    4. Installation
    5. Zigbee - SONOFF Zigbee 3.0 Dongle startet nicht
      deviobroker last edited by Homoran
      ich habe eine frische IOBroker Installation ohne etwas zu "restoren". Habe dabei Probleme mit meinem bereis in älteren Versionen laufenden Sonoff Zigbee Dongle (CC2652P). Fehlermeldung:
      error: zigbee.0 (13229) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      Drüber steht folgendes in der Logdatei:
      2024-12-28 10:46:16.267  - debug: zigbee.0 (13378) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-12-28 10:46:16.301  - debug: zigbee.0 (13378) Objects client ready ... initialize now
      2024-12-28 10:46:16.303  - debug: zigbee.0 (13378) Objects create System PubSub Client
      2024-12-28 10:46:16.305  - debug: zigbee.0 (13378) Objects create User PubSub Client
      2024-12-28 10:46:16.328  - debug: zigbee.0 (13378) Objects client initialize lua scripts
      2024-12-28 10:46:16.338  - debug: zigbee.0 (13378) Objects connected to redis: 127.0.0.1:9001
      2024-12-28 10:46:16.343  - silly: zigbee.0 (13378) redis psubscribe cfg.o.system.user.*
      2024-12-28 10:46:16.353  - silly: zigbee.0 (13378) redis psubscribe cfg.o.enum.*
      2024-12-28 10:46:16.357  - silly: zigbee.0 (13378) objectDB connected
      2024-12-28 10:46:16.361  - debug: zigbee.0 (13378) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-12-28 10:46:16.369  - debug: zigbee.0 (13378) States create System PubSub Client
      2024-12-28 10:46:16.371  - debug: zigbee.0 (13378) States create User PubSub Client
      2024-12-28 10:46:16.383  - debug: zigbee.0 (13378) States connected to redis: 127.0.0.1:9000
      2024-12-28 10:46:16.385  - silly: zigbee.0 (13378) statesDB connected
      2024-12-28 10:46:16.414  - debug: zigbee.0 (13378) Plugin sentry Do not initialize Plugin (enabled=false)
      2024-12-28 10:46:16.558  - info: zigbee.0 (13378) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
      2024-12-28 10:46:16.586  - debug: zigbee.0 (13378) Using zigbee-herdsman with settings: {"network":{"panID":6340,"extendedPanID":[173,218,18,209,218,223,208,223],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_fcdb00ac54d9eb118bf8178e6fe9f4d9-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      2024-12-28 10:46:16.652  - info: zigbee.0 (13378) Starting Zigbee  npm ...
      2024-12-28 10:46:16.683  - silly: zigbee.0 (13378) States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1735379176654,"q":0,"from":"system.adapter.zigbee.0","lc":1735377228617}
      Schritte, die ich bereits ausgeführt habe:
      1. Dongle neu geflasht (20240710)
      2. IOBroker frisch, ohne weitere Adapter, installiert.
      3. gecheckt, ob iobroker in der Gruppe dialout ist.
      4. viele verschienede Optionen unter Zigbee Einstellung ausprobiert.
      5. verschiedene USB Ports mit und ohne Verlägerungskabel ausprobiert.
      6. Adapter-Typ auf Silikon Labs umgestellt
      Alles hat nicht geholfen. Erst die Option "forceStartWithInconsistentAdapterConfiguration" hat geholfen und Zigbee adapter startet und ich konnte das erste Gerät anlernen.
      Nun steht dort : "Bitte Aktualisieren Sie den Adapter auf kompatible Firmware ..."
      Was muss ich hier machen?
      • Adaptername: zigbee
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: 1.10.3
      • js-controller Version: 7.0.6
      • Admin Version: 7.1.5
      • Hardwaresystem: Pi4 Model B Rev 1.1
      • Arbeitsspeicher: ...4GB
      • Festplattenart: SD-Karte
      • Betriebssystem: bookworm
      • Nodejs-Version: v20.18.1
      • NPM-Version: 10.8.2
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
      iob diag Summary: iobDiagSummary.txt
      iob diad Detailed: iobDiagDetailed.txt
      Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @deviobroker last edited by Thomas Braun
        @deviobroker
        Ruf iob diag mal so auf:
        ./iob_diag.sh -de --unmask
        Muss allerdings noch die Testversion von hier:
        https://forum.iobroker.net/topic/59549/iob-diag-skript
        sein. Dann stehen die im Adapter einzutragenden Werte in der Ausgabe drin.
        • haselchen
          haselchen Most Active @deviobroker last edited by haselchen
          @deviobroker
          Dein Problem wird nach der frischen Installation die PAN ID und ext. PAN ID sein.
          Deswegen wohl der Hinweis mit dem Mismatch.
          Bin am Handy und finde so schnell nicht die Anleitung von @Asgothian
          Vielleicht liest er das hier und hilft aus.
          Edit: Was hast du denn in die Felder im Adapter eingetragen?
          Neue Werte ?
            deviobroker @Thomas Braun last edited by
            Hi Thomas,
            anbei die Logdatei von iob_diag.sh
            iob_diag.sh --de --unmask: iob_diag_all.log
              @deviobroker
              Bitte keine windigen Text-Dateien hier anhängen.
              Ausgabe in CodeTags eingebettet. Dafür sind die da.
              In der Sektion
              *** ZigBee Settings ***
              finden sich aber die richtigen Einstellungen. Musste mal abgleichen, was du im Adapter/in der Instanz eingetragen hast.
                In der tat, nach der Anpassung der PAN ID und Port hat es geklappt. Ich konnte mir also weder die PAN ID noch den Port aussuchen, sondern habe die Werte aus dem Skript iob_diag --unmask eingetragen.
                Danke für den Hinweis.
                  deviobroker @haselchen last edited by
                  @haselchen,
                  Falls du die Anleitung findest, würde mich das mal interessieren.
                  Sonst hatte ich die Werte "erfunden", das hat aber nicht funktioniert.
                  Danke,
                  dev
                  Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                    @deviobroker sagte in Zigbee - SONOFF Zigbee 3.0 Dongle startet nicht:
                    Das funktioniert nicht, weil auf dem Stick bereits ein anderes Schloss eingebaut ist und du nun den passenden Schlüssel haben musst.
                    • Asgothian
                      Asgothian Developer @deviobroker last edited by
                      @haselchen,
                      Danke,
                      dev
                      Die Anleitung ist irgendwo im Forum - ist aber durch die gute Arbeit von @Thomas-Braun unnötig geworden. Er hat das diag Skript so angepasst das die gewünschten Informationen im Log stehen. Sobald das 'stabil' wird werde ich die Information in die Dokumentation vom Zigbee-Adapter aufnehmen.
                      Es gibt im Übrigen noch eine andere Option den Fehler zu beheben:
                      • Adapter anhalten
                      • nvbackup.json und shepherd.db löschen (unter \opt\iobroker\iobroker-data\zigbee_X, wobei X die InstanzID ist.)
                      • Adapter starten
                      In diesem Fall müssen alle Geräte neu angelernt werden. Dafür können Kanal, PanID und ExtPanID frei gewählt werden.
                      A.
                      haselchen 1 Reply Last reply Reply Quote 1
                      • haselchen
                        haselchen Most Active @Asgothian last edited by haselchen
                        @deviobroker
                        • Adapter anhalten
                        • Adapter starten
                        Genau die Anleitung meinte ich
                        387
