    4. Pflege des Betriebssystems
    5. [gelöst] raspi-config.service not found
    • Meister Mopper
      Meister Mopper last edited by Meister Mopper
      RPI 4 mit aktuellem Debian 12.8 bookworm
      Ich habe eine Frage an die Raspberry-Experten:
      Heute stellte ich fest, dass der raspi-config.service nicht mehr gefunden wird.
      thomas@rpizigbee:~ $ systemctl --type=service
       UNIT                                                        LOAD      ACTIVE SUB     DESCRIPTION
       alsa-restore.service                                        loaded    active exited  Save/Restore Sound Card State
       avahi-daemon.service                                        loaded    active running Avahi mDNS/DNS-SD Stack
       bluetooth.service                                           loaded    active running Bluetooth service
       console-setup.service                                       loaded    active exited  Set console font and keymap
       cpufrequtils.service                                        loaded    active exited  LSB: set CPUFreq kernel parameters
       cron.service                                                loaded    active running Regular background program processing daemon
       dbus.service                                                loaded    active running D-Bus System Message Bus
       dphys-swapfile.service                                      loaded    active exited  dphys-swapfile - set up, mount/unmount, and delete a swap file
       fake-hwclock.service                                        loaded    active exited  Restore / save the current clock
       getty@tty1.service                                          loaded    active running Getty on tty1
       ifupdown-pre.service                                        loaded    active exited  Helper to synchronize boot up for ifupdown
       iobroker.service                                            loaded    active running ioBroker Server
       keyboard-setup.service                                      loaded    active exited  Set the console keyboard layout
       kmod-static-nodes.service                                   loaded    active exited  Create List of Static Device Nodes
       loadcpufreq.service                                         loaded    active exited  LSB: Load kernel modules needed to enable cpufreq scaling
       networking.service                                          loaded    active exited  Raise network interfaces
       NetworkManager-wait-online.service                          loaded    active exited  Network Manager Wait Online
       NetworkManager.service                                      loaded    active running Network Manager
       nut-monitor.service                                         loaded    active running Network UPS Tools - power device monitor and shutdown controller
      ● raspi-config.service                                        not-found active exited  raspi-config.service
       rc-local.service                                            loaded    active exited  /etc/rc.local Compatibility
       rpc-statd-notify.service                                    loaded    active exited  Notify NFS peers of a restart
       rpi-eeprom-update.service                                   loaded    active exited  Check for Raspberry Pi EEPROM updates
       ssh.service                                                 loaded    active running OpenBSD Secure Shell server
       systemd-binfmt.service                                      loaded    active exited  Set Up Additional Binary Formats
       systemd-fsck@dev-disk-by\x2dpartuuid-e5746a7c\x2d01.service loaded    active exited  File System Check on /dev/disk/by-partuuid/e5746a7c-01
       systemd-journal-flush.service                               loaded    active exited  Flush Journal to Persistent Storage
       systemd-journald.service                                    loaded    active running Journal Service
       systemd-logind.service                                      loaded    active running User Login Management
       systemd-modules-load.service                                loaded    active exited  Load Kernel Modules
       systemd-random-seed.service                                 loaded    active exited  Load/Save Random Seed
       systemd-remount-fs.service                                  loaded    active exited  Remount Root and Kernel File Systems
       systemd-sysctl.service                                      loaded    active exited  Apply Kernel Variables
       systemd-sysusers.service                                    loaded    active exited  Create System Users
       systemd-timesyncd.service                                   loaded    active running Network Time Synchronization
       systemd-tmpfiles-setup-dev.service                          loaded    active exited  Create Static Device Nodes in /dev
       systemd-tmpfiles-setup.service                              loaded    active exited  Create System Files and Directories
       systemd-udev-trigger.service                                loaded    active exited  Coldplug All udev Devices
       systemd-udevd.service                                       loaded    active running Rule-based Manager for Device Events and Files
       systemd-update-utmp.service                                 loaded    active exited  Record System Boot/Shutdown in UTMP
       systemd-user-sessions.service                               loaded    active exited  Permit User Sessions
       triggerhappy.service                                        loaded    active running triggerhappy global hotkey daemon
       user-runtime-dir@1000.service                               loaded    active exited  User Runtime Directory /run/user/1000
       user@1000.service                                           loaded    active running User Manager for UID 1000
       wpa_supplicant.service                                      loaded    active running WPA supplicant
      Mit dem Befehl sudo raspi-config wird jedoch das config-Fenster problemlos geöffnet.
      Benötigt raspi-config diesen service nicht mehr und wenn ja, wie kann ich den Aufruf dieses raspi-config.service deaktivieren?
      Mit sudo disable raspi-config.service geht es nicht, da er ja nicht gefunden wird.
        Thomas Braun Most Active @Meister Mopper last edited by
        @meister-mopper
        So einen Service hab ich gar nicht laufen.
        Wüsste auch nicht, dass das überhaupt als systemd-Service jemals angelegt wurde.
        Da reicht ja ein Aufruf im $PATH aus.
        • Meister Mopper
          Meister Mopper @Thomas Braun last edited by
          @thomas-braun sagte in raspi-config.service not found:
          Kannst du das bitte konkretisieren? Ich finde den Sinn der Aussage leider nicht.
            Thomas Braun Most Active @Meister Mopper last edited by Thomas Braun
            @meister-mopper
            Programme, die nicht via systemd oder andere Init-Systeme beim Systemstart ausgeführt werden müssen ruft man auf, indem man nur den Programmnamen eingibt. Dann durchläuft dein Terminal (die sog. 'shell') die in der Umgebungsvariablen $PATH hinterlegten Verzeichnisse und sucht das ausführbare Programm und startet es.
            Den Inhalt von $PATH kannst du dir z. B. mit
            echo $PATH
            anschauen.
            Wenn ein Programm weder beim Systemstart über ein Init-System gestartet wird noch im $PATH liegt muss/kann das Programm mit dem vollständigem Pfad aufgerufen werden. Machen manche Dinge, die z. B. nur im /home/ des users installiert wurden.
            raspi-config ist also ein Befehl, der üblicherweise im $PATH eines users liegt.
            Meister Mopper 2 Replies Last reply Reply Quote 0
            • Meister Mopper
              OK,
              thomas@rpizigbee:~ $ echo $PATH
              /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
              Kannst du mir sagen, wie ich den Aufruf des raspi-config.service abschalten kann?
              • Meister Mopper
                Ok, die Google-KI hat empfohlen, die Meldung zu ignorieren, wenn keine anderen Funktionsstörungen auftreten.
                Tut es nicht, und ich lasse es mal so, wie es ist. 🤷‍♂️
                  @meister-mopper
                  Geht so:
                  https://superuser.com/questions/513159/how-to-remove-systemd-services
                  • Meister Mopper
                    @meister-mopper
                    Geht so:
                    Joa, hatte ich ja alles schon ausgeführt. Endergebnis => nüscht
                    thomas@rpizigbee:~ $ ls -lh /etc/systemd/raspi-config.service
                    ls: Zugriff auf '/etc/systemd/raspi-config.service' nicht möglich: Datei oder Verzeichnis nicht gefunden
                    Auf einem baugleichen RPI mit gleichem Betriebssystem habe ich das nicht. Bin ratlos, aber der innere Monk macht mich irgendwie unruhig. 😀
                    • Marc Berg
                      Marc Berg Most Active @Meister Mopper last edited by
                      @meister-mopper sagte in raspi-config.service not found:
                      da fehlt meiner Meinung auch das "system" im Pfad
                      ls -lh /etc/systemd/system/raspi-config.service
                      • Meister Mopper
                        Meister Mopper @Marc Berg last edited by
                        @marc-berg sagte in raspi-config.service not found:
                        thomas@rpizigbee:~ $ ls -lh /etc/systemd/system/raspi-config.service
                        ls: Zugriff auf '/etc/systemd/system/raspi-config.service' nicht möglich: Datei oder Verzeichnis nicht gefunden
                        • Marc Berg
                          und
                          ls -lh /usr/lib/systemd/system/raspi-config.service
                          • Meister Mopper
                            Auch da ist der Service nicht zu finden:
                            thomas@rpizigbee:~ $ ls -lh /usr/lib/systemd/system/raspi-config.service
                            ls: Zugriff auf '/usr/lib/systemd/system/raspi-config.service' nicht möglich: Datei oder Verzeichnis nicht gefunden
                            • haselchen
                              haselchen Most Active @Meister Mopper last edited by
                              @meister-mopper
                              Und wenn Du es noch mal „drüber“ installierst?
                              sudo apt install raspi-config
                              Und dann noch mal nach dem Service schaust?
                              • Meister Mopper
                                Meister Mopper @haselchen last edited by
                                @haselchen sagte in raspi-config.service not found:
                                @meister-mopper
                                thomas@rpizigbee:~ $ sudo apt update && sudo apt install raspi-config
                                OK:1 http://deb.debian.org/debian bookworm InRelease
                                OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                OK:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                OK:4 http://deb.debian.org/debian bookworm-updates InRelease
                                OK:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Paketlisten werden gelesen… Fertig
                                Abhängigkeitsbaum wird aufgebaut… Fertig
                                Statusinformationen werden eingelesen… Fertig
                                Alle Pakete sind aktuell.
                                raspi-config ist schon die neueste Version (20241210).
                                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                thomas@rpizigbee:~ $ systemctl status raspi-config.service
                                Unit raspi-config.service could not be found.
                                • Meister Mopper
                                  Meister Mopper @Meister Mopper last edited by
                                  Jetzt wird es spooky.
                                  Ich habe mal mit systemctl --type=service --all alle services anzeigen lassen und der `raspi-config.service taucht nicht mehr auf.
                                  thomas@rpizigbee:~ $ systemctl --type=service --all
                                    UNIT                                                        LOAD      ACTIVE   SUB     DESCRIPTION                   >
                                    alsa-state.service                                          loaded    inactive dead    Manage Sound Card State (resto>
                                    apparmor.service                                            loaded    inactive dead    Load AppArmor profiles
                                    apt-daily-upgrade.service                                   loaded    inactive dead    Daily apt upgrade and clean ac>
                                    apt-daily.service                                           loaded    inactive dead    Daily apt download activities
                                  ● auditd.service                                              not-found inactive dead    auditd.service
                                    auth-rpcgss-module.service                                  loaded    inactive dead    Kernel Module supporting RPCSE>
                                  ● connman.service                                             not-found inactive dead    connman.service
                                  ● console-screen.service                                      not-found inactive dead    console-screen.service
                                    cpufrequtils.service                                        loaded    active   exited  LSB: set CPUFreq kernel parame>
                                    cron.service                                                loaded    active   running Regular background program pro>
                                  ● display-manager.service                                     not-found inactive dead    display-manager.service
                                    dphys-swapfile.service                                      loaded    active   exited  dphys-swapfile - set up, mount>
                                    dpkg-db-backup.service                                      loaded    inactive dead    Daily dpkg database backup ser>
                                    e2scrub_all.service                                         loaded    inactive dead    Online ext4 Metadata Check for>
                                    e2scrub_reap.service                                        loaded    inactive dead    Remove Stale Online ext4 Metad>
                                    emergency.service                                           loaded    inactive dead    Emergency Shell
                                    fake-hwclock.service                                        loaded    active   exited  Restore / save the current clo>
                                    fstrim.service                                              loaded    inactive dead    Discard unused blocks on files>
                                    getty-static.service                                        loaded    inactive dead    getty on tty2-tty6 if dbus and>
                                  ● gssproxy.service                                            not-found inactive dead    gssproxy.service
                                    ifupdown-pre.service                                        loaded    active   exited  Helper to synchronize boot up >
                                  ● influxdb.service                                            not-found inactive dead    influxdb.service
                                    initrd-cleanup.service                                      loaded    inactive dead    Cleaning Up and Shutting Down >
                                    initrd-parse-etc.service                                    loaded    inactive dead    Mountpoints Configured in the >
                                    initrd-switch-root.service                                  loaded    inactive dead    Switch Root
                                    initrd-udevadm-cleanup-db.service                           loaded    inactive dead    Cleanup udev Database
                                  ● kbd.service                                                 not-found inactive dead    kbd.service
                                    kmod-static-nodes.service                                   loaded    active   exited  Create List of Static Device N>
                                    loadcpufreq.service                                         loaded    active   exited  LSB: Load kernel modules neede>
                                    logrotate.service                                           loaded    inactive dead    Rotate log files
                                    man-db.service                                              loaded    inactive dead    Daily man-db regeneration
                                  ● mariadb-server.service                                      not-found inactive dead    mariadb-server.service
                                    modprobe@configfs.service                                   loaded    inactive dead    Load Kernel Module configfs
                                    modprobe@dm_mod.service                                     loaded    inactive dead    Load Kernel Module dm_mod
                                    modprobe@drm.service                                        loaded    inactive dead    Load Kernel Module drm
                                    modprobe@efi_pstore.service                                 loaded    inactive dead    Load Kernel Module efi_pstore
                                    modprobe@fuse.service                                       loaded    inactive dead    Load Kernel Module fuse
                                    modprobe@loop.service                                       loaded    inactive dead    Load Kernel Module loop
                                  ● mysql-server.service                                        not-found inactive dead    mysql-server.service
                                  ● nfs-server.service                                          not-found inactive dead    nfs-server.service
                                    nfs-utils.service                                           loaded    inactive dead    NFS server and client services
                                    nut-monitor.service                                         loaded    active   running Network UPS Tools - power devi>
                                  ● nut-server.service                                          not-found inactive dead    nut-server.service
                                  ● plymouth-quit-wait.service                                  not-found inactive dead    plymouth-quit-wait.service
                                  ● plymouth-start.service                                      not-found inactive dead    plymouth-start.service
                                    polkit.service                                              loaded    active   running Authorization Manager
                                  ● raspberrypi-net-mods.service                                not-found inactive dead    raspberrypi-net-mods.service
                                  ● redis.service                                               not-found inactive dead    redis.service
                                    regenerate_ssh_host_keys.service                            loaded    inactive dead    Regenerate SSH host keys
                                    rescue.service                                              loaded    inactive dead    Rescue Shell
                                    rpc-gssd.service                                            loaded    inactive dead    RPC security service for NFS c>
                                    rpc-svcgssd.service                                         loaded    inactive dead    RPC security service for NFS s>
                                    rpi-eeprom-update.service                                   loaded    active   exited  Check for Raspberry Pi EEPROM >
                                    sshswitch.service                                           loaded    inactive dead    Turn on SSH if /boot/ssh or /b>
                                  ● syslog.service                                              not-found inactive dead    syslog.service
                                    systemd-ask-password-console.service                        loaded    inactive dead    Dispatch Password Requests to >
                                    systemd-ask-password-wall.service                           loaded    inactive dead    Forward Password Requests to W>
                                    systemd-binfmt.service                                      loaded    active   exited  Set Up Additional Binary Forma>
                                    systemd-firstboot.service                                   loaded    inactive dead    First Boot Wizard
                                    systemd-fsck-root.service                                   loaded    inactive dead    File System Check on Root Devi>
                                    systemd-fsck@dev-disk-by\x2dpartuuid-e5746a7c\x2d01.service loaded    active   exited  File System Check on /dev/disk>
                                    systemd-fsckd.service                                       loaded    inactive dead    File System Check Daemon to re>
                                  ● systemd-hwdb-update.service                                 not-found inactive dead    systemd-hwdb-update.service
                                    systemd-initctl.service                                     loaded    inactive dead    initctl Compatibility Daemon
                                    systemd-journal-flush.service                               loaded    active   exited  Flush Journal to Persistent St>
                                    systemd-machine-id-commit.service                           loaded    inactive dead    Commit a transient machine-id >
                                    systemd-networkd.service                                    loaded    inactive dead    Network Configuration
                                  ● systemd-oomd.service                                        not-found inactive dead    systemd-oomd.service
                                    systemd-pcrphase-initrd.service                             loaded    inactive dead    TPM2 PCR Barrier (initrd)
                                    systemd-pcrphase-sysinit.service                            loaded    inactive dead    TPM2 PCR Barrier (Initializati>
                                    systemd-pcrphase.service                                    loaded    inactive dead    TPM2 PCR Barrier (User)
                                    systemd-pstore.service                                      loaded    inactive dead    Platform Persistent Storage Ar>
                                    systemd-quotacheck.service                                  loaded    inactive dead    File System Quota Check
                                    systemd-remount-fs.service                                  loaded    active   exited  Remount Root and Kernel File S>
                                    systemd-repart.service                                      loaded    inactive dead    Repartition Root Disk
                                    systemd-rfkill.service                                      loaded    inactive dead    Load/Save RF Kill Switch Status
                                    systemd-sysext.service                                      loaded    inactive dead    Merge System Extension Images >
                                    systemd-tmpfiles-clean.service                              loaded    inactive dead    Cleanup of Temporary Directori>
                                    systemd-tmpfiles-setup-dev.service                          loaded    active   exited  Create Static Device Nodes in >
                                    systemd-tmpfiles-setup.service                              loaded    active   exited  Create System Files and Direct>
                                    systemd-udev-settle.service                                 loaded    inactive dead    Wait for udev To Complete Devi>
                                    systemd-udevd.service                                       loaded    active   running Rule-based Manager for Device >
                                  ● systemd-update-done.service                                 not-found inactive dead    systemd-update-done.service
                                    systemd-update-utmp-runlevel.service                        loaded    inactive dead    Record Runlevel Change in UTMP
                                    systemd-update-utmp.service                                 loaded    active   exited  Record System Boot/Shutdown in>
                                  ● systemd-vconsole-setup.service                              not-found inactive dead    systemd-vconsole-setup.service
                                    triggerhappy.service                                        loaded    active   running triggerhappy global hotkey dae>
                                    udisks2.service                                             loaded    inactive dead    Disk Manager
                                    user-runtime-dir@1000.service                               loaded    active   exited  User Runtime Directory /run/us>
                                  Seitdem wird er auch mit systemctl --type=service nicht mehr angezeigt.
                                  @Thomas-Braun
                                  Und ich dachte immer, dass nur GUI's lügen. Hier flunkert auch die Konsole ab und an 😕
                                    @meister-mopper sagte in [gelöst] raspi-config.service not found:
                                    Das ist ja auch richtig.
                                    ??? Wo stolperst du denn über eine Meldung mit dem fehlenden Service überhaupt?
                                    • Meister Mopper
                                      Meister Mopper @Thomas Braun last edited by Meister Mopper
                                      @thomas-braun sagte in [gelöst] raspi-config.service not found:
                                      Na ja, jetzt überhaupt nicht mehr. KA, was da los war.
                                      Ich checke halt ab und an, ob alle services laufen, bin sozusagen ein control freak.
                                      Den Ausfall von z. B. nut-clients lass' ich mir als Warnung ausgeben.
                                        Dann lügt doch die Konsole nicht. 😉
                                        1.1k
                                        81.1k
                                        raspberry-config
                                        1206
