    4. Grafana
    5. Fehler bei Wiederherstellung von Grafana
      wibear last edited by
      Hallo Forum,
      ich kann Grafana nicht wiederherstellen. Es ist ein Raspi4 mit Bookworm. Das Backup stammt vom Bullseye. Es gibt ein Fehler in der IOB-Log:
      Error: Command failed: sudo mount -t cifs -o username=iobrokerBackup,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      und in dem Wiederherstellungsdialog:
      11:00:40.504INFOguistarting Restore...
      11:00:40.803DEBUGgrafanaStart Grafana Restore ...
      11:00:40.811DEBUGgrafanafilename for restore: /opt/iobroker/backups/grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
      11:00:40.846DEBUGgrafanaGrafana tmp directory created: /opt/iobroker/backups/grafana_tmp
      11:00:40.853DEBUGgrafanastart decompress
      11:00:51.594DEBUGgrafanaGrafana request started
      11:00:51.942DEBUGgrafanaGrafana is available ... Status: 200
      11:00:52.040DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/infinity.json
      11:00:52.086DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/datasource/influxdb.json
      11:00:52.106DEBUGgrafanacannot restore datasource "infinity": "data source with the same name already exists"
      11:00:52.111DEBUGgrafanacannot restore datasource "influxdb": "data source with the same name already exists"
      11:00:55.006DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-ladeleistung.json
      11:00:55.065DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/batterie-soc.json
      11:00:55.074DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/energie.json
      11:00:55.089DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/funk.json
      11:00:55.112DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/gauges.json
      11:00:55.121DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/heizung.json
      11:00:55.127DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/temperaturen-ww-hz.json
      11:00:55.132DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/umwalzpumpe.json
      11:00:55.139DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-waschmaschiene.json
      11:00:55.157DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/signalstarke.json
      11:00:55.161DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/leistung-solar.json
      11:00:55.167DEBUGgrafanaTry to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/verbrauch-ww-taglich.json
      11:00:55.172DEBUGgrafanacannot restore dashboard "energie": {"message":"Unauthorized","traceID":""}
      11:00:55.175DEBUGgrafanacannot restore dashboard "batterie-soc": {"message":"Unauthorized","traceID":""}
      11:00:55.178DEBUGgrafanacannot restore dashboard "batterie-ladeleistung": {"message":"Unauthorized","traceID":""}
      11:00:55.229DEBUGgrafanacannot restore dashboard "funk": {"message":"Unauthorized","traceID":""}
      11:00:55.237DEBUGgrafanacannot restore dashboard "verbrauch-hz-taglich": {"message":"Unauthorized","traceID":""}
      11:00:55.248DEBUGgrafanacannot restore dashboard "heizung": {"message":"Unauthorized","traceID":""}
      11:00:55.275DEBUGgrafanacannot restore dashboard "gauges": {"message":"Unauthorized","traceID":""}
      11:00:55.278DEBUGgrafanacannot restore dashboard "temperaturen-ww-hz": {"message":"Unauthorized","traceID":""}
      11:00:55.285DEBUGgrafanacannot restore dashboard "verbrauch-ww-taglich": {"message":"Unauthorized","traceID":""}
      11:00:55.290DEBUGgrafanacannot restore dashboard "temperatur-shelly": {"message":"Unauthorized","traceID":""}
      11:00:55.294DEBUGgrafanacannot restore dashboard "umwalzpumpe": {"message":"Unauthorized","traceID":""}
      11:00:55.298DEBUGgrafanacannot restore dashboard "leistung-solar": {"message":"Unauthorized","traceID":""}
      11:01:00.969DEBUGgrafanacannot restore dashboard "signalstarke": {"message":"Unauthorized","traceID":""}
      11:01:01.013DEBUGgrafanacannot restore dashboard "leistung-waschmaschiene": {"message":"Unauthorized","traceID":""}
      11:01:01.022DEBUGgrafanaGrafana request ended
      11:01:01.030DEBUGgrafanaTry deleting the Grafana tmp directory
      11:01:01.037DEBUGgrafanaGrafana tmp directory was successfully deleted
      11:01:02.977DEBUGgrafanaGrafana Restore completed successfully
      Nur die Data sources werden übernommen.
      Woran könnte es liegen?
      Danke und Grüße
      Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @wibear last edited by Thomas Braun
        @wibear sagte in Fehler bei Wiederherstellung von Grafana:
        Da greift schon was auf den Mountpunkt /opt/iobroker/backups zu.
        Ist das Verzeichnis leer, wenn die Freigabe nicht gerade gemountet ist?
        mount | sort
        anschauen.
        [Edit:] Mountpunkt korrigiert.
        W 3 Replies Last reply Reply Quote 0
          wibear @Thomas Braun last edited by
          @thomas-braun sagte in Fehler bei Wiederherstellung von Grafana:
          Das Verzeichnis ist nicht leer.
            raspi@raspi:~ $ mount | sort
            binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
            bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
            cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
            configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
            debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
            devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
            /dev/sda1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
            /dev/sda2 on / type ext4 (rw,noatime)
            fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
            lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
            mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
            proc on /proc type proc (rw,relatime)
            pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
            ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
            ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
            ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
            ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
            securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
            sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
            sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
            systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4955)
            tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
            tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
            tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=388192k,mode=755)
            tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=388188k,nr_inodes=97047,mode=700,uid=1000,gid=1000)
            tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
            udev on /dev type devtmpfs (rw,nosuid,relatime,size=1672772k,nr_inodes=418193,mode=755)
              wibear @Thomas Braun last edited by wibear
              Da greift schon was auf den Mountpunkt /opt/iobroker/ zu.
                Sollte es aber sein, wenn es als Einhängepunkt fungieren soll.
                  Über welches Verzeichnis sprechen wir /opt/iobroker ?
                  Was soll ich ändern?
                    Wir sprechen vom Mountpunkt /opt/iobroker/backups. Hatte das oben falsch.
                      Dieses Verzeichnis ist ja leer. Was kann es noch sein?
                        @wibear
                        Was passiert denn, wenn du das Ding manuell mountest?
                          Bin mit Linux nicht so vertraut.
                          Wie mounte ich das bitte?
                            @wibear
                            Schauen, ob der Mountpunkt leer ist:
                            ls -l /opt/iobroker/backups
                            dann mounten:
                            Dein password muss noch gesetzt werden.
                            W 2 Replies Last reply Reply Quote 0
                              dann mounten:
                              Ich habe gemountet und danach wie empfohlen
                              sudo systemctl daemon-reload
                              ausgeführt.
                              raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackup,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobroker/backups
                              mount: (hint) your fstab has been modified, but systemd still uses
                                     the old version; use 'systemctl daemon-reload' to reload.
                              raspi@raspi:~ $ ^C
                              raspi@raspi:~ $ sudo systemctl daemon-reload
                                wibear @wibear last edited by
                                @wibear
                                ich habe umount ausgeführt, danach wieder mount:
                                raspi@raspi:~ $ sudo umount /opt/iobroker/backups
                                raspi@raspi:~ $ sudo mount -t cifs -o username=iobrokerBackup,password=iobrokerbackp,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=777,dir_mode=0777 //fritz.box/fritz.box/MemoryBoard/Share/Backup/ioBroker /opt/iobrker/backups
                                raspi@raspi:~ $
                                Es wurde ohne irgendeine Meldung ausgeführt.
                                  Das war vor mount
                                  raspi@raspi:~ $ ls -l /opt/iobroker/backups
                                  total 0
                                  und das ist nach mount:
                                  raspi@raspi:~ $ ls -l /opt/iobroker/backups                                        total 73984
                                  -rwxrwxrwx 1 iobroker iobroker     9507 Dec  1 02:41 grafana_2024_12_01-02_41_35_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker     9505 Dec  8 02:41 grafana_2024_12_08-02_41_41_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  1 02:30 homematic_2024_12_01-02_30_22_3.79.6_backupiobroker.tar.sbk
                                  -rwxrwxrwx 1 iobroker iobroker  5458346 Dec  8 02:30 homematic_2024_12_08-02_30_22_3.79.6_backupiobroker.tar.sbk
                                  -rwxrwxrwx 1 iobroker iobroker      225 Dec 10 15:20 homematic_2024_12_10-15_20_10_3.79.6_backupiobroker.tar.sbk
                                  -rwxrwxrwx 1 iobroker iobroker 28285363 Dec  1 02:41 influxDB_2024_12_01-02_40_29_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker 30373723 Dec  8 02:41 influxDB_2024_12_08-02_40_29_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker  2114413 Dec  1 02:40 iobroker_2024_12_01-02_40_20_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker  2132546 Dec  8 02:40 iobroker_2024_12_08-02_40_20_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker    31808 Dec  1 02:41 javascripts_2024_12_01-02_41_52_backupiobroker.tar.gz
                                  -rwxrwxrwx 1 iobroker iobroker    32943 Dec  8 02:42 javascripts_2024_12_08-02_41_59_backupiobroker.tar.gz
                                    @wibear
                                    So soll das aussehen.
                                      Wie soll ich bitte weiter vorgehen?
                                      Oder kann ich es irgenwie manuell machen?
                                        mount/unmount funktioniert manuell.
                                        Warum geht das nicht über Backitup (error 16)?
                                        Wie kann man es über die Konsole einspielen?
                                        Kann ich den Fehler in einer Log suchen?
                                          Erscheint die Meldung denn immer noch?
                                          Du darfst nicht mit irgendwelchen Prozessen (z. B. deinem graphischen Dateimanager) auf den Mountpunkt zugreifen.
                                            Der Fehler ist immer noch da, auch wenn ich nur die Konsole benutze.
                                            1970
