    4. g-homa Adapter Fehlermeldung im log
    • Kusselin
      Kusselin last edited by Kusselin
      Hallo Zusammen,
      ich habe mein Ubuntu container geupdated von iobroker und nach Neustart des iobrokers kommt beim adapter "G-HOMA" folgende Fehlermeldung:
      17:26:02.325  - info: g-homa.0 (2382) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.g-homa, node: v18.20.5, js-controller: 6.0.11
      2024-11-27 17:26:02.417  - info: g-homa.0 (2382) enumerating known plugs...
      2024-11-27 17:26:02.597  - info: g-homa.0 (2382) found plug with id 627de4 (offline)
      2024-11-27 17:26:02.655  - info: g-homa.0 (2382) found plug with id 3f1198 (offline)
      2024-11-27 17:26:02.702  - info: g-homa.0 (2382) found plug with id 3edea6 (offline)
      2024-11-27 17:26:02.749  - info: g-homa.0 (2382) found plug with id 3c4ca0 (offline)
      2024-11-27 17:26:02.796  - info: g-homa.0 (2382) found plug with id 3f0afc (offline)
      2024-11-27 17:26:02.923  - error: host.iobroker-live instance system.adapter.g-homa.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-11-27 17:26:02.924  - info: host.iobroker-live Restart adapter system.adapter.g-homa.0 because enabled
      2024-11-27 17:26:33.576  - info: host.iobroker-live instance system.adapter.g-homa.0 in version "0.5.3" started with pid 2403
      2024-11-27 17:26:35.726  - info: g-homa.0 (2403) starting. Version 0.5.3 in /opt/iobroker/node_modules/iobroker.g-homa, node: v18.20.5, js-controller: 6.0.11
      2024-11-27 17:26:35.786  - info: g-homa.0 (2403) enumerating known plugs...
      2024-11-27 17:26:35.975  - info: g-homa.0 (2403) found plug with id 627de4 (offline)
      2024-11-27 17:26:35.980  - info: g-homa.0 (2403) found plug with id 3f1198 (offline)
      2024-11-27 17:26:35.985  - info: g-homa.0 (2403) found plug with id 3edea6 (offline)
      2024-11-27 17:26:35.990  - info: g-homa.0 (2403) found plug with id 3c4ca0 (offline)
      2024-11-27 17:26:35.994  - info: g-homa.0 (2403) found plug with id 3f0afc (offline)
      2024-11-27 17:26:36.152  - error: host.iobroker-live instance system.adapter.g-homa.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-11-27 17:26:36.152  - info: host.iobroker-live Restart adapter system.adapter.g-homa.0 because enabled
      host.iobroker-live
      2024-11-27 17:31:34.724 error instance system.adapter.g-homa.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      Ich sehe nur das der JS-Controller stoppt, aber warum?
      Was läuft da jetzt falsch? Über ne Info herzlichen Dank.
      EDIT: keiner hier der mir helfen kann mit derMeldung?
      Nochmal iobroker Container neu gestartet jetzt geht alles wieder !!
