    4. [Gelöst] CI-Tests schlagen fehl: mime.lookup is not a function
    • AlCalzone
      Mein letztes Build in Travis/AppVeyor schlägt fehl, Grund ist anscheinend ein Fehler im JS-Controller bzw. dem Install-Script:
      > node iobroker.js setup first
      creating conf/iobroker.json
      object system.certificates created
      object system.repositories created
      object system.config created
      object enum.rooms created
      object system.group.user created
      object system.group.administrator created
      object _design/system created
      object system.meta.uuid created
      object system.user.admin created
      host.APPVYR-WIN install adapter admin
      npm install --production (System call) in "C:/projects/iobroker.tradfri/node_modules/iobroker.admin"
      got C:/projects/iobroker.tradfri/node_modules/iobroker.admin/admin
      C:\projects\iobroker.tradfri\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:289
                      var mimeType = mime.lookup(file);
      TypeError: mime.lookup is not a function
          at upload (C:\projects\iobroker.tradfri\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:289:37)
          at Timeout._onTimeout (C:\projects\iobroker.tradfri\node_modules\iobroker.js-controller\lib\setup\setupUpload.js:264:21)
          at ontimeout (timers.js:390:15)
          at tryOnTimeout (timers.js:250:5)
          at Timer.listOnTimeout (timers.js:214:5)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules\unix-dgram):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      • apollon77
        apollon77 last edited by
        Ja, Bluefox hat "Mime" auf 2.x upgegraded in js-controller 1.2.1. und das war ne blöde Idee. Sobald ich zeit finde mache ich das wieder rückgängig, dann sollte alles wieder tun.
        • apollon77
          fixed, restart tests please
          • AlCalzone
            läuft, danke!
            81.0k
