber jetzt hinbekommen.
                          Dafür die nächste Hürde: grafana in einem anderen Container als influx installiert.
                          Beim restore kommt dann das
                          18:10:02.838INFOguistarting Restore...
                          18:10:02.862DEBUGgrafanaStart Grafana Restore ...
                          18:10:02.918DEBUGgrafanafilename for restore: /opt/iobroker/backups/grafana_2024_11_23-14_38_55_backupiobroker.tar.gz
                          18:10:02.924DEBUGgrafanaGrafana tmp directory created: /opt/iobroker/backups/grafana_tmp
                          18:10:02.936DEBUGgrafanastart decompress
                          18:10:03.970DEBUGgrafanaGrafana request started
                          18:10:03.990DEBUGgrafanaGrafana is available ... Status: 200
                          18:10:04.001DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
                          18:10:04.017DEBUGgrafanacannot restore datasource "InfluxDB": "Invalid username or password"
                          18:10:04.024DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/fronius.json
                          18:10:04.067DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/haustechnik.json
                          18:10:04.072DEBUGgrafanacannot restore dashboard "haustechnik": {"message":"Unauthorized","traceID":""}
                          18:10:04.075DEBUGgrafanacannot restore dashboard "fronius": {"message":"Unauthorized","traceID":""}
                          18:10:04.110DEBUGgrafanaGrafana request ended
                          18:10:04.122DEBUGgrafanaTry deleting the Grafana tmp directory
                          18:10:04.126DEBUGgrafanaGrafana tmp directory was successfully deleted
                          18:10:06.076DEBUGgrafanaGrafana Restore completed successfully
                          grafana datenquelle zeigt beim Test
                          es wird nichts restored
                          • crunchip
                            @snopy_16 hast du deinen token erstellt?
                              @crunchip
                              Danke 👍
                                Ralph 0 @Snopy_16 last edited by
                                weil ich Antworten auf Fragen, die nie gestellt wurden so liebe ;-):
                                Proxmox hat auch eine super Backup-Funktion. Per Klick oder Zeitplan kannst Du einfach einzelne/alle Container bzw. VMs sichern oder restoren.
                                Was ich besonders nützlich finde, wenn man gerne rumspielt und/oder sich noch nicht so gut auskennt:
                                Neben dem laufendem System aus einem Backup eine Containerkopie restoren, darin die gewünschten Änderungen ausprobieren und wenn's funktioniert diese im Original umsetzen. Hat man den Container "kaputt" gespielt - löschen, neuen restoren und nochmal probieren.
                                • I
                                  io2345 @Thomas Braun last edited by io2345
                                  @thomas-braun said in Backitup - Influxdb2 Fehler bei Sicherung:
                                  @snopy_16
                                  Dann dürfte es
                                  sudo apt update
                                  sein.
                                  Da kommt bei mir allerdings:
                                  iobrokeradmin@ioBroker8neu:~$ sudo apt install influxdb2-cli
                                  Reading package lists... Done
                                  Building dependency tree... Done
                                  E: Unable to locate package influxdb2-cli
                                  Wie hast du das gelöst?
                                  Vollständige Beschreibung: Ich habe das fast identisch wie bei dir installiert: Iobroker ist ein LXC-Container auf dem Proxmox, die Influx DB in Version 2.7.5 ein weiterer LXC-Container. Den Iobroker-Container habe ich die letzten Tage erneuert (neuen Container angelegt und dann das Backup eingespielt). Seither kommt der Fehler wie bei dir: "[iobroker/influxDB] /bin/sh: 1: influx: not found" beim Backup.
                                    Thomas Braun Most Active @io2345 last edited by
                                    @io2345
                                    Ist das influxdb-Repo angelegt?
                                    sudo apt update
                                    apt policy influxdb2*
                                    sagt?
                                    • I
                                      Da kommt nichts. "sudo apt update" läuft durch, aber dann
                                      iobrokeradmin@ioBroker8neu:~$ apt policy influxdb2*
                                      N: Unable to locate package influxdb2*
                                      N: Couldn't find any package by glob 'influxdb2*'
                                      Wie bekommt man das Repo angelegt?
                                        @io2345 sagte in Backitup - Influxdb2 Fehler bei Sicherung:
                                        Zeigen!
                                        An der Ausgabe hätte ich schon sehen können was da angelegt ist oder nicht.
                                        • I
                                          Zeigen!
                                          Ah, sorry. Hier isses:
                                          iobrokeradmin@ioBroker8neu:~$ sudo apt update
                                          [sudo] password for iobrokeradmin:
                                          Hit:1 http://security.debian.org bullseye-security InRelease
                                          Hit:2 http://deb.debian.org/debian bullseye InRelease
                                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          All packages are up to date.
                                            @io2345
                                            sudo rm /etc/apt/sources.list.d/influ*
                                            wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                            echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                            echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                            rm influxdata-archive_compat.key
                                            Danach stehen die Pakete in deinem Pakermanager zur Installation bereit.
                                            1806
