    4. Installation
    5. pam_unix(su:auth): authentication failure
      Guten Tag zusammen,
      ich komm nicht mehr weiter.
      Alle bisherigen Beiträge, die ich zum Thema gefunden habe, helfen mir leider nicht weiter.
      User bei Installation: pi
      Alles aktuell, neueste Versionen.
      $ node -v --> v22.13.0
      $ iob version --> 7.0.6
      Der Service startet nicht richtig.
      an 08 14:36:20 pi5 systemd[1]: Started iobroker.service - ioBroker Server.
      Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.admin.0" for host "pi5"
      Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.backitup.0" for host "pi5"
      Jan 08 14:36:21 pi5 bash[1505]: host.pi5 check instance "system.adapter.discovery.0" for host "pi5"
      Jan 08 14:36:22 pi5 su[1541]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=root
      Jan 08 14:36:23 pi5 sudo[1559]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
      Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
      Jan 08 14:36:23 pi5 sudo[1559]: pam_unix(sudo:session): session closed for user root
      Jan 08 14:36:23 pi5 sudo[1564]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
      Jan 08 14:36:23 pi5 sudo[1564]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
      an 08 14:36:24 pi5 sudo[1564]: pam_unix(sudo:session): session closed for user root
      Jan 08 14:36:25 pi5 su[1541]: FAILED SU (to root) iobroker on none
      Jan 08 14:36:25 pi5 su[1575]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=root
      Jan 08 14:36:27 pi5 su[1575]: FAILED SU (to root) iobroker on none
      Jan 08 14:36:28 pi5 su[1592]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
      Jan 08 14:36:30 pi5 su[1592]: FAILED SU (to pi) iobroker on none
      Jan 08 14:36:31 pi5 su[1608]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
      Jan 08 14:36:33 pi5 su[1608]: FAILED SU (to pi) iobroker on none
      Jan 08 14:36:34 pi5 su[1609]: pam_unix(su:auth): authentication failure; logname= uid=1001 euid=0 tty= ruser=iobroker rhost=  user=pi
      $ iob info
      Platform       : linux
      os             : linux
      Architecture   : arm64
      CPUs           : 4
      Speed          : 2400 MHz
      Model          : Cortex-A76
      RAM            : 7.8 GB
      System uptime  : 02:46:11
      Node.js        : v22.13.0
      time           : 1736343814820
      timeOffset     : -60
      NPM            : 10.9.2
      adapters count : 554
      Disk size      : 468.9 GiB
      Disk free      : 451.1 GiB
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: pi5
             Icon name: computer
                Kernel: Linux 6.6.63-v8-16k+
          Architecture: arm64
      OS is similar to:
      Model		: Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       11:11:16 up 3 min,  4 users,  load average: 0.14, 0.06, 0.02
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-01-08 11:11:17 CET
                 Universal time: Wed 2025-01-08 10:11:17 UTC
                       RTC time: Wed 2025-01-08 10:11:16
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.5G        1.1G        6.3G         28M        1.1G        7.3G
      Swap:           536M          0B        536M
      Total:          9.0G        1.1G        6.9G
      Active iob-Instances: 	4
               8064 M total memory
               1065 M used memory
               1228 M active memory
                552 M inactive memory
               6034 M free memory
                 83 M buffer memory
                990 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 11:11:17 up 3 min,  4 users,  load average: 0.14, 0.06, 0.02
      Tasks: 237 total,   1 running, 236 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8064.2 total,   6033.3 free,   1067.0 used,   1073.5 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6997.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     807M  6.0M  801M   1% /run
      /dev/nvme0n1p2 ext4      469G   18G  428G   4% /
      tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/nvme0n1p1 vfat      510M   68M  443M  14% /boot/firmware
      tmpfs          tmpfs     807M  192K  807M   1% /run/user/1000
      [Wed Jan  8 11:08:03 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:9D:43:28 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=6a5f591c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Wed Jan  8 11:08:04 2025] EXT4-fs (nvme0n1p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
      [Wed Jan  8 11:08:04 2025] EXT4-fs (nvme0n1p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/nvme0n1p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.5G	/var/
      2.6G	/var/lib
      2.4G	/var/lib/caddy/
      Archived and active journals take up 180.6M in the file system.
      /opt/iobroker/backups:
      4.0K	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      192M	/opt/iobroker/iobroker-data/
      187M	/opt/iobroker/iobroker-data/files
      158M	/opt/iobroker/iobroker-data/files/admin.admin
      157M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      12M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      7.4M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
      7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
      7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
      7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v22.11.0
      /usr/bin/node 		v22.11.0
      /usr/bin/npm 		10.9.0
      /usr/bin/npx 		10.9.0
      /usr/bin/corepack 	0.29.4
      nodejs:
        Installed: 22.11.0-1nodesource1
        Candidate: 22.13.0-1nodesource1
        Version table:
           22.13.0-1nodesource1 500
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.12.0-1nodesource1 500
       *** 22.11.0-1nodesource1 500
              100 /var/lib/dpkg/status
           22.10.0-1nodesource1 500
           22.9.0-1nodesource1 500
           22.8.0-1nodesource1 500
           22.7.0-1nodesource1 500
           22.6.0-1nodesource1 500
           22.5.1-1nodesource1 500
           22.5.0-1nodesource1 500
           22.4.1-1nodesource1 500
           22.4.0-1nodesource1 500
           22.3.0-1nodesource1 500
           22.2.0-1nodesource1 500
           22.1.0-1nodesource1 500
           22.0.0-1nodesource1 500
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      pi5                 pi5 (version: 7.0.6, hostname: pi5           , alive, uptime: 181)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.4.10
      javascript: 	"javascript" not found
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : pi5                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : pi5                                      -  enabled
      + system.adapter.discovery.0              : discovery             : pi5                                      -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Objects and States
      Objects: 	141
      States: 	99
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Get:5 https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version InRelease [8266 B]
      Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
      Fetched 8266 B in 0s (18.1 kB/s)
      Reading package lists...
      Pending Updates: 25
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6067       740/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6952       741/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6957       741/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2046       765/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:2019          0.0.0.0:*               LISTEN      999        8432       989/caddy
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       9387       954/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6066       740/cupsd
      tcp6       0      0 :::30000                :::*                    LISTEN      1000       12297      1015/node
      tcp6       0      0 :::30001                :::*                    LISTEN      1000       9808       1016/node
      tcp6       0      0 :::9091                 :::*                    LISTEN      0          9645       1179/authelia
      tcp6       0      0 :::443                  :::*                    LISTEN      999        9461       989/caddy
      tcp6       0      0 :::22                   :::*                    LISTEN      0          2048       765/sshd: /usr/sbin
      tcp6       0      0 :::80                   :::*                    LISTEN      999        9463       989/caddy
      udp        0      0 0.0.0.0:36846           0.0.0.0:*                           104        1905       574/avahi-daemon: r
      udp        0      0 192.168.178.95:41504    0.0.0.0:*                           1000       8709       1016/node
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1903       574/avahi-daemon: r
      udp6       0      0 :::59895                :::*                                104        1906       574/avahi-daemon: r
      udp6       0      0 :::443                  :::*                                999        9462       989/caddy
      udp6       0      0 fe80::8790:86fb:544:546 :::*                                0          8534       642/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        1904       574/avahi-daemon: r
      2025-01-08 11:07:50.841  - info: host.pi5 instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2025-01-08 11:07:50.841  - info: host.pi5 All instances are stopped.
      2025-01-08 11:07:50.988  - info: host.pi5 terminated
      2025-01-08 11:08:07.000  - info: host.pi5 iobroker.js-controller version 7.0.6 js-controller starting
      2025-01-08 11:08:07.002  - info: host.pi5 Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-01-08 11:08:07.003  - info: host.pi5 hostname: pi5, node: v22.11.0
      2025-01-08 11:08:07.003  - info: host.pi5 ip addresses:
      2025-01-08 11:08:07.350  - info: host.pi5 connected to Objects and States
      2025-01-08 11:08:07.360  - info: host.pi5 added notifications configuration of host
      2025-01-08 11:08:07.473  - info: host.pi5 3 instances found
      2025-01-08 11:08:07.475  - info: host.pi5 starting 3 instances
      2025-01-08 11:08:07.637  - info: host.pi5 instance system.adapter.admin.0 in version "7.4.10" started with pid 954
      2025-01-08 11:08:08.530  - info: admin.0 (954) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v22.11.0, js-controller: 7.0.6
      2025-01-08 11:08:08.550  - info: admin.0 (954) requesting all objects
      2025-01-08 11:08:08.610  - warn: admin.0 (954) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
      2025-01-08 11:08:08.799  - info: admin.0 (954) received all objects
      2025-01-08 11:08:08.821  - warn: admin.0 (954) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
      2025-01-08 11:08:08.967  - info: admin.0 (954) socket.io server listening on port 8081
      2025-01-08 11:08:08.971  - info: admin.0 (954) http server listening on port 8081
      2025-01-08 11:08:08.971  - info: admin.0 (954) Use link "http://127.0.0.1:8081" to configure.
      2025-01-08 11:08:11.696  - info: host.pi5 instance system.adapter.backitup.0 in version "3.0.25" started with pid 1515
      2025-01-08 11:08:12.609  - info: backitup.0 (1515) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v22.11.0, js-controller: 7.0.6
      2025-01-08 11:08:12.646  - info: backitup.0 (1515) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-01-08 11:08:15.632  - info: host.pi5 instance system.adapter.discovery.0 in version "5.0.0" started with pid 1969
      2025-01-08 11:08:16.300  - info: discovery.0 (1969) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v22.11.0, js-controller: 7.0.6
        Homoran Global Moderator Administrators @Guest last edited by
        @blubby worum geht es hier?
        Da gibt es leider 0 Hintergrund!
        pam klingt nach Proxmox
        @blubby sagte in pam_unix(su:auth): authentication failure:
        zu neu!
        ist noch nicht für ioBroker empfohlen.
        Wie kommst du daran?
        mit dem Installer jedenfalls nicht.
          A Former User @Homoran last edited by A Former User
          Danke schonmal für dein Feedback.
          Node war schon auf dem System, für andere Services...
          AFAIK sollte das Problem nichts mit der Node Version zu tun haben. Es scheint ein Berechtigungsproblem zu geben.
          Der Service versucht hier als anderer (priviligierter) User zu agieren, mal als root, sonst als pi. Das scheitert aber leider aus mir unbekannten Gründen.
          Muss man hier irgendwie systemseitig noch Dinge wie su oder irgendwelche Gruppenberechtigungen für iobroker-User anlegen?
          EDIT: Proxmox läuft nicht. es ist ein Raspberry PI5, Raspbian 64bit
          EDIT2: und es geht hierum: Der Service startet nicht richtig.
            auf keinen Fall!
            das würde das gesamte Rechtegefüge von ioBroker aushebeln können.
            iob soll nie als root installiert oder gestartet werden, ebenso niemals iob...dosomething Befehle niemals mit sudo einleiten.
              Thomas Braun Most Active @Guest last edited by
              @blubby
              Zum testen:
              Als User mal
              sudo whoami
                A Former User @Thomas Braun last edited by
                @thomas-braun said in pam_unix(su:auth): authentication failure:
                sudo whoami
                ➜  ~ sudo whoami
                root
                ➜  ~ whoami
                pi
                  @blubby
                  Vollständige Ein- und Ausgaben inkl des LoginPrompts bitte
                    ich weiß deine Bemühungen zu schätzen, aber vollständiger wird's hier nicht...
                    Wenn du nach sudo whoami fragst und ich damit (s.o.) antworte.
                    LoginPrompt? von meiner SSH Sitzung oder was? nee, sorry.
                      Thomas Braun Most Active @Guest last edited by Thomas Braun
                      @blubby
                      Dann halt nicht...
                      Wenn du aber ein Thema mit den Usern und deren Rechten hast muss ich sehen, mit welchem User du da hantierst.
                        ich versteh halt nicht warum das login Prompt von Bedeutung sein soll. aber gut
                        ~ ssh pi@pi5
                        Linux pi5 6.6.63-v8-16k+ #1824 SMP PREEMPT Tue Dec  3 13:01:07 GMT 2024 aarch64
                        The programs included with the Debian GNU/Linux system are free software;
                        the exact distribution terms for each program are described in the
                        individual files in /usr/share/doc/*/copyright.
                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                        permitted by applicable law.
                        Last login: Wed Jan  8 14:30:58 2025 from 192.168.178.93
                          @blubby Das ist nicht das LogIn-Prompt...
                          Das LoginPrompt ist
                          user@host:~ $
                          Also die vollständige Eingabezeile.
                            ja dann noch mal sorry, aber wie oben schon beschrieben, vollständiger wird es nicht.
                            wenn es dir hilft, hänge ich einen Screenshot an. Aber bei mir zeigt es nun mal ➜ ~ an. Verkürzte Darstellung. Der user ist pi, der host ist pi5.
                            führe ich als user pi den Befehl sudo whoami aus, dann kommt als Ergebnis wie oben gepostet: root
                            hier noch mal:
                            ➜  ~ sudo whoami
                            root
                            ➜  ~ whoami
                            pi
                            Um was geht es hier bitte? Ob ich mich als root eingeloggt hab um das zu installieren? Nein, natürlich nicht. Ich kann ja lesen. Außerdem ist der root user beim Raspberry standardmäßig nicht für den ssh login aktiviert.
                              Ich kann ja lesen.
                              dann hast du ja auch sicherlich gekesen, dass man im prompt sieht, ob man im falschen Verzeichnis steht
                                Es geht darum, welcher user da nicht richtig über pam authentifiziert werden kann.
                                Mir ist das aber eigentlich auch zu blöde.
                                Bin dann raus, wenn du eh alles besser weißt.
                                  @Homoran
                                  und was ist das richtige / falsche Verzeichnis? von was? in welchem Kontext? Was hat bitte ein LoginPrompt oder ein Verzeichnis mit dem system.d service iobroker.service zu tun, der nicht sauber hoch fährt?
                                  Da fühle ich mich jetzt nicht wirklich ernst genommen.
                                    na das steht doch im log vom iobroker.service, siehe oben.
                                    Auf dem System gibts die User
                                    iobroker (vom Skript angelegt)
                                    pi (vom OS angelegt)
                                    root (ebenso)
                                    LOG
                                      @blubby
                                      Was ist denn bei dir im System noch alles modifiziert, wenn schon der prompt nicht vollständig ist?
                                      Thomas Braun ? 2 Replies Last reply Reply Quote 0
                                        @homoran sagte in pam_unix(su:auth): authentication failure:
                                        Das liegt am lokal verwendeten Terminal. Die Darstellung kann ja angepasst werden. Machen aber die meisten user nicht.
                                          Der Service wird aber gestartet:
                                            hier läuft einfach nur eine zsh. daher ist der Prompt modifiziert. https://ohmyz.sh/
                                            Ansonsten: ein Reverse Proxy (caddy), Authelia, eine statische Webseite, zwei Instanzen von VTT (nodeJS). das war es glaube ich.
                                            1.0k
                                            4442
