    4. Backitup: index.js fehlt
      lessthanmore last edited by
      beim Versuch die Liste der Backups zu öffnen bzw. einfach nur beim Klick auf Backitup im Menü kommt folgende Meldung:
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-4-pve
          Architecture: x86-64
      OS is similar to:
      model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       13:48:48 up 4 days, 20:05,  2 users,  load average: 0.15, 0.08, 0.02
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2024-12-03 13:48:48 CET
                 Universal time: Tue 2024-12-03 12:48:48 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      michael
      HOME=/home/michael
      GROUPS=michael tty dialout sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            8.6G        2.4G        5.3G        192K        921M        6.2G
      Swap:           4.3G         20K        4.3G
      Total:           12G        2.4G        9.6G
      Active iob-Instances: 	17
               8192 M total memory
               2242 M used memory
                790 M active memory
               2201 M inactive memory
               5070 M free memory
                  0 M buffer memory
                878 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      top - 13:48:48 up 4 days, 20:05,  2 users,  load average: 0.15, 0.08, 0.02
      Tasks:  55 total,   1 running,  54 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 50.0 id, 50.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   5068.9 free,   2244.7 used,    878.6 buff/cache
      MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   5947.3 avail Mem
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
      * certbot.service                      loaded failed failed Certbot
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      4 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       15G  7.1G  6.9G  51% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      /dev/mapper/pve-root             ext4       96G   61G   31G  67% /dev/ttyACM0
      udev                             devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
      tmpfs                            tmpfs      13G  120K   13G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET         SOURCE                                                 FSTYPE OPTIONS
      /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
      `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/100/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
      /var:
      632M	/var/
      525M	/var/lib
      274M	/var/lib/redis
      143M	/var/lib/apt/lists
      143M	/var/lib/apt
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      1.3G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      76M	/opt/iobroker/iobroker-data/
      74M	/opt/iobroker/iobroker-data/node-red
      73M	/opt/iobroker/iobroker-data/node-red/node_modules
      9.8M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email
      9.7M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules
      2.0M	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/js/app.min.js
      620K	/opt/iobroker/iobroker-data/node-red/node_modules/moment/min/moment-with-locales.js
      616K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-dashboard/dist/css/app.min.css
      600K	/opt/iobroker/iobroker-data/backitup/backitup.0.log
      544K	/opt/iobroker/iobroker-data/node-red/node_modules/node-red-node-email/node_modules/imap/deps/encoding/encoding-indexes.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2432650-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.18.1
      /usr/bin/node 		v20.18.1
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 417898)
      Core adapters versions
      js-controller: 	7.0.3
      admin: 		7.1.5
      javascript: 	8.8.3
      nodejs modules from github: 	1
      +-- iobroker.bmw@2.9.0 (git+ssh://git@github.com/TA2k/ioBroker.bmw.git#3caf730cbdf4e3a3d27b6a51f852a5c97f7aa16c)
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 10.0.1.11
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.3    , installed 7.0.3
      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.10
      Objects and States
      Objects: 	4123
      States: 	4136
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 10.0.1.11:8080          0.0.0.0:*               LISTEN      1001       5247193    524/node
      tcp        0      0 127.0.0.1:33797         0.0.0.0:*               LISTEN      1000       5234655    571/io.yahka.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5247690    830/master
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        5239408    152/redis-server 12
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          5247626    703/nginx: master p
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5239232    1/init
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          5247628    703/nginx: master p
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       5247190    505/io.zigbee2mqtt.
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       10983295   5199/node-red
      tcp6       0      0 :::80                   :::*                    LISTEN      0          5247627    703/nginx: master p
      tcp6       0      0 :::111                  :::*                    LISTEN      0          5239234    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5241038    1/init
      tcp6       0      0 :::34353                :::*                    LISTEN      1000       5234609    571/io.yahka.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5247691    830/master
      tcp6       0      0 ::1:6379                :::*                    LISTEN      107        5239409    152/redis-server 12
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       5242364    586/io.simple-api.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5249524    556/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       5241170    213/io.admin.0
      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       5247329    601/io.lovelace.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5239233    1/init
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        5227294    105/avahi-daemon: r
      udp        0      0 0.0.0.0:44712           0.0.0.0:*                           110        5227296    105/avahi-daemon: r
      udp        0      0 10.0.1.11:54653         0.0.0.0:*                           1000       10987170   5199/node-red
      udp6       0      0 :::111                  :::*                                0          5239235    1/init
      udp6       0      0 :::5353                 :::*                                110        5227295    105/avahi-daemon: r
      udp6       0      0 :::50422                :::*                                110        5227297    105/avahi-daemon: r
      2024-12-03 13:46:50.610  - error: backitup.0 (354) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
      2024-12-03 13:46:55.388  - error: backitup.0 (354) Error: Cannot find module '/opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core/build/cjs/index.js'
      			v.2024-10-19
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		64 bit
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1001
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.6G        2.4G        5.2G        192K        1.1G        6.2G
      Swap:           4.3G         20K        4.3G
      Total:           12G        2.4G        9.5G
      ioBroker Core: 		js-controller 		7.0.3
      			admin 			7.1.5
      ioBroker Status: 	iobroker is running on this host.
      Objects type: redis
      States  type: redis
      Objects: 		4123
      States: 		4136
      Size of iob-Database:
      136K	/opt/iobroker/iobroker-data/objects.json.bak
      12K	/opt/iobroker/iobroker-data/states.json.bak
      Gibt es eine Möglichkeit die Datei zu erstellen/ erstellen zu lassen ohne Neuinstallieren des Adapters?
      Danke vorab.Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
      Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
      DANKE
      Bitte ausfüllen:
      • Adaptername: ...
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: ...
      • js-controller Version: ...
      • Admin Version: ...
      • Hardwaresystem: NUC, Pi4 ...
      • Arbeitsspeicher: ...xGB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Betriebssystem: ...
      • Nodejs-Version: ...
      • NPM-Version: ...
      • Installationsart: Skript oder Manuell ?
      • Image, Docker genutzt: Ja - Nein
      • Ort, Name der Imagedatei: ...
      Linux User bitte hier den Output von iob diag einfügen.Hi,
      Script v.2024-10-19
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      michael
      HOME=/home/michael
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.3G         20K        4.3G
               8192 M total memory
               2242 M used memory
                790 M active memory
               5070 M free memory
                  0 M buffer memory
                878 M swap cache
               4096 M total swap
                  0 M used swap
               4095 M free swap
      *** FILESYSTEM ***
      /var:
      632M	/var/
      525M	/var/lib
      274M	/var/lib/redis
      143M	/var/lib/apt
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin: 		7.1.5
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	4123
      States: 	4136
      Pending Updates: 0
      			v.2024-10-19
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		64 bit
      User-ID: 		1001
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      MEMORY:
      Swap:           4.3G         20K        4.3G
      			admin 			7.1.5
      Objects type: redis
      States  type: redis
      Objects: 		4123
      States: 		4136
      Danke vorab.
        paul53 @lessthanmore last edited by
        @lessthanmore
        Versuche es mit
        iob upload backitup
          lessthanmore @paul53 last edited by
          @paul53 Leider keine Änderung.
