    4. Say IT Adapter Fehler Gyp
      csamaggi last edited by
      Ich musste leider meine Rechner mit IO neu machen und wollte eben auch den Sayit wieder installieren.
      Aber ich bekomme bei der Installation einen Fehler bzw mehre
      sayit.0	2017-10-06 18:51:40.215	info	All files uploaded
      sayit.0	2017-10-06 18:51:40.110	info	Upload announce mp3 files
      sayit.0	2017-10-06 18:51:40.108	info	Install process. Upload files and stop.
      sayit.0	2017-10-06 18:51:40.097	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.sayit, node: v6.11.4
      iobroker	2017-10-06 18:51:39.165	info	gyp ERR! not ok
      iobroker	2017-10-06 18:51:39.165	info	gyp ERR! node-gyp -v v3.4.0
      iobroker	2017-10-06 18:51:39.165	info	gyp ERR! node -v v6.11.4
      iobroker	2017-10-06 18:51:39.165	info	gyp ERR! cwd /opt/iobroker/node_modules/mdns
      iobroker	2017-10-06 18:51:39.165	info	System Linux 4.9.0-3-amd64gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker	2017-10-06 18:51:39.157	info	ERR!
      iobroker	2017-10-06 18:51:39.153	info
      iobroker	2017-10-06 18:51:39.152	info	gyp
      iobroker	2017-10-06 18:51:39.151	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      iobroker	2017-10-06 18:51:39.150	info	ERR! stack at ChildProcess.emit (events.js:191:7)
      iobroker	2017-10-06 18:51:39.148	info	gyp ERR! stack at emitTwo (events.js:106:13)gyp
      iobroker	2017-10-06 18:51:39.146	info	ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      iobroker	2017-10-06 18:51:39.145	info	stack Error: `make` failed with exit code: 2gyp
      iobroker	2017-10-06 18:51:39.144	info	ERR!
      iobroker	2017-10-06 18:51:39.143	info	gyp
      iobroker	2017-10-06 18:51:39.136	info
      iobroker	2017-10-06 18:51:39.136	info	build error
      iobroker	2017-10-06 18:51:39.135	info	ERR!
      iobroker	2017-10-06 18:51:39.132	info	gyp
      iobroker	2017-10-06 18:51:39.127	info	make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
      iobroker	2017-10-06 18:51:39.118	info	compilation terminated.
      iobroker	2017-10-06 18:51:39.118	info	^
      iobroker	2017-10-06 18:51:39.118	info	#include
      iobroker	2017-10-06 18:51:39.118	info	In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
      • lobomau
        lobomau last edited by
        Nur bei der Installation? Ist "normal"!
        Macht der Adapter danach was er soll?
