    4. Probleme mit sudo apt update / PUBKEY
      mp3junkie last edited by
      bei der Korrektur des PUBKEY von Grafana ist mir irgendwo ein dicker Fehler unterlaufen 😕 . Sudo apt update sie so aus:
      Linux raspberrypi 6.6.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (202        4-11-25) aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sat Dec 21 10:09:53 2024
      pi@raspberrypi:~ $ sudo apt update
      OK:1 http://deb.debian.org/debian bookworm InRelease
      OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
      OK:3 http://phoscon.de/apt/deconz bookworm InRelease
      OK:4 http://deb.debian.org/debian bookworm-updates InRelease
      OK:5 https://repos.influxdata.com/debian stable InRelease
      OK:6 https://apt.grafana.com stable InRelease
      Holen:7 http://archive.raspberrypi.com/debian bookworm InRelease [39,3 kB]
      OK:8 https://deb.nodesource.com/node_20.x nodistro InRelease
      Fehl:7 http://archive.raspberrypi.com/debian bookworm InRelease
        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 82B129927FA3303E
      Paketlisten werden gelesen… Fertig
      W: http://deb.debian.org/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/archive-raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://deb.debian.org/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://deb.debian.org/debian-security/dists/bookworm-security/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/archive-raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://deb.debian.org/debian-security/dists/bookworm-security/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/archive-raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/archive-raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/archive-raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: http://archive.raspberrypi.com/debian/dists/bookworm/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/raspbian.gpg are ignored as the file is not readable by user '_apt' executing apt-key.
      W: GPG-Fehler: http://archive.raspberrypi.com/debian bookworm InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 82B129927FA3303E
      E: Das Depot »http://archive.raspberrypi.com/debian bookworm InRelease« ist nicht signiert.
      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
      pi@raspberrypi:~ $
      Kann man da noch was retten oder muß ich das System neu aufsetzen?
      Danke für jede Hilfe.
        Thomas Braun Most Active @mp3junkie last edited by Thomas Braun
        @mp3junkie
        Was hast du denn da genau wie 'korrigiert' bei Grafana?
        Und warum hast du deinen keyring kaputt gemacht?
        ls -l /etc/apt/trusted.gpg.d/archive-raspbian.gpg
        sagt?
          mp3junkie @Thomas Braun last edited by
          Gute Frage. Ich weiß nicht, was ich falsch gemacht habe.
          Grafana war nicht erreichbar und ich sollte den öffentlichen Schlüssel in einen anderen Ordner verschieben.
          Das habe ich versucht.
            @mp3junkie sagte in Probleme mit sudo apt update / PUBKEY:
            Was und wie genau?
            anschauen.
              @thomas-braun sagte in Probleme mit sudo apt update / PUBKEY:
              pi@raspberrypi:~ $ ls -l /etc/apt/trusted.gpg.d/archive-raspbian.gpg
              -rw------- 1 root root 1227 19. Dez 13:37 /etc/apt/trusted.gpg.d/archive-raspbian.gpg
                insgesamt 204
                -rw------- 1 root root  1227 19. Dez 13:37 archive-raspbian.gpg
                -rw------- 1 root root     0 19. Dez 13:37 archive-raspbian.gpg~
                -rw-r--r-- 1 root root  1758 19. Dez 11:41 bookworm_InRelease.gpg~
                -rw-r--r-- 1 root root 11861 30. Jul 2023  debian-archive-bookworm-automatic.asc
                -rw-r--r-- 1 root root 11861 30. Jul 2023  debian-archive-bookworm-automatic.asc~
                -rw-r--r-- 1 root root 11873 30. Jul 2023  debian-archive-bookworm-security-automatic.asc
                -rw-r--r-- 1 root root 11873 30. Jul 2023  debian-archive-bookworm-security-automatic.asc~
                -rw-r--r-- 1 root root   461 30. Jul 2023  debian-archive-bookworm-stable.asc
                -rw-r--r-- 1 root root   461 30. Jul 2023  debian-archive-bookworm-stable.asc~
                -rw-r--r-- 1 root root 11861 30. Jul 2023  debian-archive-bullseye-automatic.asc
                -rw-r--r-- 1 root root 11861 30. Jul 2023  debian-archive-bullseye-automatic.asc~
                -rw-r--r-- 1 root root 11873 30. Jul 2023  debian-archive-bullseye-security-automatic.asc
                -rw-r--r-- 1 root root 11873 30. Jul 2023  debian-archive-bullseye-security-automatic.asc~
                -rw-r--r-- 1 root root  3403 30. Jul 2023  debian-archive-bullseye-stable.asc
                -rw-r--r-- 1 root root  3403 30. Jul 2023  debian-archive-bullseye-stable.asc~
                -rw-r--r-- 1 root root 11093 30. Jul 2023  debian-archive-buster-automatic.asc
                -rw-r--r-- 1 root root 11093 30. Jul 2023  debian-archive-buster-automatic.asc~
                -rw-r--r-- 1 root root 11105 30. Jul 2023  debian-archive-buster-security-automatic.asc
                -rw-r--r-- 1 root root 11105 30. Jul 2023  debian-archive-buster-security-automatic.asc~
                -rw-r--r-- 1 root root  1704 30. Jul 2023  debian-archive-buster-stable.asc
                -rw-r--r-- 1 root root  1704 30. Jul 2023  debian-archive-buster-stable.asc~
                -rw-r--r-- 1 root root  1189 19. Dez 15:26 deconz-keyring.gpg
                -rw-r--r-- 1 root root  1185 19. Dez 14:27 influxdata-archive_compat.gpg
                -rw-r--r-- 1 root root  1185 19. Okt 17:18 influxdata-archive_compat.gpg~
                -rw-r--r-- 1 root root  2825 19. Okt 16:33 influxdb.gpg~
                -rw-r--r-- 1 root root  1183  4. Jul 02:04 raspberrypi-archive-stable.gpg~
                -rw------- 1 root root  1269 19. Dez 13:37 raspbian.gpg
                -rw------- 1 root root     0 19. Dez 13:37 raspbian.gpg~
                -rw-r--r-- 1 root root  1189 19. Okt 15:44 trusted.gpg~
                pi@raspberrypi:~ $
                  @mp3junkie
                  sudo chmod 644 /etc/apt/trusted.gpg.d/raspbian*
                  sudo apt update
                    sudo apt update
                    pi@raspberrypi:~ $ sudo chmod 644 /etc/apt/trusted.gpg.d/raspbian*
                    OK:1 http://phoscon.de/apt/deconz bookworm InRelease
                    OK:2 http://deb.debian.org/debian bookworm InRelease
                    OK:3 https://apt.grafana.com stable InRelease
                    OK:4 http://deb.debian.org/debian-security bookworm-security InRelease
                    Holen:6 http://archive.raspberrypi.com/debian bookworm InRelease [39,3 kB]
                    OK:7 http://deb.debian.org/debian bookworm-updates InRelease
                    Fehl:6 http://archive.raspberrypi.com/debian bookworm InRelease
                    pi@raspberrypi:~ $
                        @mp3junkie
                        sudo chmod 644 /etc/apt/trusted.gpg.d/archive*
                        sudo apt update
                          insgesamt 204
                          -rw-r--r-- 1 root root  1269 19. Dez 13:37 raspbian.gpg
                          -rw-r--r-- 1 root root     0 19. Dez 13:37 raspbian.gpg~
                          pi@raspberrypi:~ $ ^C
                          pi@raspberrypi:~ $ sudo chmod 644 /etc/apt/trusted.gpg.d/archive*
                          sudo apt update
                          Holen:2 http://archive.raspberrypi.com/debian bookworm InRelease [39,3 kB]
                          OK:3 http://deb.debian.org/debian bookworm InRelease
                          OK:4 https://repos.influxdata.com/debian stable InRelease
                          OK:5 http://deb.debian.org/debian-security bookworm-security InRelease
                          OK:6 http://deb.debian.org/debian bookworm-updates InRelease
                          OK:7 https://apt.grafana.com stable InRelease
                          Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [520 kB]
                          Holen:10 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [549 kB]
                          Es wurden 1.108 kB in 1 s geholt (1.420 kB/s).
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Alle Pakete sind aktuell.
                          pi@raspberrypi:~ $
                            @mp3junkie
                            Passt wieder.
                              Danke.
                              Was habe ich falsch gemacht?
                                Keine Ahnung. Ich weiß ja nicht mal was du genau wie gemacht hast. Geschweige denn was dann dabei falsch war.
                                  @mp3junkie
                                  Zeig mal die Langfassung von
                                  iob diag
                                  Könnte es evtl. sein, dass du von einer Vorversion auf RaspberryOS 12 'Bookworm' upgegraded hast und keine Neuinstallation?
                                    ========== Start marking the full check here ===========
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                     Static hostname: raspberrypi
                                           Icon name: computer
                                              Kernel: Linux 6.6.62+rpt-rpi-2712
                                        Architecture: arm64
                                    OS is similar to:
                                    Model           : Raspberry Pi 5 Model B Rev 1.0
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    Systemuptime and Load:
                                     12:47:38 up  2:37,  4 users,  load average: 0.52, 0.43, 0.42
                                    CPU threads: 4
                                    *** LIFE CYCLE STATUS ***
                                    Operating System is the current Debian stable version codenamed 'bookworm'!
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** TIME AND TIMEZONES ***
                                                   Local time: Sat 2024-12-21 12:47:38 CET
                                               Universal time: Sat 2024-12-21 11:47:38 UTC
                                                     RTC time: Sat 2024-12-21 11:47:38
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    pi
                                    HOME=/home/pi
                                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    *** DISPLAY-SERVER SETUP ***
                                    Display-Server: true
                                    Desktop:
                                    Terminal:       tty
                                    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                    *** MEMORY ***
                                    Mem:            8.4G        3.9G        3.0G         28M        1.7G        4.6G
                                    Swap:           209M          0B        209M
                                    Total:          8.7G        3.9G        3.2G
                                    Active iob-Instances:   39
                                             8052 M total memory
                                             3697 M used memory
                                             3792 M active memory
                                              893 M inactive memory
                                             2852 M free memory
                                              162 M buffer memory
                                             1463 M swap cache
                                              199 M total swap
                                                0 M used swap
                                              199 M free swap
                                    top - 12:47:38 up  2:37,  4 users,  load average: 0.52, 0.43, 0.42
                                    Tasks: 260 total,   2 running, 258 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   8052.2 total,   2852.3 free,   3698.6 used,   1626.0 buff/cache
                                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4353.7 avail Mem
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** DMESG CRITICAL ERRORS ***
                                    No critical errors detected
                                    *** FILESYSTEM ***
                                    udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                    tmpfs          tmpfs     806M  6.2M  800M   1% /run
                                    /dev/nvme0n1p2 ext4      457G   12G  422G   3% /
                                    tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
                                    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                    /dev/nvme0n1p1 vfat      511M   77M  435M  15% /boot/firmware
                                    tmpfs          tmpfs     806M  176K  806M   1% /run/user/1000
                                    /dev/mmcblk0p2 ext4       58G   11G   45G  19% /media/pi/rootfs
                                    /dev/mmcblk0p1 vfat      510M   76M  435M  15% /media/pi/bootfs
                                    [Sat Dec 21 10:10:17 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:6D:4C:3A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4f3e1646-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                    [Sat Dec 21 10:10:18 2024] EXT4-fs (nvme0n1p2): mounted filesystem f6bb7216-cc28-4ec3-86d6-b391f5f31405 ro with ordered data mode. Quota mode: none.
                                    [Sat Dec 21 10:10:19 2024] EXT4-fs (nvme0n1p2): re-mounted f6bb7216-cc28-4ec3-86d6-b391f5f31405 r/w. Quota mode: none.
                                    [Sat Dec 21 10:10:24 2024] EXT4-fs (mmcblk0p2): recovery complete
                                    [Sat Dec 21 10:10:24 2024] EXT4-fs (mmcblk0p2): mounted filesystem f6bb7216-cc28-4ec3-86d6-b391f5f31405 r/w with ordered data mode. Quota mode: none.
                                    Show mounted filesystems:
                                    TARGET               SOURCE         FSTYPE      OPTIONS
                                    /                    /dev/nvme0n1p2 ext4        rw,noatime,commit=600
                                    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                    |-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    |-/media/pi/rootfs   /dev/mmcblk0p2 ext4        rw,nosuid,nodev,relatime,errors=remount-ro
                                    `-/media/pi/bootfs   /dev/mmcblk0p1 vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
                                    /var:
                                    1.5G    /var/
                                    639M    /var/log
                                    637M    /var/log/journal/bc573ed170a0404295df5010a84c38bc
                                    384M    /var/cache
                                    Archived and active journals take up 636.8M in the file system.
                                    /opt/iobroker/backups:
                                    215M    /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    1.4G    /opt/iobroker/iobroker-data/
                                    987M    /opt/iobroker/iobroker-data/files
                                    617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                                    32M     /opt/iobroker/iobroker-data/objects.jsonl
                                    29M     /opt/iobroker/iobroker-data/states.jsonl
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                                    USB-Devices by-id:
                                    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2251966-if00
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v20.18.1
                                    /usr/bin/node           v20.18.1
                                    /usr/bin/corepack       0.29.4
                                    nodejs:
                                      Installed: 20.18.1-1nodesource1
                                      Candidate: 20.18.1-1nodesource1
                                      Version table:
                                     *** 20.18.1-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                            100 /var/lib/dpkg/status
                                         20.18.0-1nodesource1 1001
                                         20.17.0-1nodesource1 1001
                                         20.16.0-1nodesource1 1001
                                         20.15.1-1nodesource1 1001
                                         20.15.0-1nodesource1 1001
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         18.19.0+dfsg-6~deb12u2 500
                                         18.19.0+dfsg-6~deb12u1 500
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    raspberrypi         raspberrypi (version: 7.0.3, hostname: raspberrypi   , alive, uptime: 9424)
                                    Core adapters versions
                                    js-controller:  7.0.3
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    nodejs modules from github:     3
                                    +-- iobroker.connector-local-control@0.0.4 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#dae4c44e29a8a44cfc5076aca69aac3694fac729)
                                    +-- iobroker.eusec@1.3.3 (git+ssh://git@github.com/bropat/ioBroker.eusec.git#14b7097588d080eeef69a8e2b91bfb2f9c6d1c09)
                                    +-- iobroker.lg-thinq@1.0.7 (git+ssh://git@github.com/TA2k/ioBroker.lg-thinq.git#4e823328b9f01752506f96dd8bdd78e98580c75d)
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
                                      system.adapter.bring.0                  : bring                 : raspberrypi                              - disabled
                                    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                    + system.adapter.connector-local-control.0: connector-local-control: raspberrypi                              -  enabled
                                    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                                    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
                                      system.adapter.email.0                  : email                 : raspberrypi                              - disabled
                                    + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
                                      system.adapter.eusec.0                  : eusec                 : raspberrypi                              - disabled
                                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
                                      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                                    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                                    + system.adapter.hass.0                   : hass                  : raspberrypi                              -  enabled, port: 8123
                                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                                    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              - disabled
                                    + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
                                    + system.adapter.melcloud.0               : melcloud              : raspberrypi                              -  enabled
                                    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
                                    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                                    + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
                                    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                      system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
                                    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                                      system.adapter.roborock.0               : roborock              : raspberrypi                              - disabled
                                    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                                    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
                                    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
                                      system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                                    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                                    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
                                      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                                    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : raspberrypi                              -  enabled
                                    + system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
                                    + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    ioBroker-Repositories
                                    │ (index) │ name               │ url                                                     │ auto upgrade │
                                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                    Upgrade policy: none
                                    Installed ioBroker-Instances
                                    Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                    Adapter    "ble"          : 0.14.0   , installed 0.14.0
                                    Adapter    "bring"        : 1.8.4    , installed 1.8.4
                                    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                                    Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                                    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                    Adapter    "discovery"    : 5.0.0    , installed 5.0.0
                                    Adapter    "email"        : 1.3.1    , installed 1.3.1
                                    Adapter    "ems-esp"      : 5.0.6    , installed 5.0.6
                                    Adapter    "eusec"        : 1.3.3    , installed 1.3.3
                                    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
                                    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
                                    Adapter    "hass"         : 1.4.0    , installed 1.4.0
                                    Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                    Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Controller "js-controller": 7.0.3    , installed 7.0.3
                                    Adapter    "lg-thinq"     : 1.0.5    , installed 1.0.7
                                    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                    Adapter    "melcloud"     : 2.0.4    , installed 2.0.4
                                    Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                    Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                                    Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
                                    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                    Adapter    "roborock"     : 0.6.17   , installed 0.6.17
                                    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
                                    Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
                                    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "solarmanpv"   : 0.6.2    , installed 0.6.2
                                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                    Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                                    Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                    Objects and States
                                    Objects:        23603
                                    States:         19117
                                    Hit:3 http://phoscon.de/apt/deconz bookworm InRelease
                                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                                    Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
                                    Hit:7 https://apt.grafana.com stable InRelease
                                    Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6745       916/cupsd
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10662      2340/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10657      2340/iobroker.js-co
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6064       687/deCONZ
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9266       945/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       6807       687/deCONZ
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17117      3179/io.shelly.1
                                    tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       728463     129005/nc
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      114        14423      1736/grafana
                                    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          6738       930/xrdp-sesman
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21177      3734/io.socketio.0
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        10501      1498/influxd
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22614      3682/io.simple-api.
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12873      2457/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23036      3773/io.web.0
                                    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       21362      3872/io.ws.0
                                    tcp6       0      0 :::3389                 :::*                    LISTEN      113        9416       952/xrdp
                                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       15009      2858/io.harmony.0
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6744       916/cupsd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          9268       945/sshd: /usr/sbin
                                    udp        0      0 0.0.0.0:37152           0.0.0.0:*                           104        6414       681/avahi-daemon: r
                                    udp        0      0 192.168.178.32:5353     0.0.0.0:*                           1001       18790      3263/io.tr-064.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6412       681/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15830      3137/io.shelly.0
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15386      2784/io.deconz.0
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6953       687/deCONZ
                                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       17289      3288/io.tuya.0
                                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       17290      3288/io.tuya.0
                                    udp        0      0 0.0.0.0:32101           0.0.0.0:*                           1001       17842      3375/io.connector-l
                                    udp6       0      0 fe80::a68d:18ea:57a:546 :::*                                0          140872     778/NetworkManager
                                    udp6       0      0 :::5353                 :::*                                104        6413       681/avahi-daemon: r
                                    udp6       0      0 :::1900                 :::*                                1001       15389      2784/io.deconz.0
                                    udp6       0      0 :::1900                 :::*                                1001       15388      2784/io.deconz.0
                                    udp6       0      0 :::1900                 :::*                                1001       15387      2784/io.deconz.0
                                    udp6       0      0 :::39141                :::*                                104        6415       681/avahi-daemon: r
                                    2024-12-21 11:43:20.764  - info: fb-checkpresence.0 (31196) newActive Andreas false
                                    2024-12-21 11:43:40.713  - info: fb-checkpresence.0 (31196) newActive Andreas true
                                    2024-12-21 11:52:57.675  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
                                    2024-12-21 11:52:59.705  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
                                    2024-12-21 11:53:09.694  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
                                    2024-12-21 11:53:13.146  - error: shelly.1 (3179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                                    2024-12-21 11:53:13.146  - error: shelly.1 (3179) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc42c058"
                                    2024-12-21 11:53:14.164  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
                                    2024-12-21 11:53:24.144  - info: shelly.1 (3179) [MQTT] Client Close: 192.168.178.12 (shellyplus2pm / shellyplus2pm-d48afc42c058 / shellyplus2pm#d48afc42c058#1) (false)
                                    2024-12-21 11:53:30.405  - error: shelly.1 (3179) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
                                    2024-12-21 11:53:30.406  - error: shelly.1 (3179) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-d48afc42c058"
                                    2024-12-21 11:53:32.257  - info: shelly.1 (3179) [MQTT] Device with client id "shellyplus2pm-d48afc42c058" connected!
                                    2024-12-21 11:55:19.396  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertür zu] activated Zone 'Kellerflur_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
                                    2024-12-21 12:01:45.821  - info: smartcontrol.0 (3717) Trigger 'Kontaktsensor Kellertreppe zu' was already activated 0.1 seconds ago and is ignored. Must be at least 2 seconds.
                                    2024-12-21 12:01:46.092  - info: smartcontrol.0 (3717) Trigger 'Kontaktsensor Kellertreppe zu' was already activated 0.27 seconds ago and is ignored. Must be at least 2 seconds.
                                    2024-12-21 12:04:45.725  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertreppe zu] activated Zone 'Kellertreppe_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
                                    2024-12-21 12:11:47.246  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Abstellkammer zu] activated Zone 'Abstellkammer_Licht_Aus'. However, device(s) 'Abstellkammer' not turned off as these are already off.
                                    2024-12-21 12:26:43.722  - info: smartcontrol.0 (3717) Trigger [Türkontakt Kleiderschrank links zu] activated Zone 'Schranklicht_Li_Aus'. However, device(s) 'Licht Kleiderschrank links' not turned off as these are already off.
                                    2024-12-21 12:30:57.980  - info: smartcontrol.0 (3717) Trigger [Türkontakt Kleiderschrank rechts zu] activated Zone 'Schranklicht_Re_Aus'. However, device(s) 'Licht Kleiderschrank rechts' not turned off as these are already off.
                                    2024-12-21 12:44:03.066  - info: admin.0 (2457) ==> Connected system.user.admin from ::ffff:192.168.178.28
                                    2024-12-21 12:44:16.100  - error: backitup.0 (2686) [iobroker/grafana] Error on Grafana Datasource Request
                                    2024-12-21 12:44:16.139  - error: backitup.0 (2686) [iobroker/grafana] cannot found Grafana Backup files
                                    2024-12-21 12:44:46.961  - error: backitup.0 (2686) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                    2024-12-21 12:45:35.696  - info: smartcontrol.0 (3717) Trigger [Kontaktsensor Kellertür zu] activated Zone 'Kellerflur_Licht_Aus'. However, device(s) 'Kellertreppe Licht,Kellerflur Licht' not turned off as these are already off.
                                    2024-12-21 12:46:21.152  - info: admin.0 (2457) <== Disconnect system.user.admin from ::ffff:192.168.178.28 backitup
                                    iob diag has finished.
                                    Press any key for a summary
                                      Ne, Bookworm habe ich bereits ein paar Monate laufen. Grafana habe ich wieder "in Betrieb genommen".
                                        Tu das.
                                        Ansonsten sieht das soweit okay aus.
                                        Künftig den ersten User nicht 'pi' nennen sondern was eigenes ausdenken.
                                        vorname oder forumsnick sind da besser.
                                          iob fix ist erledigt.
                                          Deine Hinweise habe ich notiert und werde sie umsetzen.
                                          Danke für deine schnelle und perfekte Hilfe. 😀
                                            puffy00007 @mp3junkie last edited by Homoran
                                            @mp3junkie Hi, ich habe ein ähnliches Problem, könnt ih mir helfen?
                                            pi@iobroker:/var/lib $ sudo apt update
                                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                            Get:5 https://repos.influxdata.com/debian stable InRelease [6,907 B]
                                            Get:6 https://packages.grafana.com/oss/deb stable InRelease [7,661 B]
                                            Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Err:5 https://repos.influxdata.com/debian stable InRelease
                                              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                            Err:6 https://packages.grafana.com/oss/deb stable InRelease
                                              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                            Fetched 6,907 B in 2s (3,699 B/s)
                                            Reading package lists... Done
                                            Building dependency tree... Done
                                            104 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                            W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
                                            W: Failed to fetch https://repos.influxdata.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
                                            W: Some index files failed to download. They have been ignored, or old ones used instead.
                                            die Zugriffsrechte (ls -l /etc/apt/trusted.gpg.d/) dind alle auf 644
                                            sudo apt update pubkey
                                            993
