    4. Automatisierung
    5. Nuki smart Lock Gen. 4 pro
    UNSOLVED Nuki smart Lock Gen. 4 pro
    • I
      ioBroker 0 last edited by
      habe mir ein Nuki Smart Lock Gen. 4 pro zugelegt und in ioBroker eingebunden.
      die web api macht mir aber Probleme laut dem log .
      Ich nutze den nuki-extended.0 Adapter der auch über den Instanzlink Daten bekommt.
      nuki-extended.0
      3640 2025-01-25 19:37:02.712 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:57.714 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:52.723 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:47.715 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:42.717 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:37.711 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:32.712 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:27.716 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:22.713 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:17.717 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      nuki-extended.0
      3640 2025-01-25 19:36:12.718 warn getWebApi(): Error retrieving users: 401 - {"detailMessage":"Your access token is not authorized","stackTrace":[],"suppressedExceptions":[]}
      Hat jemand das gleiche Problem oder noch besser eine Lösung hierfür ??
        A Former User @ioBroker 0 last edited by
        @iobroker-0
        Dein Token ist nicht authorisiert.. Check den mal, da ist der Hund begraben..
        • I
          @ilovegym
          Servus,
          was soll ich wo checken ?
          Unter web.nuki.io läuft alles keine Meldung und alle Berechtigungen vergeben.
          Bei ioBroker unter Instanzen bekommt der Instanzlink des Adapter auch Daten.
          Und steuern kann ich aus dem ioBroker auch, nur diese ständigen Warnungen nerven.
          Kannst du mir helfen was und wo ich nachschauen kann ?
          Steh momentan etwas auf dem Schlauch
            @iobroker-0
            achso, es funktioniert alles, du hast nur die Warnungen.. vielleicht fragst du zu oft ab?
            Ich nutze keine Nuki-Adapter mehr in iobroker, mach das mit ESP32&Nukihub - das bleibt lokal und ist gesichert.
