    4. Fehler beim Backup von Grafana
      Snopy_16 last edited by
      Bin von Raspi auf Mini-PC mit Proxmox umgestiegen. Mit Backitup habe ich alles wieder hergestellt.
      Daten (iobroker, History, InfluxDB, Grafana,..)liegen auf neuem System 👍
      Jetzt wollte ich nun das neue System gleich mal sichern, da kam beim grafana-backup folgende Fehlermeldung.
      backitup.0
      2024-12-11 10:30:32.950	error	[iobroker/grafana] cannot found Grafana Backup files
      backitup.0
      2024-12-11 10:30:32.936	error	[iobroker/grafana] Error on Grafana Dashboard Request: AxiosError: Request failed with status code 401
      Im Detail
      Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
      grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n    at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\n    at IncomingMessage.emit (node:events:530:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n    at processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.7.9","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.23:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
      Was hat das zu bedeuten? Wo kann ich ansetzen?
      Benutzername, PW und Servicetoken sind im Backitupadapter eingetragen.
        Snopy_16 @Snopy_16 last edited by
        Wollte nun den LXD Container von grafana upgraden, da kam das
        root@grafana:~# apt upgrade
        Reading package lists... Done
        Building dependency tree... Done
        Calculating upgrade... Done
        The following packages will be upgraded:
          grafana
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        1 not fully installed or removed.
        Need to get 0 B/127 MB of archives.
        After this operation, 643 kB of additional disk space will be used.
        Do you want to continue? [Y/n] y
        Reading changelogs... Done
        (Reading database ... 32684 files and directories currently installed.)
        Preparing to unpack .../grafana_11.4.0_amd64.deb ...
        Unpacking grafana (11.4.0) over (11.3.1) ...
        dpkg: error processing archive /var/cache/apt/archives/grafana_11.4.0_amd64.deb (--unpack):
         cannot copy extracted data for './usr/share/grafana/public/app/plugins/datasource/azuremonitor/img/contoso_loans_grafana_dashboard.png' to '/usr/share/grafana/public/app/plugins/datasource/azuremonitor/img/contoso_loans_grafana_dashboard.png.dpkg-new': failed to write (No space left on device)
        dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
        Errors were encountered while processing:
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        root@grafana:~#
          Thomas Braun Most Active @Snopy_16 last edited by
          @snopy_16 sagte in Fehler beim Backup von Grafana:
          Der Datenträger ist voll.
            Snopy_16 @Thomas Braun last edited by
            Danke, das hab ich schon behoben.
            aber beim Backup kommt steht im log (Zeile 29) ein Fehler, obwohl eigentlich vorher keiner ausgegeben wird.
            11:57:14.913INFOguiBackup gestartet ...
            [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false}
            11:57:24.953DEBUGmountnfs-mount command: "sudo mount 192.168.178.10:/Sicherung/iobroker /opt/iobroker/backups"
            11:57:25.051DEBUGmountmount successfully completed
            11:57:25.094DEBUGmountdone
            [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149}
            11:57:28.279DEBUGiobrokerhost.iobroker 13795 objects saved
            11:57:29.278DEBUGiobrokerhost.iobroker 12355 states saved
            11:57:29.326DEBUGiobrokerhost.iobroker Validating backup ...
            11:57:29.332DEBUGiobrokerhost.iobroker "config.json" is valid
            11:57:29.343DEBUGiobrokerhost.iobroker "objects.jsonl" exists
            host.iobroker "states.jsonl" exists
            11:57:29.611DEBUGiobrokerhost.iobroker JSONL lines are valid
            11:57:29.689DEBUGiobrokerhost.iobroker The backup is valid!
            11:57:30.346DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz
            11:57:30.398DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
            11:57:31.359DEBUGiobrokerdone
            11:57:32.719DEBUGgrafanaStart Grafana Backup ...
            11:57:32.730DEBUGgrafanaCreated grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
            11:57:32.736DEBUGgrafanaCreated dashboard directory
            11:57:32.746DEBUGgrafanaCreated dashboards_manually_restore directory
            11:57:32.752DEBUGgrafanaCreated datasource directory
            11:57:32.764DEBUGgrafanastart Grafana request ...
            11:57:32.930DEBUGgrafanaGrafana is available ... Status: 200
            11:57:33.070DEBUGgrafanadone
            11:57:34.217DEBUGcifsused copy path: /Sicherung/iobroker
            11:57:34.261DEBUGcifsdone
            [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
            11:57:34.867ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
            11:57:34.878DEBUGcleandone
            11:57:34.974DEBUGhistoryHTMLnew history html values created
            11:57:35.064DEBUGhistoryHTMLdone
            [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            11:57:35.222DEBUGhistoryJSONnew history json values created
            11:57:35.265DEBUGhistoryJSONdone
            11:57:35.377DEBUGumountmount active, umount is started ...
            [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            11:57:40.513DEBUGumountumount successfully completed
            11:57:40.557DEBUGumountdone
            11:57:40.840DEBUGemail[iobroker] used E-Mail-Instance: email.0
            11:57:40.877DEBUGemaildone
            [DEBUG] [email] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker","umount"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            [DEBUG] [notification] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"23:00","cronjob":"","ownCron":false,"debugging":true,"slaveBackup":"Single","everyXDays":"3","nameSuffix":"Proxmox","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_12_11-11_57_24_Proxmox_backupiobroker.tar.gz"],"errors":{"grafana":"{\"message\":\"Request failed with status code 401\",\"name\":\"AxiosError\",\"stack\":\"AxiosError: Request failed with status code 401\\n at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\\n at IncomingMessage.emit (node:events:530:35)\\n at IncomingMessage.emit (node:domain:489:12)\\n at endReadableNT (node:internal/streams/readable:1698:12)\\n at processTicksAndRejections (node:internal/process/task_queues:82:21)\\n at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\\n at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43\",\"config\":{\"transitional\":{\"silentJSONParsing\":true,\"forcedJSONParsing\":true,\"clarifyTimeoutError\":false},\"adapter\":[\"xhr\",\"http\",\"fetch\"],\"transformRequest\":[null],\"transformResponse\":[null],\"timeout\":0,\"xsrfCookieName\":\"XSRF-TOKEN\",\"xsrfHeaderName\":\"X-XSRF-TOKEN\",\"maxContentLength\":-1,\"maxBodyLength\":-1,\"env\":{},\"headers\":{\"Accept\":\"application/json, text/plain, */*\",\"Authorization\":\"Bearer 060fZi4mJKPmTHgPQRYmuaEKqL0lOUP-yvIVEPgyBB2ZZ1FBjhU-AMNOT7vQCNfRyx9_reM5l01bR27Mgop_9g==\",\"User-Agent\":\"axios/1.7.9\",\"Accept-Encoding\":\"gzip, compress, deflate, br\"},\"method\":\"get\",\"url\":\"http://192.168.178.23:3000/api/search\",\"responseType\":\"json\",\"httpsAgent\":{\"_events\":{},\"_eventsCount\":2,\"_maxListeners\":100,\"defaultPort\":443,\"protocol\":\"https:\",\"options\":{\"rejectUnauthorized\":true,\"noDelay\":true,\"path\":null},\"requests\":{},\"sockets\":{},\"freeSockets\":{},\"keepAliveMsecs\":1000,\"keepAlive\":false,\"maxSockets\":null,\"maxFreeSockets\":256,\"scheduling\":\"lifo\",\"maxTotalSockets\":null,\"totalSocketCount\":0,\"maxCachedSessions\":100,\"_sessionCache\":{\"map\":{},\"list\":[]}}},\"code\":\"ERR_BAD_REQUEST\",\"status\":401}"},"done":["mount","iobroker","umount"],"types":["iobroker"]},"timestamp":1733914634149,"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"192.168.178.70\\Sicherung\\iobroker","debugging":true,"deleteOldBackup":false,"ftpDeleteAfter":10,"advancedDelete":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"admin","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.178.10","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=2.0","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":false,"ownDir":false,"dir":"/Sicherung/iobroker","dirMinimal":"Sicherung/iobroker/standard","user":"admin","pass":"****","expertMount":"","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"dropboxDeleteAfter":10,"advancedDelete":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"onedriveDeleteAfter":10,"advancedDelete":false,"onedriveAccessJson":"****","ownDir":false,"dir":"Sicherung/iobroker","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"webdavDeleteAfter":10,"advancedDelete":false,"username":"admin","pass":"****","url":"192.168.178.70","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"host":"192.168.178.23","port":"3000","protocol":"http","username":"Admin","pass":"****","apiKey":"****","nameSuffix":"Proxmox","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"h.traunwieser@gmx.at","emailSender":"h.traunwieser@gmx.at","onlyError":false,"emailWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Proxmox","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":"25","systemLang":"de","time":"11. Dezember 2024 um 11:57 Uhr"},"backupDir":"/opt/iobroker/backups","timestamp":1733914634149,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
            11:57:42.881DEBUGnotificationAdmin notification will be sent
            11:57:42.917DEBUGnotificationdone
            11:57:43.031INFOguiDas Backup wurde erfolgreich erstellt!
            Das steht im ioboker log
            backitup.0
            2024-12-11 11:57:34.017	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
            backitup.0
            2024-12-11 11:57:32.060	error	[iobroker/grafana] cannot found Grafana Backup files
            backitup.0
            2024-12-11 11:57:32.046	error	[iobroker/grafana] Error on Grafana Dashboard Request: AxiosError: Request failed with status code 401
            backitup.0
            2024-12-11 11:57:32.042	error	[iobroker/grafana] Error on Grafana Datasource Request
            Und das im Detail
            11.12.2024, 11:57:42
              "smb":"vers=2.0"
              Versuch mal eine höhere Protokoll-Version. Eigentlich sollte alles was halbwegs aktuell ist smb=3.1.1 sprechen.
              Und das da sowohl von NFS wie auch von CIFS die Rede ist irritiert mich auch. Was soll es denn am Ende sein?
                Hab jetzt im backitupadapter unter grafana nochmal alles neu eingetragen.
                Dazu nochmal einen neuen Service-Token aus grafana geholt - jetzt funktionierts😁
                Aber jedenfalls danke für deine Mithilfe👍
                  @thomas-braun sagte in Fehler beim Backup von Grafana:
                  NFS ist im Adapter eingetragen. Woher das CIFS kommt, weiss ich nicht.
                  81.0k
