    4. Proxmox
    5. PVE Neustart, weiß nicht wieso
    • MartinP
      MartinP last edited by MartinP
      Letzten Sonntag um 08:14....
      root@pve:/var/log/apt# last -x | head | tac
      root     pts/0                         Thu Nov 21 20:31 - 18:28  (21:56)
      root     pts/0                         Fri Nov 22 18:28 - 13:08  (18:40)
      root     pts/0                         Sat Nov 23 13:08 - crash  (19:08)
      reboot   system boot  6.8.12-4-pve     Sun Nov 24 08:17   still running
      runlevel (to lvl 5)   6.8.12-4-pve     Sun Nov 24 08:22   still running
      root     pts/0                         Mon Nov 25 12:38 - 17:10  (04:31)
      root     pts/0                         Mon Nov 25 17:10 - 17:20  (00:10)
      root     pts/0                         Mon Nov 25 17:20 - 17:24  (00:04)
      root     pts/0                         Mon Nov 25 17:24   still logged in
      root     pts/3                         Tue Nov 26 09:49   still logged in
      und...
      root@pve:/var/log/apt# sudo grep -iv ': starting\|kernel: .*: Power Button\|watching system buttons\|Stopped Cleaning Up\|Started Crash recovery kernel' \
        /var/log/messages /var/log/syslog /var/log/apcupsd* \
        | grep -iw 'recover[a-z]*\|power[a-z]*\|shut[a-z ]*down\|rsyslogd\|ups'
      /var/log/messages:Nov 19 00:10:58 pve rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="565" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
      /var/log/syslog:2024-11-24T00:00:46.163500+01:00 pve rsyslogd: [origin software="rsyslogd" swVersion="8.2302.0" x-pid="612" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
      /var/log/syslog:2024-11-24T00:02:00.589712+01:00 pve systemd[3956263]: Reached target shutdown.target - Shutdown.
      /var/log/syslog:2024-11-24T00:07:01.090721+01:00 pve systemd[3959743]: Reached target shutdown.target - Shutdown.
      /var/log/syslog:2024-11-25T17:08:18.416108+01:00 pve systemd[1461592]: Reached target shutdown.target - Shutdown.
      /var/log/syslog:2024-11-25T17:12:14.162496+01:00 pve systemd[1463172]: Reached target shutdown.target - Shutdown.
      /var/log/syslog:2024-11-25T17:13:19.177557+01:00 pve systemd[1465440]: Reached target shutdown.target - Shutdown.
      /var/log/syslog:2024-11-25T17:18:19.674436+01:00 pve systemd[1469350]: Reached target shutdown.target - Shutdown.
      /var/log/syslog:2024-11-25T17:24:38.670068+01:00 pve systemd[1471141]: Reached target shutdown.target - Shutdown.
      um 17:24 enden die Meldungen...
      "Sat Nov 23 13:08 - crash (19:08)" macht mir Sorgen ...
      EDIT: Es wäre möglich, dass ich da an den Netzschalter des Mini-PC gekommen bin, das LAN-Kabel saß nur locker in seiner Buchse.
      Bei den leichten Mini-PCs muss man immer das Gehäuse festhalten, wenn gesteckt wird....
      Habe erstmal einen provisorischen Deckel über den Taster geklebt ...
      • BananaJoe
        Proxmox ist ja ein Debian,
        du könntest auch die Funktion des Power-Buttons deaktivieren:
        https://tqdev.com/2022-disable-power-button-on-ubuntu-server
        Ja, die Anleitung ist für Ubuntu, die für Debian sehen 1:1 genauso aus und diese war schön kurz und knapp.
        Müsste man natürlich testen. Die 4 Sekunden und ganz aus müssten trotzdem noch funktionieren, die gehen ja am Betriebssystem vorbei
        Dr. Bakterius 1 Reply Last reply Reply Quote 0
        • Dr. Bakterius
          Dr. Bakterius Most Active @BananaJoe last edited by
          @bananajoe sagte in PVE Neustart, weiß nicht wieso:
          Klappt bei mir leider nicht. Was mich etwas wundert: alle Einstellungen in logind.conf sind mit einem # auskommentiert. Da dürfte bei Debian die Einstellung doch wo anders zu finden sein.
          81.1k
