    4. Microcontroller
    5. Kegelstumpf Blockly in Berryscript Tasmota [gelöst]
      bishop last edited by bishop
      ich hätte gerne mein Blockly script auf den Esp32 ausgelagert.
        <variables>
          <variable id="`:H;H8V)NI74WMdws*,4">wert-23cm=0</variable>
          <variable id="*e!Qy+h)MO2flf!XL0It">hoehe_Tonne_bis_Sensor_in_cm</variable>
          <variable id="G-(dMY)T}f`7@c2malWY">Radius_oben_in_cm</variable>
          <variable id="HVLq_Zx{?_%{pb_NYC6.">Radius_unten_in_cm</variable>
          <variable id="kxN%n/_4vfYXY^W[9.VD">entfernung_invertiert</variable>
        </variables>
        <block type="comment" id="xbdQA]p:Rm0!77!u:Uzz" x="-63" y="424">
          <field name="COMMENT">Kegelstumpf Regentonne</field>
            <block type="comment" id="|YNADPJ5k[^ORlh6KlBz">
              <field name="COMMENT">Sensor misst bis 23cm</field>
                <block type="on" id="F~b*#|j@)ipdlQQopt$E">
                  <field name="OID">sonoff.0.pool_61_regentonne.SR04_Distance</field>
                    <block type="variables_set" id="$?pcIQ[ZklduDkx|)]ok">
                      <field name="VAR" id="`:H;H8V)NI74WMdws*,4">wert-23cm=0</field>
                        <block type="math_arithmetic" id="zK|Ksu)dA:3N/uHX8.x`">
                            <shadow type="math_number" id="(49.@XAbyvYM#sHmcwW9">
                              <field name="NUM">1</field>
                            <block type="on_source" id="~;N)F]CT5G1.sx{8mmm.">
                            <shadow type="math_number" id="B9a9r.S{_=SEleC]:ct]">
                              <field name="NUM">22</field>
                            <block type="math_number" id="j!7zc`XzAv(o=e7#~!Z4">
                              <field name="NUM">23</field>
                        <block type="variables_set" id=".iH{PRMOti%`!9C:,$a7">
                          <field name="VAR" id="*e!Qy+h)MO2flf!XL0It">hoehe_Tonne_bis_Sensor_in_cm</field>
                            <block type="math_number" id="^?UsQbV8@;@=QeWE_kR#">
                              <field name="NUM">140</field>
                            <block type="variables_set" id="Wci|;:wXY~@J`VW6G?hL">
                              <field name="VAR" id="G-(dMY)T}f`7@c2malWY">Radius_oben_in_cm</field>
                                <block type="math_number" id="wZz#666*ftqLP4kfX-;k">
                                  <field name="NUM">30</field>
                                <block type="variables_set" id="QyC*SpMyQA=D#ubNh6Dx">
                                  <field name="VAR" id="HVLq_Zx{?_%{pb_NYC6.">Radius_unten_in_cm</field>
                                    <block type="math_number" id="*%:nMl~*~r3lZchceG`/">
                                      <field name="NUM">25</field>
                                    <block type="timeouts_settimeout" id="Hx-?1TM^O.;}LVPXN#ho">
                                      <field name="DELAY">100</field>
                                      <field name="UNIT">ms</field>
                                        <block type="variables_set" id=":(iut~5QcavF29$`=1{L">
                                          <field name="VAR" id="kxN%n/_4vfYXY^W[9.VD">entfernung_invertiert</field>
                                            <block type="math_rndfixed" id="rQ`urI8G~mW*up[O}%a-">
                                              <field name="n">2</field>
                                              <value name="x">
                                                <shadow type="math_number" id="0TM5Vz5TwC3p%.E*NY4Q">
                                                  <field name="NUM">3.1234</field>
                                                <block type="math_arithmetic" id="1``s!BYJ{3S~_x^|TYH8">
                                                    <shadow type="math_number" id="v5PpsZu4PSyAx057^p^9">
                                                    <block type="variables_get" id="28jwSkT{!_W)Dw2AD:.z">
                                                    <shadow type="math_number" id="mj{c6)]{U{h|=8AoN-Y!">
                                                    <block type="variables_get" id="pR)8.rtSV}0RvZe2Q~U3">
                                            <block type="update" id="}8URLV|N@HzOUvJ=dgWM">
                                              <field name="OID">javascript.0.Regentonne.entfernung_invertiert</field>
                                                <block type="variables_get" id="$;z][[YW!l]9Np}hH5Q*">
                                                <block type="update" id="w=,FAsa)^dq!2`9Z|UZX">
                                                  <field name="OID">javascript.0.Regentonne.Wasserinhalt</field>
                                                    <block type="math_round" id="n:4L(^03@L;)WKDGKE?d">
                                                      <field name="OP">ROUND</field>
                                                      <value name="NUM">
                                                        <shadow type="math_number" id="5F8D1VUX]8%@[!I+U`KP">
                                                          <field name="NUM">3.1</field>
                                                        <block type="math_arithmetic" id="G:9I3$=qQ`lixEy`L#)8">
                                                          <field name="OP">DIVIDE</field>
                                                            <shadow type="math_number" id="8RB]xuYu[)(Hxz9T,h#]">
                                                            <block type="math_arithmetic" id="(8lz8X_0Yd/HYLs[*iI?" inline="false">
        <shadow type="math_number" id="q#+V35)]KK#{%)Hy(}K^">
        <block type="math_arithmetic" id="cQMs/PeTI:.u)RI.!4LG">
        <shadow type="math_number" id="`^E[57|rmC4$kCp6;T7l">
        <block type="math_arithmetic" id="RO_U/wVMG{$3R-[Z(9R@">
        <shadow type="math_number" id="z5MVmXmfh($[f+YQ8X)0">
        <block type="math_arithmetic" id="an)b`B$+-7oWrHKG2nV{">
        <shadow type="math_number" id="{x2%9pm8MD#oH!RmvkTS">
        <field name="NUM">150</field>
        <block type="variables_get" id="hIZn|]q?sSq06mfMXh2(">
        <shadow type="math_number" id="/{4m/d]]]d62w}G,vF0o">
        <block type="on_source" id="akt?UxuSJ$Tzttd4;.de">
        <shadow type="math_number" id="8TSK#8[Y^%/D|xoGin8W">
        <block type="math_constant" id="YAHz2L/9o?rW]S:!~9tG">
        <field name="CONSTANT">PI</field>
        <shadow type="math_number" id=":fdAXjfwZJ-YfHA)x.`H">
        <field name="NUM">3</field>
        <shadow type="math_number" id="dRp/LRm-wBuL~BJ/X[Hl">
        <block type="math_arithmetic" id="Axp!Zaz1YfHZO3c_%qq[" inline="false">
        <field name="OP">ADD</field>
        <shadow type="math_number" id="1:D(5[Ncv0U~Cn%1`D`t">
        <block type="math_arithmetic" id="=9UZ5%r4Nm@d|/{CTU(z" inline="false">
        <shadow type="math_number" id="z1J+Pb1N`=0zR.C%n],*">
        <block type="math_arithmetic" id="_h)Wn3vLrXP-E8WqfoGC">
        <shadow type="math_number" id="%1=s}F,x_Q9dUaQ+Im#r">
        <block type="variables_get" id="j/U;7F@C4#K_$ic_A7h-">
        <shadow type="math_number" id="B6aH,xuq-QHsC?}92,K$">
        <block type="variables_get" id="_H$0AsSI7#d*ziJfHZBa">
        <shadow type="math_number" id="fABi#19`C|Q-}F7d,+pH">
        <block type="math_arithmetic" id="fm$KD-n9|AU,Dn;Bdaof">
        <shadow type="math_number" id="Q#cQ_AM7#1XN61%/]oyV">
        <block type="variables_get" id="?-k51TG8Woy5}c/oo`yp">
        <shadow type="math_number" id="E0ow|#WNDvI%Y3%?0-KJ">
        <block type="variables_get" id="myVd3]C~JZK`?.I9r6Ac">
        <shadow type="math_number" id="V9JScxR=lN`K~1rn$[$y">
        <block type="math_arithmetic" id="nkEjUwifV:_jvgF0%Yga">
        <shadow type="math_number" id="J9I-31pLT_CR8~r**__k">
        <block type="variables_get" id=")-Aru@@Rw}6,DkD^-G7a">
        <shadow type="math_number" id="/UQ-JAZ5+Uu_hg+Ww2wI">
        <block type="variables_get" id="P2LR1`~mR)#HlZ[zX)|8">
                                                            <shadow type="math_number" id="qVyeSl:Gu)Q7dFJekEdn">
                                                              <field name="NUM">1000</field>
                                                    <block type="update" id="0B,m$6sq^-u!78mgYaR+">
                                                      <field name="OID">javascript.0.Regentonne.Füllmenge_in_Prozent</field>
                                                        <block type="math_round" id="D)#U]4czaPL0subb+wTA">
                                                          <value name="NUM">
                                                            <shadow type="math_number" id="x-:C@bh`WB+NYy~{k|VC">
                                                            <block type="math_arithmetic" id="~C7?buZDPnWI,?O)IA1@">
        <shadow type="math_number" id="mjU9uL)vyWKthB4*vFzB">
        <block type="math_arithmetic" id="Qh?#1$X7kEM673SB,}XJ">
        <shadow type="math_number" id="_hf9SH]1@k[{BEL)8cU%">
        <field name="NUM">100</field>
        <shadow type="math_number" id=")qi:Vc9rY.t^HEE~$|jp">
        <block type="variables_get" id="hY?MRbdqy=zO[s*JU|%f">
        <shadow type="math_number" id="3^^./Y-?5C?f??#8rz)o">
        <block type="variables_get" id="P{o2a}m+eae19f{A,SrZ">
      mit Blockly bekomme ich das hin aber dann hört es auchschon auf 🙂
      Kann mir jemand helfen das Blockly in Berry Script umzuwandeln?
      • Asgothian
        Asgothian Developer @bishop last edited by Asgothian
        @bishop sagte in Kegelstumpf Blockly in Berryscript Tasmota:
        Umwandeln kann ich dir das nicht, da ich BerryScript nicht kenne. Allerdings kannst Du dir den JS Code des Blockly's anzeigen lassen. ggf. gibt es dafür saubere Umsetzungsanleitungen. Zur Anzeige des JS diesen Button benutzen:
        Aufpassen musst du natürlich bei den ioBroker spezifischen Blöcken (Trigger, Timeout, Datenpunkte setzen, Datenpunkte löschen)
        A.
          bishop @Asgothian last edited by
          @asgothian
          danke für den Tip, hab aber leider nicht wirklich was gefunden um es um zu schreiben.
          Hier gibt es ein Script. Funktioniert auch nur wird da alles in inch und gallonen umgerechnet.
            peterfido @bishop last edited by
            @bishop Da sind mehrere Skripte hinterlegt. Das geeignete nehmen und umrechnen sollte gehen. 1 Inch sind 2,54 cm. 1 Gallone 4,55 Liter.
              bishop @peterfido last edited by bishop
              @peterfido
              Ja machts auch nur wie ändere ich das ab
              Inch weg und gal in cm3
              EDIT:
              habs mal umgebaut so gut ich es kann!
              Vielleicht kann es ja jemand gebrauchen.
              class FOTank : Driver
                  var tank_data
                  #build an global array-->list to store sensor for filtering
                  static buf = []
                  # this table is from the manufacturer datasheet, showing total gallons in inches, 44 entries plus a zero-entry.
                  static Tank275 =[0.38,0.76,1.16,1.55,1.96,2.36,2.77,3.19,3.61,4.04,4.47,4.91,5.35,5.8,6.25,6.71,7.17,7.64,8.11,8.59,9.07,9.56,10.06,10.56,11.07,11.58,12.09,12.62,13.14,13.68,14.22,14.76,15.31,15.87,16.43,17,17.57,18.15,18.74,19.33,19.93,20.53,21.14,21.76,22.38,23.01,23.64,24.28,24.93,25.58,26.24,26.91,27.58,28.26,28.94,29.63,30.33,31.03]
                 def tank()
                  var TableLength =   self.Tank275.size()         # 59
                  var TableTop = TableLength -1
                  var tank_offset = -3                           # offset from SR04t to top of tank (dead zone...)
                  var MaxBuf = 180                                # filtering buffer size
                  #print ("\n")
                  # Read Sensor data
                  import json
                  var sensors=json.load(tasmota.read_sensors())
                  if !(sensors.contains('SR04')) return end
                  var d = sensors['SR04']['Distance']
                  #print("Dist: ", d)
                  if (self.buf.size() >= MaxBuf) self.buf.pop(0) end      # remove old entry
                  self.buf.push(d)                                        # add new sensor reading to list
                  #print (self.buf)
                  #print ("Size: :", self.buf.size())
                  d = 0
                  for i : 0 .. (self.buf.size()-1 )               # let's sum all of the entrys
                  #print ("I: ",i)
                  d = d + self.buf.item (i)
                  end
                  #print("Buf: ", self.buf)
                  d = d / self.buf.size()                         # average the sensor data
                  #print("Dist-avd: ", d)
                  d = d + tank_offset                             # adjust for sensor to tank offset (dead zone)
                  #  Convert from CM to inch and round up
                  var d1 = d + 0.5                              # 2.54 cm to one inch
                  d1 = int(d1)                                    # we want an integer here for table lookup
                  if (d1 > TableTop) d1 = TableTop end            # do a bounds check, 0 --> 44
                  if (d1 <= 0) d1 = 0 end
                  #print("Cm: ",d1)
                  var d2 = self.Tank275.item(TableTop - d1)       # do table lookup, from end of table
                  d2 = int(d2)                                    # make sure its an integer
                  #print ("Liter: ",d2)
                  var d3 = (real(d2) / self.Tank275.item(TableTop)) * 100    # calculate percent of full
                  d3 = int (d3)
                  #print ("Prozent:", d3)
                  self.tank_data = [int (d), d1, d2, d3]          # return the data
                  return self.tank_data
                end
                def every_second()
              	if !self.tank return nil end
              	self.tank()
                end
                def web_sensor()
                  import string
                  if !self.tank_data return nil end               #- exit if not initialized -#
                  var msg = string.format(
                            "{s}Distanz{m}%.f cm{e}"..
                            "{s}Volumen{m}%.f Liter{e}"..
                            "{s}Prozent Voll{m}%.f %%{e}",
                            self.tank_data[0],self.tank_data[1],self.tank_data[2],self.tank_data[3])
                  tasmota.web_send_decimal(msg)
                end
                def json_append()
              	import string
              	var msg = string.format(",\"Tank\":{\"Distanz cm\":%.f,\"Distanz cm\":%.f,\"Volumen\":%.f,\"Prozent Voll\":%.f}",
                  tasmota.response_append(msg)
                end
              end
              FOTank = FOTank()
              tasmota.add_driver(FOTank)
              #- ************ The Very End ************* -#
                @bishop Danke fürs teilen.
                81.0k
