    4. VIS-2 JS Error in Widget ovarius. Keine Optionen an select
      trojanhector last edited by
      ich habe eine View erstellt, in der ein Widget (Vis-2 widget ovarious v0.1.9) u. a. 35 html select tags enthält. Diese selects sollen alle die gleichen Optionen enthalten. Und hier laufe ich in Javascript auf einen Fehler:
      Uncaught TypeError: select.add is not a function
      let selectid="cboRoom";
      let dp_roomsSelection = JSON.parse(dp["0_userdata.0.heatingControl.rooms"]);
      let dp_roomSelected = "0_userdata.0.heatingControl.Vis.SelectedRoom";
      let db_timeOptions = dp["0_userdata.0.heatingControl.Vis.OverrideHeatingTemperatur"];
      <script>
      let selectid="<%- selectid %>";
      let dp_roomSelected="<%- dp_roomSelected %>";
      window.writeDP<%- selectid %>=(el)=>{
          //debugger;
          if (el.selectedOptions[0].value) vis.setValue(dp_roomSelected,el.selectedOptions[0].value);
      </script>
      <select class="cbo cbo-10rem" id="<%- selectid %>" name="<%- selectid %>" size="1" onchange="javascript:writeDP<%- selectid %>(this)" >
      //debugger;
      for(let i = 0; i < dp_roomsSelection.length; i++){
      var el = dp_roomsSelection[i];
      <option value ="<%- el %>" <%- ((dp[dp_roomSelected] == el) ? "selected":"") %>><%- el %></option>
      </select>
      <%- dp["0_userdata.0.heatingControl.Vis.Profil"]; %>
      <script>
      db_timeOptions = <%- db_timeOptions %>;
      let options = db_timeOptions.map(function(val, ind){
      return $("<option></option>").val(val.id).html(val.name);
      //$('#0_userdata__0__heatingControl__Profile__1__Bad__1_Montag__1__Temperatur').append(options);
      console.log(options);
      var selects = document.getElementsByClassName('hc-vis-pr-temp');
      debugger;
      for( var i = 0; i < selects.length; i++ ) {
          db_timeOptions.forEach((element) => {
              let option = new Option(element.name, element.id)
              let select = selects[i];
              select.add(option, undefined);
      </script>
      Hat jemand eine Idee, was ich falsch mache, oder wie es anders geht?
      Node.js:v20.18.1
      NPM:10.8.2
      Javascript 8.8.3
      js-controller:7.0.6
      vis2 2.9.64
      JSON Widget 0.1.9
      mcm1957 OliverIO 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @trojanhector last edited by mcm1957
        --- deleted ---
        Der Beitrag war inhaltlich falsch.
        SORRY
        • OliverIO
          OliverIO @mcm1957 last edited by
          @mcm1957
          das ist leider nur teilweise korrekt.
          für ovarious stimmt das,
          aber nicht für vis2-widgets-ovarious
          • OliverIO
            OliverIO @trojanhector last edited by OliverIO
            @trojanhector
            wie entstehen den die elemente mit der css-klasse hc-vis-pr-temp ?
            existieren die zum zeitpunkt, wenn das javascript von JSONTemplate läuft dann schon?
            Aufgrund der Fehlermeldung würde ich vermuten, das das was da selektiert wurde kein Objekt vom Typ https://developer.mozilla.org/en-US/docs/Web/API/HTMLSelectElement/add ist
              trojanhector @OliverIO last edited by
              @oliverio
              Die lasse ich mir im Blockly zusammenbauen. Je nach ausgewähltem Raum vom einzelnen Select in der View ändern sich die IDs.
              • OliverIO
                @trojanhector hab gerade mein post erweitert
                gut wäre es das komplette konstrukt in einem erstellen zu lassen.
                für sowas ist die template engine des widgets prädestiniert
