    4. twinkly Lichterkette keine verbindung
    • Horst Böttcher
      Horst Böttcher last edited by Horst Böttcher
      Hallo ich versuche gerde eine twinkly Lichterkette
      Iob läuft auf Proxmox in eim LXC Contäner ohnne Docker
      ich nutze die letzte Adapter version Release v1.0.14
      Im letzten Jahr ging es noch supper doch jetzt verbindet sich die kette nicht mehr mit dem adapter
      twinkly.0
      2024-12-20 18:02:16.361	info	Got terminate signal TERMINATE_YOURSELF
      twinkly.0
      2024-12-20 18:02:16.361	info	cleaned everything up...
      twinkly.0
      2024-12-20 18:02:16.862	info	terminating
      twinkly.0
      2024-12-20 18:02:16.862	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      twinkly.0
      2024-12-20 18:02:21.812	info	starting. Version 1.0.14 in /opt/iobroker/node_modules/iobroker.twinkly, node: v20.18.1, js-controller: 7.0.3
      twinkly.0
      2024-12-20 18:02:21.932	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
      twinkly.0
      2024-12-20 18:02:21.934	info	Startup complete
      twinkly.0
      2024-12-20 18:03:21.937	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
      twinkly.0
      2024-12-20 18:04:21.941	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
      twinkly.0
      2024-12-20 18:05:21.945	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
      twinkly.0
      2024-12-20 18:06:21.949	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
      twinkly.0
      2024-12-20 18:07:21.953	error	[545454.ping]: [ping.probe] there was an error while executing the ping program. check the path or permissions...: /bin/ping: socket: Operation not permitted
      host.Iobroker
      2024-12-20 18:01:52.323	error	cannot call visUtils: Cannot convert undefined or null to object
      host.Iobroker
      2024-12-20 18:02:16.337	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
      host.Iobroker
      2024-12-20 18:02:16.404	info	stopInstance system.adapter.twinkly.0 send kill signal
      host.Iobroker
      2024-12-20 18:02:17.399	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:02:20.694	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4668
      host.Iobroker
      2024-12-20 18:05:48.010	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4689
      host.Iobroker
      2024-12-20 18:05:50.063	info	instance system.adapter.dwd.0 having pid 4689 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:10:48.009	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4709
      host.Iobroker
      2024-12-20 18:10:50.018	info	instance system.adapter.dwd.0 having pid 4709 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:15:38.955	error	cannot call visUtils: Cannot convert undefined or null to object
      host.Iobroker
      2024-12-20 18:15:47.010	info	instance system.adapter.daswetter.0 in version "3.1.16" started with pid 4744
      host.Iobroker
      2024-12-20 18:15:51.018	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4759
      host.Iobroker
      2024-12-20 18:15:53.168	info	instance system.adapter.dwd.0 having pid 4759 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:15:54.501	info	instance system.adapter.daswetter.0 having pid 4744 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:16:28.810	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
      host.Iobroker
      2024-12-20 18:16:28.886	info	stopInstance system.adapter.twinkly.0 send kill signal
      host.Iobroker
      2024-12-20 18:16:29.877	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:16:33.176	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4778
      host.Iobroker
      2024-12-20 18:17:22.789	info	"system.adapter.ping.0" enabled
      host.Iobroker
      2024-12-20 18:17:23.178	info	instance system.adapter.ping.0 in version "1.6.2" started with pid 4794
      host.Iobroker
      2024-12-20 18:17:28.804	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
      host.Iobroker
      2024-12-20 18:17:28.866	info	stopInstance system.adapter.twinkly.0 send kill signal
      host.Iobroker
      2024-12-20 18:17:29.861	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:17:33.168	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4809
      host.Iobroker
      2024-12-20 18:18:05.469	error	cannot call visUtils: Cannot convert undefined or null to object
      host.Iobroker
      2024-12-20 18:18:19.013	info	instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 4839
      host.Iobroker
      2024-12-20 18:18:32.876	info	stopInstance system.adapter.twinkly.0 (force=false, process=true)
      host.Iobroker
      2024-12-20 18:18:32.936	info	stopInstance system.adapter.twinkly.0 send kill signal
      host.Iobroker
      2024-12-20 18:18:33.934	info	instance system.adapter.twinkly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:18:35.313	info	instance system.adapter.openweathermap.0 having pid 4839 terminated with code 0 (NO_ERROR)
      host.Iobroker
      2024-12-20 18:18:37.215	info	instance system.adapter.twinkly.0 in version "1.0.14" started with pid 4854
      host.Iobroker
      2024-12-20 18:18:57.859	info	stopInstance system.adapter.ping.0 (force=false, process=true)
      host.Iobroker
      2024-12-20 18:18:57.933	info	stopInstance system.adapter.ping.0 send kill signal
      host.Iobroker
      2024-12-20 18:18:58.926	info	instance system.adapter.ping.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.Iobroker
      2024-12-20 18:19:02.236	info	instance system.adapter.ping.0 in version "1.6.2" started with pid 4870
      host.Iobroker
      2024-12-20 18:20:48.010	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 4897
      host.Iobroker
      2024-12-20 18:20:50.046	info	instance system.adapter.dwd.0 having pid 4897 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      • crunchip
        crunchip Forum Testing Most Active @Horst Böttcher last edited by crunchip
        @horst-böttcher sagte in twinkly Lichterkette keine verbindung:
        in eim LXC Contäner
        https://github.com/patrickbs96/ioBroker.twinkly/issues/298
        der-eine created this issue in patrickbs96/ioBroker.twinkly
        closed Adapter findet keine Gerät in einem LXC Container #298
        Horst Böttcher 1 Reply Last reply Reply Quote 0
        • Horst Böttcher
          Horst Böttcher @crunchip last edited by
          @crunchip hab die lösung probiet hat aber nicht geholfen
          fürleicht setzte ich iob in einer VM um fürleicht geht es dann alles
          • crunchip
            Weil, keine Meldung im LOG?
