    2. English
    4. state value : needs integer instead of text
      ClaudeCoppens last edited by
      to read values of adapters in loxone I need to be able to read values. Loxone cannot read text, only values. E.g. with the LG-think adapter the state values are text, while the corresponding numbers are also available, but not via the state variable. So I am looking for a way to easily read those values via the rest API. Can anyone help with this ?
        MCU @ClaudeCoppens last edited by
        @claudecoppens Example
        on({ id: 'lg-thinq.device.state', change: 'any' }, function (obj) {
            let numValue;
            switch (obj.state.val) {
                case 'ON':
                    numValue = 1;
                    break;
                case 'OFF':
                    numValue = 0;
                    break;
                default:
                    numValue = -1; // or any default value
            setState('0_userdata.0.device.numericState', numValue); // Replace with your target state
        REST-API (simpleApi)
        GET http://<iobroker-ip>:8087/get/0_userdata.0.device.numericState
