    4. OSRAM Smart+ schaltet unkontrolliert (Zigbee)
    • surfer09
      surfer09 last edited by
      ich habe eine OSRAM Smart+ Steckdose, die sich häufig unkontrolliert an und aus schaltet. Warum auch immer sie das macht, es schaltet sie aktiv niemand ein / aus.
      Ich habe gestern das LOG mal auf "Debug" gestellt und das hier eingefangen als sie eingeschaltet hat.
      2025-01-17 13:41:47.874 - debug: zigbee.0 (5036) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":29,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":9,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.09"}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x7cb03eaa0a09c05c","deviceNetworkAddress":41270,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a09c05c"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a09c05c","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1737117707874,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":41270,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_linkquality":172,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577},"linkquality":172,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-01-17 13:41:47.874 - debug: zigbee.0 (5036) Received Zigbee message from '0x7cb03eaa0a09c05c', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577}' from endpoint 3 with groupID 0
      2025-01-17 13:41:47.874 - debug: zigbee.0 (5036) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":29,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":9,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.09"}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x7cb03eaa0a09c05c","deviceNetworkAddress":41270,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a09c05c"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a09c05c","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1737117707874,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":41270,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_linkquality":172,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"linkquality","label":"Linkquality","access":1,"type":"numeric","property":"linkquality","description":"Link quality (signal strength)","category":"diagnostic","unit":"lqi","value_max":255,"value_min":0}],"onEvent":null,"ota":{},"zigbeeModel":["Plug 01"],"model":"AB3257001NJ","description":"Smart+ plug","vendor":"OSRAM","whiteLabel":[{"vendor":"LEDVANCE","model":"AB3257001NJ"},{"vendor":"LEDVANCE","model":"AC03360"}],"options":["[Circular]"]},"name":"0x7cb03eaa0a09c05c"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":29,"_applicationVersion":9,"_dateCode":"20140331DEOS****","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"profileID":49246,"ID":3,"clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":9,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.09"}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x7cb03eaa0a09c05c","deviceNetworkAddress":41270,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x4c5bb3fffe92c427","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":3,"deviceIeeeAddress":"0x7cb03eaa0a09c05c"}}],"_hardwareVersion":1,"_ieeeAddr":"0x7cb03eaa0a09c05c","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1737117707874,"_manufacturerID":48042,"_manufacturerName":"OSRAM","_modelID":"Plug 01","_networkAddress":41270,"_powerSource":"Mains (single phase)","_softwareBuildID":"V1.05.09","_stackVersion":2,"_type":"Router","_zclVersion":1,"_linkquality":172,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909577},"linkquality":172,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
        arteck Developer Most Active @surfer09 last edited by
        @surfer09 schmeiss weg das olle Ding..
        surfer09 1 Reply Last reply Reply Quote 1
        • surfer09
          surfer09 @arteck last edited by
          @arteck Ich setze den eigentlich nur noch ein, weil sich die anderen Zigbee Geräte dort auch anmelden können, weil der Zigbee Stick nicht ganz in der Nähe ist. Gibts da eine Alternative für?
          Fabio 1 Reply Last reply Reply Quote 0
          • Fabio
            Fabio @surfer09 last edited by Fabio
            @surfer09 du kannst zum Beispiel einen Lidl Plug nehmen, davon habe ich sehr viele im System, die laufen einwandfrei und sind auch gute Router.
            Oder von Aetoc das hier https://aeotec.com/products/aeotec-range-extender-zi/ die sind auch sehr gut.
            surfer09 1 Reply Last reply Reply Quote 3
            • surfer09
              surfer09 @Fabio last edited by
              @fabio Super, Dankeschön für den Tipp!
              Fabio haselchen 2 Replies Last reply Reply Quote 1
              • Fabio
                @surfer09 hier siehst du die Verbindungen gut, Stehlampe ist ein Lidl Plug.
                • haselchen
                  haselchen Most Active @surfer09 last edited by
                  @surfer09
                  Eigentlich musste Dir nur merken ,
                  Zigbee = Batterie = kein Repeater
                  Zigbee = Strom = Repeater
                  Und danach suchst Du im Netz .
                  Am Strom hängen meistens Birnen, Steckdosen….
                  T 1 Reply Last reply Reply Quote 2
                  • Asgothian
                    Asgothian Developer @Fabio last edited by Asgothian
                    @fabio sagte in OSRAM Smart+ schaltet unkontrolliert (Zigbee):
                    Blende mal in der Map die Nachbarn (siblings) aus. Nur dann kannst du sehen wie die Verbindung wirklich läuft.
                    A.
                    • Fabio
                      Fabio @Asgothian last edited by
                      @asgothian hab ich gemacht das sieht denk ich nicht so gut aus oder?
                        ticaki Developer @haselchen last edited by ticaki
                        @haselchen sagte in OSRAM Smart+ schaltet unkontrolliert (Zigbee):
                        @surfer09
                        Das stimmt leider nur "meistens".
                        Hab noch keine Steckdose oder Lampe gesehen die kein Router ist aber ->
                        Das ist ein FP1E hat Dauerstrom und ist kein router.
                        Ich kaufe mir gerne die Steckdosen von Nous A1Z ... mag die Firma wegen dem Tasmota Kram.
                        EDIT: oh rechtschreibfehler im Lampen namen 😄
                        • Asgothian
                          Jein. Jetzt siehst du wenigstens mal was. Unter anderem auch das du da irgendeinen Router hast der seine Routing Table nicht sauber weiter gibt 🙂
                          Ansonsten kannst du jetzt wirklich die Verbindungen sehen, nicht nur ein Meer aus grünen Linien
                          A.
                          Fabio 1 Reply Last reply Reply Quote 1
                          • Fabio
                            @asgothian okay, aber das jetzt rauszufinden, wer was nicht weiterleitet, ist mir zu viel Arbeit, da müsste ich quasi wieder von vorne anfangen und alles 24 Stunden schauen wo es hängt. Habe jetzt fast einen Monat mein System auf den ZigBee Adapter etc. umgestellt, jetzt reicht es erst mal.
                            Und wieder was gelernt hier. 😉
                            Herzliche Grüße
                            Fabio
                              legro @Fabio last edited by
                              .. rauszufinden, wer was nicht weiterleitet, ist mir zu viel Arbeit, ..
                              Das habe ich schon lange aufgegeben.😕
                              Ich habe mich schweren Herzens entschieden, alle OSRAM Teile nach und nach in die Mülltonne einzubauen. Was ich da schon an Zeit für die Fehlersuche aufbringen musste, ließ mich so manche Ausgaben verschmerzen.
                              Fabio 1 Reply Last reply Reply Quote 2
                              • Fabio
                                Fabio @legro last edited by
                                @legro das glaube ich dir gerne. Ich achte jetzt immer bei Neukauf ob die ZigBee 3.0 können.
                                Fabio
                                  arteck Developer Most Active @ticaki last edited by
                                  @ticaki sagte in OSRAM Smart+ schaltet unkontrolliert (Zigbee):
                                  das sind die Sonderfälle.. meistens sind das die PIR's.. die brauchen mehr Strom deshalb hängen die am Strom.. machen aber kein Routing..
                                  730
