    4. Systemabsturz nach Raspi updating repository
      retostoeckli last edited by
      Schon 2-3 mal beobachtet. Nach dem Updating des repository schiesst sich das System, respektive so wie ich vermute der Redis Server.
      Danach läuft mal 1-2 Minuten nichts, bis sich das System irgendwie wieder fängt.
      2024-12-28 14:50:24.175 - info: admin.0 (66276) Request actual repository...
      2024-12-28 14:50:24.797 - info: host.raspberrypi4 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2024-12-28 14:50:30.875 - info: admin.0 (66276) Repository received successfully.
      2024-12-28 15:13:57.576 - error: sourceanalytix.0 (66754) States database error: read ECONNRESET
      2024-12-28 15:13:57.648 - error: sprinklecontrol.0 (66773) States database error: write ECONNRESET
      2024-12-28 15:13:57.669 - error: swiss-weather-api.0 (66790) States database error: write ECONNRESET
      2024-12-28 15:13:57.723 - error: broadlink2.0 (66409) States database error: write ECONNRESET
      2024-12-28 15:13:57.732 - error: device-watcher.0 (66449) States database error: write ECONNRESET
      2024-12-28 15:13:57.732 - error: telegram.0 (264790) States database error: read ECONNRESET
      2024-12-28 15:13:57.747 - error: javascript.0 (66332) States database error: write ECONNRESET
      2024-12-28 15:13:57.746 - error: history.0 (66303) States database error: read ECONNRESET
      2024-12-28 15:13:57.735 - error: device-watcher.0 (66449) Objects database error: read ECONNRESET
      2024-12-28 15:13:57.624 - error: echarts.0 (66666) States database error: write ECONNRESET
      2024-12-28 15:13:57.873 - error: chromecast.0 (66428) Wohnzimmer - Error disconnecting - TypeError: Cannot read properties of null (reading 'socket')
      2024-12-28 15:13:57.572 - error: simple-api.0 (66728) States database error: read ECONNRESET
      2024-12-28 15:13:57.626 - error: notification-manager.0 (66494) States database error: write ECONNRESET
      2024-12-28 15:13:57.805 - error: backitup.0 (66394) States database error: write ECONNRESET
      2024-12-28 15:13:57.684 - error: lgtv.0 (67140) States database error: write ECONNRESET
      2024-12-28 15:13:57.722 - error: sainlogic.0 (66709) Objects database error: write EPIPE
      2024-12-28 15:13:58.032 - error: sainlogic.0 (66709) States database error: write ECONNRESET
      2024-12-28 15:13:57.426 - info: harmony.0 (66464) [CONNECT] lost Connection to Harmony Wohnzimmer Hub (192.168.0.43)
      2024-12-28 15:13:58.031 - error: harmony.0 (66464) States database error: write ECONNRESET
      2024-12-28 15:13:57.732 - error: text2command.0 (66835) States database error: write ECONNRESET
      2024-12-28 15:13:57.670 - error: web.0 (66868) States database error: read ECONNRESET
      2024-12-28 15:13:57.883 - error: ping.0 (67117) States database error: write ECONNRESET
      2024-12-28 15:13:57.682 - error: iot.0 (66682) States database error: read ECONNRESET
      2024-12-28 15:03:20.330 - info: mqtt.0 (66479) Client [SL3P_35736FF4] connection closed: timeout
      2024-12-28 15:13:58.197 - error: mqtt.0 (66479) States database error: write ECONNRESET
      2024-12-28 15:13:58.198 - info: mqtt.0 (66479) Client [] connection closed: timeout
      2024-12-28 15:13:58.236 - info: iot.0 (66682) Connection changed: disconnect
      2024-12-28 15:13:58.237 - info: iot.0 (66682) Connection lost
      2024-12-28 15:13:57.936 - error: rest-api.0 (66698) States database error: write ECONNRESET
      2024-12-28 15:13:57.878 - error: tuya.0 (66587) States database error: write EPIPE
      2024-12-28 15:13:58.244 - error: mqtt.0 (66479) Objects database error: read ECONNRESET
      2024-12-28 15:13:58.445 - error: zigbee.0 (284006) States database error: write ECONNRESET
      2024-12-28 15:13:58.424 - error: socketio.0 (66743) States database error: write ECONNRESET
      2024-12-28 15:13:58.582 - error: host.raspberrypi4 States database error: write ECONNRESET
      2024-12-28 15:13:58.638 - error: host.raspberrypi4 Objects database error: read ECONNRESET
      2024-12-28 15:13:58.678 - error: pushover.0 (66349) States database error: write ECONNRESET
      2024-12-28 15:13:58.964 - error: scenes.0 (66360) States database error: write ECONNRESET
      2024-12-28 15:13:58.991 - error: chromecast.0 (66428) States database error: write EPIPE
      2024-12-28 15:13:59.079 - error: dreame.0 (66651) States database error: write ECONNRESET
      2024-12-28 15:13:58.879 - error: rpi2.0 (66529) States database error: read ECONNRESET
      2024-12-28 15:13:59.406 - error: discovery.0 (66631) States database error: write ECONNRESET
      2024-12-28 15:13:59.443 - info: harmony.0 (66464) [CONNECT] Connected to Harmony Wohnzimmer Hub (192.168.0.43)
      2024-12-28 15:13:57.667 - error: shelly.0 (177635) Objects database error: write EPIPE
      2024-12-28 15:13:58.354 - error: shelly.0 (177635) States database error: write EPIPE
      2024-12-28 15:14:00.625 - info: shelly.0 (177635) [MQTT] Client Close: 192.168.0.121 (shellyplus1pm / shellyplus1pm-441793932584 / shellyplus1pm#441793932584#1) (false)
      2024-12-28 15:14:02.661 - info: sprinklecontrol.0 (66773) Objects database successfully reconnected
      2024-12-28 15:14:02.672 - info: sourceanalytix.0 (66754) Objects database successfully reconnected
      2024-12-28 15:14:02.705 - info: swiss-weather-api.0 (66790) Objects database successfully reconnected
      2024-12-28 15:14:02.750 - info: device-watcher.0 (66449) Objects database successfully reconnected
      2024-12-28 15:14:02.751 - info: device-watcher.0 (66449) Objects database successfully reconnected
      Der Redis Server melded jeweils zur gleichen Zeit:
      * redis-server.service - Advanced key-value store
           Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; preset: enabled)
           Active: active (running) since Sat 2024-12-28 15:14:16 CET; 1h 54min ago
             Docs: http://redis.io/documentation,
                   man:redis-server(1)
         Main PID: 287147 (redis-server)
           Status: "Ready to accept connections"
            Tasks: 6 (limit: 3916)
              CPU: 8min 42.178s
           CGroup: /system.slice/redis-server.service
                   `-287147 "/usr/bin/redis-server 127.0.0.1:6379"
      Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Main process exited, code=killed, status=9/KILL
      Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Failed with result 'signal'.
      Dec 28 15:13:58 raspberrypi4 systemd[1]: redis-server.service: Consumed 1h 42min 12.683s CPU time.
      Dec 28 15:13:59 raspberrypi4 systemd[1]: redis-server.service: Scheduled restart job, restart counter is at 4.
      Dec 28 15:13:59 raspberrypi4 systemd[1]: Stopped redis-server.service - Advanced key-value store.
      Dec 28 15:13:59 raspberrypi4 systemd[1]: redis-server.service: Consumed 1h 42min 12.683s CPU time.
      Dec 28 15:13:59 raspberrypi4 systemd[1]: Starting redis-server.service - Advanced key-value store...
      Dec 28 15:14:16 raspberrypi4 systemd[1]: Started redis-server.service - Advanced key-value store.
      An was kann das liegen?
      Bitte ausfüllen:
      • js-controller Version: 7.0.3
      • Admin Version: 7.1.5
      • Hardwaresystem: Pi4
      • Arbeitsspeicher: 4 GB
      • Festplattenart: SD-Karte,..
      • Betriebssystem: ...
      • Nodejs-Version: .20.18.1
      • NPM-Version: ...10.8.2
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: raspberrypi4
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       17:29:56 up 5 days,  8:18,  2 users,  load average: 0.74, 0.42, 0.43
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2024-12-28 17:29:56 CET
                 Universal time: Sat 2024-12-28 16:29:56 UTC
                       RTC time: n/a
                      Time zone: Europe/Zurich (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        3.2G        587M        286K        280M        790M
      Swap:           209M         37M        172M
      Total:          4.2G        3.2G        760M
      Active iob-Instances:   33
               3791 M total memory
               3037 M used memory
               1763 M active memory
               1334 M inactive memory
                560 M free memory
                 29 M buffer memory
                238 M swap cache
                199 M total swap
                 35 M used swap
                164 M free swap
      top - 17:29:57 up 5 days,  8:18,  2 users,  load average: 0.74, 0.42, 0.43
      Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 14.3 us,  0.0 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3791.9 total,    560.5 free,   3037.7 used,    268.1 buff/cache
      MiB Swap:    200.0 total,    164.5 free,     35.4 used.    754.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      1 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       29G  7.9G   20G  29% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Mon Dec 23 09:11:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A2:09:83 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e6a5e38d-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Dec 23 09:11:15 2024] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
      [Mon Dec 23 09:11:16 2024] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.7G    /var/
      2.1G    /var/lib
      1.9G    /var/lib/redis
      226M    /var/log
      224M    /var/log/journal/1f3048c74be54e7dafe9fd893512ef3a
      Archived and active journals take up 223.7M in the file system.
      /opt/iobroker/backups:
      75M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      196M    /opt/iobroker/iobroker-data/
      129M    /opt/iobroker/iobroker-data/history
      62M     /opt/iobroker/iobroker-data/files
      31M     /opt/iobroker/iobroker-data/files/backitup.admin
      31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      14M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
      5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
      5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
      5.0M    /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      raspberrypi4        raspberrypi4 (version: 7.0.3, hostname: raspberrypi4  , alive, uptime: 2481)
      Core adapters versions
      js-controller:  7.0.3
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     3
      +-- iobroker.dreame@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#741b3bc2ab551669c0e4a47ae176967518cfca90)
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
      +-- iobroker.sprinklecontrol@0.2.13 (git+ssh://git@github.com/Dirk-Peter-md/ioBroker.sprinklecontrol.git#b9bbf48c1de1215c059d1c653ee5631d448d8cc7)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi4                             -  enabled
      + system.adapter.chromecast.0             : chromecast            : raspberrypi4                             -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi4                             -  enabled
        system.adapter.devices.0                : devices               : raspberrypi4                             - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi4                             -  enabled
      + system.adapter.dreame.0                 : dreame                : raspberrypi4                             -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi4                             -  enabled
        system.adapter.habpanel.0               : habpanel              : raspberrypi4                             - disabled
      + system.adapter.harmony.0                : harmony               : raspberrypi4                             -  enabled
      + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4                             - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi4                             - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi4                             - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi4                             -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : raspberrypi4                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4                             -  enabled, port: 1883, bind: 192.168.0.54
      + system.adapter.notification-manager.0   : notification-manager  : raspberrypi4                             -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi4                             -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
      + system.adapter.rest-api.0               : rest-api              : raspberrypi4                             -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4                             -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : raspberrypi4                             -  enabled, port: 8099, bind: 0.0.0.0
      + system.adapter.scenes.0                 : scenes                : raspberrypi4                             -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi4                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi4                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : raspberrypi4                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4                             -  enabled
      + system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi4                             -  enabled
      + system.adapter.swiss-weather-api.0      : swiss-weather-api     : raspberrypi4                             -  enabled
        system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi4                             - disabled
      + system.adapter.telegram.0               : telegram              : raspberrypi4                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi4                             -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi4                             -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816081001-if00
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
      Adapter    "lgtv"         : 2.3.1    , installed 2.3.1
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "notification-manager": 1.2.1, installed 1.2.1
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
      Adapter    "rpi2"         : 2.2.1    , installed 2.2.1
      Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
      Adapter    "scenes"       : 3.2.3    , installed 3.0.4  [Updatable]
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "swiss-weather-api": 2.2.2, installed 2.2.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "telegram-menu": 2.1.3    , installed 2.1.3
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        12761
      States:         11090
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 https://packages.redis.io/deb bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        3555271    287147/redis-server
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3601926    291083/io.shelly.0
      tcp        0      0 0.0.0.0:8099            0.0.0.0:*               LISTEN      1001       3602063    291221/io.sainlogic
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5657       672/sshd: /usr/sbin
      tcp        0      0 192.168.0.54:1883       0.0.0.0:*               LISTEN      1001       3603771    290989/io.mqtt.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      106        3555272    287147/redis-server
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       3602097    291255/io.socketio.
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       3604724    291240/io.simple-ap
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3600993    290779/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3602244    291376/io.web.0
      tcp6       0      0 :::8093                 :::*                    LISTEN      1001       3603971    291207/io.rest-api.
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5659       672/sshd: /usr/sbin
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       3601824    290974/io.harmony.0
      udp        0      0 0.0.0.0:51697           0.0.0.0:*                           1001       3623456    290925/io.broadlink
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       3604523    291098/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       3604524    291098/io.tuya.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       3601825    290974/io.harmony.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       3603660    290925/io.broadlink
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       3603695    290940/io.chromecas
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6414       540/avahi-daemon: r
      udp        0      0 0.0.0.0:42359           0.0.0.0:*                           1001       3603663    290925/io.broadlink
      udp        0      0 0.0.0.0:52846           0.0.0.0:*                           104        6416       540/avahi-daemon: r
      udp6       0      0 :::37106                :::*                                104        6417       540/avahi-daemon: r
      udp6       0      0 fe80::b666:a771:981:546 :::*                                0          6552       618/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        6415       540/avahi-daemon: r
      2024-12-28 17:11:27.217  - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49
      2024-12-28 17:11:31.663  - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 admin
      2024-12-28 17:13:41.709  - warn: admin.0 (290779) rpi2 has an invalid jsonConfig: [{"instancePath":"/items/_monitoring/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["accordion","alive","autocomplete","autocompleteSendTo","certificate","certificates","checkLicense","checkbox","chips","color","coordinates","cron","custom","datePicker","deviceManager","divider","file","fileSelector","func","header","icon","image","imageSendTo","instance","interface","ip","jsonEditor","language","number","objectId","panel","password","pattern","port","qrCode","room","select","selectSendTo","sendTo","setState","slider","state","staticImage","staticLink","staticText","table","text","textSendTo","timePicker","user","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      2024-12-28 17:13:53.876  - info: host.raspberrypi4 stopInstance system.adapter.rpi2.0 (force=false, process=true)
      2024-12-28 17:13:53.888  - info: host.raspberrypi4 stopInstance system.adapter.rpi2.0 send kill signal
      2024-12-28 17:13:53.889  - info: rpi2.0 (291039) Got terminate signal TERMINATE_YOURSELF
      2024-12-28 17:13:53.893  - info: rpi2.0 (291039) terminating
      2024-12-28 17:13:53.894  - info: rpi2.0 (291039) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-12-28 17:13:54.392  - info: rpi2.0 (291039) terminating
      2024-12-28 17:13:54.449  - info: host.raspberrypi4 instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-12-28 17:13:57.932  - info: host.raspberrypi4 instance system.adapter.rpi2.0 in version "2.2.1" started with pid 292378
      2024-12-28 17:14:00.537  - info: rpi2.0 (292378) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.18.1, js-controller: 7.0.3
      2024-12-28 17:14:01.027  - info: rpi2.0 (292378) GPIO ports are not configured
      2024-12-28 17:14:45.852  - info: history.0 (290794) enabled logging of rpi2.0.memory.memory_free, Alias=false, WriteNulls=true
      2024-12-28 17:15:53.928  - info: history.0 (290794) enabled logging of rpi2.0.sdcard.sdcard_boot_used, Alias=false, WriteNulls=true
      2024-12-28 17:16:02.572  - warn: zigbee.0 (291437) DeviceAvailability:Failed to ping 0xa4c138b7fd6a2783 TS0505B
      2024-12-28 17:16:09.736  - info: history.0 (290794) enabled logging of rpi2.0.sdcard.sdcard_root_used, Alias=false, WriteNulls=true
      2024-12-28 17:16:21.591  - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49
      2024-12-28 17:16:23.478  - info: admin.0 (290779) ==> Connected system.user.admin from ::ffff:192.168.0.49
      2024-12-28 17:17:38.907  - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 echarts-show
      2024-12-28 17:17:38.914  - info: admin.0 (290779) <== Disconnect system.user.admin from ::ffff:192.168.0.49 echarts
      2024-12-28 17:19:14.992  - info: javascript.0 (290834) script.js.Light.Atrium.Atrium: Atrium On
      2024-12-28 17:26:03.346  - info: broadlink2.0 (290925) interface to be used: { netmaskBits: 24, address: '192.168.0.54/24', addrs: [ 192, 168, 0, 54 ], cidr: '192.168.0.54/24', bcaddr: '192.168.0.255'
      2024-12-28 17:26:03.348  - info: broadlink2.0 (290925) discover  [ '192.168.0.181' ] from 192.168.0.181:51697
      Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
      • Ro75
        Ro75 @retostoeckli last edited by
        @retostoeckli Redis arbeitet komplett im RAM. Möglicherweise ist dieser dir bei 4GB ausgegangen. Erhöhe SWAP oder ein PI oder anderes Gerät mit mehr RAM oder verzichte auf Redis.
        Ro75.
          Thomas Braun Most Active @retostoeckli last edited by
          @retostoeckli
          RAM zu knapp, Spannungsversorgung zweifelhaft, critical errors in dmesg, unnötiger Einsatz von redis.
            @thomas-braun @ro75 danke euch. Ich hab mal auf jsonl umgestellt und beobachte weiter. Sonst hilft nur das upgrade der HW
