    4. [gelöst] Hohe Schreibaktivitäten am iobroker
      m.schalk last edited by m.schalk
      ich habe seit 31.12.2024 hohe Schreibaktivitäten am iobroker System. Wo kann man nachschauen welcher Dienst dafür verantworlich ist?
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: BU02SMART02-iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
      Operating System: Ubuntu 24.04.1 LTS
                Kernel: Linux 6.8.12-2-pve
          Architecture: x86-64
      OS is similar to: debian
      model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       15:53:40 up 20:52,  4 users,  load average: 7.82, 5.97, 4.87
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Ubuntu LTS release codenamed 'noble'!
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-01-05 15:53:40 CET
                 Universal time: Sun 2025-01-05 14:53:40 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mario
      HOME=/home/mario
      GROUPS=mario sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.6G        3.9G        3.3G         98K        1.3G        4.7G
      Swap:           8.1G        1.0G        7.1G
      Total:           16G        5.0G         10G
      Active iob-Instances:   37
               8192 M total memory
               3756 M used memory
               3016 M active memory
               1715 M inactive memory
               3162 M free memory
                  0 M buffer memory
               1273 M swap cache
               7759 M total swap
                966 M used swap
               6793 M free swap
      top - 15:53:41 up 20:52,  4 users,  load average: 7.75, 5.99, 4.88
      Tasks:  77 total,   6 running,  70 sleeping,   0 stopped,   1 zombie
      %Cpu(s): 50.0 us, 42.0 sy,  0.0 ni,  4.0 id,  0.0 wa,  0.0 hi,  4.0 si,  0.0 st
      MiB Mem :   8192.0 total,   3159.7 free,   3759.1 used,   1273.3 buff/cache
      MiB Swap:   7760.0 total,   6793.4 free,    966.6 used.   4432.9 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * apparmor.service loaded failed failed Load AppArmor profiles
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--566--disk--0 ext4    40G   26G   12G  69% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs  3.1G  188K  3.1G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs  1.6G  8.0K  1.6G   1% /run/user/1001
      [Thu Dec 26 02:01:32 2024] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Thu Dec 26 02:01:33 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Thu Dec 26 02:01:34 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Thu Dec 26 02:08:09 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Thu Dec 26 02:08:10 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Thu Dec 26 02:08:11 2024] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 01:31:22 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Fri Dec 27 01:31:22 2024] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Fri Dec 27 01:40:11 2024] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Fri Dec 27 02:01:37 2024] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Fri Dec 27 02:01:37 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Fri Dec 27 02:01:39 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 02:08:26 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Fri Dec 27 02:08:28 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Fri Dec 27 02:08:28 2024] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 01:31:38 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sat Dec 28 01:31:38 2024] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Sat Dec 28 01:41:16 2024] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Sat Dec 28 02:01:52 2024] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Sat Dec 28 02:01:52 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sat Dec 28 02:01:53 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 02:08:14 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sat Dec 28 02:08:16 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sat Dec 28 02:08:16 2024] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 01:31:57 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Dec 29 01:31:57 2024] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Sun Dec 29 01:41:25 2024] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Sun Dec 29 02:01:46 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Dec 29 02:01:46 2024] EXT4-fs (dm-22): mounted filesystem 0b201620-47d9-424a-98f7-0eef827b7602 ro without journal. Quota mode: none.
      [Sun Dec 29 02:16:09 2024] EXT4-fs (dm-22): unmounting filesystem 0b201620-47d9-424a-98f7-0eef827b7602.
      [Sun Dec 29 02:16:23 2024] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Sun Dec 29 02:16:23 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sun Dec 29 02:16:24 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 02:23:16 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sun Dec 29 02:23:18 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 02:23:18 2024] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Sun Dec 29 03:02:06 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Dec 29 03:02:06 2024] EXT4-fs (dm-22): mounted filesystem 97e4bf13-aa6a-490a-9084-0ef966e27059 ro without journal. Quota mode: none.
      [Sun Dec 29 03:04:30 2024] EXT4-fs (dm-22): unmounting filesystem 97e4bf13-aa6a-490a-9084-0ef966e27059.
      [Sun Dec 29 03:04:31 2024] EXT4-fs (dm-22): mounted filesystem ae35cdaa-1a62-4b98-a296-ba8f12f56ddf ro without journal. Quota mode: none.
      [Sun Dec 29 03:05:37 2024] EXT4-fs (dm-22): unmounting filesystem ae35cdaa-1a62-4b98-a296-ba8f12f56ddf.
      [Sun Dec 29 03:05:38 2024] EXT4-fs (dm-22): mounted filesystem f869841f-36e0-4558-9733-9c048981acb7 ro without journal. Quota mode: none.
      [Sun Dec 29 03:06:52 2024] EXT4-fs (dm-22): unmounting filesystem f869841f-36e0-4558-9733-9c048981acb7.
      [Sun Dec 29 03:06:53 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Dec 29 03:06:53 2024] EXT4-fs (dm-22): mounted filesystem 4d085891-c3dd-4cfa-befe-7a06a81ff97f ro without journal. Quota mode: none.
      [Sun Dec 29 03:07:32 2024] EXT4-fs (dm-22): unmounting filesystem 4d085891-c3dd-4cfa-befe-7a06a81ff97f.
      [Mon Dec 30 01:32:08 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Mon Dec 30 01:32:08 2024] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Mon Dec 30 01:41:17 2024] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Mon Dec 30 02:02:18 2024] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Mon Dec 30 02:02:18 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Mon Dec 30 02:02:19 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Mon Dec 30 02:08:37 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Mon Dec 30 02:08:39 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Mon Dec 30 02:08:39 2024] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Tue Dec 31 01:32:25 2024] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Tue Dec 31 01:32:25 2024] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Tue Dec 31 01:43:48 2024] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Tue Dec 31 02:02:38 2024] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Tue Dec 31 02:02:39 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Tue Dec 31 02:02:40 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Tue Dec 31 02:08:43 2024] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Tue Dec 31 02:08:45 2024] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Tue Dec 31 02:08:45 2024] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Wed Jan  1 01:32:29 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Wed Jan  1 01:32:29 2025] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Wed Jan  1 01:40:23 2025] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Wed Jan  1 02:02:42 2025] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Wed Jan  1 02:02:42 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Wed Jan  1 02:02:43 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Wed Jan  1 02:08:22 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Wed Jan  1 02:08:24 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Wed Jan  1 02:08:24 2025] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Thu Jan  2 01:32:42 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Thu Jan  2 01:32:42 2025] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Thu Jan  2 01:41:22 2025] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Thu Jan  2 02:03:01 2025] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Thu Jan  2 02:03:01 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Thu Jan  2 02:03:02 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Thu Jan  2 02:09:09 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Thu Jan  2 02:09:11 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Thu Jan  2 02:09:11 2025] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Fri Jan  3 01:32:52 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Fri Jan  3 01:32:52 2025] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Fri Jan  3 01:41:09 2025] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Fri Jan  3 02:03:13 2025] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Fri Jan  3 02:03:14 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Fri Jan  3 02:03:14 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Fri Jan  3 02:09:02 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Fri Jan  3 02:09:03 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Fri Jan  3 02:09:03 2025] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Sat Jan  4 01:33:12 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sat Jan  4 01:33:12 2025] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Sat Jan  4 01:42:19 2025] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Sat Jan  4 02:03:26 2025] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Sat Jan  4 02:03:26 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sat Jan  4 02:03:27 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sat Jan  4 02:09:30 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sat Jan  4 02:09:32 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sat Jan  4 02:09:32 2025] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Sat Jan  4 18:26:48 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sat Jan  4 18:26:48 2025] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Sat Jan  4 18:36:46 2025] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Sat Jan  4 19:04:10 2025] EXT4-fs (dm-20): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Sat Jan  4 19:04:12 2025] EXT4-fs (dm-20): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 r/w with ordered data mode. Quota mode: none.
      [Sun Jan  5 01:33:14 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Jan  5 01:33:14 2025] EXT4-fs (dm-22): mounted filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9 ro without journal. Quota mode: none.
      [Sun Jan  5 01:41:36 2025] EXT4-fs (dm-22): unmounting filesystem 74b0caa6-c920-47dd-a380-8fcf95cbc8d9.
      [Sun Jan  5 02:03:16 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Jan  5 02:03:16 2025] EXT4-fs (dm-22): mounted filesystem 0b201620-47d9-424a-98f7-0eef827b7602 ro without journal. Quota mode: none.
      [Sun Jan  5 02:20:06 2025] EXT4-fs (dm-22): unmounting filesystem 0b201620-47d9-424a-98f7-0eef827b7602.
      [Sun Jan  5 02:20:21 2025] EXT4-fs (dm-17): unmounting filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6.
      [Sun Jan  5 02:20:21 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sun Jan  5 02:20:22 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sun Jan  5 02:26:26 2025] EXT4-fs (dm-16): unmounting filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49.
      [Sun Jan  5 02:26:28 2025] EXT4-fs (dm-16): mounted filesystem 0ff95afb-f745-4aa4-a51f-d73f68adef49 r/w with ordered data mode. Quota mode: none.
      [Sun Jan  5 02:26:28 2025] EXT4-fs (dm-17): mounted filesystem 54635ccf-accc-4c8b-bfcb-843eb62defd6 r/w with ordered data mode. Quota mode: none.
      [Sun Jan  5 03:03:17 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Jan  5 03:03:17 2025] EXT4-fs (dm-22): mounted filesystem 97e4bf13-aa6a-490a-9084-0ef966e27059 ro without journal. Quota mode: none.
      [Sun Jan  5 03:05:38 2025] EXT4-fs (dm-22): unmounting filesystem 97e4bf13-aa6a-490a-9084-0ef966e27059.
      [Sun Jan  5 03:05:39 2025] EXT4-fs (dm-22): mounted filesystem ae35cdaa-1a62-4b98-a296-ba8f12f56ddf ro without journal. Quota mode: none.
      [Sun Jan  5 03:06:50 2025] EXT4-fs (dm-22): unmounting filesystem ae35cdaa-1a62-4b98-a296-ba8f12f56ddf.
      [Sun Jan  5 03:06:51 2025] EXT4-fs (dm-22): mounted filesystem f869841f-36e0-4558-9733-9c048981acb7 ro without journal. Quota mode: none.
      [Sun Jan  5 03:07:47 2025] EXT4-fs (dm-22): unmounting filesystem f869841f-36e0-4558-9733-9c048981acb7.
      [Sun Jan  5 03:07:48 2025] EXT4-fs (dm-22): write access unavailable, skipping orphan cleanup
      [Sun Jan  5 03:07:48 2025] EXT4-fs (dm-22): mounted filesystem 4d085891-c3dd-4cfa-befe-7a06a81ff97f ro without journal. Quota mode: none.
      [Sun Jan  5 03:08:20 2025] EXT4-fs (dm-22): unmounting filesystem 4d085891-c3dd-4cfa-befe-7a06a81ff97f.
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--566--disk--0 ext4   rw,relatime,stripe=16
      /var:
      5.5G    /var/
      4.0G    /var/log/journal/a4cc250a83fe4944adccd8462a307fa7
      4.0G    /var/log
      792M    /var/lib
      Archived and active journals take up 51.5M in the file system.
      /opt/iobroker/backups:
      777M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      9.9G    /opt/iobroker/iobroker-data/
      7.4G    /opt/iobroker/iobroker-data/history
      1.4G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      98M     /opt/iobroker/iobroker-data/objects.json.migrated
      98M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      71M     /opt/iobroker/iobroker-data/objects.jsonl
      43M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.c9e0f545.js.map
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d653ffa49dc9eb11ade6914f1d69213e-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 100
              100 /var/lib/dpkg/status
           18.19.1+dfsg-6ubuntu5 500
              500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Hosts:
      BU02SMART02-iobroker BU02SMART02-iobroker (version: 7.0.6, hostname: BU02SMART02-iobroker, alive, uptime: 75155)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.2.6
      javascript:     8.8.3
      nodejs modules from github:     1
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      Adapter State
      + system.adapter.admin.0                  : admin                 : BU02SMART02-iobroker                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : BU02SMART02-iobroker                     -  enabled
      + system.adapter.alexa2.0                 : alexa2                : BU02SMART02-iobroker                     -  enabled
        system.adapter.bosesoundtouch.0         : bosesoundtouch        : BU02SMART02-iobroker                     - disabled
      + system.adapter.daikin.0                 : daikin                : BU02SMART02-iobroker                     -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : BU02SMART02-iobroker                     -  enabled
      + system.adapter.device-watcher.1         : device-watcher        : BU02SMART02-iobroker                     -  enabled
      + system.adapter.discovery.0              : discovery             : BU02SMART02-iobroker                     -  enabled
        system.adapter.dwd.0                    : dwd                   : BU02SMART02-iobroker                     -  enabled
        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : BU02SMART02-iobroker                     - disabled
      + system.adapter.ems-esp.0                : ems-esp               : BU02SMART02-iobroker                     -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : BU02SMART02-iobroker                     -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : BU02SMART02-iobroker                     -  enabled
        system.adapter.feiertage.0              : feiertage             : BU02SMART02-iobroker                     -  enabled
        system.adapter.flot.0                   : flot                  : BU02SMART02-iobroker                     -  enabled
      + system.adapter.followthesun.0           : followthesun          : BU02SMART02-iobroker                     -  enabled
      + system.adapter.hass-mqtt.0              : hass-mqtt             : BU02SMART02-iobroker                     -  enabled
      + system.adapter.history.0                : history               : BU02SMART02-iobroker                     -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : BU02SMART02-iobroker                     -  enabled
        system.adapter.ical.0                   : ical                  : BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: BU02SMART02-iobroker                     -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : BU02SMART02-iobroker                     -  enabled
      + system.adapter.influxdb.0               : influxdb              : BU02SMART02-iobroker                     -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : BU02SMART02-iobroker                     -  enabled
      + system.adapter.javascript.0             : javascript            : BU02SMART02-iobroker                     -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : BU02SMART02-iobroker                     -  enabled
        system.adapter.material.0               : material              : BU02SMART02-iobroker                     -  enabled
        system.adapter.mercedesme.0             : mercedesme            : BU02SMART02-iobroker                     - disabled
        system.adapter.mqtt-client.0            : mqtt-client           : BU02SMART02-iobroker                     - disabled, port: 1892
      + system.adapter.mqtt.0                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : BU02SMART02-iobroker                     -  enabled, port: 1891, bind: 192.168.2.166
      + system.adapter.net-tools.0              : net-tools             : BU02SMART02-iobroker                     -  enabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : BU02SMART02-iobroker                     -  enabled
        system.adapter.openweathermap.0         : openweathermap        : BU02SMART02-iobroker                     -  enabled
      + system.adapter.ping.0                   : ping                  : BU02SMART02-iobroker                     -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : BU02SMART02-iobroker                     -  enabled
        system.adapter.ring.0                   : ring                  : BU02SMART02-iobroker                     - disabled
      + system.adapter.samsung.0                : samsung               : BU02SMART02-iobroker                     -  enabled
      + system.adapter.shelly.0                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : BU02SMART02-iobroker                     -  enabled, port: 1890, bind: 192.168.2.166
      + system.adapter.slideshow.0              : slideshow             : BU02SMART02-iobroker                     -  enabled
      + system.adapter.smartthings.0            : smartthings           : BU02SMART02-iobroker                     -  enabled
        system.adapter.socketio.0               : socketio              : BU02SMART02-iobroker                     - disabled, port: 8084, bind: 192.168.2.166, run as: admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : BU02SMART02-iobroker                     -  enabled
      + system.adapter.telegram.0               : telegram              : BU02SMART02-iobroker                     -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : BU02SMART02-iobroker                     -  enabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-2.0                  : vis-2                 : BU02SMART02-iobroker                     - disabled
        system.adapter.vis-bars.0               : vis-bars              : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-history.0            : vis-history           : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-homekittiles.0       : vis-homekittiles      : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : BU02SMART02-iobroker                     -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-material.0           : vis-material          : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis-weather.0            : vis-weather           : BU02SMART02-iobroker                     -  enabled
        system.adapter.vis.0                    : vis                   : BU02SMART02-iobroker                     -  enabled
        system.adapter.vw-connect.0             : vw-connect            : BU02SMART02-iobroker                     - disabled
      + system.adapter.web.0                    : web                   : BU02SMART02-iobroker                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : BU02SMART02-iobroker                     -  enabled
        system.adapter.yahka.1                  : yahka                 : BU02SMART02-iobroker                     - disabled
      + system.adapter.zigbee.0                 : zigbee                : BU02SMART02-iobroker                     -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Instances
      Adapter    "admin"        : 7.1.5    , installed 7.2.6
      Adapter    "alarm"        : 3.6.7    , installed 3.6.4  [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.7
      Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
      Adapter    "ems-esp"      : 5.0.6    , installed 5.1.1
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.1  [Updatable]
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.5.1    , installed 0.5.1
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "iot"          : 3.3.0    , installed 3.4.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "megaesp"      : 0.1.0    , installed 0.1.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 2.1.0    , installed 2.0.0  [Updatable]
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "ping"         : 1.6.2    , installed 1.7.9
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "ring"         : 6.3.0    , installed 6.2.1  [Updatable]
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "shelly"       : 8.2.1    , installed 8.5.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "virtualpowermeter": 1.5.0, installed 1.4.6  [Updatable]
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.1
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-homekittiles": 0.3.2 , installed 0.3.1  [Updatable]
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "web"          : 6.2.5    , installed 6.3.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.9
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.3 [Updatable]
      Objects and States
      Objects:        40799
      States:         37909
      Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
      Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu noble-updates InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          151268540  424/master
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       151270643  441/iobroker.js-con
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        151267750  215/systemd-resolve
      tcp        0      0 127.0.0.1:38239         0.0.0.0:*               LISTEN      1000       151280948  932/io.yahka.0
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      106        151267752  215/systemd-resolve
      tcp        0      0 127.0.0.1:6011          0.0.0.0:*               LISTEN      1001       160612688  166587/sshd: mario@
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      113        151267862  241/redis-server 12
      tcp        0      0 192.168.2.166:1890      0.0.0.0:*               LISTEN      1000       156039839  80889/io.shelly.1
      tcp        0      0 192.168.2.166:1891      0.0.0.0:*               LISTEN      1000       151276441  805/io.mqtt.1
      tcp        0      0 127.0.0.1:39377         0.0.0.0:*               LISTEN      1000       159206900  932/io.yahka.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       151276165  790/io.mqtt.0
      tcp        0      0 0.0.0.0:42501           0.0.0.0:*               LISTEN      1000       151284998  932/io.yahka.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          151266620  1/init
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       151298150  1438/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       151271024  476/io.admin.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      113        151267863  241/redis-server 12
      tcp6       0      0 ::1:6011                :::*                    LISTEN      1001       160612687  166587/sshd: mario@
      tcp6       0      0 :::3000                 :::*                    LISTEN      112        151269730  246/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          151267763  1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          151266621  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          151268541  424/master
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       151285003  932/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       151285002  932/io.yahka.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       151292381  900/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       151298055  917/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       151298056  917/io.tuya.0
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           106        151267751  215/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        151267749  215/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          151264210  1/init
      udp        0      0 0.0.0.0:41660           0.0.0.0:*                           1000       151292383  900/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          151264215  1/init
      2025-01-05 13:59:17.781  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:00:18.311  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:04:20.584  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:05:21.337  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:09:22.910  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:27:30.382  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:28:30.782  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:30:31.987  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:33:33.360  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:39:36.044  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:46:39.160  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 14:54:44.000  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:02:47.300  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:04:48.157  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:12:52.483  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:17:54.589  - error: daikin.0 (696) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:33:36.140  - info: vis.0 (160203) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.1, js-controller: 7.0.6
      2025-01-05 15:33:39.545  - info: vis.0 (160203) Changes in index.html detected => update cache.manifest
      2025-01-05 15:33:39.568  - info: vis.0 (160203) Upload vis anew, while changes detected...
      2025-01-05 15:33:47.680  - warn: host.BU02SMART02-iobroker instance system.adapter.vis.0 already running with pid 160203
      2025-01-05 15:34:12.046  - info: vis.0 (160203) Uploaded. 0
      2025-01-05 15:34:12.549  - info: vis.0 (160203) Terminated (NO_ERROR): Without reason
      2025-01-05 15:38:05.650  - error: daikin.0 (160290) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:48:11.175  - error: daikin.0 (160290) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
      2025-01-05 15:49:11.692  - error: daikin.0 (160290) Error updating data: Error occured: Error while communicating with Daikin device: ECONNRESET
                              v.2024-10-19
        Virtualization: lxc
      Installation:           lxc
      User-ID:                1001
      Pending OS-Updates:     0
      Pending iob updates:    7
      Nodejs-Installation:
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.6G        4.0G        3.3G         98K        1.3G        4.6G
      Total:           16G        5.0G         10G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.2.6
      Objects type: jsonl
      States  type: redis
      Objects:                40799
      States:                 37909
      Size of iob-Database:
      28M     /opt/iobroker/iobroker-data/states.jsonl
      Meister Mopper Feuersturm 2 Replies Last reply Reply Quote 0
      • Meister Mopper
        Meister Mopper @m.schalk last edited by
        @m-schalk
        Was zeigt dir top? Da kann man vielleicht sehen, was da rödelt.
        • Feuersturm
          Feuersturm @m.schalk last edited by
          @m-schalk du hast viele Meldungen zum Thema
          Ich kann dir leider nicht sagen, was die Meldungen als Ursache haben.
          Dein history Ordner ist 7 GB groß und auch das var/log vom Betriebssystem ist mit 4gb sehr groß.
          Deaktiviere Mal den history adapter und schau wie sich das System verhält. Prüfe auch deine Datenpunkte was du in welchem Intervall loggst.
          Wo liegt die influx Datenbank? Auf dem gleichen system?
            m.schalk @Feuersturm last edited by
            @feuersturm said in Hohe Schreibaktivitäten am iobroker:
            Die Influx liegt wo anders, den History Adapter räume ich mal auf, allederings hat es bisher keinen Einfluß auf die Schreibtätigkeit.
            Sonst noch Ideen?
            • Meister Mopper
              @m-schalk sagte in Hohe Schreibaktivitäten am iobroker:
              Sonst noch Ideen?
              Wie auch, hast ja das Ergebnis von top noch immer nicht gezeigt.
                m.schalk @Meister Mopper last edited by m.schalk
                @meister-mopper said in Hohe Schreibaktivitäten am iobroker:
                Sonst noch Ideen?
                Hallo Meister-mopper, anbei der TOP Auszug.
                top - 08:05:43 up 13:06,  1 user,  load average: 7.72, 4.88, 3.53
                    Tasks:  60 total,   1 running,  59 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 30.9 us, 12.8 sy,  0.0 ni, 50.3 id,  4.7 wa,  0.0 hi,  1.3 si,  0.0 st
                    MiB Mem :   8192.0 total,   3783.4 free,   3773.8 used,    634.9 buff/cache
                    MiB Swap:   7760.0 total,   7227.8 free,    532.2 used.   4418.2 avail Mem
                        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                       1226 iobroker  20   0   21.4g 220468  46848 S  15.9   2.6 133:56.97 io.web.0
                        808 iobroker  20   0   21.1g 159384  50048 S  10.6   1.9 157:09.64 io.shelly.0
                        426 iobroker  20   0   21.6g 474444  50816 D   8.6   5.7 205:08.63 iobroker.js-con
                        235 redis     20   0  939884 187004   9344 S   6.3   2.2  68:53.92 redis-server
                      77999 iobroker  20   0   21.1g 143324  50432 S   5.3   1.7   7:09.31 io.shelly.1
                        535 iobroker  20   0   21.3g 414704  50048 S   3.0   4.9  38:42.61 io.javascript.0
                        500 iobroker  20   0   21.1g 141500  45312 S   2.7   1.7  28:42.33 io.influxdb.0
                        474 iobroker  20   0   21.0g  95884  44672 S   2.3   1.1  24:34.54 io.history.0
                        844 iobroker  20   0   21.3g 147084  51456 S   1.0   1.8   1:09.11 io.tuya.0
                        696 iobroker  20   0   21.0g  92612  44800 S   0.7   1.1   1:46.87 io.mqtt.0
                        232 grafana   20   0 1621988  75456  23680 S   0.3   0.9   1:12.34 grafana
                        614 iobroker  20   0   21.0g  96740  49792 S   0.3   1.2   3:11.49 io.device-watch
                        860 iobroker  20   0   21.0g 107276  45440 S   0.3   1.3   3:08.22 io.yahka.0
                        936 iobroker  20   0   21.0g  81820  44928 S   0.3   1.0   2:57.40 io.energiefluss
                        958 iobroker  20   0   21.0g  77588  44800 S   0.3   0.9   2:02.99 io.energiefluss
                       1011 iobroker  20   0   21.1g 100212  46080 S   0.3   1.2   0:24.12 io.iot.0
                       1031 iobroker  20   0   21.1g 122148  51200 S   0.3   1.5   4:12.21 io.linkeddevice
                       1096 iobroker  20   0   21.2g  89032  46592 S   0.3   1.1   0:49.04 io.slideshow.0
                       1136 iobroker  20   0   21.0g  91580  43904 S   0.3   1.1  12:17.99 io.sourceanalyt
                      99840 mario     20   0    8940   5248   3200 R   0.3   0.1   0:00.03 top
                          1 root      20   0   21500  12160   9088 S   0.0   0.1   0:00.68 systemd
                         49 root      19  -1   83788  25192  23920 S   0.0   0.3   0:12.12 systemd-journal
                         99 systemd+  20   0   18852   7296   7040 S   0.0   0.1   0:00.12 systemd-network
                        132 _rpc      20   0    7968   3712   3456 S   0.0   0.0   0:00.05 rpcbind
                        136 systemd+  20   0   21456  11520   9984 S   0.0   0.1   0:00.30 systemd-resolve
                        229 root      20   0    3808   2176   2048 S   0.0   0.0   0:00.10 cron
                        230 message+  20   0    9532   4864   4480 S   0.0   0.1   0:00.06 dbus-daemon
                        233 root      20   0   29416   5504   5248 S   0.0   0.1   0:00.24 networkd-dispat
                        240 root      20   0   17880   8064   7552 S   0.0   0.1   0:00.15 systemd-logind
                        244 root      20   0    2732   1536   1536 S   0.0   0.0   0:00.00 agetty
                        245 root      20   0    6956   4412   3840 S   0.0   0.1   0:00.11 login
                        254 root      20   0    2732   1664   1664 S   0.0   0.0   0:00.00 agetty
                        267 syslog    20   0  222508   4736   3840 S   0.0   0.1   0:02.54 rsyslogd
                        412 root      20   0   42856   4500   4224 S   0.0   0.1   0:00.16 master
                        414 postfix   20   0   43344   7424   6912 S   0.0   0.1   0:00.03 qmgr
                        458 iobroker  20   0   21.4g 243488  51456 S   0.0   2.9   5:42.57 io.admin.0
                        565 iobroker  20   0   21.0g  84344  50176 S   0.0   1.0   0:19.61 io.alarm.0
                • Meister Mopper
                  @m-schalk
                  Keine Ahnung, was da los ist.
                  CPU ist gemäß den dargestellten Prozessen nicht großartig belastet, allerdings zeigt der load etwas anderes.
                    mading last edited by
                    Ich hatte auch Probleme, bei mir lag es daran, dass zu oft Daten an influx geschickt wurden
                    • MartinP
                      MartinP @Meister Mopper last edited by MartinP
                      @meister-mopper es gibt ein linux tool namens "iotop" - da funktioniert aber in der Regel nicht in LXC-Containern.... aus der Hypervisor shell aber schon - da sieht man dann auch die Prozesse der Container
                      https://www.thomas-krenn.com/de/wiki/Linux_I/O_Performance_Messungen_mit_iotop
                      root@pve:~# iotop -o -b -n 1
                      Total DISK READ:         0.00 B/s | Total DISK WRITE:        34.93 K/s
                      Current DISK READ:       0.00 B/s | Current DISK WRITE:     104.80 K/s
                          TID  PRIO  USER     DISK READ  DISK WRITE  SWAPIN      IO    COMMAND
                      3903119 be/4 root        0.00 B/s   17.47 K/s ?unavailable?  dockerd -H fd:// --containerd=/run/containerd/containerd.sock
                      3904116 be/4 root        0.00 B/s   17.47 K/s ?unavailable?  node index.js
                        m.schalk @MartinP last edited by
                        @martinp said in Hohe Schreibaktivitäten am iobroker:
                        Hallo zusammen
                        hier mal die Auswertung, liegt am iobroker.js-controller dauerhaft über 3 M/s
                        Was tun?
                        Total DISK READ:         0.00 B/s | Total DISK WRITE:         5.98 M/s
                        Current DISK READ:       5.42 K/s | Current DISK WRITE:       6.12 M/s
                            TID  PRIO  USER     DISK READ DISK WRITE>    COMMAND
                           2717 be/4 1000        0.00 B/s    5.89 M/s iobroker.js-controller
                           8449 be/4 100108      0.00 B/s   24.37 K/s bin/mongod --dbpath /usr/lib/unifi/data/db --port 27117~id --wiredTigerEngineConfigString=cache_size=256M [ftdc]
                           2183 be/3 root        0.00 B/s   18.96 K/s [jbd2/dm-19-8]
                           4719 be/4 100000      0.00 B/s   10.83 K/s systemd-journald
                           9089 be/4 100999      0.00 B/s    8.12 K/s influxd
                           1104 be/4 root        0.00 B/s    5.42 K/s pmxcfs
                           1111 be/4 root        0.00 B/s    5.42 K/s pmxcfs
                           1953 be/4 root        0.00 B/s    5.42 K/s pmxcfs
                           1747 be/4 100998      0.00 B/s    2.71 K/s pihole-FTL -f
                           5284 be/4 100000      0.00 B/s    2.71 K/s nmbd --foreground --no-process-group
                        Feuersturm 1 Reply Last reply Reply Quote 0
                        • Feuersturm
                          @m-schalk schalte doch einmal sukzessive deine Instanzen alle ab. Z.b im ersten Schritt die ersten 50% und schaue ob sich etwas ändert. Den Javascript Adapter würde ich zuerst abschalten.
                          Was steht denn so im ioBroker log? Läuft eine Instanz im debug oder gar silly log level?
                            @feuersturm @meister-mopper @martinp
                            Danke für die Hilfestellung, ich habe den "Fehler" gefunden. In der Shelly Instanz hatte ich das "HTTP-Antworten speichern (zum Debuggen)" aktiviert, weil ich probleme hatte Shelly über ipsec zu abzufragen. Man sollte solchen Sachen nicht kurz vor Neujahr aktivieren. 🙂
                            MartinP Feuersturm 2 Replies Last reply Reply Quote 2
                            • MartinP
                              MartinP @m.schalk last edited by
                              ... nicht kurz vor Neujahr ...
                              @m-schalk Teile des Gedächtnisses mit Feuerzangenbowle gelöscht? 😉
                              • Feuersturm
                                @m-schalk Danke für die Rückmeldung. Bitte setze noch ein "[gelöst]" in den Titel von deinem ersten Beitrag, dann sieht man, das das Thema abgeschlossen ist.
                                443
