    4. Sonoff Zigbee will einfach nicht.
      Se7en last edited by
      Hallo Leute,
      ich suche schon den ganzen Nachmittag nach dem Fehler und finde ihn einfach nicht.
      Ich habe einen Sonoff Zigbee 3.0 USB Dongle plus, und wollte eben ein paar Geräte hinzufügen. Der Adapter wird einfach nicht grün.
      Hier mal der Log von meinem Raspi
      2024-12-03 22:30:09.245  - info: host.iobroker "system.adapter.zigbee.0" disabled
      2024-12-03 22:30:09.245  - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-12-03 22:30:09.306  - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
      2024-12-03 22:30:09.306  - info: zigbee.0 (72819) Got terminate signal TERMINATE_YOURSELF
      2024-12-03 22:30:09.309  - info: zigbee.0 (72819) cleaned everything up...
      2024-12-03 22:30:09.320  - info: zigbee.0 (72819) Zigbee: disabling joining new devices.
      2024-12-03 22:30:09.437  - warn: zigbee.0 (72819) Failed to stop zigbee during startup
      2024-12-03 22:30:09.438  - info: zigbee.0 (72819) terminating
      2024-12-03 22:30:09.440  - info: zigbee.0 (72819) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-12-03 22:30:09.810  - info: zigbee.0 (72819) terminating
      2024-12-03 22:30:10.026  - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-03 22:30:58.837  - info: host.iobroker "system.adapter.zigbee.0" enabled
      2024-12-03 22:30:59.386  - info: host.iobroker instance system.adapter.zigbee.0 in version "1.10.3" started with pid 79481
      2024-12-03 22:31:03.633  - info: admin.0 (1449) <== Disconnect system.user.admin from ::ffff:192.168.2.115
      2024-12-03 22:31:05.084  - info: zigbee.0 (79481) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.16.0, js-controller: 7.0.3
      2024-12-03 22:31:05.175  - info: zigbee.0 (79481) delete old Backup files. keep only last 10
      2024-12-03 22:31:05.178  - info: zigbee.0 (79481) Starting Zigbee  npm ...
      2024-12-03 22:31:05.570  - info: zigbee.0 (79481) Installed Version: iobroker.zigbee@1.10.3
      2024-12-03 22:31:06.277  - error: zigbee.0 (79481) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      2024-12-03 22:31:06.278  - error: zigbee.0 (79481) Failed to start Zigbee
      2024-12-03 22:31:06.278  - error: zigbee.0 (79481) Error herdsman start
      2024-12-03 22:31:16.283  - info: zigbee.0 (79481) Try to reconnect. 1 attempts left
      2024-12-03 22:31:16.284  - info: zigbee.0 (79481) Starting Zigbee  npm ...
      2024-12-03 22:31:16.297  - info: zigbee.0 (79481) Installed Version: iobroker.zigbee@1.10.3
      2024-12-03 22:31:16.545  - error: zigbee.0 (79481) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      2024-12-03 22:31:16.547  - error: zigbee.0 (79481) Failed to start Zigbee
      2024-12-03 22:31:16.547  - error: zigbee.0 (79481) Error herdsman start
      Ich habe schon probiert eventuelle Backup Dateien zu löschen, war nichts vorhanden. Unterschiedliche USB-Ports ausprobiert. Adapter gestoppt, USB-Stick ausgesteckt, gewartet und dann wieder eingesteckt und den Adapter gestartet, nichts funktionierte.
      Habe auch versucht mit der PAN ID zu spielen, hilft auch nichts.
      Ich habe jetzt mal den Start vom Adapter erzwungen dann wird er grün. Hier zu der Log im iob
      2024-12-03 22:49:43.914  - error: zigbee.0 (79481) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      2024-12-03 22:49:44.133  - info: zigbee.0 (79481) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"5a71161ff6e6ed11a95fcf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_5a71161ff6e6ed11a95fcf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyAMA0"}]
      2024-12-03 22:49:49.026  - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
      2024-12-03 22:49:49.090  - info: zigbee.0 (79481) Got terminate signal TERMINATE_YOURSELF
      2024-12-03 22:49:49.090  - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
      2024-12-03 22:49:49.204  - info: admin.0 (1449) <== Disconnect system.user.admin from ::ffff:192.168.2.115
      2024-12-03 22:49:49.092  - info: zigbee.0 (79481) cleaned everything up...
      2024-12-03 22:49:49.104  - info: zigbee.0 (79481) Zigbee: disabling joining new devices.
      2024-12-03 22:49:49.246  - warn: zigbee.0 (79481) Failed to stop zigbee during startup
      2024-12-03 22:49:49.253  - info: zigbee.0 (79481) terminating
      2024-12-03 22:49:49.264  - info: zigbee.0 (79481) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-12-03 22:49:49.594  - info: zigbee.0 (79481) terminating
      2024-12-03 22:49:49.853  - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-03 22:49:53.353  - info: host.iobroker instance system.adapter.zigbee.0 in version "1.10.3" started with pid 81904
      2024-12-03 22:49:59.313  - info: zigbee.0 (81904) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.16.0, js-controller: 7.0.3
      2024-12-03 22:49:59.404  - info: zigbee.0 (81904) delete old Backup files. keep only last 10
      2024-12-03 22:49:59.416  - info: zigbee.0 (81904) Starting Zigbee  npm ...
      2024-12-03 22:49:59.796  - info: zigbee.0 (81904) Installed Version: iobroker.zigbee@1.10.3
      2024-12-03 22:50:03.903  - info: zigbee.0 (81904) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
      2024-12-03 22:50:03.913  - info: zigbee.0 (81904) Unable to disable LED, unsupported function.
      2024-12-03 22:50:03.950  - info: zigbee.0 (81904)   --> transmitPower : normal
      2024-12-03 22:50:03.962  - info: zigbee.0 (81904) Currently no devices.
      2024-12-03 22:50:03.963  - info: zigbee.0 (81904) Zigbee started
      2024-12-03 22:50:04.313  - info: zigbee.0 (81904) debug devices set to []
      Der Name meines USB-Sticks:
      sven@iobroker:~ $ ls -la /dev/serial/by-id/
      total 0
      drwxr-xr-x 2 root root 60 Dec  3 22:30 .
      drwxr-xr-x 4 root root 80 Dec  3 22:30 ..
      lrwxrwxrwx 1 root root 13 Dec  3 22:30 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_5a71161ff6e6ed11a95fcf770b2af5ab-if00-port0 -> ../../ttyUSB0
      Meine Einstellung selbst im Adapter sieht folgend aus:
      Ich hoffe mir kann jemand helfen, wahrscheinlich übersehe ich was total banales.
      Vielen Dank und Grüße
      Sven
      • haselchen
        haselchen Most Active @Se7en last edited by
        @se7en
        Versuch mal den Adapter anzuhalten.
        In iobroker data / zigbee.0 die Datei
        zu löschen.
        Dann in den Adapter und gib mal die Standard erweiterte PAN ID ein.
        DDDDDDDDDDDDDDDD
        Ich hab ne 4 stellige PAN ID (Feld darunter) , weil vorher da auch 4 Zahlen standen.
        Versuch auch mal ne 4 stellige Zahl.
        Und dann den Adapter wieder starten.
        S Asgothian 2 Replies Last reply Reply Quote 0
          Se7en @haselchen last edited by
          @haselchen
          danke für den Tipp.
          Habe zuerst gedacht es hat nichts geholfen, da der Adapter eigentlich gelb war.
          Das Log habe ich gerade gesucht um damit zu antworten und noch ein paar Sachen getestet.
          Seh ich nochmal zur Sicherheit im iob vorbei. Ist der Adapter Grün, man glaubt es kaum 🙂
          Vielen Dank nochmals, schöne Nacht noch.
          Sven
          • Asgothian
            Asgothian Developer @haselchen last edited by
            @haselchen sagte in Sonoff Zigbee will einfach nicht.:
            @se7en
            zu löschen.
            DDDDDDDDDDDDDDDD
            auf Keinen Fall die PanID auf DDDDDDDDDDDDDDDD setzen - das ist eine Sackgasse.Bei der Einstellung wird die PanID von der Hardware abgeleitet - das geht so lange gut bis dann der Hardware Koordinator kaputt ist.
            Die eigentlich korrekte Lösung für den Fall (charakterisiert durch diese Meldung im Log startup failed - configuration-adapter mismatch - see logs above for more information) ist
            • nvbackup.json auslesen - darin zu finden: PanID, ExtPanID und Zigbee Kanal
            • Entscheiden: will ich das Netz wieder verbinden oder will ich alles neu machen.
              -- zum alles neu machen: Adapter anhalten, nvbackup.json und shepherd.db löschen
              -- zum Netz wieder verbinden: Zigbee Adapter neu starten. Warn/Fehlermeldung ignorieren und auf die Konfigurationsseite gehen, PanID, ExtPanID und Zigbee Kanal aus der NVBackup.json eintragen, Adapter anhalten, 15 Sekunden warten Wichtig:in der NVBackup.json ist die PanID als Hex Wert (0x12ab) angegeben - dieser muss in eine Dezimalzahl (4779) umgewandelt werden.
            • Adapter starten, Warten bis er grün wird.
            A.
            haselchen 1 Reply Last reply Reply Quote 2
            • haselchen
              haselchen Most Active @Asgothian last edited by
              @asgothian sagte in Sonoff Zigbee will einfach nicht.:
              Gut, dass wir das mal geklärt haben 😬
              • BananaJoe
                BananaJoe Most Active @haselchen last edited by
                @haselchen mein erstes ZigBee Netz hatte - warum auch immer, auch diese PAN-ID ....
                1Topf 1 Reply Last reply Reply Quote 0
                • 1Topf
                  1Topf @BananaJoe last edited by
                  @bananajoe Dito.
                    Thomas Braun Most Active @1Topf last edited by
                    Das ist halt die Voreinstellung 'ab Werk'
                    Muss halt vom Admin angepasst werden.
                    Wlan-Router haben ja auch in der Regel irgendwas von Hersteller voreingestellt beim WLAN-Namen.
                    • haselchen
                      haselchen Most Active @Thomas Braun last edited by
                      @thomas-braun sagte in Sonoff Zigbee will einfach nicht.:
                      Das passiert aber nicht adäquat das, wenn man die Einstellungen nach jedem Reset übernehmen würde:
                        Thomas Braun Most Active @haselchen last edited by Thomas Braun
                        @haselchen
                        Ja doch, im Grunde schon. Ein Client muss sich am richtigen Netz anmelden. Und wenn da schon mal was gesetzt wurde ist DDDDDDDDDDDD halt falsch und man kann sich nicht damit anmelden.
                        'Früher' gab es im Log ja entsprechende Meldungen, wie das Netz richtig heißt.
                        herdsman problem sonoff zigbee
                        375
