    4. Installation
    5. Pi3 Neuinstallation Deprecation section in apt-key(8)
      Smallfeuer last edited by
      aus gegebenen Anlass versuche ich grad einen 2. alten Pi3Model B V1.2 in Betrieb zu nehmen. Leider bisher ohne Erfolg.
      Folgendes passiert bei der Installation, egal ob 32 oder 64 Bit Version. Die Meldungen zu den Deprecation section kommt dann nach jeder Installation bis er irgendwann abbricht.
          Welcome to the ioBroker installer!
          Installer version: 2024-10-22
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Get:1 http://archive.raspberrypi.com/debian bookworm InRelease [39.3 kB]
      Get:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease [15.0 kB]
      Get:3 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages [14.        5 MB]
      Get:4 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [520 kB        ]
      Get:5 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [549 kB        ]
      Fetched 15.6 MB in 22s (724 kB/s)
      Reading package lists... Done
      W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg k        eyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Node.js not found. Installing...
      W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg': No such file or directory
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      • crunchip
        crunchip Forum Testing Most Active @Smallfeuer last edited by
        @smallfeuer sagte in Pi3 Neuinstallation Deprecation section in apt-key(8):
        z.b https://github.com/RPi-Distro/repo/issues/348#issuecomment-1856137060
        reraikes created this issue in RPi-Distro/repo
        closed Warning from 'apt update' in Raspberry Pi OS Bookworm 32-bit #348
          Smallfeuer @crunchip last edited by
          @crunchip Dankeschön. Problem behoben.
          Package: nodejs
          Pin-Priority: 1001
           Processing triggers for man-db (2.11.2-2) ...ource1_armhf.deb ...led.)
          Installed nodejs
          Node.js Installed successfully!
          Guten Rutsch. 😉
