    4. Mihome-vacuum Adapter error Socket Close nach Node.js update
    • Elektroniker86
      Elektroniker86 last edited by
      nachdem ich meine ioBroker Instanz auf die aktuellste Node.js: v20.18.1 aktualisiert hatte, läuft der Mihome-vacuum Adapter leider nicht mehr. Im Log kommt oben genannter Fehler.
      mihome-vacuum.0
      2024-12-01 13:48:05.866	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:47:53.864	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:47:41.864	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:47:29.861	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:47:17.859	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:47:05.857	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:46:53.855	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:46:41.854	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:46:29.852	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:46:17.851	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:46:05.848	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:45:53.848	debug	Helo message Timeout
      mihome-vacuum.0
      2024-12-01 13:45:51.847	debug	server started on 0.0.0.0:53421
      mihome-vacuum.0
      2024-12-01 13:45:51.847	info	IOT enabled, create state
      mihome-vacuum.0
      2024-12-01 13:45:51.845	debug	MIIO: Config: ip:192.168.1.91 token: 67336a5578XXXXXXXXX
      mihome-vacuum.0
      2024-12-01 13:45:51.845	debug	Create State for deviceInfounsupported
      mihome-vacuum.0
      2024-12-01 13:45:51.845	debug	Create State for deviceInfowifi_signal
      mihome-vacuum.0
      2024-12-01 13:45:51.845	debug	Create State for deviceInfofw_ver
      mihome-vacuum.0
      2024-12-01 13:45:51.845	debug	Create State for deviceInfomodel
      mihome-vacuum.0
      2024-12-01 13:45:51.845	debug	Create State for deviceInfomac
      mihome-vacuum.0
      mihome-vacuum.0
      2024-12-01 13:45:51.839	debug	load Map creator... true
      mihome-vacuum.0
      2024-12-01 13:45:51.822	info	starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
      mihome-vacuum.0
      2024-12-01 13:45:51.697	debug	Plugin sentry Initialize Plugin (enabled=true)
      mihome-vacuum.0
      2024-12-01 13:45:47.680	info	terminating
      mihome-vacuum.0
      2024-12-01 13:45:47.181	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      mihome-vacuum.0
      2024-12-01 13:45:47.180	info	terminating
      mihome-vacuum.0
      2024-12-01 13:45:47.180	error	Socket Close
      mihome-vacuum.0
      2024-12-01 13:45:47.179	info	Got terminate signal TERMINATE_YOURSELF
      mihome-vacuum.0
      2024-12-01 13:44:45.411	info	IOT enabled, create state
      mihome-vacuum.0
      2024-12-01 13:44:45.383	info	starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
      mihome-vacuum.0
      2024-12-01 13:44:41.073	info	terminating
      mihome-vacuum.0
      2024-12-01 13:44:40.573	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      mihome-vacuum.0
      2024-12-01 13:44:40.573	info	terminating
      mihome-vacuum.0
      2024-12-01 13:44:40.573	error	Socket Close
      mihome-vacuum.0
      2024-12-01 13:44:40.572	info	Got terminate signal TERMINATE_YOURSELF
      Hat jemand eine Idee wie man das fixt oder hab ich was übersehen?
      Danke schonmal für eure Hilfe!
        Thomas Braun Most Active @Elektroniker86 last edited by
        @elektroniker86
        Das sollte aber nichts mit nodejs 20.18.1 zu tun haben, denn:
        2024-12-01 13:56:09.624  - info: mihome-vacuum.0 (85667) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
        2024-12-01 13:56:09.679  - info: mihome-vacuum.0 (85667) IOT enabled, create state
        2024-12-01 13:56:09.739  - info: mihome-vacuum.0 (85667) select standard vacuum protocol....
        2024-12-01 13:56:09.944  - info: mihome-vacuum.0 (85667) create state for carpet_mode
        2024-12-01 13:56:10.327  - info: mihome-vacuum.0 (85667) settest next timer: not available
        Hol mal einen gescheiten Auszug aus dem log ran.
        Per
        iob logs --watch
        z. B.
        Elektroniker86 1 Reply Last reply Reply Quote 0
        • Elektroniker86
          Elektroniker86 @Thomas Braun last edited by Elektroniker86
          @thomas-braun sagte in Mihome-vacuum Adapter error Socket Close nach Node.js update:
          iob logs --watch
          Ist wirklich komisch, nach dem update liefen beide Adapter nicht mehr hab schon die Adapter mehrmals neu gestartet. Sogar den iob fix habe ich nach dem update durchlaufen lassen -> keine Fehler.
          2024-12-01 14:01:10.305  - info: host.ioBroker stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
          2024-12-01 14:01:10.306  - info: mihome-vacuum.0 (5618) Got terminate signal TERMINATE_YOURSELF
          2024-12-01 14:01:10.307  - error: mihome-vacuum.0 (5618) Socket Close
          2024-12-01 14:01:10.307  - info: mihome-vacuum.0 (5618) terminating
          2024-12-01 14:01:10.308  - debug: mihome-vacuum.0 (5618) Plugin sentry destroyed
          2024-12-01 14:01:10.308  - info: mihome-vacuum.0 (5618) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-12-01 14:01:10.370  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 68.5ms (Tried 0/1 times)
          2024-12-01 14:01:10.383  - info: host.ioBroker stopInstance system.adapter.mihome-vacuum.0 send kill signal
          2024-12-01 14:01:10.808  - info: mihome-vacuum.0 (5618) terminating
          2024-12-01 14:01:10.898  - info: host.ioBroker instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-12-01 14:01:11.250  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:12.306  - info: smartmeter.0 (2661) Received 13 values, 5 updated
          2024-12-01 14:01:13.380  - info: smartmeter.0 (2661) Received 13 values, 5 updated
          2024-12-01 14:01:14.183  - info: host.ioBroker instance system.adapter.mihome-vacuum.0 in version "4.2.0" started with pid 6369
          2024-12-01 14:01:14.456  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:14.609  - debug: mihome-vacuum.0 (6369) Redis Objects: Use Redis connection: 0.0.0.0:9001
          2024-12-01 14:01:14.627  - debug: mihome-vacuum.0 (6369) Objects client ready ... initialize now
          2024-12-01 14:01:14.628  - debug: mihome-vacuum.0 (6369) Objects create System PubSub Client
          2024-12-01 14:01:14.628  - debug: mihome-vacuum.0 (6369) Objects create User PubSub Client
          2024-12-01 14:01:14.664  - debug: mihome-vacuum.0 (6369) Objects client initialize lua scripts
          2024-12-01 14:01:14.667  - debug: mihome-vacuum.0 (6369) Objects connected to redis: 0.0.0.0:9001
          2024-12-01 14:01:14.685  - debug: mihome-vacuum.0 (6369) Redis States: Use Redis connection: 0.0.0.0:9000
          2024-12-01 14:01:14.694  - debug: mihome-vacuum.0 (6369) States create System PubSub Client
          2024-12-01 14:01:14.695  - debug: mihome-vacuum.0 (6369) States create User PubSub Client
          2024-12-01 14:01:14.749  - debug: mihome-vacuum.0 (6369) States connected to redis: 0.0.0.0:9000
          2024-12-01 14:01:14.764  - debug: mihome-vacuum.0 (6369) Plugin sentry Initialize Plugin (enabled=true)
          2024-12-01 14:01:14.888  - info: mihome-vacuum.0 (6369) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v20.18.1, js-controller: 7.0.3
          2024-12-01 14:01:14.904  - debug: mihome-vacuum.0 (6369) load Map creator... true
          2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfo
          2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfomac
          2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfomodel
          2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfofw_ver
          2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfowifi_signal
          2024-12-01 14:01:14.913  - debug: mihome-vacuum.0 (6369) Create State for deviceInfounsupported
          2024-12-01 14:01:14.914  - debug: mihome-vacuum.0 (6369) MIIO: Config: ip:192.168.1.91 token: 67336a5578XXXXXXXXX
          2024-12-01 14:01:14.915  - info: mihome-vacuum.0 (6369) IOT enabled, create state
          2024-12-01 14:01:14.916  - debug: mihome-vacuum.0 (6369) server started on 0.0.0.0:53421
          2024-12-01 14:01:15.387  - debug: ping.0 (2512) Pinging alive 192.168.1.95
          2024-12-01 14:01:15.387  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.95
          2024-12-01 14:01:15.527  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:16.118  - debug: ping.0 (2512) Ping result for 192.168.1.95: true in 729ms (Tried 0/1 times)
          2024-12-01 14:01:16.121  - debug: ping.0 (2512) Pinging alive 192.168.1.161
          2024-12-01 14:01:16.121  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.161
          2024-12-01 14:01:16.128  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 4.75ms (Tried 0/1 times)
          2024-12-01 14:01:16.584  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:16.916  - debug: mihome-vacuum.0 (6369) Helo message Timeout
          2024-12-01 14:01:17.658  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:18.746  - info: smartmeter.0 (2661) Received 13 values, 5 updated
          2024-12-01 14:01:19.803  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:20.877  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:21.173  - debug: ping.0 (2512) Pinging alive 192.168.1.95
          2024-12-01 14:01:21.173  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.95
          2024-12-01 14:01:21.355  - debug: ping.0 (2512) Ping result for 192.168.1.95: true in 180ms (Tried 0/1 times)
          2024-12-01 14:01:21.358  - debug: ping.0 (2512) Pinging alive 192.168.1.161
          2024-12-01 14:01:21.358  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.161
          2024-12-01 14:01:21.425  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 65.0ms (Tried 0/1 times)
          2024-12-01 14:01:21.965  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:23.039  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:24.112  - info: smartmeter.0 (2661) Received 13 values, 5 updated
          2024-12-01 14:01:25.203  - info: smartmeter.0 (2661) Received 13 values, 5 updated
          2024-12-01 14:01:26.291  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:26.428  - debug: ping.0 (2512) Pinging alive 192.168.1.95
          2024-12-01 14:01:26.428  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.95
          2024-12-01 14:01:27.199  - debug: ping.0 (2512) Ping result for 192.168.1.95: true in 769ms (Tried 0/1 times)
          2024-12-01 14:01:27.203  - debug: ping.0 (2512) Pinging alive 192.168.1.161
          2024-12-01 14:01:27.203  - debug: ping.0 (2512) System command: /bin/ping -n -w 2 -c 1 192.168.1.161
          2024-12-01 14:01:27.260  - debug: ping.0 (2512) Ping result for 192.168.1.161: true in 54.4ms (Tried 0/1 times)
          2024-12-01 14:01:27.380  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:28.453  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:28.916  - debug: mihome-vacuum.0 (6369) Helo message Timeout
          2024-12-01 14:01:29.559  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:30.007  - debug: unifi.0 (6261) Update started
          2024-12-01 14:01:30.310  - debug: unifi.0 (6261) Login successful
          2024-12-01 14:01:30.341  - debug: unifi.0 (6261) fetchSites: default
          2024-12-01 14:01:30.341  - debug: unifi.0 (6261) Update site: default
          2024-12-01 14:01:30.370  - debug: unifi.0 (6261) fetchSiteSysinfo default: 1
          2024-12-01 14:01:30.445  - debug: unifi.0 (6261) fetchClients default: 77
          2024-12-01 14:01:30.653  - info: smartmeter.0 (2661) Received 13 values, 6 updated
          2024-12-01 14:01:30.944  - debug: unifi.0 (6261) fetchDevices default: 10
          2024-12-01 14:01:31.185  - debug: unifi.0 (6261) fetchWlans default: 3
          2024-12-01 14:01:31.208  - debug: unifi.0 (6261) fetchNetworks default: 9
            Homoran Global Moderator Administrators @Elektroniker86 last edited by
            @elektroniker86 und englisch ist das auch nicht 😉
            • Elektroniker86
              Ok... falscher Alarm nachdem ich beide Roboter komplett aus und wieder eingeschaltet habe und danach die Instanzen neu gestartet hatte, ist wieder alles grün und connectet.
              Trotzdem Danke!
                @elektroniker86
                Das wollte ich gerade sagen. Denn hier
                antwortet der Sauger nicht.
                • Elektroniker86
                  Elektroniker86 @Homoran last edited by
                  Sorry, hab ich mich wohl verklickt.
                  Wie kann ich das Thema auf gelöst setzen?
                  • mcm1957
                    mcm1957 @Elektroniker86 last edited by
                    @elektroniker86
                    Titel im ersten Beitrag editieren
