    4. Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem
      Dschones last edited by
      Hallo - ich bin neu in der Materie und viele meiner Probleme wurden durch dieses Forum schon gelöst.
      Diesmal aber nicht - ich bekomme meinen neuen SONOFF Zigbee 3.0 USB Dongle Plus nicht im IO Broker zum laufen.
      es ist immer dieses Bild:
      hier der passende Log dazu:
      2025-01-03 12:49:26.125 - info: zigbee.0 (7400) Got terminate signal TERMINATE_YOURSELF
      2025-01-03 12:49:26.131 - info: zigbee.0 (7400) cleaned everything up...
      2025-01-03 12:49:26.134 - info: zigbee.0 (7400) Zigbee: disabling joining new devices.
      2025-01-03 12:49:26.142 - info: zigbee.0 (7400) terminating
      2025-01-03 12:49:26.144 - info: zigbee.0 (7400) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-01-03 12:49:26.217 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 send kill signal
      2025-01-03 12:49:26.717 - info: host.iobroker-pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-03 12:49:29.275 - info: host.iobroker-pi instance system.adapter.zigbee.0 started with pid 10642
      2025-01-03 12:49:33.967 - info: zigbee.0 (10642) starting. Version 1.10.13 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.20.5, js-controller: 4.0.23
      2025-01-03 12:49:34.077 - info: zigbee.0 (10642) delete old Backup files. keep only last 10
      2025-01-03 12:49:34.080 - info: zigbee.0 (10642) Starting Zigbee npm ...
      2025-01-03 12:49:34.863 - info: zigbee.0 (10642) Installed Version: iobroker.zigbee@1.10.13
      2025-01-03 12:49:55.119 - error: zigbee.0 (10642) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      2025-01-03 12:49:55.120 - error: zigbee.0 (10642) Failed to start Zigbee
      2025-01-03 12:49:55.121 - error: zigbee.0 (10642) Error herdsman start
      2025-01-03 12:50:05.125 - info: zigbee.0 (10642) Try to reconnect. 1 attempts left
      2025-01-03 12:50:05.126 - info: zigbee.0 (10642) Starting Zigbee npm ...
      2025-01-03 12:50:05.138 - info: zigbee.0 (10642) Installed Version: iobroker.zigbee@1.10.13
      2025-01-03 12:50:05.305 - error: zigbee.0 (10642) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
      2025-01-03 12:50:05.306 - error: zigbee.0 (10642) Failed to start Zigbee
      2025-01-03 12:50:05.307 - error: zigbee.0 (10642) Error herdsman start
      Die Einstellungen im Adapter sind die folgenden - ich haeb auch schon andere PAN ID's versucht , aber das Problem blieb das gleiche
      Was kann ich noch tun ? Der Zigbee - Adapter ist neu, mein raspberry pi 4 (4GB RAM; 64GB Speicher nahezu unbenutzt) ist aktuell
      Dnake für eure Hilfe !
      Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Dschones last edited by Thomas Braun
        @dschones sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
        Dann verwende als Neuling auch die aktuellen Versionen.
        node@20 und js-controller@7 sind das Stand heute.
        stimmt also nicht.
          Dschones @Thomas Braun last edited by
          Sorry, das war unpräzise - hier der Log mit dem Richtigen / Aktuellen Version, das Problem ist aber das gleiche...
          025-01-03 14:30:10.628 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 (force=false, process=true)
          2025-01-03 14:30:10.633 - info: zigbee.0 (16404) Got terminate signal TERMINATE_YOURSELF
          2025-01-03 14:30:10.636 - info: zigbee.0 (16404) cleaned everything up...
          2025-01-03 14:30:10.639 - info: zigbee.0 (16404) Zigbee: disabling joining new devices.
          2025-01-03 14:30:10.647 - info: zigbee.0 (16404) terminating
          2025-01-03 14:30:10.648 - info: zigbee.0 (16404) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-01-03 14:30:10.753 - info: host.iobroker-pi stopInstance system.adapter.zigbee.0 send kill signal
          2025-01-03 14:30:11.138 - info: zigbee.0 (16404) terminating
          2025-01-03 14:30:11.234 - info: host.iobroker-pi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-03 14:30:14.769 - info: host.iobroker-pi instance system.adapter.zigbee.0 in version "1.10.13" started with pid 22621
          2025-01-03 14:30:20.074 - info: zigbee.0 (22621) starting. Version 1.10.13 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
          2025-01-03 14:30:20.174 - info: zigbee.0 (22621) delete old Backup files. keep only last 10
          2025-01-03 14:30:20.176 - info: zigbee.0 (22621) Starting Zigbee npm ...
          2025-01-03 14:30:20.515 - info: zigbee.0 (22621) Installed Version: iobroker.zigbee@1.10.13
          2025-01-03 14:30:28.032 - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 22688
          2025-01-03 14:30:31.031 - info: daswetter.0 (22688) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
          2025-01-03 14:30:41.100 - error: zigbee.0 (22621) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
          2025-01-03 14:30:41.102 - error: zigbee.0 (22621) Failed to start Zigbee
          2025-01-03 14:30:41.104 - error: zigbee.0 (22621) Error herdsman start
          2025-01-03 14:30:45.914 - info: daswetter.0 (22688) still wrong data structure from server received! repaired...
          2025-01-03 14:30:49.914 - info: daswetter.0 (22688) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2025-01-03 14:30:50.431 - info: daswetter.0 (22688) cleaned everything up...
          2025-01-03 14:30:50.445 - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 22688 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-03 14:30:51.110 - info: zigbee.0 (22621) Try to reconnect. 1 attempts left
          2025-01-03 14:30:51.112 - info: zigbee.0 (22621) Starting Zigbee npm ...
          2025-01-03 14:30:51.124 - info: zigbee.0 (22621) Installed Version: iobroker.zigbee@1.10.13
          2025-01-03 14:30:51.278 - error: zigbee.0 (22621) Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
          2025-01-03 14:30:51.280 - error: zigbee.0 (22621) Failed to start Zigbee
          2025-01-03 14:30:51.280 - error: zigbee.0 (22621) Error herdsman start
          was mache ich falsch?
            Homoran Global Moderator Administrators @Dschones last edited by
            @dschones gib mal die Langversion von iob diag preis.
              Dschones @Homoran last edited by
              @homoran said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
              hmm ... das will irgendwie nicht - es kommt immer:
              *** iob diag is starting up, please wait ***
              iob diag needs to be updated. Please execute 'iobroker fix' first.
              Führe ich iobroker fix aus, so läuft folgendes durch, aber das Ergebnis ist das gleiche.
              pi@iobroker-pi:~ $ iobroker fix
              library: loaded
              Library version=2024-10-22
                  Welcome to the ioBroker installation fixer!
                  Script version: 2024-10-22
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              Get:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease [54.0 kB]
              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
              Err:1 http://deb.debian.org/debian bullseye-proposed-updates InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
              Reading package lists... Done
              W: GPG error: http://deb.debian.org/debian bullseye-proposed-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
              E: The repository 'http://deb.debian.org/debian bullseye-proposed-updates InRelease' is not signed.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
              Installed polkitd
                  Checking ioBroker user and directory permissions (2/5)
              Created /etc/sudoers.d/iobroker
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
              Authentication is required to stop 'iobroker.service'.
              Authenticating as: ,,, (pi)
              Password:
              ==== AUTHENTICATION COMPLETE ===
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              Homoran J 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @Dschones last edited by Homoran
                @dschones
                ist das ein Raspi?
                da braucht es im Moment eine Sonderbehandlung
                curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
                chmod 744 iob_diag.sh
                ./iob_diag.sh
                  Jaksa @Dschones last edited by
                  @dschones said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                  library: loaded
                  Installed polkitd
                  Done.
                  Password:
                  Autostart enabled!
                  Dein System ist alles nur nicht aktuell. Du hast da noch Debian Bullseye drauf laut den Paketquellen.
                  Mach die Karte platt, installiert Debian Bookworm und probiere es dann nochmal.
                  • Asgothian
                    Asgothian Developer @Dschones last edited by
                    Das ist auch nicht verwunderlich. Dem Adapter gelingt es nicht mit der Firmware auf dem Stick zu reden. Mögliche Ursachen:
                    • Störungen durch USB3 (in welchem Port steckt der Zigbee-Stick ? In einem der USB3 oder einem der USB2, mit oder ohne USB Verlängerung
                    • Defekte Firmware auf dem Stick - da wäre dann neu Flaschen angesagt
                    • falsche Auswahl der Firmware im Adapter. Welchen Sonoff Dongle hast du genau ?
                    A.
                    p.s. All dies ist unabhängig von der alten Software auf dem PI4. Ein Update macht sicher Sinn, hat aber mit diesem Problem wenig bis nichts zu tun.
                      Dschones @Asgothian last edited by
                      @asgothian said in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                      ohne USB-Verlängerung , ich habe auch schon andere USB-Ports versucht - gleiches Ergebnis
                      pi@iobroker-pi:~ $ ls -la /dev/serial/by-id/
                      total 0
                      drwxr-xr-x 2 root root 80 Jan  2 22:17 .
                      drwxr-xr-x 4 root root 80 Jan  2 22:17 ..
                      lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEH                                                    P-if00-port0 -> ../../ttyUSB0
                      lrwxrwxrwx 1 root root 13 Jan  2 22:17 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Pl                                                    us_902fb787e3e7ed119668d7770b2af5ab-if00-port0 -> ../../ttyUSB1
                      ok, das habe ich noch nicht in Betracht zu gezogen, das ding ist ja "frisch"
                      hast du da ne gute Anleitung ?
                      Hier:
                      A.
                      Das sehe ich ähnlich - Freunde von mir haben den Stick ebenfalls (auf noch viel älteren System) problemlos am laufen
                      Asgothian Codierknecht 2 Replies Last reply Reply Quote 0
                        Dschones @Homoran last edited by Dschones
                        da komme ich nicht weiter:
                        pi@iobroker-pi:~ $ curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.shchmod 744 iob_diag.sh./iob_diag.sh
                          % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                         Dload  Upload   Total   Spent    Left  Speed
                        100 42291  100 42291    0     0   581k      0 --:--:-- --:--:-- --:--:--  581k
                          0     0    0     0    0     0      0      0 --:--:--  0:02:09 --:--:--     0
                        curl: (28) Failed to connect to 744 port 80: Connection timed out
                          0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: iob_diag.sh.
                        • Asgothian
                          Bitte eine USB Verlängerung einsetzen, damit der Stick vom PI weg kommt - ich denke da gibt es Störungen aus dem USB3 Bereich. Nutzt Du ggf. eine SSD ?
                          A.
                            bitte die Befehle nicht verschmelzen
                              @asgothian
                              Usb- Verlängerung ist drin , Problem ist dasselbe
                                da tut sich leider nix
                                100 42291  100 42291    0     0   522k      0 --:--:-- --:--:-- --:--:--  522k
                                 0     0    0     0    0     0      0      0 --:--:--  0:00:24 --:--:--     0
                                 0     0    0     0    0     0      0      0 --:--:--  0:02:11 --:--:--     0
                                was mache ich falsch ?
                                Homoran Meister Mopper 2 Replies Last reply Reply Quote 0
                                  du hast immer noch 2 Befehle verschmolzen!
                                  sieh dir die drei einzelnen Befehle mal hier an
                                  @homoran sagte in Zigbee Sonoff lässt sich nicht aktivieren- Herdsman Problem:
                                  @dschones
                                  ist das ein Raspi?
                                  ./iob_diag.sh
                                  • Meister Mopper
                                    Meister Mopper @Dschones last edited by
                                    @dschones
                                    Du kannst das nicht einfach ins Clipboard kopieren und in der Konsole ausführen, denn es sind drei Befehle.
                                    Du kannst sie allerdings mit && verbinden und dann in der Konsole ausführen. Dann wird der nächste Befehl erst ausgeführt, wenn der vorherige abgeschlossen ist.
                                    z. B.
                                    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh && chmod 744 && iob_diag.sh && ./iob_diag.sh
                                      sorry - ich bin da noch etwas zu ungeübt und unerfahren
                                      hier das Ergebnis
                                                              v.2024-12-09 Raspbian+zigbee diag+masking
                                         Static hostname: iobroker-pi
                                               Icon name: computer
                                                  Kernel: Linux 6.1.21-v7l+
                                            Architecture: arm
                                      Kernel:                 armv7l
                                      Userland:               32 bit
                                      User-ID:                1000
                                      Display-Server:         false
                                      Pending OS-Updates:     0
                                      Pending iob updates:    23
                                      Nodejs-Installation:
                                      /usr/bin/nodejs         v20.18.1
                                      /usr/bin/node           v20.18.1
                                      /usr/bin/corepack       0.29.4
                                      Recommended versions are nodejs 20.18.1 and npm 10.8.2
                                      nodeJS installation is correct
                                      MEMORY:
                                      Mem:            3.9G        1.1G        2.1G        0.0K        697M        2.6G
                                      Swap:            99M          0B         99M
                                      Total:          4.0G        1.1G        2.2G
                                      Active iob-Instances:   18
                                      Upgrade policy: none
                                      ioBroker Core:          js-controller           7.0.6
                                                              admin                   7.1.5
                                      Objects type: jsonl
                                      States  type: jsonl
                                      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                        system.adapter.web.0                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                9605
                                      States:                 8668
                                      Size of iob-Database:
                                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                                      2.8M    /opt/iobroker/iobroker-data/states.jsonl
                                      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                        hier das Ergebnis
                                        das ist leider nur das Summary!
                                        bitte die Langfassung, die kommt vorher.
                                        • Meister Mopper
                                          Bevor weitere geriatrische Analysen durchgeführt werden, solltest du nach meiner Meinung auf bookworm wechseln und zwar in der minimalen 64Bit-Version.
                                          Hast du aktuelle, funktionierende Backups mit dem backitup-Adapter außerhalb des ioBroker gesichert?
                                            Script v.2024-12-09 Raspbian+zigbee diag+masking
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm
                                            OS is similar to: debian
                                            Model           : Raspberry Pi 4 Model B Rev 1.5
                                            Docker          : false
                                            Virtualization  : none
                                            Kernel          : armv7l
                                            Userland        : 32 bit
                                            Systemuptime and Load:
                                             16:56:37 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
                                            CPU threads: 4
                                            *** LIFE CYCLE STATUS ***
                                            *** RASPBERRY THROTTLING ***
                                            Current issues:
                                            Previously detected issues:
                                            *** TIME AND TIMEZONES ***
                                                           Local time: Sat 2025-01-11 16:56:38 CET
                                                       Universal time: Sat 2025-01-11 15:56:38 UTC
                                                             RTC time: Sat 2025-01-11 15:56:38
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            *** Users and Groups ***
                                            User that called 'iob diag':
                                            pi
                                            HOME=/home/pi
                                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                            iobroker
                                            HOME=/home/iobroker
                                            *** DISPLAY-SERVER SETUP ***
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            3.9G        1.1G        1.8G        0.0K        982M        2.6G
                                            Swap:            99M          0B         99M
                                            Total:          4.0G        1.1G        1.9G
                                                     3887 M total memory
                                                     1106 M used memory
                                                      464 M active memory
                                                     1500 M inactive memory
                                                     1799 M free memory
                                                      113 M buffer memory
                                                      868 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            top - 16:56:38 up 8 days, 18:38,  1 user,  load average: 0.65, 0.41, 0.25
                                            Tasks: 190 total,   1 running, 189 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s):  0.0 us,  3.0 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :   3887.9 total,   1799.4 free,   1105.6 used,    982.9 buff/cache
                                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2641.8 avail Mem
                                            *** FAILED SERVICES ***
                                            0 loaded units listed.
                                            *** DMESG CRITICAL ERRORS ***
                                            No critical errors detected
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       58G  7.2G   49G  13% /
                                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                            tmpfs          tmpfs     778M  876K  777M   1% /run
                                            /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                                            tmpfs          tmpfs     389M     0  389M   0% /run/user/1000
                                            Show mounted filesystems:
                                            TARGET  SOURCE         FSTYPE OPTIONS
                                            /       /dev/mmcblk0p2 ext4   rw,noatime
                                            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                            /var:
                                            du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
                                            3.3G    /var/
                                            1.9G    /var/log
                                            1.8G    /var/log/journal/834f3657738944fca3e7840589ae9346
                                            755M    /var/cache
                                            Archived and active journals take up 1.7G in the file system.
                                            /opt/iobroker/backups:
                                            402M    /opt/iobroker/backups/
                                            /opt/iobroker/iobroker-data:
                                            198M    /opt/iobroker/iobroker-data/
                                            132M    /opt/iobroker/iobroker-data/files
                                            49M     /opt/iobroker/iobroker-data/backup-objects
                                            48M     /opt/iobroker/iobroker-data/files/javascript.admin
                                            32M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                            12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
                                            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                                            6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
                                            6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
                                            USB-Devices by-id:
                                            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
                                            /dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEHP-if00-port0
                                            *** ZigBee Settings ***
                                            HINT:
                                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                            zigbee.X
                                            Extended Pan ID:
                                            *** MASKED ***
                                            Pan ID:
                                            *** MASKED ***
                                            Channel:
                                            *** MASKED ***
                                            Network Key:
                                            *** MASKED ***
                                            *** NodeJS-Installation ***
                                            nodejs:
                                              Installed: 20.18.1-1nodesource1
                                              Candidate: 20.18.1-1nodesource1
                                              Version table:
                                             *** 20.18.1-1nodesource1 1001
                                                    500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                                    100 /var/lib/dpkg/status
                                                 20.18.0-1nodesource1 1001
                                                 20.17.0-1nodesource1 1001
                                                 20.16.0-1nodesource1 1001
                                                 20.15.1-1nodesource1 1001
                                                 20.15.0-1nodesource1 1001
                                                 20.14.0-1nodesource1 1001
                                                 20.13.1-1nodesource1 1001
                                                 20.13.0-1nodesource1 1001
                                                 20.12.2-1nodesource1 1001
                                                 20.12.1-1nodesource1 1001
                                                 20.12.0-1nodesource1 1001
                                                 20.11.1-1nodesource1 1001
                                                 20.11.0-1nodesource1 1001
                                                 20.10.0-1nodesource1 1001
                                                 20.9.0-1nodesource1 1001
                                                 20.8.1-1nodesource1 1001
                                                 20.8.0-1nodesource1 1001
                                                 20.7.0-1nodesource1 1001
                                                 20.6.1-1nodesource1 1001
                                                 20.6.0-1nodesource1 1001
                                                 20.5.1-1nodesource1 1001
                                                 20.5.0-1nodesource1 1001
                                                 20.4.0-1nodesource1 1001
                                                 20.3.1-1nodesource1 1001
                                                 20.3.0-1nodesource1 1001
                                                 20.2.0-1nodesource1 1001
                                                 20.1.0-1nodesource1 1001
                                                 20.0.0-1nodesource1 1001
                                                 12.22.12~dfsg-1~deb11u5 500
                                            No problems detected
                                            Errors in npm tree: 0
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Hosts:
                                            iobroker-pi         iobroker-pi (version: 7.0.6, hostname: iobroker-pi   , alive, uptime: 673253)
                                            Core adapters versions
                                            admin:          7.1.5
                                            javascript:     6.0.3
                                            Adapter State
                                            + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
                                              system.adapter.daswetter.0              : daswetter             : iobroker-pi                              -  enabled
                                              system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
                                            + system.adapter.fronius.0                : fronius               : iobroker-pi                              -  enabled
                                              system.adapter.history.0                : history               : iobroker-pi                              -  enabled
                                            + system.adapter.hm-rega.1                : hm-rega               : iobroker-pi                              -  enabled
                                            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pi                              -  enabled, port: 0
                                            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pi                              -  enabled, port: 18701
                                            + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
                                              system.adapter.modbus.0                 : modbus                : iobroker-pi                              - disabled
                                            + system.adapter.mqtt-client.0            : mqtt-client           : iobroker-pi                              -  enabled, port: 1883
                                            + system.adapter.ping.0                   : ping                  : iobroker-pi                              -  enabled
                                            + system.adapter.rpi2.0                   : rpi2                  : iobroker-pi                              -  enabled
                                              system.adapter.sayit.0                  : sayit                 : iobroker-pi                              -  enabled
                                            + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
                                            + system.adapter.smartmeter.0             : smartmeter            : iobroker-pi                              -  enabled
                                            + system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              -  enabled, port: 1883, bind: 0.0.0.0
                                            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-pi                              -  enabled
                                            + system.adapter.terminal.0               : terminal              : iobroker-pi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                            + system.adapter.velux.0                  : velux                 : iobroker-pi                              -  enabled
                                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              -  enabled
                                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              -  enabled
                                              system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
                                            + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_902fb787e3e7ed119668d7770b2af5ab-if00-port0
                                            + instance is alive
                                            ioBroker-Repositories
                                            Active repo(s): stable
                                            Installed ioBroker-Instances
                                            Used repository: stable
                                            Adapter    "admin"        : 7.4.10   , installed 7.1.5  [Updatable]
                                            Adapter    "backitup"     : 3.0.31   , installed 2.4.12 [Updatable]
                                            Adapter    "daswetter"    : 3.2.2    , installed 3.1.3  [Updatable]
                                            Adapter    "discovery"    : 5.0.0    , installed 3.0.5  [Updatable]
                                            Adapter    "fronius"      : 2.1.1    , installed 2.0.2  [Updatable]
                                            Adapter    "history"      : 3.0.1    , installed 2.2.0  [Updatable]
                                            Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                                            Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.12 [Updatable]
                                            Adapter    "javascript"   : 8.8.3    , installed 6.0.3  [Updatable]
                                            Controller "js-controller": 7.0.6    , installed 7.0.6
                                            Adapter    "modbus"       : 6.3.2    , installed 5.0.11 [Updatable]
                                            Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                            Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                            Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                                            Adapter    "rpi2"         : 2.2.1    , installed 1.3.2  [Updatable]
                                            Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
                                            Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
                                            Adapter    "simple-api"   : 2.8.0    , installed 2.7.1  [Updatable]
                                            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                            Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                                            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                            Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                                            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                            Adapter    "velux"        : 0.0.8    , installed 0.0.7  [Updatable]
                                            Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
                                            Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                                            Adapter    "web"          : 6.2.5    , installed 4.3.0  [Updatable]
                                            Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                                            Adapter    "zigbee"       : 1.10.14  , installed 1.10.13 [Updatable]
                                            Objects and States
                                            Objects:        9605
                                            States:         8668
                                            Pending Updates: 0
                                            *** Listening Ports ***
                                            tcp        0      0 192.168.178.50:18701    0.0.0.0:*               LISTEN      1001       1161594    6723/io.hm-rpc.1
                                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1264871    20308/io.sonoff.0
                                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1160161    6800/io.shelly.0
                                            tcp        0      0 192.168.178.50:2010     0.0.0.0:*               LISTEN      1001       1159103    6518/io.hm-rpc.0
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16436      968/sshd: /usr/sbin
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1158040    6374/iobroker.js-co
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1158045    6374/iobroker.js-co
                                            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14656      1013/dnsmasq
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1160707    6397/io.admin.0
                                            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       1161918    7217/io.terminal.0
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          16438      968/sshd: /usr/sbin
                                            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14655      1013/dnsmasq
                                            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14652      1013/dnsmasq
                                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12249      808/dhclient
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11089      406/avahi-daemon: r
                                            udp        0      0 0.0.0.0:38251           0.0.0.0:*                           108        11091      406/avahi-daemon: r
                                            udp6       0      0 :::5353                 :::*                                108        11090      406/avahi-daemon: r
                                            udp6       0      0 :::35121                :::*                                108        11092      406/avahi-daemon: r
                                            2025-01-11 16:13:12.167  - info: host.iobroker-pi instance system.adapter.velux.0 in version "0.0.7" started with pid 31891
                                            2025-01-11 16:13:14.688  - info: velux.0 (31891) starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.velux, node: v20.18.1, js-controller: 7.0.6
                                            2025-01-11 16:13:14.999  - error: velux.0 (31891) null
                                            2025-01-11 16:13:15.004  - error: velux.0 (31891) Login was not successful
                                            2025-01-11 16:15:54.022  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 32127
                                            2025-01-11 16:15:56.927  - info: daswetter.0 (32127) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                            2025-01-11 16:16:11.263  - info: daswetter.0 (32127) still wrong data structure from server received! repaired...
                                            2025-01-11 16:16:15.476  - info: daswetter.0 (32127) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                            2025-01-11 16:16:15.997  - info: daswetter.0 (32127) cleaned everything up...
                                            2025-01-11 16:16:16.015  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 32127 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2025-01-11 16:30:54.025  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 899
                                            2025-01-11 16:30:56.939  - info: daswetter.0 (899) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                            2025-01-11 16:31:11.118  - info: daswetter.0 (899) still wrong data structure from server received! repaired...
                                            2025-01-11 16:31:15.240  - info: daswetter.0 (899) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                            2025-01-11 16:31:15.755  - info: daswetter.0 (899) cleaned everything up...
                                            2025-01-11 16:31:15.772  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 899 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2025-01-11 16:45:54.020  - info: host.iobroker-pi instance system.adapter.daswetter.0 in version "3.1.3" started with pid 3933
                                            2025-01-11 16:45:56.966  - info: daswetter.0 (3933) starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.1, js-controller: 7.0.6
                                            2025-01-11 16:46:11.024  - info: daswetter.0 (3933) still wrong data structure from server received! repaired...
                                            2025-01-11 16:46:15.423  - info: daswetter.0 (3933) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                            2025-01-11 16:46:15.941  - info: daswetter.0 (3933) cleaned everything up...
                                            2025-01-11 16:46:15.958  - info: host.iobroker-pi instance system.adapter.daswetter.0 having pid 3933 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            2025-01-11 16:51:25.964  - info: admin.0 (6397) Request actual repository...
                                            2025-01-11 16:51:26.593  - info: host.iobroker-pi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                            2025-01-11 16:51:31.666  - info: admin.0 (6397) Repository received successfully.
                                            1859
