    4. [gelöst] Problem mit Ansicht der Protokolle
      homecineplexx last edited by homecineplexx
      hallo
      ich hab an und für sich nichts an meiner ioBroker Installation geändert, aber wenn ich auf die "Protokolle" Seite geh, bekomm ich einen Error View:
      Access to fetch at 'https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F8.30.0' from origin 'http://192.168.1.8:8081' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.Fehler nachvollziehenAI
      sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F8.30.0:1
             Failed to load resource: net::ERR_FAILEDFehler nachvollziehenAI
      6Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was receivedFehler nachvollziehenAI
      :8081/#tab-objects:1 Access to fetch at 'https://sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7&sentry_client=sentry.javascript.browser%2F8.30.0' from origin 'http://192.168.1.8:8081' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.Fehler nachvollziehenAI
      socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399762660&name=admin' failed:
      (anonym) @ socket.io.js:140Fehler nachvollziehenAI
      socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399763885&name=admin' failed:
      socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399766885&name=admin' failed:
      socket.io.js:140 WebSocket connection to 'ws://192.168.1.8:8081/?sid=1736399770885&name=admin' failed:
      :8081/static/js/6552.0a447e18.chunk.js:1
             Failed to load resource: the server responded with a status of 404 (Not Found)Fehler nachvollziehenAI
      5056.9247882b.chunk.js:2 ChunkLoadError: Loading chunk 6552 failed.
      (error: http://192.168.1.8:8081/static/js/6552.0a447e18.chunk.js)
          at Object.j (main.1a310c87.js:1:14222)
          at main.1a310c87.js:1:1162
          at Array.reduce (<anonymous>)
          at Function.e (main.1a310c87.js:1:1140)
          at 4684.31dece60.chunk.js:1:1657648
          at P (4905.33747b16.chunk.js:2:3345)
          at xi (5096.3a6e8bdb.chunk.js:2:120729)
          at bs (5096.3a6e8bdb.chunk.js:2:109361)
          at vs (5096.3a6e8bdb.chunk.js:2:109289)
          at gs (5096.3a6e8bdb.chunk.js:2:109152)
          at is (5096.3a6e8bdb.chunk.js:2:106268)
          at Hl (5096.3a6e8bdb.chunk.js:2:46915)
          at 5096.3a6e8bdb.chunk.js:2:103865
      (anonym) @ 5056.9247882b.chunk.js:2Fehler nachvollziehenAI
      4684.f5525d8f.chunk.css:1
      was kann ich tun?
      Edit: Browsercache geleert und neu geladen...funktioniert wieder
