    4. Update Node-Red 4.03 -> 5.2.1 auf RaspPi funktioniert nicht
    • E
      EndofPi last edited by
      Hallo, ich bin der Neue!
      Ich habe versucht den Node-Red Adapter über die Admin-GUI zu aktualisieren und
      leider keine Idee, was hier das Problem lösen könnte.
      • Adaptername: node-red
      • Link zu Adapterrepository: http://download.iobroker.net/sources-dist.json
      • Adapterversion: 4.0.3 -> 5.2.1
      • js-controller Version: 7.0.6
      • Admin Version: 7.4.10
      • Hardwaresystem: Pi3
      • Arbeitsspeicher: 8 GB
      • Festplattenart: SD-Karte
      • Betriebssystem: Raspbian GNU/Linux 11 (bullseye)
      • Nodejs-Version: 20.18.1
      • NPM-Version: 10.8.2
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
      • Ort, Name der Imagedatei: ...
      $ iobroker upgrade node-red@5.2.1 --debug
      Update node-red from @4.0.3 to @5.2.1
      NPM version: 10.8.2Installing iobroker.node-red@5.2.1... (System call)
      > bcrypt@5.1.1 install> node-pre-gyp install --fallback-to-build
      node-pre-gyp info using node-pre-gyp@1.0.11node-pre-gyp info using node@18.20.5 | linux | arm
      node-pre-gyp info check checked for "/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" (not found)
      node-pre-gyp http GET https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
      node-pre-gyp WARN Pre-built binaries not installable for bcrypt@5.1.1 and node@18.20.5 (node-v108 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/kelektiv/node.bcrypt.js/releases/download/v5.1.1/bcrypt_lib-v5.1.1-napi-v3-linux-arm-glibc.tar.gz
      gyp info it worked if it ends with okgyp info using node-gyp@10.1.0gyp info using node@18.20.5 | linux | arm
      gyp info ok
      gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/bcrypt/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/18.20.5/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.20.5',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.20.5/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bcrypt',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
      gyp info ok
      gyp info spawn make
      gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      make: Verzeichnis „/opt/iobroker/node_modules/bcrypt/build“ wird betreten
      CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
      make: cc: Keine Berechtigung
      make: *** [../node-addon-api/nothing.target.mk:107: Release/obj.target/nothing/../node-addon-api/nothing.o] Fehler 127make: Verzeichnis „/opt/iobroker/node_modules/bcrypt/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
      gyp ERR! System Linux 6.1.21-v8+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node" "--module_name=bcrypt_lib" "--module_path=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=3" "--node_napi_label=napi-v3"gyp ERR! cwd /opt/iobroker/node_modules/bcryptgyp ERR! node -v v18.20.5gyp ERR! node-gyp -v v10.1.0gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3 --napi_version=9 --node_abi_napi=napi --napi_build_version=3 --node_napi_label=napi-v3' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)node-pre-gyp ERR! stack at ChildProcess.emit (node:events:517:28)node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1098:16)node-pre-gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:303:5)
      node-pre-gyp ERR! System Linux 6.1.21-v8+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/bcryptnode-pre-gyp ERR! node -v v18.20.5node-pre-gyp ERR! node-pre-gyp -v v1.0.11node-pre-gyp ERR! not ok Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/opt/iobroker/node_modules/bcrypt/lib/binding/napi-v3 --napi_version=9 --node_abi_napi=napi --napi_build_version=3 --node_napi_label=napi-v3' (1)
      npm error code 1
      npm error path /opt/iobroker/node_modules/bcryptnpm error command failednpm error command sh -c node-pre-gyp install --fallback-to-build
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-01-18T09_32_23_658Z-debug-0.log
      Updating objects from io-package.json for adapter "node-red" with version "4.0.3"
      upload [15] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
      upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/j
      son
      upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
      upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
      upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
      Process exited with code 0
      Homoran mickym 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @EndofPi last edited by Homoran
        @endofpi ob das ein Bug ist werden wir sehen.
        Auf jeden Fall passt schon mal
        @endofpi sagte in Update Node-Red 4.03 -> 5.2.1 auf RaspPi funktioniert nicht:
        nicht zu
        bitte iob diag in der Langfassung posten
        EDIT:
        Da du einen Raspi verwendest bitte dafür diese drei Befehle nutzen
        curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
        chmod 744 iob_diag.sh
        ./iob_diag.sh
        • E
          Hallo Homoran,
          die manuell eingetragene Versionsinfo zu Nodejs-Version hatte ich aus dem hosts-Reiter von iobroker abgeschrieben, der Unterschied zum Update-Script ist mir aber nicht aufgefallen.
          Nachfolgend die Zusammenfassung aus dem Shellscript:
          			v.2024-12-09 Raspbian+zigbee diag+masking
             Static hostname: iobroker
                   Icon name: computer
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Installation: 		native
          Kernel: 		aarch64
          Userland: 		32 bit
          Timezone: 		Europe/Berlin (CET, +0100)
          User-ID: 		1000
          Display-Server: 	false
          Boot Target: 		multi-user.target
          Pending OS-Updates: 	0
          Pending iob updates: 	1
          Nodejs-Installation:
          /usr/bin/nodejs 	v20.18.1
          /usr/bin/node 		v20.18.1
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          /usr/bin/corepack 	0.29.4
          Recommended versions are nodejs 20.18.1 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            7.8G        520M        3.1G        1.0M        4.2G        7.2G
          Swap:            99M          0B         99M
          Total:          7.9G        520M        3.2G
          Active iob-Instances: 	8
          Upgrade policy: none
          ioBroker Core: 		js-controller 		7.0.6
          			admin 			7.4.10
          ioBroker Status: 	iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.44 (SSL), run as: admin
            system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 192.168.178.44, run as: admin
          Objects: 		2169
          States: 		1710
          Size of iob-Database:
          12M	/opt/iobroker/iobroker-data/objects.jsonl
          9.8M	/opt/iobroker/iobroker-data/states.jsonl
          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
          • mcm1957
            mcm1957 last edited by
            @endofpi
            Komisch ist dass er offensichtlich nicht auf den cc Kompiler zugreifen kann:
            (in Zeile 20)
              Homoran Global Moderator Administrators @mcm1957 last edited by
              @mcm1957 sagte in Update Node-Red 4.03 -> 5.2.1 auf RaspPi funktioniert nicht:
              ist nicht meine Kragenweite, hab ich geflissentlich ignoriert.
              Da mehrfach node v18 im log erwähnt wird, ist sowieso anscheinend einiges schief.
              Bestenfalls zwei node Installationen parallel
              • E
                18.20.5 dürfte die default-version aus Raspbian sein.
                Auf Grund des Fehlers mit Node-Red habe ich versucht durch ein manuelles Upgrade mittels
                iob nodejs-update
                das Problem zu lösen. Das Problem mit dem Adapter bestand aber auch vorher.
                  Raspbian sollte kein eigenes nodejs mitbringen!
                  d.h. wir bekommen keine Langfassung von iob diag mehr, die den Zeitpunkt des logs widerspiegelt?
                  bitte lesen:
                  • mickym
                    mickym Most Active @EndofPi last edited by
                    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript Process exited with code 0
                    Mal blöd gefragt - bist Du Dir denn sicher, dass das nicht funktioniert hat. - Vielleicht nur ein Browserrefresh. Der Prozess endet mit RC = 0 und das heißt, dass alles geklappt hat.
