    4. Z2M-Adapter: Geräte als offline markiert obwohl online
    • Kodijack
      Kodijack last edited by Kodijack
      Due to request from @arteck : Here's the post.
      Problem:
      After a fresh start of the z2m-instance, all devices are available and working. After a while most devices now show as
      offline, despite being online. Everything works fine though. it's just availability=false
      Steps tried so far:
      • double-checking config-settings according to documentation.
      advanced:
        ota_timeout: 1200
        output: json
        cache_state: false
      availability:
        enabled: true
        active:
          timeout: 120
        passive:
          timeout: 1500
      (removing the timeouts doesn't change the behaviour)
      • Trying all possible settings in MQTT/Z2M+Z2M-Adapter in desperately trying to fix it.
      -Zigbee2mqtt-Adapter 3.0.2
      -Zigbee2mqtt v2.0
      -MQTT (external server)
      • js-cont 7.0.6
      • admin-adapter: most current
      • nodejs 20.10.0
      • npm 10.8.2
                              v.2024-10-19
         Static hostname: iobroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 5.4.0-204-generic
            Architecture: x86-64
      Installation:           kvm
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     12
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.0
      /usr/bin/node           v20.18.0
      /usr/bin/corepack       0.29.3
      Recommended versions are nodejs 20.18.1 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:           9.7G        2.5G        3.9G        1.0M        3.3G        6.9G
      Swap:          2.0G          0B        2.0G
      Total:          11G        2.5G        5.9G
      Active iob-Instances:   25
      Upgrade policy: none
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.14
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.0.10 (SSL), run as: admin
        system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8099, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.0.10 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8084, bind: 192.168.0.10, run as: httpuser
      + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8098, bind: 0.0.0.0 (SSL), run as: httpuser
      Objects:                15731
      States:                 12426
      Size of iob-Database:
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/objects.json.migrated
      15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      0       /opt/iobroker/iobroker-data/objects.json.broken
      48M     /opt/iobroker/iobroker-data/states.jsonl
      2.8M    /opt/iobroker/iobroker-data/states.json.migrated
      2.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
      Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
      Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
      DANKE
      Bitte ausfüllen:
      • Adaptername: ...
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: ...
      • js-controller Version: ...
      • Admin Version: ...
      • Hardwaresystem: NUC, Pi4 ...
      • Arbeitsspeicher: ...xGB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Betriebssystem: ...
      • Nodejs-Version: ...
      • NPM-Version: ...
      • Installationsart: Skript oder Manuell ?
      • Image, Docker genutzt: Ja - Nein
      • Ort, Name der Imagedatei: ...
      Linux User bitte hier den Output von iob diag einfügen.Due to request from @arteck : Here's the post.
      Problem:
      Steps tried so far:
      advanced:
        ota_timeout: 1200
        output: json
        cache_state: false
      availability:
        enabled: true
        active:
          timeout: 120
        passive:
          timeout: 1500
      -Zigbee2mqtt v2.0
      • js-cont 7.0.6
      • nodejs 20.10.0
      • npm 10.8.2
                              v.2024-10-19
                 Chassis: vm
          Virtualization: kvm
      Installation:           kvm
      User-ID:                1000
      MEMORY:
      Swap:          2.0G          0B        2.0G
                              admin                   7.4.14
      Objects type: jsonl
      States  type: jsonl
      Objects:                15731
      States:                 12426
        arteck Developer Most Active @Kodijack last edited by arteck
        @kodijack sagte in Z2M-Adapter: Devices marked offline despite being online:
        active:
        timeout: 120
        passive:
        timeout: 1500
        hast du die mal ausgeschaltet ?? hat auch nix gebracht ?
        und wie war das
        so oder ??
        Kodijack 1 Reply Last reply Reply Quote 0
        • Kodijack
          Kodijack @arteck last edited by
          @arteck said in Z2M-Adapter: Devices marked offline despite being online:
          active:
          timeout: 120
          passive:
          timeout: 1500
          Nein, nix geändert nach Löschung beider Optionen
          und wie war das
          so oder ??
          External, ja.
            @kodijack poste mal bitte nach adapterstart das log.
            irgendwas ist bei dir anders.
              Hab das mal hier hingeschoben. Ist ja wohl kein Bug von ioBroker.
              @Kodijack kannst du bitte den Threadtitel noch auf deutsch ändern!
              • Kodijack
                zigbee2mqtt.0
                	2025-01-21 18:28:54.000	info	==================================================================================
                zigbee2mqtt.0
                	2025-01-21 18:28:54.000	info	|| Network panid 6555 channel: 11 ext_pan_id: 0x5a9b81c29a3de1d1
                zigbee2mqtt.0
                	2025-01-21 18:28:54.000	info	|| Coordinator type: zStack3x0 Version: 20240710 Serial: tcp://192.168.0.250:6638
                zigbee2mqtt.0
                	2025-01-21 18:28:54.000	info	|| Zigbee2MQTT Version: 2.0.0
                zigbee2mqtt.0
                	2025-01-21 18:28:53.999	info	============================ Zigbee2MQTT Information =============================
                zigbee2mqtt.0
                	2025-01-21 18:28:53.988	info	Connect to Zigbee2MQTT over external mqtt connection.
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	==================================================================================
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Coordinator Check Cron : 0 3 * * *
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Coordinator Check Loglevel: info
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Use Automatic Coordinator Check: no
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Use Simple Press/Release State: yes
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Use Simple Move/Stop State: yes
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Use Simple Hold/Release State: yes
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Use Device Icons: yes
                zigbee2mqtt.0
                	2025-01-21 18:28:53.857	info	|| Use Event In Desc: yes
                zigbee2mqtt.0
                	2025-01-21 18:28:53.856	info	|| Use BrightnessStep OnOff: no
                zigbee2mqtt.0
                	2025-01-21 18:28:53.856	info	|| Use BrightnessMove OnOff: no
                zigbee2mqtt.0
                	2025-01-21 18:28:53.856	info	|| Use ColorTemperature ColorSync: no
                zigbee2mqtt.0
                	2025-01-21 18:28:53.856	info	|| Use Kelvin: no
                zigbee2mqtt.0
                	2025-01-21 18:28:53.856	info	|| Proxy Zigbee2MQTT Logs to ioBroker Logs: deactivated
                zigbee2mqtt.0
                	2025-01-21 18:28:53.856	info	|| Zigbee2MQTT Debug Log: deactivated
                zigbee2mqtt.0
                	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Externanl MQTT Credentials: use
                zigbee2mqtt.0
                	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Externanl MQTT Port: 1883
                zigbee2mqtt.0
                	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Externanl MQTT Server: mosquitto.<redacted domain>
                zigbee2mqtt.0
                	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Connection Type: exmqtt
                zigbee2mqtt.0
                	2025-01-21 18:28:53.855	info	|| Zigbee2MQTT Frontend Port: 8080
                zigbee2mqtt.0
                	2025-01-21 18:28:53.854	info	|| Zigbee2MQTT Frontend Server:
                zigbee2mqtt.0
                	2025-01-21 18:28:53.854	info	|| Zigbee2MQTT Frontend Scheme: http
                zigbee2mqtt.0
                	2025-01-21 18:28:53.854	info	================================= Adapter Config =================================
                zigbee2mqtt.0
                	2025-01-21 18:28:53.844	info	starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.zigbee2mqtt, node: v20.18.0, js-controller: 7.0.6
                Irgendwas hilfreiches dabei oder meintest du eher das z2m-log? Soll ich nochmal mit dem forwarded-log zusammen posten?
                  @kodijack direkt nach dem start sind die alle online.. ??
                  zeigmal ein screenshot von paar objekten
                  • Kodijack
                    Kodijack @arteck last edited by Kodijack
                    @arteck said in Z2M-Adapter: Geräte als offline markiert obwohl online:
                    Ja, direkt nach Adapter-Neustart sind alle online (die auch tatsächlich online sind natürlich). Das Gleiche auch wenn ich Z2M selber neustarte, nicht aber den Adapter.
                    Es dauerte ein paar Stunden bis (fast) alle wieder offline waren.
                    Die anderen sind auch alle available:false. Änder ich einen state wie "on" im gleichen Gerät, funktioniert es, availability bleibt jedoch offline.
                    Hier sind ein paar noch online, aber bald auch offline 🙂
                      @kodijack sagte in Z2M-Adapter: Geräte als offline markiert obwohl online:
                      cache_state: false
                      setzt den mal auf
                      cache_state: false
                      • Kodijack
                        cache_state: false
                        setzt den mal auf
                        cache_state: false
                        Öh. Ist doch schon 🙂
                          @kodijack jo hast recht....
                            cache_state: false
                          device_options: {}
                          availability:
                            enabled: true
                            active:
                              timeout: 10
                            passive:
                              timeout: 1500
                          das ist meine Einstellung.. kann ja dann nur ean dem timeout liegen
                          • Kodijack
                            Den hatte ich ja schon rausgenommen. War deine erste Idee in Tgram.
                            Deine Version ist ja, glaub ich, der default, 10 und 1500. Werd ich aber auch nochmal explizit so übernehmen, who knows...
                            590
