    4. [gelöst] Zigbee Adapter bleibt gelb nach Raspi update
      darkblu last edited by darkblu
      Hallo, ich habe gerade mein Bookworm (Raspi Pi5) geupdatet, es gab 2 Pakete.
      Update erfolge mittels:
      sudo apt update && sudo apt full-upgrade
      Leider bleibt jetzt nach dem ioBroker Neustart der Zigbee Adapter gelb.
      Folgendes steht im Log:
      2024-12-01 16:39:52.536 - info: host.smart stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-12-01 16:39:52.540 - info: zigbee.0 (7470) Got terminate signal TERMINATE_YOURSELF
      2024-12-01 16:39:52.652 - info: host.smart stopInstance system.adapter.zigbee.0 send kill signal
      2024-12-01 16:39:52.542 - info: zigbee.0 (7470) cleaned everything up...
      2024-12-01 16:39:52.553 - info: zigbee.0 (7470) Zigbee: disabling joining new devices.
      2024-12-01 16:39:52.775 - warn: zigbee.0 (7470) Failed to stop zigbee during startup
      2024-12-01 16:39:52.776 - info: zigbee.0 (7470) terminating
      2024-12-01 16:39:52.776 - info: zigbee.0 (7470) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-12-01 16:39:52.799 - info: zigbee.0 (7470) debug devices set to []
      2024-12-01 16:39:53.042 - info: zigbee.0 (7470) terminating
      2024-12-01 16:39:53.345 - info: host.smart instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-01 16:39:56.763 - info: host.smart instance system.adapter.zigbee.0 in version "1.10.3" started with pid 7486
      2024-12-01 16:39:58.685 - info: zigbee.0 (7486) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
      2024-12-01 16:39:58.715 - info: zigbee.0 (7486) delete old Backup files. keep only last 10
      2024-12-01 16:39:58.716 - info: zigbee.0 (7486) Starting Zigbee npm ...
      2024-12-01 16:39:58.851 - info: zigbee.0 (7486) Installed Version: iobroker.zigbee@1.10.3
      iob diag sagt das hier:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: smart
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       16:36:45 up 19 min,  2 users,  load average: 7.43, 6.59, 4.18
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2024-12-01 16:36:45 CET
                 Universal time: Sun 2024-12-01 15:36:45 UTC
                       RTC time: Sun 2024-12-01 15:36:45
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      dirk
      HOME=/home/dirk
      GROUPS=dirk adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.4G        3.0G        4.2G        5.6M        1.3G        5.5G
      Swap:           209M          0B        209M
      Total:          8.7G        3.0G        4.5G
      Active iob-Instances:   41
               8052 M total memory
               2834 M used memory
               2717 M active memory
                783 M inactive memory
               4046 M free memory
                121 M buffer memory
               1151 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 16:36:45 up 19 min,  2 users,  load average: 7.43, 6.59, 4.18
      Tasks: 204 total,   1 running, 203 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.2 total,   4046.0 free,   2835.3 used,   1273.1 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5216.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      15 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     806M  5.3M  800M   1% /run
      /dev/sda2      ext4      117G  7.2G  104G   7% /
      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/sda1      vfat      510M   65M  446M  13% /boot/firmware
      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
      [Sun Dec  1 16:16:52 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:4D:70:41 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eae5867b-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Dec  1 16:16:55 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
      [Sun Dec  1 16:16:55 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      710M    /var/
      206M    /var/cache
      200M    /var/cache/apt
      197M    /var/lib
      134M    /var/lib/apt/lists
      Archived and active journals take up 105.6M in the file system.
      /opt/iobroker/backups:
      403M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2440876-if00
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      smart               smart (version: 7.0.3, hostname: smart         , alive, uptime: 617)
      Core adapters versions
      admin:          7.1.5
      javascript:     8.8.3
      Adapter State
      + system.adapter.admin.0                  : admin                 : smart                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : smart                                    -  enabled
        system.adapter.alias-manager.0          : alias-manager         : smart                                    -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : smart                                    -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : smart                                    -  enabled
      + system.adapter.awtrix-light.2           : awtrix-light          : smart                                    -  enabled
      + system.adapter.backitup.0               : backitup              : smart                                    -  enabled
      + system.adapter.cloud.0                  : cloud                 : smart                                    -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : smart                                    -  enabled
      + system.adapter.discovery.0              : discovery             : smart                                    -  enabled
        system.adapter.dwd.0                    : dwd                   : smart                                    -  enabled
      + system.adapter.echarts.0                : echarts               : smart                                    -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : smart                                    -  enabled
        system.adapter.feiertage.0              : feiertage             : smart                                    -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : smart                                    -  enabled
      + system.adapter.hmip.0                   : hmip                  : smart                                    -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : smart                                    -  enabled
      + system.adapter.hue.0                    : hue                   : smart                                    -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : smart                                    -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : smart                                    -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : smart                                    -  enabled
      + system.adapter.influxdb.0               : influxdb              : smart                                    -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : smart                                    -  enabled
      + system.adapter.javascript.0             : javascript            : smart                                    -  enabled
      + system.adapter.linux-control.0          : linux-control         : smart                                    -  enabled
      + system.adapter.melcloud.0               : melcloud              : smart                                    -  enabled
      + system.adapter.modbus.0                 : modbus                : smart                                    -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : smart                                    -  enabled, port: 1887, bind: 0.0.0.0
      + system.adapter.mytime.0                 : mytime                : smart                                    -  enabled
      + system.adapter.nuki.0                   : nuki                  : smart                                    -  enabled
        system.adapter.reolink.0                : reolink               : smart                                    - disabled
      + system.adapter.shelly.0                 : shelly                : smart                                    -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : smart                                    -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.smart-eq.0               : smart-eq              : smart                                    - disabled
      + system.adapter.sonoff.0                 : sonoff                : smart                                    -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : smart                                    -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : smart                                    -  enabled
      + system.adapter.statistics.0             : statistics            : smart                                    -  enabled
      + system.adapter.tr-064.0                 : tr-064                : smart                                    -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : smart                                    -  enabled
      + system.adapter.tuya.0                   : tuya                  : smart                                    -  enabled
      + system.adapter.upnp.0                   : upnp                  : smart                                    -  enabled
        system.adapter.uv-protect.0             : uv-protect            : smart                                    -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : smart                                    -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smart                                    -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : smart                                    -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : smart                                    -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : smart                                    -  enabled
        system.adapter.vis-players.0            : vis-players           : smart                                    -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : smart                                    -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : smart                                    -  enabled
        system.adapter.vis.0                    : vis                   : smart                                    -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : smart                                    -  enabled
      + system.adapter.web.0                    : web                   : smart                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : smart                                    -  enabled
      + system.adapter.wled.0                   : wled                  : smart                                    -  enabled
      + system.adapter.zigbee.0                 : zigbee                : smart                                    -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "energiefluss" : 3.6.1    , installed 3.6.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "hmip"         : 1.24.3   , installed 1.24.3
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "melcloud"     : 2.0.4    , installed 2.0.4
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "reolink"      : 1.1.2    , installed 1.1.2
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "uv-protect"   : 0.6.3    , installed 0.6.3
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        20343
      States:         15086
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 https://repos.influxdata.com/debian stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6420       777/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       21715      3679/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20039      3742/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       20004      3724/io.shelly.1
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18347      3372/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20488      3372/iobroker.js-co
      tcp        0      0 192.168.178.40:9092     0.0.0.0:*               LISTEN      1001       22713      3694/io.nuki.0
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        7194       889/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6422       777/sshd: /usr/sbin
      tcp6       0      0 :::3001                 :::*                    LISTEN      1001       22094      3998/io.fullybrowse
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       24364      4532/io.upnp.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        3941       889/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17247      3390/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21937      3878/io.web.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21155      3757/io.sonos.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22771      3787/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22772      3787/io.tuya.0
      udp        0      0 0.0.0.0:41825           0.0.0.0:*                           104        4957       647/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24067      4564/io.wled.0
      udp        0      0 192.168.178.40:5353     0.0.0.0:*                           1001       21245      3772/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4955       647/avahi-daemon: r
      udp        0      0 0.0.0.0:58814           0.0.0.0:*                           1001       23541      4532/io.upnp.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21093      3709/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25810      4532/io.upnp.0
      udp6       0      0 fe80::1fd4:b7df:3ba:546 :::*                                0          3857       731/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        4956       647/avahi-daemon: r
      udp6       0      0 :::50457                :::*                                104        4958       647/avahi-daemon: r
      2024-12-01 16:31:00.415  - info: admin.0 (3390) ==> Connected system.user.admin from ::ffff:192.168.178.24
      2024-12-01 16:31:00.474  - error: zigbee.0 (4610) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-12-01 16:31:10.190  - info: admin.0 (3390) <== Disconnect system.user.admin from ::ffff:192.168.178.24
      2024-12-01 16:32:21.351  - info: javascript.0 (3447) script.js.Hue_Push_API: missing update instructions for sensors.light.light_level_report
      2024-12-01 16:32:21.351  - info: javascript.0 (3447) script.js.Hue_Push_API: {"light":{"light_level":20188,"light_level_report":{"changed":"2024-12-01T15:32:21.516Z","light_level":20188}},"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"}}
      2024-12-01 16:35:52.012  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 6147
      2024-12-01 16:35:53.069  - info: dwd.0 (6147) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
      2024-12-01 16:35:53.525  - info: dwd.0 (6147) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-12-01 16:35:54.038  - info: host.smart instance system.adapter.dwd.0 having pid 6147 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-01 16:37:05.488  - info: javascript.0 (3447) script.js.Hue_Push_API: missing update instructions for sensors.temperature.temperature_report
      2024-12-01 16:37:05.488  - info: javascript.0 (3447) script.js.Hue_Push_API: {"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"},"temperature":{"temperature":5.61,"temperature_report":{"changed":"2024-12-01T15:37:05.657Z","temperature":5.61}}}
      und das summary sagt das hier:
                              v.2024-10-19
             Icon name: computer
          Architecture: arm64
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.4G        2.9G        4.3G        5.6M        1.3G        5.5G
      Swap:           209M          0B        209M
      Total:          8.7G        2.9G        4.5G
      ioBroker Core:          js-controller           7.0.3
                              admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                20343
      States:                 15085
      Size of iob-Database:
      6.8M    /opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      Mich wundern auch die 15 Errors im iob diag Zeile 93
      dirk@smart:~ $ sudo dmesg --level=emerg,alert,crit -T
      [Sun Dec  1 16:16:57 2024] Unable to handle kernel paging request at virtual address ffffc00080adbf04
      [Sun Dec  1 16:16:57 2024] Mem abort info:
      [Sun Dec  1 16:16:57 2024]   ESR = 0x0000000096000047
      [Sun Dec  1 16:16:57 2024]   EC = 0x25: DABT (current EL), IL = 32 bits
      [Sun Dec  1 16:16:57 2024]   SET = 0, FnV = 0
      [Sun Dec  1 16:16:57 2024]   EA = 0, S1PTW = 0
      [Sun Dec  1 16:16:57 2024]   FSC = 0x07: level 3 translation fault
      [Sun Dec  1 16:16:57 2024] Data abort info:
      [Sun Dec  1 16:16:57 2024]   ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
      [Sun Dec  1 16:16:57 2024]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
      [Sun Dec  1 16:16:57 2024]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
      [Sun Dec  1 16:16:57 2024] swapper pgtable: 16k pages, 47-bit VAs, pgdp=0000000001398000
      [Sun Dec  1 16:16:57 2024] [ffffc00080adbf04] pgd=100000010019c003, p4d=100000010019c003, pud=100000010019c003, pmd=10000001001a0003, pte=0000000000000000
      [Sun Dec  1 16:16:57 2024] Internal error: Oops: 0000000096000047 [#1] PREEMPT SMP
      [Sun Dec  1 16:16:57 2024] Code: d503201f b50000e2 14000020 38401423 (39000003)
      keine Ahnung ob das da schon "immer" stand oder neu ist.
        @darkblu sagte in Zigbee Adapter bleibt gelb nach Raspi update:
        Das schaut von der Konfiguration her gut aus.
        Bis auf den zigbee-Port, den würde ich auf
        setzen.
        • haselchen
          haselchen Most Active @darkblu last edited by haselchen
          Deine Load Average ist viel zu hoch.
          Du könntest mal das Ergebnis von htop hier in CodeTags posten.
          Und zu Deinen Errors.
          Die Fehlermeldung habe ich im Netz gefunden. Da wird gerätselt ob es ein Kernel Bug ist oder dem RAM zuzuordnen ist.
          Mit @Thomas-Braun Erlaubnis könntest Du ein KernelUpdate auf 6.6.63 machen und gucken, ob es damit behoben ist.
          sudo rpi-update
          Habs eben mal für Dich getestet
            darkblu @Thomas Braun last edited by darkblu
            setzen.
            dumme Frage, gebe ich das in der Instanz unter Einstellungen COM Anschlussname ein ?
            Kannst du noch etwas zu den 15 Errors sagen ?
            Nach gefühlt 20x iob fix und rebooten des Raspis ist der Adapter jetzt wieder grün.
            Ein Adventswunder
              Thomas Braun Most Active @darkblu last edited by
              @darkblu sagte in [gelöst] Zigbee Adapter bleibt gelb nach Raspi update:
              Ja. Du ersetzt den bisherigen Eintrag.
              Nein.
                darkblu @haselchen last edited by
                @haselchen said in [gelöst] Zigbee Adapter bleibt gelb nach Raspi update:
                hier die htop Ausgabe ( ok, leider nur ein screenshot)
                Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                  sudo rpi-update
                  und war der Test jetzt positiv, also soll ich das auch machen oder lieber doch nicht ?
                    @darkblu
                    Auf dem Screenshot ist es okay, beim iob diag von oben deutlich zu hoch:
                    • haselchen
                      @darkblu
                      Ok, jetzt ist sie wieder normal. Vermutlich musste nach dem Update noch was verarbeitet werden ?!
                      Wie sieht iob diag jetzt aus?
                      Errors noch da?
                        Nein, besser nicht.
                          hier der ganz frische iob diag:
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           18:11:14 up 49 min,  2 users,  load average: 0.35, 0.28, 0.32
                          CPU threads: 4
                          Current issues:
                                         Local time: Sun 2024-12-01 18:11:14 CET
                                     Universal time: Sun 2024-12-01 17:11:14 UTC
                                           RTC time: Sun 2024-12-01 17:11:14
                                        NTP service: active
                                    RTC in local TZ: no
                          dirk
                          HOME=/home/dirk
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            8.4G        3.0G        4.3G        5.6M        1.2G        5.4G
                          Swap:           209M          0B        209M
                                   8052 M total memory
                                   2906 M used memory
                                   2798 M active memory
                                    749 M inactive memory
                                   4137 M free memory
                                     83 M buffer memory
                                   1025 M swap cache
                                    199 M total swap
                                      0 M used swap
                                    199 M free swap
                          top - 18:11:15 up 49 min,  2 users,  load average: 0.35, 0.28, 0.32
                          Tasks: 195 total,   1 running, 194 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   8052.2 total,   4137.6 free,   2906.7 used,   1109.4 buff/cache
                          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5145.6 avail Mem
                          No critical errors detected
                          *** FILESYSTEM ***
                          /dev/sda2      ext4      117G  7.3G  104G   7% /
                          [Sun Dec  1 17:21:59 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:4D:70:41 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eae5867b-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Sun Dec  1 17:22:02 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                          [Sun Dec  1 17:22:02 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                          /var:
                          715M    /var/
                          206M    /var/cache
                          202M    /var/lib
                          200M    /var/cache/apt
                          1.3G    /opt/iobroker/iobroker-data/
                          26M     /opt/iobroker/iobroker-data/states.jsonl
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyACM0
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          smart               smart (version: 7.0.3, hostname: smart         , alive, uptime: 2942)
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        20343
                          States:         15006
                          Hit:3 https://repos.influxdata.com/debian stable InRelease
                          Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 192.168.178.40:9092     0.0.0.0:*               LISTEN      1001       6946       1216/io.nuki.0
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        859        865/influxd
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          798        776/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6566       904/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6571       904/iobroker.js-con
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7803       1261/io.sonoff.0
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       6940       1246/io.shelly.1
                          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       6913       1201/io.mqtt.0
                          tcp6       0      0 :::3001                 :::*                    LISTEN      1001       9512       1517/io.fullybrowse
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7307       924/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9380       1397/io.web.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        5802       865/influxd
                          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       10174      2051/io.upnp.0
                          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       7815       1276/io.sonos.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          800        776/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:60854           0.0.0.0:*                           104        742        647/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10944      2082/io.wled.0
                          udp        0      0 192.168.178.40:5353     0.0.0.0:*                           1001       9221       1291/io.tr-064.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        740        647/avahi-daemon: r
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7756       1231/io.shelly.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10105      2051/io.upnp.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9244       1306/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9245       1306/io.tuya.0
                          udp        0      0 0.0.0.0:52000           0.0.0.0:*                           1001       9962       2051/io.upnp.0
                          udp6       0      0 fe80::1fd4:b7df:3ba:546 :::*                                0          886        729/NetworkManager
                          udp6       0      0 :::5353                 :::*                                104        741        647/avahi-daemon: r
                          udp6       0      0 :::35092                :::*                                104        743        647/avahi-daemon: r
                          2024-12-01 18:02:59.299  - info: javascript.0 (981) script.js.Hue_Push_API: missing update instructions for groups.owner.rid
                          2024-12-01 18:02:59.299  - info: javascript.0 (981) script.js.Hue_Push_API: {"dimming":{"brightness":71.15},"owner":{"rid":"f8c6e02c-9bd3-4e55-ad28-71d18c81224f","rtype":"room"}}
                          2024-12-01 18:02:59.299  - info: javascript.0 (981) script.js.Hue_Push_API: missing update instructions for groups.owner.rtype
                          2024-12-01 18:03:21.717  - info: admin.0 (924) <== Disconnect system.user.admin from ::ffff:192.168.178.24
                          2024-12-01 18:05:27.011  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 2344
                          2024-12-01 18:05:28.123  - info: dwd.0 (2344) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                          2024-12-01 18:05:28.569  - info: dwd.0 (2344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-12-01 18:05:29.080  - info: host.smart instance system.adapter.dwd.0 having pid 2344 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-12-01 18:06:30.394  - info: hmip.0 (1111) switchState - id "3014F711A000021A498E296C" - Too fast value changes, change blocked!
                          2024-12-01 18:06:36.652  - info: hmip.0 (1111) Value unchanged, do not send this value
                          2024-12-01 18:06:37.100  - info: fullybrowser.0 (1517) 🗸 192.168.178.128: Command screenOn successfully set to true
                          2024-12-01 18:06:37.101  - info: fullybrowser.0 (1517) 🗸 192.168.178.128: Command screenOn successfully set to true
                          2024-12-01 18:06:44.264  - info: web.0 (1397) ==> Connected system.user.admin from ::ffff:192.168.178.128
                          2024-12-01 18:07:05.373  - info: javascript.0 (981) script.js.Hue_Push_API: missing update instructions for sensors.temperature.temperature_report
                          2024-12-01 18:07:05.373  - info: javascript.0 (981) script.js.Hue_Push_API: {"owner":{"rid":"b6d6ddc7-c7c6-4a77-9ad4-aedbf18fe9db","rtype":"device"},"temperature":{"temperature":3.58,"temperature_report":{"changed":"2024-12-01T17:07:05.547Z","temperature":3.58}}}
                          2024-12-01 18:08:11.668  - info: fullybrowser.0 (1517) 🗸 192.168.178.128: Command screenOff successfully set to true
                          2024-12-01 18:09:09.758  - info: vw-connect.0 (1382) State value to set for "vw-connect.0.wecharge.chargeandpay.records.latestItem.location_coordinates_latitude" has to be type "number" but received type "string"
                          2024-12-01 18:09:09.758  - info: vw-connect.0 (1382) State value to set for "vw-connect.0.wecharge.chargeandpay.records.latestItem.location_coordinates_longitude" has to be type "number" but received type "string"
                          2024-12-01 18:09:37.655  - info: hmip.0 (1111) Value unchanged, do not send this value
                          2024-12-01 18:10:27.013  - info: host.smart instance system.adapter.dwd.0 in version "2.8.5" started with pid 2403
                          2024-12-01 18:10:28.213  - info: dwd.0 (2403) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.1, js-controller: 7.0.3
                          2024-12-01 18:10:28.662  - info: dwd.0 (2403) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-12-01 18:10:29.176  - info: host.smart instance system.adapter.dwd.0 having pid 2403 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-12-01 18:10:43.209  - info: hmip.0 (1111) Value unchanged, do not send this value
                          iob diag has finished.
                          das war wohl wirklich nur eine ungünstige Momenaufnahme zu kurz nach dem update.
                          Ich danke euch vielmals
                            USB-Devices by-id:
                            Stell das um...
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyACM0
                              @thomas-braun , JAAA - hetz mich nicht 😃
                              erledigt:
                              • Asgothian
                                Asgothian Developer @darkblu last edited by
                                @darkblu
                                Nachdem das jetzt vom Tisch ist - poste bitte nochmal ein log vom Start des Adapters - aber bitte vollständig, sprich:
                                • Adapter anhalten
                                • sicherstellen das kein Prozess oder Unterprozess des Adapters noch läuft - das kann manchmal ein paar Sekunden dauern bis alles aufgeräumt ist.
                                • Markierung im Log setzen (ich lösch das Log an der stelle immer gerne)
                                • Adapter starten
                                • ca, 30 Sekunden warten
                                • Log ab der Markierung nehmen - nur die Einträge die von anderen Adaptern sind löschen (Ausgenommen Admin, JS-Controller, host, Zigbee)
                                • Hier posten.
                                A.
                                  darkblu @Asgothian last edited by
                                  @asgothian ,
                                  hier ist es (hoffentlich wie gewünscht):
                                  2024-12-02 14:50:44.263 - info: host.smart "system.adapter.zigbee.0" enabled
                                  2024-12-02 14:50:44.849 - info: host.smart instance system.adapter.zigbee.0 in version "1.10.3" started with pid 9991
                                  2024-12-02 14:50:46.700 - info: zigbee.0 (9991) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-02 14:50:46.738 - info: zigbee.0 (9991) delete old Backup files. keep only last 10
                                  2024-12-02 14:50:46.740 - info: zigbee.0 (9991) Starting Zigbee npm ...
                                  2024-12-02 14:50:46.882 - info: zigbee.0 (9991) Installed Version: iobroker.zigbee@1.10.3
                                  2024-12-02 14:50:47.071 - info: zigbee.0 (9991) Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
                                  2024-12-02 14:50:47.092 - info: zigbee.0 (9991) Unable to disable LED, unsupported function.
                                  2024-12-02 14:50:47.098 - info: zigbee.0 (9991) --> transmitPower : normal
                                  2024-12-02 14:50:47.138 - info: zigbee.0 (9991) Unable to set transmit power, unsupported function.
                                  2024-12-02 14:50:47.141 - info: zigbee.0 (9991) Currently 41 devices are joined:
                                  2024-12-02 14:50:47.231 - info: zigbee.0 (9991) 0xa4c138263bc0fd54 (addr 48646): A1Z - Nous Smart plug (with power monitoring) (Router)
                                  2024-12-02 14:50:47.233 - info: zigbee.0 (9991) 0x00158d00068a104e (addr 5382): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.234 - info: zigbee.0 (9991) 0x00158d00067bd760 (addr 5944): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.234 - info: zigbee.0 (9991) 0x00158d00068a0fc8 (addr 61509): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.235 - info: zigbee.0 (9991) 0x00158d000689b44c (addr 15607): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.235 - info: zigbee.0 (9991) 0x00158d00044fd0ff (addr 51864): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.236 - info: zigbee.0 (9991) 0x00158d000659483a (addr 7445): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.237 - info: zigbee.0 (9991) 0xa4c1383c2241067d (addr 37641): A1Z - Nous Smart plug (with power monitoring) (Router)
                                  2024-12-02 14:50:47.238 - info: zigbee.0 (9991) 0x00158d00065a416f (addr 36888): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.238 - info: zigbee.0 (9991) 0x00158d000689def2 (addr 8433): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.239 - info: zigbee.0 (9991) 0x00158d000679680d (addr 55433): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.239 - info: zigbee.0 (9991) 0x00158d000689725b (addr 47949): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.240 - info: zigbee.0 (9991) 0x00158d000679208d (addr 34859): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.240 - info: zigbee.0 (9991) 0x00158d00068971cc (addr 60564): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.240 - info: zigbee.0 (9991) 0x00158d00067bd833 (addr 59748): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.241 - info: zigbee.0 (9991) 0x00158d00067bf5e6 (addr 18745): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.241 - info: zigbee.0 (9991) 0x00158d00067c039a (addr 47927): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.242 - info: zigbee.0 (9991) 0x00158d00067bd6a0 (addr 2007): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.242 - info: zigbee.0 (9991) 0x847127fffe7f023c (addr 4772): SP 220 - Innr Smart plug (Router)
                                  2024-12-02 14:50:47.243 - info: zigbee.0 (9991) 0x847127fffe1a1543 (addr 18863): SP 220 - Innr Smart plug (Router)
                                  2024-12-02 14:50:47.243 - info: zigbee.0 (9991) 0x00158d00067bfbdd (addr 61571): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.243 - info: zigbee.0 (9991) 0x00158d0006897144 (addr 14303): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.244 - info: zigbee.0 (9991) 0x00158d000651801e (addr 55867): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                                  2024-12-02 14:50:47.244 - info: zigbee.0 (9991) 0x00158d00067233bc (addr 13967): SJCGQ11LM - Aqara Water leak sensor (EndDevice)
                                  2024-12-02 14:50:47.245 - info: zigbee.0 (9991) 0xbc33acfffe22f54d (addr 52407): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                  2024-12-02 14:50:47.245 - info: zigbee.0 (9991) 0x3425b4fffe7d9225 (addr 50663): E1743 - IKEA TRADFRI on/off switch (EndDevice)
                                  2024-12-02 14:50:47.246 - info: zigbee.0 (9991) 0x00158d00067bf5ba (addr 12983): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                                  2024-12-02 14:50:47.246 - info: zigbee.0 (9991) 0xbc33acfffe1dbb97 (addr 28468): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                  2024-12-02 14:50:47.247 - info: zigbee.0 (9991) 0xcc86ecfffe25fcc0 (addr 14766): SP 220 - Innr Smart plug (Router)
                                  2024-12-02 14:50:47.247 - info: zigbee.0 (9991) 0xcc86ecfffe2abecf (addr 7625): SP 220 - Innr Smart plug (Router)
                                  2024-12-02 14:50:47.247 - info: zigbee.0 (9991) 0x00158d0007105346 (addr 41994): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.248 - info: zigbee.0 (9991) 0x00158d0006e4c790 (addr 42188): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                                  2024-12-02 14:50:47.248 - info: zigbee.0 (9991) 0x00158d0007504e37 (addr 49576): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                  2024-12-02 14:50:47.248 - info: zigbee.0 (9991) 0x00158d00073a24bb (addr 243): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                  2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x00158d00073a2955 (addr 43923): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                                  2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x84fd27fffe2a515f (addr 16538): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                  2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x001788010bd5349f (addr 48418): 929002469202 - Philips Hue white A60 bulb E27 1050lm with Bluetooth (Router)
                                  2024-12-02 14:50:47.249 - info: zigbee.0 (9991) 0x04cd15fffe330915 (addr 30337): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                                  2024-12-02 14:50:47.250 - info: zigbee.0 (9991) 0x04cd15fffe2e1e25 (addr 32635): E1525/E1745 - IKEA TRADFRI motion sensor (EndDevice)
                                  2024-12-02 14:50:47.250 - info: zigbee.0 (9991) 0x84b4dbfffe9f6168 (addr 11791): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
                                  2024-12-02 14:50:47.250 - info: zigbee.0 (9991) 0xf082c0fffede13d6 (addr 43459): E1743 - IKEA TRADFRI on/off switch (EndDevice)
                                  2024-12-02 14:50:47.251 - info: zigbee.0 (9991) Zigbee started
                                  2024-12-02 14:50:47.317 - info: zigbee.0 (9991) debug devices set to []
                                  • Asgothian
                                    @darkblu Das sieht doch gut aus - es sollte laufen ?
                                      @asgothian said in [gelöst] Zigbee Adapter bleibt gelb nach Raspi update:
                                      ja, es löppt alles 😰
                                      531
