    4. Cannot find module iobroker.js bei iobroker start
      ceerix last edited by
      heute über Nacht hat meine iobroker Installation die Segel gestrichen.
      Ist zuvor schon über Monate ohne Probleme auf meinem Pi 3 gelaufen.
      Ich bekommen nun beim Versuch das Kommando sudo iobroker start auszuführen folgenden Fehler
       sudo iobroker start
      module.js:327
          throw err;
          at Function.Module._resolveFilename (module.js:325:15)
          at Function.Module._load (module.js:276:25)
          at Function.Module.runMain (module.js:441:10)
          at startup (node.js:140:18)
          at node.js:1043:3
      Habe daraufhin folgende Befehle probiert:
      cd /opt/iobroker
      sudo chmod 777 * -R
      sudo npm install iobroker.js-controller --production
      Dann gibt es aber wieder Probleme:
      ! npm ERR! tar.unpack unzip error /root/.npm/readable-stream/2.0.6/package.tgz
      ! npm ERR! tar.unpack untar error /root/.npm/readable-stream/2.0.6/package.tgz
      ! > unix-dgram@0.2.3 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
      ! > node-gyp rebuild
      ! gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.0"
      ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/.node-gyp"
      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build'
      ! CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
      ! SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      ! COPY Release/unix_dgram.node
      ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/build'
      ! > ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa
      ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/.node-gyp"
      ! make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build'
      ! CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
      ! SOLINK_MODULE(target) Release/obj.target/ursaNative.node
      ! COPY Release/ursaNative.node
      ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/build'
      ! npm ERR! Linux 4.4.50-v7+
      ! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "–production"
      ! npm ERR! node v4.8.0
      ! npm ERR! npm v2.15.11
      ! npm ERR! code Z_DATA_ERROR
      ! npm ERR! errno -3
      ! npm ERR! incorrect data check
      ! npm ERR!
      ! npm ERR! If you need help, you may report this error at:
      ! npm ERR! <https://github.com/npm/npm/issues>
      ! npm ERR! Please include the following file with any support request:
      ! npm ERR! /opt/iobroker/npm-debug.log
      Tja und jetzt weiß ich nicht mehr wirklich weiter.
      Hat jemand eine Idee was ich probieren könnte?
      Beste Grüße
      Alex
        Das Thema hat sich mittlerweile leider von selbst erledigt. Mir hat es gestern noch die komplette SD Karte zerbröselt so dass ich nun neu installieren werde…
          Das war auch mein verdacht, dass die karte einen schlag weg hat.
          81.0k
