    4. Massive Performance Probleme beim GUI Zugriff
      sunny9999 last edited by
      Servus,
      hab seit ca. 1 Woche ( letztes Update von Debian) gefühlt immer schlimmer werdende Zugriffsprobleme auf die GUI ( egal welcher Tab)
      Sei es über die IP:Port oder über die DNS Adresse.
      Teilweise braucht der Zugriff Minuten, teilweise überhaupt nicht möglich.....
      Maßnahmen bissher :
      reboot
      iob fix
      iob diag full ( nachfolgend)
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: IOBROKER-MASTER
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: vmware
                Kernel: Linux 6.1.0-30-amd64
          Architecture: x86-64
       Hardware Vendor: VMware, Inc.
        Hardware Model: VMware Virtual Platform
      Firmware Version: 6.00
      OS is similar to:
      model name      : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz
      Docker          : false
      Virtualization  : vmware
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       12:44:47 up 3 days,  2:39,  1 user,  load average: 3.08, 1.51, 1.00
      CPU threads: 16
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-01-21 12:44:47 CET
                 Universal time: Tue 2025-01-21 11:44:47 UTC
                       RTC time: Tue 2025-01-21 11:44:47
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      debian
      HOME=/home/debian
      GROUPS=debian adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             12G        5.3G        2.1G        1.4M        5.5G        7.2G
      Swap:           2.1G          0B        2.1G
      Total:           14G        5.3G        4.2G
      Active iob-Instances:   26
              11926 M total memory
               5059 M used memory
               1760 M active memory
               6261 M inactive memory
               1987 M free memory
                954 M buffer memory
               4304 M swap cache
               2043 M total swap
                  0 M used swap
               2043 M free swap
      top - 12:44:47 up 3 days,  2:39,  1 user,  load average: 3.08, 1.51, 1.00
      Tasks: 325 total,   3 running, 322 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  9.5 us,  4.8 sy,  0.0 ni, 81.0 id,  0.0 wa,  0.0 hi,  4.8 si,  0.0 st
      MiB Mem :  11926.6 total,   1984.6 free,   5062.4 used,   5258.6 buff/cache
      MiB Swap:   2044.0 total,   2044.0 free,      0.0 used.   6864.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                                                               Type      Size  Used Avail Use% Mounted on
      udev        devtmpfs  5.8G     0  5.8G   0% /dev
      tmpfs        tmpfs     1.2G  1.3M  1.2G   1% /run
      /dev/mapper/debian10--vg-root                                            ext4      107G   40G   62G  39% /
      tmpfs        tmpfs     5.9G     0  5.9G   0% /dev/shm
      tmpfs        tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda1        ext2      234M  186M   36M  84% /boot
      /dev/mapper/debian10--vg-home                                            ext4       70G   11G   57G  16% /home
      /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  328K  1.1G   1% /tmp
      /dev/mapper/debian10--vg-var                                             ext4      6.4G  2.4G  3.6G  40% /var
      192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4      1.9T  672G  1.3T  35% /mnt/photosyno
      192.168.10.47:/volume1/IOBROKER                                          nfs4      2.7T  1.6T  1.1T  60% /mnt/IOBROKERDATA
      192.168.10.47:/volume2/Backup                                            nfs4      1.9T  672G  1.3T  35% /mnt/BACKUP
      tmpfs        tmpfs     1.2G   60K  1.2G   1% /run/user/1000
      //192.168.10.47/Backup/IOBROKER/iobroker                                 cifs      1.9T  672G  1.3T  35% /opt/iobroker/backups
      [Sat Jan 18 10:04:53 2025] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 18 10:04:54 2025] EXT4-fs (dm-0): re-mounted. Quota mode: none.
      [Sat Jan 18 10:04:55 2025] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
      [Sat Jan 18 10:04:55 2025] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
      [Sat Jan 18 10:04:55 2025] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 18 10:04:55 2025] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 18 10:04:55 2025] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET                  SOURCE        FSTYPE OPTIONS
      /                       /dev/mapper/debian10--vg-root                                            ext4   rw,relatime,errors=remount-ro
      |-/boot                 /dev/sda1        ext2   rw,relatime
      |-/home                 /dev/mapper/debian10--vg-home                                            ext4   rw,relatime
      |-/tmp                  /dev/mapper/debian10--vg-tmp                                             ext4   rw,relatime
      |-/var                  /dev/mapper/debian10--vg-var                                             ext4   rw,relatime
      |-/opt/iobroker/backups //192.168.10.47/Backup/IOBROKER/iobroker                                 cifs   rw,relatime,vers=3.1.1,cache=strict,username=IOBROKER,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.10.47,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
      |-/mnt/IOBROKERDATA     192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
      |-/mnt/photosyno        192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
      `-/mnt/BACKUP           192.168.10.47:/volume2/Backup                                            nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
      /var:
      2.4G    /var/
      2.0G    /var/lib
      680M    /var/lib/redis
      537M    /var/lib/grafana
      532M    /var/lib/grafana/plugins
      Archived and active journals take up 320.1M in the file system.
      /opt/iobroker/backups:
      23G     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      27G     /opt/iobroker/iobroker-data/
      26G     /opt/iobroker/iobroker-data/history
      947M    /opt/iobroker/iobroker-data/files
      195M    /opt/iobroker/iobroker-data/backup-objects
      176M    /opt/iobroker/iobroker-data/files/vis-2
      46M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      HINT:
      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.1-1nodesource1
        Version table:
       *** 20.18.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      IOBROKER-MASTER     IOBROKER-MASTER (version: 7.0.6, hostname: IOBROKER-MASTER, alive, uptime: 137)
      IOBROKER-SLAVE      IOBROKER-SLAVE (version: 7.0.6, hostname: IOBROKER-SLAVE, alive, uptime: 706164)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     17
      +-- iobroker.dreame@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.dreame.git#beda212e3313d3477707fb5a8f52c7eefed9bfd7)
      +-- iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#9ec12d2f39898351be9ff6105043a408251e6174)
      +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#384363b87eaf0fa0b66ad2b54f2f51427dbc738d)
      +-- iobroker.govee@0.0.5 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#0d983c49135b87ac2f88f9d832a6d632c4889606)
      +-- iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954)
      +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#c0fcc9a6aa79b281951215cf86726f45622c8409)
      | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
      +-- iobroker.notificationforandroidtv@3.0.1 (git+ssh://git@github.com/DNAngelX/ioBroker.notificationforandroidtv.git#4f5ec5635498f83f87b68fd6d5e8371b1414b764)
      +-- iobroker.oasecontrol@0.0.2 (git+ssh://git@github.com/mr-suw/ioBroker.oasecontrol.git#d8f1584259393298b214d605c6934579860276b3)
      +-- iobroker.ocpp@0.12.5 (git+ssh://git@github.com/foxriver76/ioBroker.ocpp.git#6f0316acb6d3bacb9cfd82293590a9dd307d3d9d)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#6b9894252659ebf564221d3119361a20c8f82d1d)
      +-- iobroker.sprinklecontrol@0.2.13 (git+ssh://git@github.com/Dirk-Peter-md/ioBroker.sprinklecontrol.git#d201c1d92bbf728f16420c85804151b7dce29157)
      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#221464afaa7db4eff676ab588786c40d35e8bad6)
      +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#be2791c1dfe1467e21e081ac1a6de1d36eac0e41)
      `-- paesslerag-node-red-contrib-prtg@0.0.0-development (git+ssh://git@github.com/PaesslerAG/node-red-contrib-prtg.git#8c7a526e6975caef38d3b3f384ba5125d888b103)
      Adapter State
        system.adapter.adb.0                    : adb                   : IOBROKER-MASTER                          -  enabled
      + system.adapter.admin.0                  : admin                 : IOBROKER-MASTER                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : IOBROKER-MASTER                          -  enabled
        system.adapter.alexa2.0                 : alexa2                : IOBROKER-MASTER                          -  enabled
        system.adapter.alias-manager.0          : alias-manager         : IOBROKER-MASTER                          -  enabled
        system.adapter.asterisk.0               : asterisk              : IOBROKER-MASTER                          -  enabled, port: 5038
        system.adapter.backitup.0               : backitup              : IOBROKER-MASTER                          -  enabled
      + system.adapter.backitup.1               : backitup              : IOBROKER-SLAVE                           -  enabled
        system.adapter.chromecast.0             : chromecast            : IOBROKER-MASTER                          -  enabled
        system.adapter.daswetter.0              : daswetter             : IOBROKER-MASTER                          -  enabled
        system.adapter.device-watcher.0         : device-watcher        : IOBROKER-MASTER                          - disabled
        system.adapter.devices.0                : devices               : IOBROKER-MASTER                          -  enabled
        system.adapter.discovery.0              : discovery             : IOBROKER-MASTER                          -  enabled
        system.adapter.dreame.0                 : dreame                : IOBROKER-MASTER                          -  enabled
        system.adapter.dwd.0                    : dwd                   : IOBROKER-MASTER                          -  enabled
        system.adapter.echarts.0                : echarts               : IOBROKER-MASTER                          -  enabled
      + system.adapter.email.0                  : email                 : IOBROKER-MASTER                          -  enabled
        system.adapter.feiertage.0              : feiertage             : IOBROKER-MASTER                          -  enabled
        system.adapter.flot.0                   : flot                  : IOBROKER-MASTER                          -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : IOBROKER-MASTER                          -  enabled
        system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : IOBROKER-MASTER                          -  enabled
        system.adapter.govee-app.0              : govee-app             : IOBROKER-MASTER                          -  enabled
        system.adapter.ham.0                    : ham                   : IOBROKER-MASTER                          - disabled
        system.adapter.hass.0                   : hass                  : IOBROKER-MASTER                          - disabled, port: 8123
        system.adapter.heatingcontrol.0         : heatingcontrol        : IOBROKER-MASTER                          - disabled
        system.adapter.hiob.0                   : hiob                  : IOBROKER-MASTER                          - disabled, port: 8090
      + system.adapter.history.0                : history               : IOBROKER-MASTER                          -  enabled
        system.adapter.hm-rega.0                : hm-rega               : IOBROKER-MASTER                          -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : IOBROKER-MASTER                          -  enabled, port: 80
        system.adapter.husq-automower.0         : husq-automower        : IOBROKER-MASTER                          - disabled
        system.adapter.ical.0                   : ical                  : IOBROKER-MASTER                          -  enabled
        system.adapter.ical.1                   : ical                  : IOBROKER-MASTER                          -  enabled
        system.adapter.ical.2                   : ical                  : IOBROKER-MASTER                          -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : IOBROKER-MASTER                          -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBROKER-MASTER                          -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBROKER-MASTER                          -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOBROKER-MASTER                          -  enabled
      + system.adapter.influxdb.0               : influxdb              : IOBROKER-MASTER                          -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : IOBROKER-MASTER                          -  enabled
        system.adapter.kodi.0                   : kodi                  : IOBROKER-MASTER                          - disabled, port: 9090
        system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER-MASTER                          -  enabled
        system.adapter.linktap.0                : linktap               : IOBROKER-MASTER                          - disabled
        system.adapter.linux-control.0          : linux-control         : IOBROKER-MASTER                          - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : IOBROKER-MASTER                          - disabled, port: 54321
        system.adapter.mqtt-client.0            : mqtt-client           : IOBROKER-MASTER                          - disabled, port: 1884, bind: 0.0.0.0
        system.adapter.mqtt.0                   : mqtt                  : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mytime.0                 : mytime                : IOBROKER-MASTER                          - disabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOBROKER-MASTER                          - disabled
      + system.adapter.node-red.0               : node-red              : IOBROKER-MASTER                          -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER                          -  enabled
        system.adapter.nuki-extended.0          : nuki-extended         : IOBROKER-MASTER                          - disabled
      + system.adapter.nuki.0                   : nuki                  : IOBROKER-MASTER                          -  enabled
        system.adapter.oasecontrol.0            : oasecontrol           : IOBROKER-MASTER                          -  enabled
        system.adapter.ocpp.0                   : ocpp                  : IOBROKER-MASTER                          -  enabled, port: 9220
        system.adapter.onkyo.0                  : onkyo                 : IOBROKER-MASTER                          -  enabled
        system.adapter.onvif.0                  : onvif                 : IOBROKER-MASTER                          - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.ping.0                   : ping                  : IOBROKER-MASTER                          -  enabled
      + system.adapter.pushover.0               : pushover              : IOBROKER-MASTER                          -  enabled
        system.adapter.reolink.0                : reolink               : IOBROKER-MASTER                          - disabled
        system.adapter.robonect.0               : robonect              : IOBROKER-MASTER                          - disabled
        system.adapter.samsung.0                : samsung               : IOBROKER-MASTER                          - disabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : IOBROKER-MASTER                          -  enabled, port: 8002
        system.adapter.sayit.0                  : sayit                 : IOBROKER-MASTER                          -  enabled
      + system.adapter.scenes.0                 : scenes                : IOBROKER-MASTER                          -  enabled
      + system.adapter.scheduler.0              : scheduler             : IOBROKER-MASTER                          -  enabled
      + system.adapter.shelly.0                 : shelly                : IOBROKER-MASTER                          -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : IOBROKER-MASTER                          - disabled
        system.adapter.simple-api.0             : simple-api            : IOBROKER-MASTER                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartcontrol.0           : smartcontrol          : IOBROKER-MASTER                          -  enabled
        system.adapter.smartmeter.0             : smartmeter            : IOBROKER-SLAVE                           - disabled
        system.adapter.smartthings.0            : smartthings           : IOBROKER-MASTER                          -  enabled
        system.adapter.sonoff.0                 : sonoff                : IOBROKER-MASTER                          -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : IOBROKER-MASTER                          -  enabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER-MASTER                          -  enabled
        system.adapter.synology.0               : synology              : IOBROKER-MASTER                          -  enabled, port: 5000
      + system.adapter.tahoma.0                 : tahoma                : IOBROKER-MASTER                          -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : IOBROKER-MASTER                          -  enabled
      + system.adapter.telegram.0               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.2               : telegram              : IOBROKER-MASTER                          - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : IOBROKER-MASTER                          -  enabled
        system.adapter.text2command.1           : text2command          : IOBROKER-MASTER                          -  enabled
        system.adapter.time-switch.0            : time-switch           : IOBROKER-MASTER                          -  enabled
        system.adapter.trashschedule.0          : trashschedule         : IOBROKER-MASTER                          -  enabled
        system.adapter.trashschedule.1          : trashschedule         : IOBROKER-MASTER                          -  enabled
      + system.adapter.unifi.0                  : unifi                 : IOBROKER-MASTER                          -  enabled
        system.adapter.upnp.0                   : upnp                  : IOBROKER-MASTER                          - disabled
        system.adapter.vaillant.0               : vaillant              : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-2.0                  : vis-2                 : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-bars.0               : vis-bars              : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-metro.0              : vis-metro             : IOBROKER-MASTER                          - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBROKER-MASTER                          -  enabled
        system.adapter.vis-weather.0            : vis-weather           : IOBROKER-MASTER                          -  enabled
        system.adapter.vis.0                    : vis                   : IOBROKER-MASTER                          -  enabled
        system.adapter.vw-connect.0             : vw-connect            : IOBROKER-MASTER                          -  enabled
      + system.adapter.weatherunderground.0     : weatherunderground    : IOBROKER-MASTER                          -  enabled
        system.adapter.web.0                    : web                   : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.webcal.0                 : webcal                : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
        system.adapter.yahka.0                  : yahka                 : IOBROKER-MASTER                          -  enabled
        system.adapter.zigbee.1                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.24:6638
      + system.adapter.zigbee.2                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.39:6638
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "adb"          : 0.0.7    , installed 0.0.7
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "alarm"        : 3.6.7    , installed 3.6.7
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "apcups"       : 4.0.2    , installed 4.0.2
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "doorio"       : 2.1.5    , installed 2.1.5
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
      Adapter    "hiob"         : 0.1.6    , installed 0.1.6
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hue"          : 3.13.1   , installed 3.13.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "kodi"         : 3.1.0    , installed 3.1.0
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "linktap"      : 1.0.1    , installed 1.0.1
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mpd"          : 2.2.0    , installed 2.2.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
      Adapter    "mytime"       : 1.2.2    , installed 1.2.2
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "reolink"      : 1.1.2    , installed 1.1.2
      Adapter    "robonect"     : 1.4.2    , installed 1.4.2
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "volumio"      : 0.2.0    , installed 0.2.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "webcal"       : 1.3.10   , installed 1.3.10
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        63662
      States:         52903
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 24
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3772413    1309329/cupsd
      tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       4570060    1579527/io.hm-rpc.0
      tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       4567920    1578389/io.hm-rpc.1
      tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       4574739    1579932/io.hm-rpc.2
      tcp        0      0 192.168.10.16:9092      0.0.0.0:*               LISTEN      1001       4567030    1578552/io.nuki.0
      tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        18163      983/asterisk
      tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        27853      951/redis-server 0.
      tcp        0      0 127.0.0.1:36819         0.0.0.0:*               LISTEN      122        28078      1398/plugin_start_l
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       4571119    1579931/nc
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       4567887    1578300/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       4573412    1578852/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       4577469    1579579/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       4577470    1579579/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       4575614    1579963/io.sonoff.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14491      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13275      958/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4569565    1577776/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        14644      989/influxd
      tcp6       0      0 :::9220                 :::*                    LISTEN      1001       4574765    1580000/io.ocpp.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          18446      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13277      958/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3772412    1309329/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      122        14713      1295/grafana
      udp        0      0 0.0.0.0:1905            0.0.0.0:*                           1001       4579617    1578337/io.sonos.0
      udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        18180      983/asterisk
      udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        18181      983/asterisk
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4578392    1579434/io.chromeca
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        25796      857/avahi-daemon: r
      udp        0      0 0.0.0.0:55448           0.0.0.0:*                           111        25798      857/avahi-daemon: r
      udp        0      0 0.0.0.0:40505           0.0.0.0:*                           121        15598      983/asterisk
      udp        0   1536 0.0.0.0:49055           0.0.0.0:*                           1001       4576756    1579356/io.onkyo.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          26678      1/init
      udp6       0      0 :::34917                :::*                                111        25799      857/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                111        25797      857/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          25624      1/init
      udp6       0      0 :::33604                :::*                                121        15599      983/asterisk
      2025-01-21 12:45:04.799  - info: alexa2.0 (1578990) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-01-21 12:45:04.799  - info: alexa2.0 (1578990)     Device-type:A2ZOTUOF1IBEYI - Markus's Plantronics Voyager 5200 Series (Plantronics Voyager 5200 Series) (Plantronics Voyager 5200 Series) (Plantronics Voyager 5200 Series) (KINDLE_BOOKS,DREAM_TRAINING,I_HEART_RADIO,SLEEP,AUDIBLE,APPLE_MUSIC,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,AMAZON_MUSIC,SIRIUSXM,ADAPTIVE_LISTENING,DEEZER,TOUCH_INITIATED,PERSISTENT_CONNECTION,TIDAL,CHANGE_NAME,VOLUME_SETTING,TUNE_IN,MUSIC_SKILL,DEREGISTER_DEVICE,AUDIO_PLAYER,GOLDFISH,TIMERS_AND_ALARMS,MICROPHONE)
      2025-01-21 12:45:06.832  - error: chromecast.0 (1579434) Gewaechshaus- Cannot get status: Error: Could not connect after 10 seconds
      2025-01-21 12:45:07.005  - info: host.IOBROKER-MASTER instance system.adapter.mqtt.0 in version "6.1.2" started with pid 1579579
      2025-01-21 12:45:07.030  - error: chromecast.0 (1579434) Gewächshaus- Cannot get status: Error: Could not connect after 10 seconds
      2025-01-21 12:45:08.212  - info: mqtt.0 (1579579) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.1, js-controller: 7.0.6
      2025-01-21 12:45:08.574  - info: mqtt.0 (1579579) Starting MQTT authenticated server on 0.0.0.0:1883
      2025-01-21 12:45:08.575  - info: mqtt.0 (1579579) Starting MQTT-WebSocket authenticated server on 0.0.0.0:1884
      2025-01-21 12:45:09.449  - info: mqtt.0 (1579579) Client [LINK-TAP-GATEWAY] connected with secret 1737459909442_5060
      2025-01-21 12:45:11.224  - info: host.IOBROKER-MASTER instance system.adapter.hm-rpc.2 in version "2.0.2" started with pid 1579932
      2025-01-21 12:45:14.215  - info: synology.0 (1579484) DSM 7
      2025-01-21 12:45:14.216  - info: synology.0 (1579484) DSM 7 detected, set all to true
      2025-01-21 12:45:14.469  - info: mqtt.0 (1579579) Client [LINK-TAP-GATEWAY] subscribes on "mqtt.0.linktap.up_cmd_ack"
      2025-01-21 12:45:14.470  - info: mqtt.0 (1579579) Client [LINK-TAP-GATEWAY] subscribes on "mqtt.0.linktap.down_cmd"
      2025-01-21 12:45:15.026  - info: host.IOBROKER-MASTER instance system.adapter.sonoff.0 in version "3.1.2" started with pid 1579963
      2025-01-21 12:45:16.304  - info: sonoff.0 (1579963) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v20.18.1, js-controller: 7.0.6
      2025-01-21 12:45:16.328  - info: sonoff.0 (1579963) Starting MQTT authenticated  server on port 1885
      2025-01-21 12:45:18.347  - info: alexa2.0 (1578990) Unknown Device, but enabling commands, Try it and report back if commands work.
      2025-01-21 12:45:18.347  - info: alexa2.0 (1578990) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-01-21 12:45:18.348  - info: alexa2.0 (1578990)     Device-type:A2N49KXGVA18AR - Markus' 7. Fire (REMINDERS,SPEECH_RECOGNIZER_USS,FIND_MY_TABLET,SUPPORTS_LOCALE,NO_TIME_ZONE_SETTING,CUSTOM_ALARM_TONE,ADAPTIVE_LISTENING,PERSISTENT_CONNECTION,SUPPORTS_LOCALE_SWITCH,DIALOG_INTERFACE_VERSION,ASX_TIME_ZONE,EARCONS,MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,SOUND_SETTINGS)
      2025-01-21 12:45:19.500  - info: host.IOBROKER-MASTER instance system.adapter.ocpp.0 in version "0.12.5" (non-npm: foxriver76/ioBroker.ocpp) started with pid 1580000
      2025-01-21 12:45:22.863  - info: sonoff.0 (1579963) Client [KUECHE] connected with secret 1737459922859_7118
      2025-01-21 12:45:23.048  - info: host.IOBROKER-MASTER instance system.adapter.vis-2.0 in version "2.9.64" started with pid 1580385
      2025-01-21 12:45:24.291  - info: vis-2.0 (1580385) starting. Version 2.9.64 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.1, js-controller: 7.0.6
      2025-01-21 12:45:24.507  - info: vis-2.0 (1580385) vis-2 license is OK.
      Jemand ne Idee wo ich ansetzen soll ?
      Danke & Grüße
      Sunny
        sunny9999 @sunny9999 last edited by
        @sunny9999
        und noch die Summary :
        ```bash
                                v.2024-10-19
                 Chassis: vm 🖴
        Installation:           vmware
        User-ID:                1000
        Pending OS-Updates:     24
        Pending iob updates:    0
        Nodejs-Installation:
        Recommended versions are nodejs 20.18.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:             12G        6.6G        937M        1.4M        5.3G        5.9G
        Swap:           2.1G        524K        2.1G
        Total:           14G        6.6G        3.1G
        Active iob-Instances:   66
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.4.10
        Objects type: redis
        States  type: redis
        + system.adapter.web.0                    : web                   : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.webcal.0                 : webcal                : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                63205
        States:                 52733
        Size of iob-Database:
        22M     /opt/iobroker/iobroker-data/objects.json.migrated
        22M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        612K    /opt/iobroker/iobroker-data/states.json
        260K    /opt/iobroker/iobroker-data/states.json.bak
        === Mark text until here for copying ===
          Thomas Braun Most Active @sunny9999 last edited by
          @sunny9999
          Bring die Kiste insgesamt auf Stand. Da stehen noch Updates aus.
            sunny9999 @Thomas Braun last edited by
            Danke für Feedback
            Hab ich nun gemacht, keine Veränderung
            *** BASE SYSTEM ***
                     Chassis: vm 🖴
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             13:33:43 up 26 min,  1 user,  load average: 1.00, 0.92, 0.74
            CPU threads: 16
                           Local time: Tue 2025-01-21 13:33:43 CET
                       Universal time: Tue 2025-01-21 12:33:43 UTC
                             RTC time: Tue 2025-01-21 12:33:43
                          NTP service: active
                      RTC in local TZ: no
            debian
            HOME=/home/debian
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             12G        6.6G        3.4G        1.4M        2.8G        5.9G
            Swap:           2.1G          0B        2.1G
            Total:           14G        6.6G        5.6G
                     6264 M used memory
                      705 M active memory
                     7311 M inactive memory
                     3276 M free memory
                      234 M buffer memory
                     2474 M swap cache
                     2043 M total swap
                        0 M used swap
                     2043 M free swap
            top - 13:33:43 up 26 min,  1 user,  load average: 1.00, 0.92, 0.74
            Tasks: 370 total,   1 running, 369 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  4.0 us,  4.0 sy,  0.0 ni, 88.0 id,  0.0 wa,  0.0 hi,  4.0 si,  0.0 st
            MiB Mem :  11926.6 total,   3276.1 free,   6264.9 used,   2708.9 buff/cache
            MiB Swap:   2044.0 total,   2044.0 free,      0.0 used.   5661.8 avail Mem
            *** FILESYSTEM ***
            /dev/mapper/debian10--vg-var                                             ext4      6.4G  2.5G  3.5G  42% /var
            [Tue Jan 21 13:06:58 2025] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Jan 21 13:06:59 2025] EXT4-fs (dm-0): re-mounted. Quota mode: none.
            [Tue Jan 21 13:07:00 2025] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
            [Tue Jan 21 13:07:00 2025] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
            [Tue Jan 21 13:07:00 2025] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Jan 21 13:07:00 2025] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
            [Tue Jan 21 13:07:00 2025] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
            /var:
            2.5G    /var/
            2.0G    /var/lib
            676M    /var/lib/redis
            1.9G    /opt/iobroker/backups/
            USB-Devices by-id:
            HINT:
            tcp
            HINT:
            tcp
            nodejs:
              Version table:
            ioBroker Status
            Objects type: redis
            States  type: redis
            Hosts:
            IOBROKER-MASTER     IOBROKER-MASTER (version: 7.0.6, hostname: IOBROKER-MASTER, alive, uptime: 1593)
            IOBROKER-SLAVE      IOBROKER-SLAVE (version: 7.0.6, hostname: IOBROKER-SLAVE, alive, uptime: 709104)
            admin:          7.4.10
            javascript:     8.8.3
            Adapter State
            + system.adapter.adb.0                    : adb                   : IOBROKER-MASTER                          -  enabled
              system.adapter.alexa2.0                 : alexa2                : IOBROKER-MASTER                          - disabled
            + system.adapter.asterisk.0               : asterisk              : IOBROKER-MASTER                          -  enabled, port: 5038
            + system.adapter.backitup.0               : backitup              : IOBROKER-MASTER                          -  enabled
            + system.adapter.chromecast.0             : chromecast            : IOBROKER-MASTER                          -  enabled
            + system.adapter.discovery.0              : discovery             : IOBROKER-MASTER                          -  enabled
            + system.adapter.dreame.0                 : dreame                : IOBROKER-MASTER                          -  enabled
            + system.adapter.echarts.0                : echarts               : IOBROKER-MASTER                          -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : IOBROKER-MASTER                          -  enabled
            + system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : IOBROKER-MASTER                          -  enabled
            + system.adapter.govee-app.0              : govee-app             : IOBROKER-MASTER                          -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : IOBROKER-MASTER                          -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
            + system.adapter.hm-rpc.2                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
            + system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER-MASTER                          -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER                          -  enabled
            + system.adapter.oasecontrol.0            : oasecontrol           : IOBROKER-MASTER                          -  enabled
            + system.adapter.ocpp.0                   : ocpp                  : IOBROKER-MASTER                          -  enabled, port: 9220
            + system.adapter.onkyo.0                  : onkyo                 : IOBROKER-MASTER                          -  enabled
            + system.adapter.ping.0                   : ping                  : IOBROKER-MASTER                          -  enabled
            + system.adapter.sayit.0                  : sayit                 : IOBROKER-MASTER                          -  enabled
            + system.adapter.simple-api.0             : simple-api            : IOBROKER-MASTER                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.smartcontrol.0           : smartcontrol          : IOBROKER-MASTER                          -  enabled
            + system.adapter.smartthings.0            : smartthings           : IOBROKER-MASTER                          -  enabled
            + system.adapter.sonoff.0                 : sonoff                : IOBROKER-MASTER                          -  enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER-MASTER                          -  enabled
            + system.adapter.synology.0               : synology              : IOBROKER-MASTER                          -  enabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBROKER-MASTER                          -  enabled
            + system.adapter.text2command.0           : text2command          : IOBROKER-MASTER                          -  enabled
            + system.adapter.text2command.1           : text2command          : IOBROKER-MASTER                          -  enabled
            + system.adapter.time-switch.0            : time-switch           : IOBROKER-MASTER                          -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : IOBROKER-MASTER                          -  enabled
            + system.adapter.trashschedule.1          : trashschedule         : IOBROKER-MASTER                          -  enabled
            + system.adapter.vaillant.0               : vaillant              : IOBROKER-MASTER                          -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : IOBROKER-MASTER                          -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBROKER-MASTER                          -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : IOBROKER-MASTER                          -  enabled
            + system.adapter.yahka.0                  : yahka                 : IOBROKER-MASTER                          -  enabled
            + system.adapter.zigbee.1                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.24:6638
            + instance is alive
            Objects and States
            Objects:        63205
            States:         52732
            Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:33323         0.0.0.0:*               LISTEN      1001       24277      2442/io.yahka.0
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17057      930/cupsd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15141      939/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:33131         0.0.0.0:*               LISTEN      122        17241      1292/plugin_start_l
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18444      1/init
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       27194      2128/io.mqtt.0
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       28460      2053/io.sonoff.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       13844      2038/io.shelly.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       27193      2128/io.mqtt.0
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       21901      1529/node-red
            tcp        0      0 127.0.0.1:34661         0.0.0.0:*               LISTEN      1001       24273      2442/io.yahka.0
            tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       68725      11916/nc
            tcp        0      0 127.0.0.1:43911         0.0.0.0:*               LISTEN      1001       24285      2442/io.yahka.0
            tcp        0      0 127.0.0.1:43205         0.0.0.0:*               LISTEN      1001       24294      2442/io.yahka.0
            tcp        0      0 127.0.0.1:36455         0.0.0.0:*               LISTEN      1001       24289      2442/io.yahka.0
            tcp        0      0 127.0.0.1:44151         0.0.0.0:*               LISTEN      1001       24303      2442/io.yahka.0
            tcp        0      0 127.0.0.1:36207         0.0.0.0:*               LISTEN      1001       24281      2442/io.yahka.0
            tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        28146      963/asterisk
            tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       19169      2707/adb
            tcp        0      0 192.168.10.16:9092      0.0.0.0:*               LISTEN      1001       19901      1914/io.nuki.0
            tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       25115      1869/io.hm-rpc.2
            tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       13710      1727/io.hm-rpc.0
            tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       37946      1787/io.hm-rpc.1
            tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        19670      931/redis-server 0.
            tcp6       0      0 :::41519                :::*                    LISTEN      1001       40486      2442/io.yahka.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15143      939/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          17428      1/init
            tcp6       0      0 :::9220                 :::*                    LISTEN      1001       36385      2502/io.ocpp.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      122        24918      1258/grafana
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17056      930/cupsd
            tcp6       0      0 :::35335                :::*                    LISTEN      1001       40478      2442/io.yahka.0
            tcp6       0      0 :::43197                :::*                    LISTEN      1001       40480      2442/io.yahka.0
            tcp6       0      0 :::44713                :::*                    LISTEN      1001       40482      2442/io.yahka.0
            tcp6       0      0 :::45939                :::*                    LISTEN      1001       40476      2442/io.yahka.0
            tcp6       0      0 :::37833                :::*                    LISTEN      1001       40484      2442/io.yahka.0
            tcp6       0      0 :::46697                :::*                    LISTEN      1001       40488      2442/io.yahka.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      998        17110      971/influxd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       38247      2729/io.simple-api.
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34203      2412/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       36917      1374/io.admin.0
            tcp6       0      0 :::40845                :::*                    LISTEN      1001       40474      2442/io.yahka.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16891      1/init
            udp        0      0 0.0.0.0:51051           0.0.0.0:*                           121        13469      963/asterisk
            udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       63040      1895/io.sonos.0
            udp        0      0 0.0.0.0:52826           0.0.0.0:*                           111        18587      851/avahi-daemon: r
            udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        28163      963/asterisk
            udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        28164      963/asterisk
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25088      1802/io.chromecast.
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        18585      851/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          26635      1/init
            udp6       0      0 :::35104                :::*                                121        13470      963/asterisk
            udp6       0      0 :::59932                :::*                                111        18588      851/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                111        18586      851/avahi-daemon: r
            2025-01-21 13:20:51.628  - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 having pid 6309 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-01-21 13:25:49.011  - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 in version "2.8.5" started with pid 7985
            2025-01-21 13:25:51.730  - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 having pid 7985 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-01-21 13:30:00.031  - info: host.IOBROKER-MASTER instance system.adapter.ical.2 in version "1.16.1" started with pid 9704
            2025-01-21 13:30:04.038  - info: host.IOBROKER-MASTER instance system.adapter.ical.1 in version "1.16.1" started with pid 9721
            2025-01-21 13:30:07.722  - info: host.IOBROKER-MASTER instance system.adapter.ical.2 having pid 9704 terminated with code 0 (NO_ERROR)
            2025-01-21 13:30:08.047  - info: host.IOBROKER-MASTER instance system.adapter.ical.0 in version "1.16.1" started with pid 9736
            2025-01-21 13:30:12.063  - info: host.IOBROKER-MASTER instance system.adapter.ical.1 having pid 9721 terminated with code 0 (NO_ERROR)
            2025-01-21 13:30:15.573  - info: host.IOBROKER-MASTER instance system.adapter.ical.0 having pid 9736 terminated with code 0 (NO_ERROR)
            2025-01-21 13:30:38.014  - info: host.IOBROKER-MASTER instance system.adapter.daswetter.0 in version "3.2.2" started with pid 9763
            2025-01-21 13:30:44.182  - info: host.IOBROKER-MASTER instance system.adapter.daswetter.0 having pid 9763 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-01-21 13:30:44.183  - info: javascript.0 (1455) script.js.common.Wetterstation.Wetterdatengraph: Material Design Widgets: Wetter Skript triggered by 'system.adapter.daswetter.0.alive'
            2025-01-21 13:30:49.012  - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 in version "2.8.5" started with pid 9778
            2025-01-21 13:30:52.031  - info: host.IOBROKER-MASTER instance system.adapter.dwd.0 having pid 9778 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-01-21 13:31:59.859  - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252
            2025-01-21 13:32:12.356  - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin
            2025-01-21 13:32:14.080  - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252
            2025-01-21 13:32:19.539  - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252
            2025-01-21 13:32:30.923  - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252
            2025-01-21 13:32:57.848  - info: admin.0 (1374) ==> Connected system.user.markus from ::ffff:192.168.10.252
            2025-01-21 13:33:27.904  - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin
            2025-01-21 13:33:30.434  - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 javascript
            2025-01-21 13:33:30.436  - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin
            2025-01-21 13:33:33.790  - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin
            2025-01-21 13:33:35.331  - info: admin.0 (1374) <== Disconnect system.user.markus from ::ffff:192.168.10.252 admin
            v.2024-10-19
            Chassis: vm 🖴
            Kernel: x86_64
            Userland: 64 bit
            User-ID: 1000
            Pending OS-Updates: 0
            /usr/bin/npm 10.8.2
            /usr/bin/npx 10.8.2
            MEMORY:
            total used free shared buff/cache available
            Mem: 12G 6.6G 3.0G 1.4M 3.3G 5.9G
            Swap: 2.1G 0B 2.1G
            Total: 14G 6.6G 5.1G
            admin 7.4.10
            ioBroker Status: iobroker is running on this host.
            Objects type: redis
            States type: redis
            • system.adapter.admin.0 : admin : IOBROKER-MASTER - enabled, port: 8081, bind: 0.0.0.0, run as: admin
            • system.adapter.web.0 : web : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            • system.adapter.webcal.0 : webcal : IOBROKER-MASTER - enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects: 63205
            States: 52732
            Was immer mörderlange dauert sind den Objekt Tab zu laden....aber der Rest auch, mindestens ne Minute oder zwei pro tab, wenn er überhaupt aufgeht.....
            Noch ne Idee ?
            Sunny
              Homoran Global Moderator Administrators @sunny9999 last edited by
              @sunny9999 sagte in Massive Performance Probleme beim GUI Zugriff:
              dann hast du zu viele Nodes geöffnet.
              Pass auf, dass dir die Ansicht nicht einfriert.
              was zeigt denn die Browser Konsole?
                sunny9999 @Homoran last edited by
                Browser Console zeigt nur :
                iobroker.admin@7.0.25
                socket.io.js:1 [2025-01-21T13:49:43.058Z] Try to connect
                • haselchen
                  haselchen Most Active @sunny9999 last edited by
                  @sunny9999
                  Was für nen Slave schleppst Du mit rum?
                  Welche Hardware?
                  Web und Webcal benutzen den gleichen Port .
                  Da mal verschiedene auswählen.
                    sunny9999 @haselchen last edited by
                    @haselchen
                    @haselchen
                    Danke für den Hinweis...
                    Sag mal bitte wo ich den Port für Webcal ändern kann ? In der Instanz steht nichts ....
                    Danke für nen Tip !
                    Sunny
