Kaputt nach Update
Ich habe gemäss Anweisung
iobroker stop
iobroker update
iobroker fix
ipbroker uprade self
meine iobroker Installation beim Upgrade kaputt gemacht. Es startet praktisch nichts mehr, keine Adapter, keine Weboberfläche. Die Fehlermeldungen sind immer die gleichen, aber für mich wenig aufschlussreich:2025-01-03 10:26:11.417 - info: host.UBU14 iobroker.js-controller version 7.0.6 js-controller starting 2025-01-03 10:26:11.419 - info: host.UBU14 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker 2025-01-03 10:26:11.420 - info: host.UBU14 hostname: UBU14, node: v18.17.1 2025-01-03 10:26:11.421 - info: host.UBU14 ip addresses: 10.0.2.3 fe80::8400:ff:fe48:7a5 2025-01-03 10:26:12.020 - info: host.UBU14 connected to Objects and States 2025-01-03 10:26:12.034 - info: host.UBU14 added notifications configuration of host 2025-01-03 10:26:12.332 - info: host.UBU14 34 instances found 2025-01-03 10:26:12.348 - info: host.UBU14 starting 31 instances 2025-01-03 10:26:12.521 - info: host.UBU14 instance system.adapter.admin.0 in version "6.13.16" started with pid 4476 2025-01-03 10:26:14.012 - error: admin.0 (4476) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2025-01-03 10:26:14.023 - error: admin.0 (4476) unhandled promise rejection: callback is not a function 2025-01-03 10:26:14.025 - error: admin.0 (4476) TypeError: callback is not a function at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17 2025-01-03 10:26:14.025 - error: admin.0 (4476) callback is not a function 2025-01-03 10:26:14.387 - info: admin.0 (4476) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.17.1, js-controller: 7.0.6 2025-01-03 10:26:14.559 - info: admin.0 (4476) terminating 2025-01-03 10:26:14.560 - warn: admin.0 (4476) Terminated (UNCAUGHT_EXCEPTION): Without reason 2025-01-03 10:26:15.123 - error: host.UBU14 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2025-01-03 10:26:15.124 - error: host.UBU14 Caught by controller[1]: TypeError: callback is not a function 2025-01-03 10:26:15.124 - error: host.UBU14 Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17 2025-01-03 10:26:15.125 - error: host.UBU14 instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2025-01-03 10:26:15.125 - info: host.UBU14 Restart adapter system.adapter.admin.0 because enabled 2025-01-03 10:26:16.502 - info: host.UBU14 instance system.adapter.sql.0 in version "2.2.0" started with pid 4494System ist
Ubuntu 22.04.5 LTS (GNU/Linux 5.15.0-130-generic aarch64)Wo soll ich als erstes hinlangen?
Vielen Dank.
@64kbyte sagte in Kaputt nach Update:
die Langfassung von
iob diagposten -
Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: UBU14 Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Ubuntu 22.04.5 LTS Kernel: Linux 5.15.0-130-generic Architecture: arm64 Hardware Vendor: Hetzner Hardware Model: vServer OS is similar to: debian Docker : false Virtualization : kvm Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 10:51:53 up 37 min, 3 users, load average: 0.66, 0.34, 0.29 CPU threads: 2 *** LIFE CYCLE STATUS *** Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time! *** TIME AND TIMEZONES *** Local time: Fri 2025-01-03 10:51:53 CET Universal time: Fri 2025-01-03 09:51:53 UTC RTC time: Fri 2025-01-03 09:51:54 Time zone: Europe/Zurich (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iobroker OPENHAB_HOME=/usr/share/openhab HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'! A root login is not required in most Linux Distributions. Run 'iobroker fix' or use the system tools to create a user. *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix' *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 1.1G 824M 22M 1.8G 2.5G Swap: 1.0G 0B 1.0G Total: 4.8G 1.1G 1.8G Active iob-Instances: 2 3813 M total memory 1149 M used memory 708 M active memory 1894 M inactive memory 824 M free memory 205 M buffer memory 1634 M swap cache 1023 M total swap 0 M used swap 1023 M free swap *** top - Table Of Processes *** top - 10:51:54 up 37 min, 3 users, load average: 0.66, 0.34, 0.29 Tasks: 193 total, 2 running, 191 sleeping, 0 stopped, 0 zombie %Cpu(s): 50.0 us, 12.5 sy, 0.0 ni, 37.5 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3813.8 total, 818.5 free, 1155.2 used, 1840.1 buff/cache MiB Swap: 1024.0 total, 1024.0 free, 0.0 used. 2450.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 382M 1.1M 381M 1% /run /dev/sda1 ext4 38G 14G 23G 39% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda15 vfat 253M 6.3M 246M 3% /boot/efi tmpfs tmpfs 382M 0 382M 0% /run/user/0 Messages concerning ext4 filesystem in dmesg: [Fri Jan 3 10:14:45 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Fri Jan 3 10:14:46 2025] EXT4-fs (sda1): re-mounted. Opts: (null). Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime `-/boot/efi /dev/sda15 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.6G /var/ 1.4G /var/log 1.2G /var/log/journal/d00883623d1e40b08f3f029f850712c9 1.2G /var/log/journal 1023M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 400.1M in the file system. /opt/iobroker/backups: 116M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 157M /opt/iobroker/iobroker-data/ 117M /opt/iobroker/iobroker-data/files 51M /opt/iobroker/iobroker-data/files/javascript.admin 32M /opt/iobroker/iobroker-data/files/javascript.admin/static/js 32M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 8.2M /opt/iobroker/iobroker-data/objects.jsonl 6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map 6.6M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 4.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 20.18.1-1nodesource1 Candidate: 20.18.1-1nodesource1 Version table: *** 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 12.22.9~dfsg-1ubuntu3.6 500 500 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 Packages 500 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Hosts: UBU14 UBU14 (version: 7.0.6, hostname: UBU14 , alive, uptime: 91) Core adapters versions js-controller: 7.0.6 admin: 6.13.16 javascript: 7.8.0 nodejs modules from github: 9 +-- iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#b60ff276702bbee5ca4cb4ef90ca743055281b20) +-- iobroker.garmin@0.0.4 (git+ssh://git@github.com/TA2k/ioBroker.garmin.git#eb23cf2960bb35e7b2917d859f153c21bf60e5d3) +-- iobroker.luxtronik2@0.4.2 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#68def1b194fb8cc418dc0543c3a0b48e5206cb45) +-- iobroker.miele@0.1.6 (git+ssh://git@github.com/soef/ioBroker.miele.git#5e90c7af1e5d8f83beaff7767e065e166e8cc544) +-- iobroker.mielecloudservice@6.5.4 (git+ssh://git@github.com/Grizzelbee/ioBroker.mielecloudservice.git#756d7a4dcae64ea50459e8af38e24bd8f0dd14da) +-- iobroker.swiss-weather-api@2.1.0 (git+ssh://git@github.com/baerengraben/ioBroker.swiss-weather-api.git#82276c9d7fb6dda69499c3d6e193a682eaabf7d0) +-- iobroker.vis-inventwo@3.3.3 (git+ssh://git@github.com/inventwo/ioBroker.vis-inventwo.git#c0ac2de2a01b3e616f1d230b8def838c70a680d4) +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92) +-- iobroker.vw-connect@0.5.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#85f79d2a7282c7dacb8899fe2d0822971e549018) Adapter State system.adapter.admin.0 : admin : UBU14 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.backitup.0 : backitup : UBU14 - enabled system.adapter.discovery.0 : discovery : UBU14 - enabled system.adapter.energiefluss.0 : energiefluss : UBU14 - enabled system.adapter.hm-rega.0 : hm-rega : UBU14 - enabled system.adapter.hm-rpc.0 : hm-rpc : UBU14 - enabled, port: 0 system.adapter.hm-rpc.1 : hm-rpc : UBU14 - enabled, port: 0 system.adapter.hue.0 : hue : UBU14 - disabled, port: 443 + system.adapter.javascript.0 : javascript : UBU14 - enabled system.adapter.luftdaten.0 : luftdaten : UBU14 - enabled system.adapter.luxtronik2.0 : luxtronik2 : UBU14 - enabled, port: 8214 system.adapter.meteoalarm.0 : meteoalarm : UBU14 - enabled system.adapter.mielecloudservice.0 : mielecloudservice : UBU14 - enabled system.adapter.modbus.0 : modbus : UBU14 - enabled system.adapter.modbus.1 : modbus : UBU14 - enabled system.adapter.modbus.2 : modbus : UBU14 - enabled system.adapter.modbus.3 : modbus : UBU14 - enabled system.adapter.modbus.4 : modbus : UBU14 - enabled system.adapter.modbus.5 : modbus : UBU14 - enabled system.adapter.modbus.6 : modbus : UBU14 - enabled system.adapter.modbus.7 : modbus : UBU14 - enabled system.adapter.modbus.8 : modbus : UBU14 - enabled system.adapter.netatmo.0 : netatmo : UBU14 - enabled system.adapter.openhab.0 : openhab : UBU14 - enabled, port: 8080 system.adapter.pvforecast.0 : pvforecast : UBU14 - enabled system.adapter.pvforecast.1 : pvforecast : UBU14 - disabled system.adapter.robonect.0 : robonect : UBU14 - disabled system.adapter.sql.0 : sql : UBU14 - enabled system.adapter.sql.1 : sql : UBU14 - enabled system.adapter.swiss-weather-api.0 : swiss-weather-api : UBU14 - enabled system.adapter.vis.0 : vis : UBU14 - enabled system.adapter.vw-connect.0 : vw-connect : UBU14 - enabled system.adapter.vw-connect.1 : vw-connect : UBU14 - enabled system.adapter.web.0 : web : UBU14 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings system.adapter.admin.0 : admin : UBU14 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.hm-rpc.0 : hm-rpc : UBU14 - enabled, port: 0 system.adapter.hm-rpc.1 : hm-rpc : UBU14 - enabled, port: 0 system.adapter.luxtronik2.0 : luxtronik2 : UBU14 - enabled, port: 8214 system.adapter.openhab.0 : openhab : UBU14 - enabled, port: 8080 system.adapter.web.0 : web : UBU14 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.1.5 , installed 6.13.16 [Updatable] Adapter "backitup" : 3.0.25 , installed 2.10.11 [Updatable] Adapter "discovery" : 5.0.0 , installed 4.4.0 [Updatable] Adapter "energiefluss" : 3.6.2 , installed 3.6.0 [Updatable] Adapter "garmin" : 0.0.3 , installed 0.0.4 Adapter "hm-rega" : 5.1.0 , installed 4.0.0 [Updatable] Adapter "hm-rpc" : 2.0.2 , installed 1.16.0 [Updatable] Adapter "hue" : 3.13.1 , installed 3.10.2 [Updatable] Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "javascript" : 8.8.3 , installed 7.8.0 [Updatable] Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "luftdaten" : 4.0.0 , installed 3.1.0 [Updatable] Adapter "meteoalarm" : 3.0.3 , installed 3.0.2 [Updatable] Adapter "miele" : 0.1.5 , installed 0.1.6 Adapter "mielecloudservice": 6.5.7, installed 6.5.4 [Updatable] Adapter "modbus" : 6.3.2 , installed 6.1.0 [Updatable] Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "openhab" : 1.2.0 , installed 1.2.0 Adapter "pvforecast" : 4.1.0 , installed 2.9.1 [Updatable] Adapter "robonect" : 1.4.2 , installed 1.3.4 [Updatable] Adapter "simple-api" : 2.8.0 , installed 2.7.2 [Updatable] Adapter "smartgarden" : 2.0.1 , installed 2.0.0 [Updatable] Adapter "socketio" : 6.7.1 , installed 6.6.1 [Updatable] Adapter "sql" : 3.0.1 , installed 2.2.0 [Updatable] Adapter "swiss-weather-api": 2.2.2, installed 2.1.0 [Updatable] Adapter "vis" : 1.5.6 , installed 1.5.4 [Updatable] Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.4.0 [Updatable] Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.3 [Updatable] Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "web" : 6.2.5 , installed 6.2.3 [Updatable] Adapter "ws" : 2.6.2 , installed 2.5.11 [Updatable] Objects and States Please stand by - This may take a while Objects: 12300 States: 10876 *** OS-Repositories and Updates *** Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease Hit:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease Hit:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease Hit:7 https://repo.zabbix.com/zabbix/6.4/ubuntu-arm64 jammy InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN 114 24398 762/zabbix_server tcp 0 0 10.0.2.3:53 0.0.0.0:* LISTEN 121 21326 734/named tcp 0 0 10.0.2.3:53 0.0.0.0:* LISTEN 121 21325 734/named tcp 0 0 0.0.0.0:8888 0.0.0.0:* LISTEN 33 22107 718/python3 tcp 0 0 0.0.0.0:514 0.0.0.0:* LISTEN 0 21760 712/rsyslogd tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 20797 637/systemd-resolve tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 121 21322 734/named tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 121 21321 734/named tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 17927 1/init tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 121 21328 734/named tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 121 21327 734/named tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 21206 728/sshd: /usr/sbin tcp6 0 0 :::8080 :::* LISTEN 116 26899 1473/java tcp6 0 0 :::10050 :::* LISTEN 114 22052 719/zabbix_agent2 tcp6 0 0 :::10051 :::* LISTEN 114 24399 762/zabbix_server tcp6 0 0 127.0.0.1:8101 :::* LISTEN 116 26419 1473/java tcp6 0 0 127.0.0.1:37203 :::* LISTEN 116 26352 1473/java tcp6 0 0 :::8888 :::* LISTEN 33 22108 718/python3 tcp6 0 0 :::514 :::* LISTEN 0 21761 712/rsyslogd tcp6 0 0 :::5007 :::* LISTEN 116 27214 1473/java tcp6 0 0 :::3000 :::* LISTEN 117 22169 675/grafana tcp6 0 0 :::8443 :::* LISTEN 116 26897 1473/java tcp6 0 0 :::111 :::* LISTEN 0 17929 1/init tcp6 0 0 :::22 :::* LISTEN 0 21217 728/sshd: /usr/sbin udp 0 0 127.0.0.1:323 0.0.0.0:* 0 21066 700/chronyd udp 0 0 0.0.0.0:514 0.0.0.0:* 0 21756 712/rsyslogd udp 0 0 10.0.2.3:53 0.0.0.0:* 121 21324 734/named udp 0 0 10.0.2.3:53 0.0.0.0:* 121 21323 734/named udp 0 0 127.0.0.1:53 0.0.0.0:* 121 21320 734/named udp 0 0 127.0.0.1:53 0.0.0.0:* 121 21319 734/named udp 0 0 127.0.0.53:53 0.0.0.0:* 102 20796 637/systemd-resolve udp 0 0 0.0.0.0:68 0.0.0.0:* 0 21304 686/dhclient udp 0 0 10.0.2.3:68 0.0.0.0:* 101 21533 635/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17928 1/init udp6 0 0 ::1:323 :::* 0 21067 700/chronyd udp6 0 0 :::514 :::* 0 21757 712/rsyslogd udp6 0 0 :::5353 :::* 116 27035 1473/java udp6 0 0 :::1900 :::* 116 27352 1473/java udp6 0 0 :::1902 :::* 116 27946 1473/java udp6 0 0 10.0.2.3:59483 :::* 116 27919 1473/java udp6 0 0 :::111 :::* 0 17930 1/init *** Log File - Last 25 Lines *** 2025-01-03 10:52:23.385 - error: host.UBU14 Caught by controller[1]: at runNextTicks (node:internal/process/task_queues:60:5) 2025-01-03 10:52:23.385 - error: host.UBU14 Caught by controller[1]: at processImmediate (node:internal/timers:454:9) 2025-01-03 10:52:23.385 - error: host.UBU14 instance system.adapter.modbus.4 terminated with code 6 (UNCAUGHT_EXCEPTION) 2025-01-03 10:52:23.386 - info: host.UBU14 Restart adapter system.adapter.modbus.4 because enabled 2025-01-03 10:52:23.386 - warn: host.UBU14 Do not restart adapter system.adapter.modbus.4 because restart loop detected 2025-01-03 10:52:23.731 - info: host.UBU14 instance system.adapter.pvforecast.0 in version "2.9.1" started with pid 14090 2025-01-03 10:52:24.385 - info: host.UBU14 instance system.adapter.vw-connect.0 in version "0.5.4" (non-npm: ta2k/ioBroker.vw-connect) started with pid 14454 2025-01-03 10:52:24.847 - info: host.UBU14 instance system.adapter.modbus.3 in version "6.1.0" started with pid 14463 2025-01-03 10:52:25.358 - error: pvforecast.0 (14090) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2025-01-03 10:52:25.360 - error: pvforecast.0 (14090) unhandled promise rejection: callback is not a function 2025-01-03 10:52:25.361 - error: pvforecast.0 (14090) TypeError: callback is not a function at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17 at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) 2025-01-03 10:52:25.362 - error: pvforecast.0 (14090) callback is not a function 2025-01-03 10:52:25.891 - info: pvforecast.0 (14090) terminating 2025-01-03 10:52:25.891 - warn: pvforecast.0 (14090) Terminated (UNCAUGHT_EXCEPTION): Without reason 2025-01-03 10:52:25.931 - info: pvforecast.0 (14090) starting. Version 2.9.1 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v20.18.1, js-controller: 7.0.6 2025-01-03 10:52:26.443 - error: host.UBU14 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: 2025-01-03 10:52:26.444 - error: host.UBU14 Caught by controller[1]: TypeError: callback is not a function 2025-01-03 10:52:26.444 - error: host.UBU14 Caught by controller[1]: at /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17 2025-01-03 10:52:26.444 - error: host.UBU14 Caught by controller[1]: at runNextTicks (node:internal/process/task_queues:60:5) 2025-01-03 10:52:26.444 - error: host.UBU14 Caught by controller[1]: at processImmediate (node:internal/timers:454:9) 2025-01-03 10:52:26.445 - error: host.UBU14 instance system.adapter.pvforecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2025-01-03 10:52:26.445 - info: host.UBU14 Restart adapter system.adapter.pvforecast.0 because enabled -
iob update iob upgrade all -y iob start adminUnd ob die Idee, das auf einem vServer bei Hetzner zu betreiben die beste Idee ist wahrlich auch zu bezweifeln.
@thomas-braun said in Kaputt nach Update:
@64kbyte
Und ob die Idee, das auf einem vServer bei Hetzner zu betreiben die beste Idee ist wahrlich auch zu bezweifeln.Warum nicht? Ich habe mir da ne private cloud gebaut. Zugriff erfolgt via Site2Site VPN. Ausser vielleicht "Laufzeiten" mache ich mir da keine grossen Sorgen.
Ich mach' mal die angegebenen Befehle und melde mich wieder
iob update iob upgrade all -y iob start adminDas war weitestgehend erfolgreich. Eine Fehlermeldung bleibt:
2025-01-03 11:16:43.082 - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry' Require stack: - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js - /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js -
@64kbyte
Hast du nun alle Adapter auf einem aktuellen Stand?
Poste bitte nochmal ein aktualisiertesiob diag.UNd zeig bitte mal den output von
npm ls @iobroker/plugin-sentrySollte in etwa so aussehen:
xxx@xxx:/opt/iobroker $ npm ls @iobroker/plugin-sentry iobroker.inst@3.0.0 /opt/iobroker └─┬ iobroker.js-controller@7.0.3 └── @iobroker/plugin-sentry@2.0.4EDIT: name of plugin korrigiert
@mcm1957 said in Kaputt nach Update:
npm ls @iobroker/sentry-plugin
Glaub schon, dass die Adapter alle auf dem aktuellen Stand sind. Jedenfalls funktioniert alles bis auf die Sentry Fehlermeldung. Hier das diag:
Script v.2024-10-19 *** BASE SYSTEM *** Static hostname: UBU14 Icon name: computer-vm Chassis: vm Virtualization: kvm Operating System: Ubuntu 22.04.5 LTS Kernel: Linux 5.15.0-130-generic Architecture: arm64 Hardware Vendor: Hetzner Hardware Model: vServer OS is similar to: debian Docker : false Virtualization : kvm Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 21:22:22 up 10:24, 2 users, load average: 0.24, 0.25, 0.20 CPU threads: 2 *** LIFE CYCLE STATUS *** Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time! *** TIME AND TIMEZONES *** Local time: Fri 2025-01-03 21:22:22 CET Universal time: Fri 2025-01-03 20:22:22 UTC RTC time: Fri 2025-01-03 20:22:23 Time zone: Europe/Zurich (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': iobroker OPENHAB_HOME=/usr/share/openhab HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'! A root login is not required in most Linux Distributions. Run 'iobroker fix' or use the system tools to create a user. *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix' *** MEMORY *** total used free shared buff/cache available Mem: 3.8G 2.3G 243M 22M 1.3G 1.3G Swap: 1.0G 0.0K 1.0G Total: 4.8G 2.3G 1.3G Active iob-Instances: 29 3813 M total memory 2303 M used memory 565 M active memory 2682 M inactive memory 243 M free memory 122 M buffer memory 1143 M swap cache 1023 M total swap 0 M used swap 1023 M free swap *** top - Table Of Processes *** top - 21:22:22 up 10:24, 2 users, load average: 0.24, 0.25, 0.20 Tasks: 211 total, 3 running, 208 sleeping, 0 stopped, 0 zombie %Cpu(s): 33.3 us, 3.0 sy, 0.0 ni, 60.6 id, 0.0 wa, 0.0 hi, 3.0 si, 0.0 st MiB Mem : 3813.8 total, 243.4 free, 2303.3 used, 1267.1 buff/cache MiB Swap: 1024.0 total, 1023.2 free, 0.8 used. 1303.5 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** [sudo] password for iobroker: No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on tmpfs tmpfs 382M 1.1M 381M 1% /run /dev/sda1 ext4 38G 15G 22G 41% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock /dev/sda15 vfat 253M 6.3M 246M 3% /boot/efi tmpfs tmpfs 382M 0 382M 0% /run/user/0 Messages concerning ext4 filesystem in dmesg: [Fri Jan 3 10:58:15 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Fri Jan 3 10:58:16 2025] EXT4-fs (sda1): re-mounted. Opts: (null). Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime `-/boot/efi /dev/sda15 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 2.6G /var/ 1.4G /var/log 1.2G /var/log/journal/d00883623d1e40b08f3f029f850712c9 1.2G /var/log/journal 1023M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 400.1M in the file system. /opt/iobroker/backups: 116M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 157M /opt/iobroker/iobroker-data/ 117M /opt/iobroker/iobroker-data/files 51M /opt/iobroker/iobroker-data/files/javascript.admin 32M /opt/iobroker/iobroker-data/files/javascript.admin/static/js 32M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 8.2M /opt/iobroker/iobroker-data/objects.jsonl 6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map 6.6M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map 6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map 4.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v20.18.1 /usr/bin/node v20.18.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.29.4 nodejs: Installed: 20.18.1-1nodesource1 Candidate: 20.18.1-1nodesource1 Version table: *** 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 12.22.9~dfsg-1ubuntu3.6 500 500 http://ports.ubuntu.com/ubuntu-ports jammy-updates/universe arm64 Packages 500 http://ports.ubuntu.com/ubuntu-ports jammy-security/universe arm64 Packages 12.22.9~dfsg-1ubuntu3 500 500 http://ports.ubuntu.com/ubuntu-ports jammy/universe arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. At least one iobroker host is running. Objects type: redis States type: redis Hosts: UBU14 UBU14 (version: 7.0.6, hostname: UBU14 , alive, uptime: 36662) Core adapters versions js-controller: 7.0.6 admin: 7.1.5 javascript: 8.8.3 nodejs modules from github: 5 +-- iobroker.garmin@0.0.4 (git+ssh://git@github.com/TA2k/ioBroker.garmin.git#eb23cf2960bb35e7b2917d859f153c21bf60e5d3) +-- iobroker.luxtronik2@0.4.2 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#68def1b194fb8cc418dc0543c3a0b48e5206cb45) +-- iobroker.miele@0.1.6 (git+ssh://git@github.com/soef/ioBroker.miele.git#5e90c7af1e5d8f83beaff7767e065e166e8cc544) +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92) +-- iobroker.vw-connect@0.5.4 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#85f79d2a7282c7dacb8899fe2d0822971e549018) Adapter State + system.adapter.admin.0 : admin : UBU14 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : UBU14 - enabled + system.adapter.discovery.0 : discovery : UBU14 - enabled + system.adapter.energiefluss.0 : energiefluss : UBU14 - enabled + system.adapter.hm-rega.0 : hm-rega : UBU14 - enabled + system.adapter.hm-rpc.0 : hm-rpc : UBU14 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : UBU14 - enabled, port: 0 system.adapter.hue.0 : hue : UBU14 - disabled, port: 443 + system.adapter.javascript.0 : javascript : UBU14 - enabled system.adapter.luftdaten.0 : luftdaten : UBU14 - enabled + system.adapter.luxtronik2.0 : luxtronik2 : UBU14 - enabled, port: 8214 system.adapter.meteoalarm.0 : meteoalarm : UBU14 - enabled + system.adapter.mielecloudservice.0 : mielecloudservice : UBU14 - enabled + system.adapter.modbus.0 : modbus : UBU14 - enabled + system.adapter.modbus.1 : modbus : UBU14 - enabled + system.adapter.modbus.2 : modbus : UBU14 - enabled + system.adapter.modbus.3 : modbus : UBU14 - enabled + system.adapter.modbus.4 : modbus : UBU14 - enabled + system.adapter.modbus.5 : modbus : UBU14 - enabled + system.adapter.modbus.6 : modbus : UBU14 - enabled + system.adapter.modbus.7 : modbus : UBU14 - enabled + system.adapter.modbus.8 : modbus : UBU14 - enabled + system.adapter.netatmo.0 : netatmo : UBU14 - enabled + system.adapter.openhab.0 : openhab : UBU14 - enabled, port: 8080 + system.adapter.pvforecast.0 : pvforecast : UBU14 - enabled system.adapter.pvforecast.1 : pvforecast : UBU14 - disabled system.adapter.robonect.0 : robonect : UBU14 - disabled + system.adapter.sql.0 : sql : UBU14 - enabled + system.adapter.sql.1 : sql : UBU14 - enabled + system.adapter.swiss-weather-api.0 : swiss-weather-api : UBU14 - enabled system.adapter.vis.0 : vis : UBU14 - enabled + system.adapter.vw-connect.0 : vw-connect : UBU14 - enabled + system.adapter.vw-connect.1 : vw-connect : UBU14 - enabled + system.adapter.web.0 : web : UBU14 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : UBU14 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : UBU14 - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : UBU14 - enabled, port: 0 + system.adapter.luxtronik2.0 : luxtronik2 : UBU14 - enabled, port: 8214 + system.adapter.openhab.0 : openhab : UBU14 - enabled, port: 8080 + system.adapter.web.0 : web : UBU14 - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.1.5 , installed 7.1.5 Adapter "backitup" : 3.0.25 , installed 3.0.25 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "garmin" : 0.0.3 , installed 0.0.4 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "hue" : 3.13.1 , installed 3.13.1 Adapter "icons-fatcow-hosting": 0.1.0, installed 0.1.0 Adapter "icons-material-png": 0.1.0, installed 0.1.0 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "luftdaten" : 4.0.0 , installed 4.0.0 Adapter "meteoalarm" : 3.0.3 , installed 3.0.3 Adapter "miele" : 0.1.5 , installed 0.1.6 Adapter "mielecloudservice": 6.5.7, installed 6.5.7 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "openhab" : 1.2.0 , installed 1.2.0 Adapter "pvforecast" : 4.1.0 , installed 4.1.0 Adapter "robonect" : 1.4.2 , installed 1.4.2 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartgarden" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "swiss-weather-api": 2.2.2, installed 2.2.2 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-icontwo" : 1.5.0 , installed 1.5.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.94 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 14075 States: 12650 *** OS-Repositories and Updates *** Hit:1 http://ports.ubuntu.com/ubuntu-ports jammy InRelease Hit:2 http://ports.ubuntu.com/ubuntu-ports jammy-updates InRelease Hit:3 http://ports.ubuntu.com/ubuntu-ports jammy-backports InRelease Hit:4 http://ports.ubuntu.com/ubuntu-ports jammy-security InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease Hit:7 https://repo.zabbix.com/zabbix/6.4/ubuntu-arm64 jammy InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 21092 729/sshd: /usr/sbin tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 17555 1/init tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 102 20742 638/systemd-resolve tcp 0 0 0.0.0.0:8888 0.0.0.0:* LISTEN 33 22168 719/python3 tcp 0 0 10.0.2.3:53 0.0.0.0:* LISTEN 121 21193 734/named tcp 0 0 10.0.2.3:53 0.0.0.0:* LISTEN 121 21192 734/named tcp 0 0 0.0.0.0:514 0.0.0.0:* LISTEN 0 21011 713/rsyslogd tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 121 21189 734/named tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN 121 21188 734/named tcp 0 0 10.0.2.3:2010 0.0.0.0:* LISTEN 1000 47554 4751/io.hm-rpc.0 tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 121 21203 734/named tcp 0 0 127.0.0.1:953 0.0.0.0:* LISTEN 121 21202 734/named tcp 0 0 0.0.0.0:2001 0.0.0.0:* LISTEN 1000 46825 4688/io.hm-rpc.1 tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN 114 22143 769/zabbix_server tcp6 0 0 :::8443 :::* LISTEN 116 53308 5179/java tcp6 0 0 :::22 :::* LISTEN 0 21094 729/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 17557 1/init tcp6 0 0 :::8888 :::* LISTEN 33 22169 719/python3 tcp6 0 0 :::514 :::* LISTEN 0 21012 713/rsyslogd tcp6 0 0 127.0.0.1:8101 :::* LISTEN 116 52709 5179/java tcp6 0 0 :::3000 :::* LISTEN 117 22256 676/grafana tcp6 0 0 :::5007 :::* LISTEN 116 52804 5179/java tcp6 0 0 127.0.0.1:36473 :::* LISTEN 116 52681 5179/java tcp6 0 0 :::8082 :::* LISTEN 1000 49767 5017/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1000 46429 4564/io.admin.0 tcp6 0 0 :::8080 :::* LISTEN 116 52716 5179/java tcp6 0 0 :::10051 :::* LISTEN 114 22144 769/zabbix_server tcp6 0 0 :::10050 :::* LISTEN 114 22132 720/zabbix_agent2 udp 0 0 10.0.2.3:53 0.0.0.0:* 121 21191 734/named udp 0 0 10.0.2.3:53 0.0.0.0:* 121 21190 734/named udp 0 0 127.0.0.1:53 0.0.0.0:* 121 21187 734/named udp 0 0 127.0.0.1:53 0.0.0.0:* 121 21186 734/named udp 0 0 127.0.0.53:53 0.0.0.0:* 102 20741 638/systemd-resolve udp 0 0 0.0.0.0:68 0.0.0.0:* 0 21973 686/dhclient udp 0 0 10.0.2.3:68 0.0.0.0:* 101 20733 636/systemd-network udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17556 1/init udp 0 0 127.0.0.1:323 0.0.0.0:* 0 20974 709/chronyd udp 0 0 0.0.0.0:514 0.0.0.0:* 0 21007 713/rsyslogd udp6 0 0 :::1900 :::* 116 52837 5179/java udp6 0 0 :::1902 :::* 116 53588 5179/java udp6 0 0 :::111 :::* 0 17558 1/init udp6 0 0 ::1:323 :::* 0 20975 709/chronyd udp6 0 0 :::514 :::* 0 21008 713/rsyslogd udp6 0 0 10.0.2.3:54045 :::* 116 52838 5179/java udp6 0 0 :::5353 :::* 116 52733 5179/java *** Log File - Last 25 Lines *** 2025-01-03 21:22:02.565 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888 2025-01-03 21:22:03.045 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0') 2025-01-03 21:22:03.190 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section. 2025-01-03 21:22:03.190 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section. 2025-01-03 21:22:12.605 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888 2025-01-03 21:22:14.323 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0') 2025-01-03 21:22:14.465 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section. 2025-01-03 21:22:14.466 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section. 2025-01-03 21:22:22.647 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888 2025-01-03 21:22:25.633 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0') 2025-01-03 21:22:25.771 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section. 2025-01-03 21:22:25.771 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section. 2025-01-03 21:22:32.688 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888 2025-01-03 21:22:37.012 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0') 2025-01-03 21:22:37.182 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section. 2025-01-03 21:22:37.182 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section. 2025-01-03 21:22:42.729 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888 2025-01-03 21:22:48.357 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0') 2025-01-03 21:22:48.504 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section. 2025-01-03 21:22:48.504 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section. 2025-01-03 21:22:52.771 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888 2025-01-03 21:22:59.911 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Ablaufzeiten' -> 'Abschaltung VD': TypeError: Cannot read properties of undefined (reading '0') 2025-01-03 21:23:00.083 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Wärmemenge': Error: setStateAsync() not supported on section. 2025-01-03 21:23:00.083 - error: luxtronik2.0 (13431) Couldn't handle 'Informationen.Energiemonitor' -> 'Leistungsaufnahme': Error: setStateAsync() not supported on section. 2025-01-03 21:23:02.812 - error: luxtronik2.0 (13431) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 10.90.1.3:8888Der luxtronik Fehler ist mir bekannt, der ist schon immer da. Stört nicht, füllt nur das Log.
und die nmp Abfrage:
iobroker@UBU14:~$ npm ls @iobroker/sentry-plugin /home/iobroker └── (empty) -
@64kbyte
npm ls bitte in /opt(/iobroker absetzen.
Sorry, hab ich nicht extra geschrieben. -
@mcm1957 bei dir heisst es auch
plugin-sentry -
YEP, das ist der zweite Fehler. Bin heute wohl schon zu lange am PC... -
Hab beides gemacht:
iobroker@UBU14:~$ cd /opt/iobroker/ iobroker@UBU14:/opt/iobroker$ npm ls @iobroker/sentry-plugin iobroker.inst@3.0.0 /opt/iobroker └── (empty) iobroker@UBU14:/opt/iobroker$ npm ls @iobroker/plugin-sentry iobroker.inst@3.0.0 /opt/iobroker └─┬ iobroker.js-controller@7.0.6 └── @iobroker/plugin-sentry@2.0.4 -
OK schaut mal normal aus.
ioBroker funktioniert normal abgesehen von der Fehlermeldung im Log. Hab ich das richtig mitbekommen?
Ehrlich - ich hab keine Idee mehr was da nicht stimmen könnte. Ich glaub da kann maximal @foxriver76 noch was dazu sagen. Ev. mach ein Issue beim js-controller auf. Wenn du ein Testsystem hast, check mal mit der aktuellen Beta des js-controllers.
Hast du Statistic Reporting generell gesperrt / Sentry global deaktiviert? Sollte dann auch nicht den Fehler werfen aber wer weiß :-).
Habe ich probiert, ist wirkungslos:
iobroker@UBU14:~$ iob plugin disable sentry The plugin "sentry" was successfully disabled for host "UBU14". iobroker@UBU14:~$ iob restartund trotzdem im Log:
2025-01-04 08:58:58.360 - info: host.UBU14 instance system.adapter.sql.0 in version "3.0.1" started with pid 45612 2025-01-04 08:58:58.984 - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry' Require stack: - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js - /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js [...] 2025-01-04 08:59:02.406 - info: host.UBU14 instance system.adapter.javascript.0 in version "8.8.3" started with pid 45642 2025-01-04 08:59:03.326 - error: Could not add plugins: Cannot find module '@iobroker/plugin-sentry' Require stack: - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/lib/PluginHandler.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/node_modules/@iobroker/plugin-base/index.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/index.js - /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js... und immer so weiter bei jedem einzelnen Adapter
@foxriver76
Irgendeine Idee dazu?
