    4. Syntax Error seit Stromausfall
      markphilip last edited by
      seit heute Mittag kurz der Strom weg war bekomme ich meinen Iobroker nicht mehr ans laufen.
      Zugriff per Console habe ich hier die Ausgabe von Iobroker diag
                              v.2024-10-19
       Static hostname: IoBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-23-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.11.1-0-g0551a4be2c-prebuilt.qemu-project.org
      Installation:           kvm
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     0
      file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
      import tar from 'tar';
      SyntaxError: The requested module 'tar' does not provide an export named 'default'
          at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
          at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
          at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
      Node.js v20.18.1
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      nodeJS installation is correct
      MEMORY:
      Mem:            3.1G        371M        325M        712K        2.6G        2.7G
      Swap:           3.2G         21M        3.2G
      Total:          6.3G        392M        3.5G
      Active iob-Instances:   0
      Node.js v20.18.1
      Node.js v20.18.1
      ioBroker Core:          js-controller
      Node.js v20.18.1
                              admin
      Node.js v20.18.1
      ioBroker Status:
      Objects:                0
      States:                 0
      Size of iob-Database:
      15M     /opt/iobroker/iobroker-data/objects.jsonl
      11M     /opt/iobroker/iobroker-data/objects.json.migrated
      11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      8.0K    /opt/iobroker/iobroker-data/states.json.bak
      Operating System is the current Debian stable version codenamed 'bookworm'!
      === Mark text until here for copying ===
      wendy2702 Meister Mopper ? 3 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @markphilip last edited by
        @markphilip erster Versuch wäre das:
        iobroker stop
        iobroker fix
        iobroker restart
        • Meister Mopper
          Meister Mopper @markphilip last edited by
          @markphilip
          Zeig bitte mal die Langfassung.
            markphilip @Meister Mopper last edited by
            @meister-mopper
            Script v.2024-10-19
            *** BASE SYSTEM ***
                     Chassis: vm 🖴
              Virtualization: kvm
            OS is similar to:
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
            CPU threads: 2
            *** LIFE CYCLE STATUS ***
            *** TIME AND TIMEZONES ***
                           Local time: Sat 2025-01-04 18:33:40 CET
                       Universal time: Sat 2025-01-04 17:33:40 UTC
                             RTC time: Sat 2025-01-04 17:33:40
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            mark
            HOME=/home/mark
            GROUPS=mark cdrom floppy sudo audio dip video plugdev netdev iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.1G        346M        344M        704K        2.6G        2.8G
            Swap:           3.2G         21M        3.2G
            Total:          6.3G        367M        3.5G
                     2972 M total memory
                      330 M used memory
                      638 M active memory
                     1496 M inactive memory
                      328 M free memory
                      163 M buffer memory
                     2337 M swap cache
                     3069 M total swap
                       20 M used swap
                     3049 M free swap
            top - 18:33:40 up  5:09,  3 users,  load average: 0.08, 0.09, 0.09
            Tasks:  95 total,   1 running,  94 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   2972.2 total,    328.1 free,    330.8 used,   2501.4 buff/cache
            MiB Swap:   3070.0 total,   3049.6 free,     20.4 used.   2641.4 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  1.5G     0  1.5G   0% /dev
            tmpfs          tmpfs     298M  556K  297M   1% /run
            /dev/sda1      ext4       29G   20G  7.9G  71% /
            tmpfs          tmpfs     1.5G     0  1.5G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     298M     0  298M   0% /run/user/1000
            [Sat Jan  4 13:23:55 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Jan  4 13:23:56 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            979M    /var/
            542M    /var/log
            516M    /var/log/journal/c4e4bfe1d7c94199919f017b537b1ac0
            235M    /var/cache
            Archived and active journals take up 38.8M in the file system.
            /opt/iobroker/backups:
            115M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.6G    /opt/iobroker/iobroker-data/
            1.4G    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            nodejs:
              Installed: 20.18.1-1nodesource1
              Candidate: 20.18.1-1nodesource1
              Version table:
             *** 20.18.1-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian stable/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security stable-security/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Node.js v20.18.1
            Hosts:
            Node.js v20.18.1
            Core adapters versions
            Node.js v20.18.1
            js-controller:
            Node.js v20.18.1
            admin:
            Node.js v20.18.1
            javascript:
            nodejs modules from github:     1
            |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
            Adapter State
            ioBroker-Repositories
            Node.js v20.18.1
            Installed ioBroker-Instances
            Node.js v20.18.1
            Objects and States
            Objects:        0
            States:         0
            Hit:1 http://security.debian.org/debian-security stable-security InRelease
            Hit:2 http://deb.debian.org/debian stable InRelease
            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15654      515/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12762      1/systemd
            tcp        0      0 0.0.0.0:9418            0.0.0.0:*               LISTEN      110        103270     23071/git-daemon
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          103234     22998/exim4
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        15827      476/redis-server 12
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15664      515/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          12768      1/systemd
            tcp6       0      0 :::80                   :::*                    LISTEN      0          102711     22610/apache2
            tcp6       0      0 :::9418                 :::*                    LISTEN      110        103271     23071/git-daemon
            tcp6       0      0 ::1:6379                :::*                    LISTEN      108        15828      476/redis-server 12
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          103235     22998/exim4
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           107        15554      465/avahi-daemon: r
            udp        0      0 0.0.0.0:36253           0.0.0.0:*                           107        15556      465/avahi-daemon: r
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14024      349/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12765      1/systemd
            udp6       0      0 :::56189                :::*                                107        15557      465/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                107        15555      465/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          12771      1/systemd
            2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) exit, all done
            2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) timer killed
            2025-01-04 12:46:02.255  - debug: daswetter.0 (3742622) Plugin sentry destroyed
            2025-01-04 12:46:02.255  - info: daswetter.0 (3742622) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-01-04 12:46:02.760  - info: daswetter.0 (3742622) cleaned everything up...
            2025-01-04 12:46:02.768  - info: host.IoBroker instance system.adapter.daswetter.0 having pid 3742622 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-01-04 12:48:46.617  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2025-01-04 12:48:46.622  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
            2025-01-04 12:48:46.625  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at processImmediate (node:internal/timers:483:21)
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350) You are assigning a number to the state "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.<anonymous> (script.js.Meine_Geräte.Photovoltaik.Verfügbare_Leistung:3:3)
            2025-01-04 12:48:46.626  - warn: javascript.0 (1458350)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
            2025-01-04 12:48:46.641  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
            2025-01-04 12:48:46.642  - info: javascript.0 (1458350) State value to set for "Meine_Geräte.0.Photovoltaik.VerfügbareLeistung" has to be type "string" but received type "number"
            2025-01-04 12:49:02.295  - error: hm-rpc.1 (1458491) Cannot call listDevices: socket hang up
            2025-01-04 12:49:04.231  - info: sonoff.0 (1458585) Client [Absaugung] connection closed: closed
              markphilip @wendy2702 last edited by
              @wendy2702
              iobroker fixer läuft durch ändert allerdings nichts. Der Fehler bleibt der gleiche.
              Der Syntax Fehler erscheint auch wenn ich Versuche JS Controller neu zu installieren.
              wendy2702 Homoran 2 Replies Last reply Reply Quote 0
              • wendy2702
                wendy2702 @markphilip last edited by wendy2702
                @markphilip Dann zeige uns deinen Versuch den JS Controller neu zu installieren mal als log komplett mit ein und Ausgabe der Konsole
                  markphilip @wendy2702 last edited by markphilip
                  @wendy2702 Ich hoffe das ist so richtig
                  mark@IoBroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                  npm warn skipping integrity check for git dependency ssh://git@github.com/klein0r/ioBroker.comfoairq.git
                  npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                  npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                  npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                  npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                  npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                  npm warn deprecated @humanwhocodes/config-array@0.13.0: Use @eslint/config-array instead
                  npm warn deprecated har-validator@5.1.5: this library is no longer supported
                  npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                  npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                  npm warn deprecated @humanwhocodes/object-schema@2.0.3: Use @eslint/object-schema instead
                  npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                  npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                  npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                  npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                  npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                  npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                  npm warn deprecated gauge@4.0.4: This package is no longer supported.
                  npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm warn deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                  npm warn deprecated sinon@15.2.0: 16.1.1
                  npm warn deprecated eslint@8.57.1: This version is no longer supported. Please see https://eslint.org/version-support for other options.
                  npm error code 1
                  npm error path /opt/iobroker/node_modules/iobroker.js-controller
                  npm error command failed
                  npm error command sh -c node iobroker.js setup first
                  npm error file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5
                  npm error import tar from 'tar';
                  npm error        ^^^
                  npm error SyntaxError: The requested module 'tar' does not provide an export named 'default'
                  npm error     at ModuleJob._instantiate (node:internal/modules/esm/module_job:146:21)
                  npm error     at async ModuleJob.run (node:internal/modules/esm/module_job:229:5)
                  npm error     at async ModuleLoader.import (node:internal/modules/esm/loader:473:24)
                  npm error
                  npm error Node.js v20.18.1
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
                  mark@IoBroker:/opt/iobroker$ /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log
                  -bash: /home/iobroker/.npm/_logs/2025-01-04T17_51_36_141Z-debug-0.log: Keine Berechtigung
                  mikeal created this issue in request/request
                  open Request’s Past, Present and Future #3142
                  Qix- created this issue in visionmedia/debug
                  closed ReDos Vulnerability Regression Visibility Notice #797
                  • wendy2702
                    Hm,
                    Fällt mir auf die schnelle nichts zu ein.
                    Vielleicht hat @Thomas-Braun eine Idee.
                      Homoran Global Moderator Administrators @markphilip last edited by
                      @markphilip sagte in Syntax Error seit Stromausfall:
                      welcher Syntaxfehler?
                        markphilip @Homoran last edited by Homoran
                        @homoran hi oben im ersten Post im Code:
                          Homoran Global Moderator Administrators @markphilip last edited by Homoran
                          @markphilip
                          Achso, im iob diag.
                          Hatte ich mir gar nicht angesehen weil nur Summary.
                          laut letztem debug-log ist da noch einiges mehr kaputt, und diese Meldung wohl nur eine Folge davon
                            @homoran ok eine Idee was ich machen kann oder soll ich das System einmal neu aufsetzen?
                              leider nein, das ist weit über meinen skills.
                              das würde ich jetzt machen, aber vielleicht hat @thomas-braun eine Idee, oder gar Lust das zu fixen, wenn möglich.
                                A Former User @markphilip last edited by
                                @markphilip
                                da das ne VM ist, wuerd ich einfach das letzte Backup der VM wieder einspielen.
                                Da hats was in deinem System geschossen.. hoffentlich ist nicht die Platte im Eimer.. hast du noch mehr VM's laufen?
                                  @ALLE
                                  liest doch mal ALLE das diag richtig
                                  Objects:                0
                                  States:                 0
                                  da ist NIX an objekten und states.. was soll dann da laufen
                                  @markphilip
                                  hoffe du hast ein backup.. sonst schaumal in den iobroker-data ordner da sollte eine objects.bak und eine states.bak liegen.. und die sollten grösser sein als die entsprechenden jsonl's
                                  sonst hilft dir nur backup zurück
                                  wendy2702 1 Reply Last reply Reply Quote 1
                                  • wendy2702
                                    wendy2702 @arteck last edited by
                                    @arteck soll das jetzt die Erklärung für den Syntax Fehler sein oder was?
                                      A Former User @wendy2702 last edited by
                                      @wendy2702
                                      Schlechte Laune? Geh mal an die Luft... 🙂
                                      Wenn du weiter liest, siehst du, was passiert ist und warum das so ist.
                                      • wendy2702
                                        wendy2702 @Guest last edited by
                                        @ilovegym keine schlechte Laune.
                                        Hätte es nur gerne vernünftig erklärt wenn man schon schreibt wir würden alle nicht richtig lesen.
                                        Vor allem warum es beim Versuch den Controller neu zu installieren immer noch zum Syntax Fehler kommt.
                                          @wendy2702
                                          Nehme an, dass es das Dateisystem zerrissen hat..
                                          das kann uns aber auch nur der TE erklären..
                                          Vielleicht war auch schon vorher was krumm und jetzt ist es endgültig durch…
                                            Homoran Global Moderator Administrators @Guest last edited by
                                            @ilovegym sagte in Syntax Error seit Stromausfall:
                                            ich auch
                                            Deswegen war meine Meinung
                                            @homoran sagte in Syntax Error seit Stromausfall:
                                            1259
