    4. iob started nicht nach raspi os update
      hukio last edited by hukio
      Ich habe das empfohlene OS update (Raspi 5) gemacht. Danach started der Iobroker nocht mehr. Fix hat nicht geholfen.
      Hier ist das DIAG summary
      ```bash
                              v.2024-10-19
       Static hostname: raspi5
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-2712
          Architecture: arm64
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.4G        266M        7.4G        5.7M        886M        8.2G
      Swap:           209M          0B        209M
      Total:          8.7G        266M        7.6G
      Active iob-Instances:   1
      Upgrade policy: none
      ioBroker Core:          js-controller           7.0.3
                              admin                   7.1.5
      ioBroker Status:        iobroker is not running on this host.
      Objects type: jsonl
      States  type: redis
        system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                11619
      States:                 7667
      Size of iob-Database:
      37M     /opt/iobroker/iobroker-data/objects.jsonl
      4.3M    /opt/iobroker/iobroker-data/states.jsonl
      Operating System is the current Debian stable version codenamed 'bookworm'!
      Was kann ich machen?
      In den log files von DIAG gab es einen error:
      2024-12-18 13:27:30.654  - error: host.raspi5 Cannot find view "system" for search "instance" : Connection is closed.
      • haselchen
        haselchen Most Active @hukio last edited by haselchen
        @hukio
        Die Langfassung schicken bitte.
        Und vorher probieren:
        iobroker start admin.0
          hukio @haselchen last edited by
          @haselchen
          admin.0 hat nichts gebracht.
          Script v.2024-10-19
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           17:17:16 up 11 min,  2 users,  load average: 0.07, 0.15, 0.10
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Wed 2024-12-18 17:17:16 CET
                     Universal time: Wed 2024-12-18 16:17:16 UTC
                           RTC time: Wed 2024-12-18 16:17:16
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev influxdb gpio i2c spi iobroker
          js-controller is not running
          *** DISPLAY-SERVER SETUP ***
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.4G        257M        7.6G        5.7M        734M        8.2G
          Swap:           209M          0B        209M
          Total:          8.7G        257M        7.8G
                   8052 M total memory
                    245 M used memory
                    281 M active memory
                    426 M inactive memory
                   7208 M free memory
                     65 M buffer memory
                    634 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 17:17:16 up 11 min,  2 users,  load average: 0.15, 0.17, 0.11
          Tasks: 160 total,   1 running, 159 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8052.2 total,   7208.4 free,    245.2 used,    700.3 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   7807.1 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     806M  5.4M  800M   1% /run
          /dev/sdb2      ext4       29G   15G   13G  55% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/sdb1      vfat      253M   64M  189M  26% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          [Wed Dec 18 17:05:40 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:26:02:CA vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=4fa94ab9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
          [Wed Dec 18 17:05:46 2024] EXT4-fs (sdb2): mounted filesystem 59fa7759-b600-4279-9af4-cd8198395907 ro with ordered data mode. Quota mode: none.
          [Wed Dec 18 17:05:48 2024] EXT4-fs (sdb2): re-mounted 59fa7759-b600-4279-9af4-cd8198395907 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sdb2 ext4   rw,noatime,commit=600
          `-/boot/firmware /dev/sdb1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          2.4G    /var/
          1.6G    /var/log/journal/9bc553d4544e4bcc96a7d5aa03a8d697
          1.6G    /var/log
          453M    /var/cache
          Archived and active journals take up 1.5G in the file system.
          /opt/iobroker/backups:
          6.0G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          882M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          *** NodeJS-Installation ***
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          Hosts:
          raspi5              raspi5 (version: 7.0.3, hostname: raspi5        , alive, uptime: 3845)
          Core adapters versions
          js-controller:  7.0.3
          admin:          7.1.5
          javascript:     8.8.3
          nodejs modules from github:     1
          `-- iobroker.zigbee@1.10.10 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#40073e03301995ffa45471b6b32204a37c9d6743)
          Adapter State
            system.adapter.adb.0                    : adb                   : raspi5                                   - disabled
            system.adapter.alexa2.0                 : alexa2                : raspi5                                   -  enabled
            system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
            system.adapter.ble.0                    : ble                   : raspi5                                   - disabled
            system.adapter.broadlink2.0             : broadlink2            : raspi5                                   - disabled
            system.adapter.daikin.0                 : daikin                : raspi5                                   -  enabled
            system.adapter.daikin.1                 : daikin                : raspi5                                   -  enabled
            system.adapter.discovery.0              : discovery             : raspi5                                   - disabled
            system.adapter.doorbird.0               : doorbird              : raspi5                                   -  enabled
            system.adapter.email.0                  : email                 : raspi5                                   - disabled
            system.adapter.email.1                  : email                 : raspi5                                   -  enabled
            system.adapter.flot.0                   : flot                  : raspi5                                   - disabled
            system.adapter.fritzdect.0              : fritzdect             : raspi5                                   -  enabled
            system.adapter.fullybrowser.0           : fullybrowser          : raspi5                                   -  enabled
            system.adapter.history.0                : history               : raspi5                                   -  enabled
            system.adapter.influxdb.0               : influxdb              : raspi5                                   -  enabled, port: 8086
            system.adapter.iot.0                    : iot                   : raspi5                                   -  enabled
            system.adapter.iqontrol.0               : iqontrol              : raspi5                                   -  enabled
            system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
            system.adapter.lgtv.0                   : lgtv                  : raspi5                                   -  enabled
            system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.netatmo.0                : netatmo               : raspi5                                   -  enabled
            system.adapter.nuki-extended.0          : nuki-extended         : raspi5                                   -  enabled
            system.adapter.onkyo.0                  : onkyo                 : raspi5                                   -  enabled
            system.adapter.onvif.0                  : onvif                 : raspi5                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            system.adapter.onvif.1                  : onvif                 : raspi5                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            system.adapter.ping.0                   : ping                  : raspi5                                   - disabled
            system.adapter.robonect.0               : robonect              : raspi5                                   - disabled
            system.adapter.scenes.0                 : scenes                : raspi5                                   -  enabled
            system.adapter.shelly.0                 : shelly                : raspi5                                   -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : raspi5                                   -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.signal-cmb.0             : signal-cmb            : raspi5                                   -  enabled
            system.adapter.simple-api.0             : simple-api            : raspi5                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.socketio.0               : socketio              : raspi5                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.sonoff.0                 : sonoff                : raspi5                                   -  enabled, port: 1889, bind: 0.0.0.0
            system.adapter.telegram.0               : telegram              : raspi5                                   - disabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : raspi5                                   - disabled
            system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspi5                                   - disabled
            system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "adb"          : 0.0.7    , installed 0.0.7
          Adapter    "admin"        : 7.1.5    , installed 7.1.5
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "discovery"    : 5.0.0    , installed 5.0.0
          Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.3    , installed 7.0.3
          Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "robonect"     : 1.4.2    , installed 1.4.2
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 8.2.1    , installed 8.2.1
          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
          Objects and States
          Objects:        11619
          States:         7667
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        7217       801/redis-server 12
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5694       809/sshd: /usr/sbin
          tcp6       0      0 :::22                   :::*                    LISTEN      0          5696       809/sshd: /usr/sbin
          tcp6       0      0 ::1:6379                :::*                    LISTEN      106        7218       801/redis-server 12
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4096       666/avahi-daemon: r
          udp        0      0 0.0.0.0:58704           0.0.0.0:*                           104        7170       666/avahi-daemon: r
          udp6       0      0 fe80::555:b02a:8105:546 :::*                                0          5080       768/NetworkManager
          udp6       0      0 fe80::a6d8:8469:6a0:546 :::*                                0          5733       768/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        7169       666/avahi-daemon: r
          udp6       0      0 :::54578                :::*                                104        7171       666/avahi-daemon: r
          2024-12-18 13:27:27.731  - info: host.raspi5 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:27.773  - info: host.raspi5 instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:27.850  - info: host.raspi5 instance system.adapter.daikin.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:27.892  - info: host.raspi5 instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:27.930  - info: host.raspi5 instance system.adapter.lgtv.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.006  - info: host.raspi5 instance system.adapter.netatmo.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.045  - info: host.raspi5 instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.087  - info: host.raspi5 instance system.adapter.fullybrowser.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.159  - info: host.raspi5 instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.201  - info: host.raspi5 instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.244  - warn: host.raspi5 instance system.adapter.javascript.0 terminated due to SIGKILL
          2024-12-18 13:27:28.244  - info: host.raspi5 instance system.adapter.javascript.0 terminated with code null ()
          2024-12-18 13:27:28.319  - warn: host.raspi5 instance system.adapter.sonoff.0 terminated due to SIGKILL
          2024-12-18 13:27:28.319  - info: host.raspi5 instance system.adapter.sonoff.0 terminated with code null ()
          2024-12-18 13:27:28.359  - warn: host.raspi5 instance system.adapter.signal-cmb.0 terminated due to SIGKILL
          2024-12-18 13:27:28.359  - info: host.raspi5 instance system.adapter.signal-cmb.0 terminated with code null ()
          2024-12-18 13:27:28.431  - warn: host.raspi5 instance system.adapter.web.0 terminated due to SIGKILL
          2024-12-18 13:27:28.431  - info: host.raspi5 instance system.adapter.web.0 terminated with code null ()
          2024-12-18 13:27:28.469  - info: host.raspi5 instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
          2024-12-18 13:27:28.470  - info: host.raspi5 All instances are stopped.
          2024-12-18 13:27:30.655  - warn: host.raspi5 instance system.adapter.zigbee.0 terminated due to SIGKILL
          2024-12-18 13:27:30.655  - info: host.raspi5 instance system.adapter.zigbee.0 terminated with code null ()
          2024-12-18 13:27:30.655  - info: host.raspi5 All instances are stopped.
          2024-12-18 13:27:30.664  - info: host.raspi5 terminated
          iob diag has finished.
          • haselchen
            haselchen Most Active last edited by
            @hukio sagte in iob started nicht nach raspi os update:
            Den Raspberry mal neu gestartet?
              @haselchen
              mehrfach
              • haselchen
                @hukio
                iobroker start
                iobroker restart
                auch schon probiert?
                  @haselchen
                  Ja
                    Thomas Braun Most Active @hukio last edited by
                    @hukio
                    Die Langfassung ist gefragt.
                      hukio @Thomas Braun last edited by
                      hab ich oben doch schon gesendet
                      H Thomas Braun 2 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @hukio last edited by Homoran
                        mal mit --debug!
                        iob start admin.0 --debug
                        und Ergebnis zeigen!
                          hukio @hukio last edited by
                          wenn ich iob fix laufen lasse kommt bei checking autostart folgende rote warnung:
                          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                          Authentication is required to stop 'iobroker.service'.
                          Authenticating as: ,,, (pi)
                          Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                          hukraspiEnabling autostart...
                          Autostart enabled!
                            @hukio
                            Sorry, hatte ich übersehen.
                            apt policy redis
                            sagt? Und
                            systemctl status iobroker.service
                              Thomas Braun Most Active @hukio last edited by Thomas Braun
                              Hast du den User 'pi' nach der Installation des iobrokers ab- und wieder angemeldet? Oder gleich die ganze Kiste mal sauber durchgestartet?
                              Grundsätzlich ist es auch nicht mehr empohlen, den ersten User 'pi' zu nennen. Verwende deinen Vornamen oder Forennick oder sowas.
                                hukio @Homoran last edited by
                                @homoran said in iob started nicht nach raspi os update:
                                iob start admin.0 --debug bringt keine reaktion, läuft durch
                                  pi@raspi5:~ $ systemctl status iobroker.service
                                  ○ iobroker.service - ioBroker Server
                                       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                                       Active: inactive (dead)
                                         Docs: http://iobroker.net
                                  Dec 18 17:33:25 raspi5 systemd[1]: Failed to start iobroker.service.
                                  lines 1-6/6 (END)
                                  pi@raspi5:~ $ apt policy redis
                                  redis:
                                    Installed: 5:7.0.15-1~deb12u1
                                    Candidate: 5:7.0.15-1~deb12u1
                                    Version table:
                                   *** 5:7.0.15-1~deb12u1 500
                                          500 http://deb.debian.org/debian bookworm/main armhf Packages
                                          500 http://deb.debian.org/debian-security bookworm-security/main armhf Packages
                                    Ich bin mir nicht sicher. Schon länger her, daß ich installiert habe. Glaube aber, daß ich user nach user pi umbenannt habe.
                                      ich bat
                                      @homoran sagte in iob started nicht nach raspi os update:
                                      Ergebnis zeigen!
                                      preset: ena>
                                      abgeschnitten!
                                      fehlt sonst noch was?
                                        nochmals
                                        das ist das ganze
                                          @hukio
                                          Nein, das geht rechts weiter.
                                          Terminalfenster größer ziehen.
                                          Hast du mal den hostname nachträglich geändert?
                                            hukio @Thomas Braun last edited by hukio
                                            glaube ich nicht. Habe installiert und dann nichts mehr geändert. Habe früher schon OS updates gemacht
                                            2158
