    4. Alias Umwandlung bei JSON mit "null" bereitet Probleme
      Heinz53 last edited by
      Hallo allerseits,
      mein ioBroker lief stabil in einem Container auf meiner synology.
      Seit einigen Tagen habe ich nach der Umstellung von zigbee auf zigbee2mqtt Probleme:
      Beim starten des Containers erscheint folgende Fehlermeldung:
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
      This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      TypeError: Cannot read properties of undefined (reading 'toString')
      at applyAliasConvenienceConversion (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/aliasProcessing.ts:78:30)
      at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2753:17)
      at AdapterClass._processStatesSecondary (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9376:31)
      at processTicksAndRejections (node:internal/process/task_queues:95:5)
      at AdapterClass._getForeignStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9526:29)
      Beim Aufruf der Instanz mit einem alias Datenpunkt friert das System ein, und erstellt folgende Fehlermeldungen:
      host.iobroker
      2025-01-02 18:13:58.435	error	instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      2025-01-02 18:13:58.434	error	Caught by controller[1]: at Admin._getForeignStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9526:29)
      host.iobroker
      2025-01-02 18:13:58.434	error	Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
      host.iobroker
      2025-01-02 18:13:58.434	error	Caught by controller[1]: at Admin._processStatesSecondary (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9376:31)
      host.iobroker
      2025-01-02 18:13:58.434	error	Caught by controller[1]: at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2753:17)
      host.iobroker
      2025-01-02 18:13:58.434	error	Caught by controller[1]: at applyAliasConvenienceConversion (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/aliasProcessing.ts:78:30)
      host.iobroker
      2025-01-02 18:13:58.434	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'toString')
      host.iobroker
      2025-01-02 18:13:58.433	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      admin.0
      2025-01-02 18:13:57.822	error	Cannot read properties of undefined (reading 'toString')
      admin.0
      2025-01-02 18:13:57.821	error	TypeError: Cannot read properties of undefined (reading 'toString') at applyAliasConvenienceConversion (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/aliasProcessing.ts:78:30) at Object.formatAliasValue (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2753:17) at Admin._processStatesSecondary (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9376:31) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Admin._getForeignStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9526:29)
      admin.0
      2025-01-02 18:13:57.672	error	unhandled promise rejection: Cannot read properties of undefined (reading 'toString')
      admin.0
      2025-01-02 18:13:57.672	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Die Datenpunkte sind folgendermaßen definiert:
      alias.0.Button.Cube1.action - mit Typ mixed
        "common": {
          "name": "action",
          "desc": "Manuell erzeugt",
          "role": "state",
          "type": "mixed",
          "read": true,
          "write": true,
          "def": "",
          "alias": {
            "id": "mqtt.0.zigbee2mqtt.Cube1",
            "read": "JSON.parse(val).action"
        "type": "state",
        "native": {},
        "_id": "alias.0.Button.Cube1.action",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
        "user": "system.user.admin",
        "ts": 1735832197825
      alias.0.Button.Cube1.alias.0.Button.Cube1.action_from_side - mit Typ String
        "common": {
          "name": "action_from_side",
          "role": "state",
          "type": "string",
          "read": true,
          "write": true,
          "def": "",
          "alias": {
            "read": "JSON.parse(val).action_from_side"
        "type": "state",
        "native": {},
        "_id": "alias.0.Button.Cube1.action_from_side",
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1735834100918
      Meine Systemeinstellungen habe ich mit iobroker diag hier eingefügt:
      The ioBroker diag script is not specifically designed to run in Docker.
      Although it is generally safe to use, use it at your own risk.
      *** iob diag is starting up, please wait ***
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      ========== Start marking the full check here ===========
      Script v.2024-10-19
      *** BASE SYSTEM ***
      Hardware Vendor : Synology
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v10.0.0
      Virtualization  : docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       17:47:39 up 15 days, 21:39,  0 user,  load average: 0.45, 0.39, 0.44
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
      Thu Jan  2 16:47:39 UTC 2025
      Thu Jan  2 17:47:39 CET 2025
      CET +0100
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             20G        5.0G        2.3G        336M         14G         15G
      Swap:            14G        1.4G         13G
      Total:           35G        6.4G         15G
      Active iob-Instances: 	1
              19852 M total memory
               4771 M used memory
               8293 M active memory
               7281 M inactive memory
               2151 M free memory
               1065 M buffer memory
              12608 M swap cache
              13959 M total swap
               1297 M used swap
              12662 M free swap
      top - 17:47:39 up 15 days, 21:39,  0 user,  load average: 0.45, 0.39, 0.44
      Tasks:   8 total,   1 running,   7 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  19852.1 total,   2150.2 free,   4772.8 used,  13673.8 buff/cache
      MiB Swap:  13959.9 total,  12662.6 free,   1297.3 used.  15079.3 avail Mem
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      /dev/mapper/cachedev_0 btrfs   14T  7.4T  6.7T  53% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  9.7G     0  9.7G   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_0 btrfs   14T  7.4T  6.7T  53% /opt/iobroker
      /dev/mapper/cachedev_0 btrfs   14T  7.4T  6.7T  53% /etc/hosts
      tmpfs                  tmpfs  9.7G     0  9.7G   0% /proc/acpi
      tmpfs                  tmpfs  9.7G     0  9.7G   0% /proc/scsi
      tmpfs                  tmpfs  9.7G     0  9.7G   0% /sys/firmware
      Show mounted filesystems:
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/192331e0bdd039fa603c9a2d9aa939e3abd9c6d9cb2905154c13a7371af3a5bb]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=6521,subvol=/@syno/@docker/btrfs/subvolumes/192331e0bdd039fa603c9a2d9aa939e3abd9c6d9cb2905154c13a7371af3a5bb
      |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker245]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=786,subvol=/@syno/docker
      |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/e01a8487ad4b8b2f86e8c2510e9eb4a8ee872205cc6b01bf942823a07b8d393e/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
      |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/e01a8487ad4b8b2f86e8c2510e9eb4a8ee872205cc6b01bf942823a07b8d393e/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
      `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/e01a8487ad4b8b2f86e8c2510e9eb4a8ee872205cc6b01bf942823a07b8d393e/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
      /var:
      35M	/var/
      33M	/var/lib
      19M	/var/lib/apt/lists
      19M	/var/lib/apt
      13M	/var/lib/dpkg/info
      /opt/iobroker/backups:
      840M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.9G	/opt/iobroker/iobroker-data/
      1.3G	/opt/iobroker/iobroker-data/files
      616M	/opt/iobroker/iobroker-data/files/javascript.admin
      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      32M	/opt/iobroker/iobroker-data/objects.jsonl
      27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.18.1
      /usr/bin/node 		v20.18.1
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 3017)
      Core adapters versions
      js-controller: 	7.0.3
      admin: 		7.1.5
      javascript: 	8.8.3
      nodejs modules from github: 	1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled, compact disabled
        system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
        system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled, compact disabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
        system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled, compact disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled, compact disabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled, compact disabled
        system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
        system.adapter.eventlist.0              : eventlist             : iobroker                                 -  enabled, compact disabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled, compact disabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled, compact disabled
        system.adapter.hm-rega.1                : hm-rega               : iobroker                                 -  enabled, compact disabled
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
        system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, compact disabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, compact disabled, port: 8086
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 - disabled, compact disabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, compact disabled
        system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled, compact disabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, compact disabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
        system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled, compact disabled
        system.adapter.synology.0               : synology              : iobroker                                 - disabled, compact disabled, port: 5000
        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled, compact disabled
        system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled, compact disabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled, compact disabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled, compact disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled, compact disabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled, compact disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.2.1    , installed 8.2.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.6.3
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects: 	14941
      States: 	12189
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.11:36365        0.0.0.0:*               LISTEN      0          361034420  -
      udp        0      0 127.0.0.11:43162        0.0.0.0:*                           0          361034419  -
      2025-01-02 17:31:01.056  - warn: host.iobroker instance system.adapter.sayit.0 terminated due to SIGKILL
      2025-01-02 17:31:01.056  - info: host.iobroker instance system.adapter.sayit.0 terminated with code null ()
      2025-01-02 17:31:01.056  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-02 17:31:01.449  - warn: host.iobroker instance system.adapter.telegram.0 terminated due to SIGKILL
      2025-01-02 17:31:01.449  - info: host.iobroker instance system.adapter.telegram.0 terminated with code null ()
      2025-01-02 17:31:01.449  - warn: host.iobroker instance system.adapter.hm-rega.1 terminated due to SIGKILL
      2025-01-02 17:31:01.449  - info: host.iobroker instance system.adapter.hm-rega.1 terminated with code null ()
      2025-01-02 17:31:01.483  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGKILL
      2025-01-02 17:31:01.484  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
      2025-01-02 17:31:01.484  - warn: host.iobroker instance system.adapter.echarts.0 terminated due to SIGKILL
      2025-01-02 17:31:01.484  - info: host.iobroker instance system.adapter.echarts.0 terminated with code null ()
      2025-01-02 17:31:01.484  - warn: host.iobroker instance system.adapter.fullybrowser.0 terminated due to SIGKILL
      2025-01-02 17:31:01.485  - info: host.iobroker instance system.adapter.fullybrowser.0 terminated with code null ()
      2025-01-02 17:31:01.529  - info: host.iobroker instance system.adapter.socketio.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-02 17:31:01.530  - info: host.iobroker All instances are stopped.
      2025-01-02 17:31:01.530  - warn: host.iobroker instance system.adapter.statistics.0 terminated due to SIGKILL
      2025-01-02 17:31:01.530  - info: host.iobroker instance system.adapter.statistics.0 terminated with code null ()
      2025-01-02 17:31:01.530  - warn: host.iobroker instance system.adapter.text2command.0 terminated due to SIGKILL
      2025-01-02 17:31:01.530  - info: host.iobroker instance system.adapter.text2command.0 terminated with code null ()
      2025-01-02 17:31:01.542  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
      2025-01-02 17:31:01.542  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
      2025-01-02 17:31:01.543  - info: host.iobroker All instances are stopped.
      2025-01-02 17:31:01.703  - info: host.iobroker terminated
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      			v.2024-10-19
      model name	: Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v10.0.0
      Installation: 		Docker
      Kernel: 		x86_64
      Userland: 		64 bit
      Timezone: 		CET +0100
      User-ID: 		0
      Pending OS-Updates: 	0
      Pending iob updates: 	1
      Nodejs-Installation:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:             20G        5.0G        2.3G        337M         14G         15G
      Swap:            14G        1.4G         13G
      Total:           35G        6.4G         15G
      ioBroker Core: 		js-controller 		7.0.3
      			admin 			7.1.5
      ioBroker Status: 	iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		14941
      States: 		12189
      Size of iob-Database:
      6.1M	/opt/iobroker/iobroker-data/states.jsonl
      === Mark text until here for copying ===
      Wie muss die Umwandlung gesetzt werden damit undefinierte Werte nicht zu den Problemen führen?
      Die Änderungen von Datenpunkten werden ebenfalls nicht mehr im Javascript oder Blockly erkannt. Hängt das mit den alias Problemen zusammen? Was kann ich für die weitere Fehleranalyse / -behebung unternehmen?
      Ich hoffe auf eure Unterstützung.
      Heinz
        paul53 @Heinz53 last edited by paul53
        @heinz53 sagte: Was kann ich für die weitere Fehleranalyse / -behebung unternehmen?
              "read":  "val ? JSON.parse(val).action : 'no Action'"
          @paul53 : DANKE! Das ist die Lösung!
          Es war für mich unverständlich dass falsche Werte im alias das ganze System aus dem Tritt bringen.
          Vielleicht hast du noch einen Tipp für mich: Die Steckdosen melden über zigbee2mqtt als string "on" oder off.
          Ich versuche sie als boolean umzuwandeln und erhalte folgende Meldung
          Object alias.0.Steckdose.Strom28.POWER is invalid: Default value has to be type "boolean" but received type "string" This will throw an error up from js-controller version 7.0.0!
            "common": {
              "name": "POWER",
              "role": "state",
              "type": "boolean",
              "read": true,
              "write": true,
              "def": "",
              "alias": {
                "id": {
                  "read": "mqtt.0.zigbee2mqtt.Strom28",
                  "write": "mqtt.0.zigbee2mqtt.Strom28.set"
                "read": "val == 'on' ? true : val == 'off' ? false : null"
            "type": "state",
            "native": {},
            "_id": "alias.0.Steckdose.Strom28.POWER",
            "acl": {
              "object": 1636,
              "state": 1636,
            "ts": 1735929801444
          Ist die Umsetzung nicht mehr möglich?
          Vielen Dank für deine Unterstützung
          Heinz
          FredF paul53 2 Replies Last reply Reply Quote 0
          • FredF
            FredF Most Active Forum Testing @Heinz53 last edited by
            @heinz53
            Ich antworte mal:
            "read": "val == 'on' ? true : false"
              @heinz53 sagte: folgende Meldung
              Wenn auch geschrieben werden soll, muss man beim Schreiben konvertieren, denn ich nehme an, dass "Strom28.set" ebenfalls "on"/"off" erwartet?
                    "read": "val == 'on'",
                    "write": "val ? 'on' : 'off'"
                Danke für eure Tipps. Leider kann ich sie gerade nicht testen weil mein ioBroker in einer Endlosschleife läuft.
                Ich habe ihn gestoppt, neu gestartet und den Container neu erstellt., ioBroker fix ausgeführt, ... Das Ergebnis bleibt gleich:
                    at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10961:37)
                    at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:383:37)
                    at processImmediate (node:internal/timers:483:21)
                Ich kann nicht über den ioBroker auf meine Datenpunkte zugreifen.
                Vermutlich habe ich noch ungültige alias Definitionen.
                Wie kann ich den Zugriff wieder herstellen?
                  Mein ursprüngliches Problem ist mittlerweile behoben. Der Zugriff auf den ioBroker war nach Start der Admin Instanz über SSH wieder möglich.
                  iobroker start admin
                  Als Ursache für meine Probleme vermute ich den "Schlafmodus" meiner Zigbee Button beim Versuch des öffnens eines "schlafenden" alias Datenpunktes in den Objekten.
                  Dies führte bei mir reproduzierbar zu Problemen der Admin Instanz.
                  Nach dem Setzen des Retain bei den Problematischen Geräten traten keine Abbrüche mehr auf.
                  "retain": true
                  @FredF und @paul53 : Ich habe noch Probleme meine Zigbee Steckdose (mit JSON) zu schalten.
                  Bei der Anbindung eines direkten Datenpunktes funktioniert es:
                    "common": {
                      "name": "Test_1",
                      "role": "state",
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "def": false,
                      "alias": {
                        "id": "0_userdata.0.Test.TestOnOff",
                        "read": "val == 'on' ? true : false",
                  Bei der Steckdose habe ich noch Probleme. Ich erhalte die Fehlermeldung:
                  Invalid write function for "alias.0.Steckdose.Strom28.state": "val ? JSON.stringify{'state' : 'on'} : JSON.stringify{'state' : 'off'}" => Unexpected token '{'
                  Ich habe schon viele Varianten erfolglos durchprobiert.
                    "common": {
                      "name": "state",
                      "role": "state",
                      "type": "boolean",
                      "read": true,
                      "write": true,
                      "def": "",
                      "alias": {
                        "id": {
                        "read": "JSON.parse(val).state == 'on' ? true : false",
                        "write": "val ? JSON.stringify{'state' : 'on'} : JSON.stringify{'state' : 'off'}"
                  Wie geht es richtig?
                    @heinz53 sagte: Wie geht es richtig?
                    Es fehlenden die runden Klammern.
                          "read": "JSON.parse(val).state == 'on'",
                          "write": "JSON.stringify({state: val ? 'on' : 'off'})"
                    Die Rolle sollte "switch" sein. Außerdem bietet sich an, einen eindeutigen, verständlichen Namen zu vergeben.
                      @paul53 said in Alias Umwandlung bei JSON mit "null" bereitet Probleme:
                      @paul53 Nun erhalte ich folgende Fehlermeldung:
                      Object alias.0.Steckdose.Strom28.state is invalid: Default value has to be type "boolean" but received type "string" This will throw an error up from js-controller version 7.0.0!
                      Wenn die Steckdose ausgeschaltet ist wird sie über den alias eingeschaltet.
                      Das Ausschalten über den alias ist nicht möglich.
                        "common": {
                          "name": "Steckdose_Strom28",
                          "role": "switch",
                          "type": "boolean",
                          "read": true,
                          "write": true,
                          "def": "",
                          "alias": {
                            "id": {
                            "read": "JSON.parse(val).state == 'on' ? true : false ",
                      Was kann ich machen?
                        @heinz53 sagte: Was kann ich machen?
                        Ändere "def":
                            "def": false,
                        @heinz53 sagte in Alias Umwandlung bei JSON mit "null" bereitet Probleme:
                        ?? Wie sieht der Wert von "mqtt.0.zigbee2mqtt.Strom28" bei ausgeschalteter Steckdose aus?
                          Die mqtt Daten sind:
                            "common": {
                              "role": "switch",
                              "type": "boolean",
                              "read": true,
                              "write": true,
                              "def": false,
                              "alias": {
                                "id": {
                          Nach der Änderung von "def" erhalte ich keine Fehlermeldung mehr im log.
                          Das Ausschalten ist weiterhin nicht möglich.
                            "common": {
                              "role": "switch",
                              "type": "boolean",
                              "read": true,
                              "write": true,
                              "def": false,
                              "alias": {
                                "id": {
                            die mqtt Daten:
                            "child_lock": "UNLOCK",
                            "countdown": 0,
                            "current": 0,
                            "energy": 0.03,
                            "indicator_mode": "off/on",
                            "last_seen": "2025-01-08T20:10:18+01:00",
                            "linkquality": 138,
                            "power": 0,
                            "power_outage_memory": "restore",
                            "state": "OFF",
                            "update": {
                            "installed_version": 80,
                            "latest_version": 80,
                            "state": "idle"
                            "update_available": false,
                            "voltage": 225
                              @heinz53 sagte: "state": "OFF",
                              ... groß geschrieben! Auch "ON"?
                                Danke! Das war's. Nun funktioniert es.
                                  "common": {
                                    "role": "switch",
                                    "type": "boolean",
                                    "read": true,
                                    "write": true,
                                    "def": false,
                                    "alias": {
                                      "id": {
                                      "read": "JSON.parse(val).state == 'ON'",
                                      "write": "JSON.stringify({state: val ? 'ON' : 'OFF'})"
                                Es funktionieren beim direkten Schalten beide Schreibweisen (Groß oder Kleinschrift)
                                ... und wieder was gelernt ...
                                Danke für die Unterstützung!
                                  c1olli @Heinz53 last edited by
                                  Ich habe ein wenigstens der Überschrift nach ähnliches Problem.
                                  Ich bekomme die Daten aus der Victron VRM als json ins MQTT geliefert.
                                  Diese wandele ich mit:
                                  Math.round(JSON.parse(val).value * 10) / 10
                                  im Alias zu Werten um und das funktioniert auch recht gut.
                                  Aber wenn die PV nichts mehr einspeist meldet der Datenpunkt :
                                  {"value":null}
                                  Damit kommt dann der alias nicht klar und meldet folgenden Fehler:
                                  Invalid read function for "alias.0.Vic-Erz": "Math.round(JSON.parse(val).value * 10) / 10" => Cannot read properties of null (reading 'value')
                                  Weil Null kein Wert ist.
                                  So sieht der Datenpunkt dann aus:
                                    "common": {
                                      "name": "PV-Pow-Ges",
                                      "role": "value",
                                      "type": "number",
                                      "read": true,
                                      "write": true,
                                      "def": 0,
                                      "alias": {
                                        "read": "Math.round(JSON.parse(val).value * 100) / 100",
                                        "id": "mqtt.0.N.48e7da85dd79.pvinverter.22.Ac.Power"
                                      "unit": "W"
                                    "type": "state",
                                    "native": {},
                                    "_id": "alias.0.PV-Pow-Ges",
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                    "ts": 1736334728344
                                  Wie kann ich nun die Fehlermeldung verhindern?
                                  • mickym
                                    @c1olli sagte in Alias Umwandlung bei JSON mit "null" bereitet Probleme:
                                    Probier halt das Gleiche was vorgeschlagen wurde:
                                    val ? Math.round(JSON.parse(val).value * 10) / 10 : val
                                      paul53 @c1olli last edited by paul53
                                      @c1olli sagte: {"value":null}
                                      "JSON.parse(val).value ? Math.round(JSON.parse(val).value * 100) / 100 : 0",
                                      Das JSON wird noch so erzeugt? Es ist nicht der gesamte Wert null?
                                      C 2 Replies Last reply Reply Quote 0
                                        c1olli @paul53 last edited by c1olli
                                        ich habe die Variante von @mickym und auch die von Dir probiert (2 verschiedene Werte) und beides funktioniert erst einmal.
                                        Ob das mit Null funktioniert weiß ich nicht, da die PV erst heute abend auf "null" stellt.
                                        Ich versuche mal beides zu simulieren.
                                        Edit:
                                        In der Simulation hat beides funktioniert. Ich warte also mal ab was passiert.
                                          @mickym
                                          Ich hab die Varianten jetzt laufen lassen und die Variante von @mickym funktioniert.
                                          Bei der anderen Variante kommt dann wieder "null" und die Fehlermeldung,
                                          Danke für die Hilfe.
                                          blockly javascript
                                          1368
