    5. Wert in einen Datenunkt schreiben
      krodon last edited by krodon
      Hallo ich möchte den State einer LED in einen Datenpunkt schreiben. Es handelt sich um switch_led des Typs Boolean. Diesen Punkt habe ich auch so angelegt Mit folgendem Script schreibe ich ihn::
      on({ id: 'mihome.0.devices.switch_158d00023e651b.click' /* Simple click */, val: true }, async (obj) => {
        let value = obj.state.val;
        setState('0_userdata.0.Licht.Fenster3.switch_led' /* Licht.Fenster3.switch_led */, Object.keys(getObject('tuya.0.bff11e43a9cf6c6fd92nlc.20')));
      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
      Wenn ich es nun ausführe, bekomme ich folgenden Fehler:
      javascript.0
      2025-01-27 15:31:42.346	warn	at process.processImmediate (node:internal/timers:483:21)
      javascript.0
      2025-01-27 15:31:42.345	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      javascript.0
      2025-01-27 15:31:42.345	warn	at Object.<anonymous> (script.js.Licht.Küche.Test_Variable:5:3)
      javascript.0
      2025-01-27 15:31:42.345	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
      javascript.0
      2025-01-27 15:31:42.345	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      javascript.0
      2025-01-27 15:31:42.345	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7336:48)
      javascript.0
      2025-01-27 15:31:42.344	warn	You are assigning a array to the state "0_userdata.0.Licht.Fenster3.switch_led" which expects a boolean. Please fix your code to use a boolean or change the state type to array. This warning might become an error in future versions.
      Wo liegt mein Fehler?
      Ideal wäre ein Script, das alle Leuchten im Tuya Adapter mit den Werten switch::led, work_mode, bright_value und colour_data RGB ausließt.
      VG
      Krodon
      Homoran paul53 haus-automatisierung 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @krodon last edited by
        @krodon sagte in Wert in einen Datenunkt schreiben:
        wenn das ein Blockly ist, wie die Kategorie erahnen lässt, bitte auch das Blockly zeigen
          krodon @Homoran last edited by
          @homoran ich habe es eingefügt, leider habe ich den rechten Teil nicht komplett drauf bekommen
            paul53 @krodon last edited by paul53
            @krodon sagte: You are assigning a array to the state "0_userdata.0.Licht.Fenster3.switch_led" which expects a boolean
            Was willst du mit der Liste der Objekt-Attribute?
            Für eigene Datenpunkte verwendet man Block "aktualisiere" anstelle von "steuere".
            • haus-automatisierung
              haus-automatisierung Developer Most Active @krodon last edited by haus-automatisierung
              Ja, die erwartet einen Boolschen Wert. Also true oder false. Du schreibst alle Attribute eines Objektes (was ein Array ist) in den Datenpunkt. Das ist natürlich Quatsch. Was möchtest Du damit bezwecken?
              Suchst Du eventuell einfach nur den "umschalten"-Baustein, wenn Du auf den Button drückst?
              Grundlagen anschauen (wobei Du ja seit 2018 dabei bist und das eigentlich können müsstest).
              K 2 Replies Last reply Reply Quote 1
                krodon @haus-automatisierung last edited by
                @haus-automatisierung ich möchte nur einzelne Datenpunkte aus einem Array schreiben, nicht eine Kopie des Arrays. Der Hintergedanken ist nachdem ein Bewegungsmelder die Beleuchtung verändert hat, den alten Zustand wieder zu erzeugen.
                VG
                Krodon
                  @krodon sagte: Beleuchtung verändert hat, den alten Zustand wieder zu erzeugen.
                  Dann verwende eine ID-Liste mit allen betreffenden Datenpunkten und eine korrespondierende Werte-Liste, in der die Werte in einer Schleife gemerkt werden.
                  Prinzip:
                    @haus-automatisierung said in Wert in einen Datenunkt schreiben:
                    Leider hatte ich mich die letzten Jahre nicht mehr damit beschftigt 😞
                      krodon @paul53 last edited by
                      @paul53 danke für das script. In meinen Augen ist es komplex, verstehe aber im Prinzip was Du damit bezweckst. Zu Blockly habe ich immer nur sehr einfache Anleitungen gefunden. Hast Du eine Quelle die besser ist?
                      VG
                      Edi
                        Möglicherweise liegt das an deinen Anforderungen.
                        eine einfache Lampe, bei der nur an/aus geschaltet würde wäte nur ein Parameter
                        selbst bei einer gedimmten Lsmpe wäte es nur Brightness, die zwischengespeichert werden müsste
                          krodon @Homoran last edited by krodon
                          @homoran said in Wert in einen Datenunkt schreiben:
                          Die einfache Lampe ist nur ein erster Schritt, bei dem ich lernen möchte, ich habe noch anspruchsvollere Iden. Das Problem ist, dass mir Javascript nicht liegt oder ich auch nicht die Zeit hierfür finde.
                          Bei Blockly habe ich leider keine Anleitungen für "for each" und "array" finden können, dies würde viel weiterhelfen.
                          Dennoch bleibt noch mein ursprüngliches Problem, wie ich ein Boolean in das Array schreiben kann. Mir fehlt der Befehl "dim"
                          VG
                          Krodon
                            @krodon sagte: wie ich ein Boolean in das Array schreiben kann.
                            In ein Array kann man jeden Wert schreiben - egal ob boolean, number, string oder object - und das auch gemischt.
                            Ich hatte in meinem Vorschlag die "for Schleife" mit Index-Zähler verwendet, weil nur bei dieser Schleife die Reihenfolge garantiert ist.
                              @paul53 said in Wert in einen Datenunkt schreiben:
                              Wieso bekomme ich dann diese Fehlermeldung?
                              javascript.0
                              In VBScript konnte ich die einzelnen Ebenen definieren.
                              Hast Du gute Anleitungen zu Blockly die weiter als die Basics gehen?
                              VG
                              Krodon
                                @krodon sagte: Wieso bekomme ich dann diese Fehlermeldung?
                                Du schreibst ein Array in einen Datenpunkt vom Typ "boolean".
                                Zeige mal das Skript!
                                  @paul53 das Script steht gleich im ersten Posting.
                                  VG
                                  Krodon
                                    @krodon sagte: das Script steht gleich im ersten Posting.
                                    Das Skript ist sinnfrei. Was soll es machen?
                                    Der Attribute-Block liefert eine Liste der Objekt-Keys:
                                    [ '_id', 'type', 'common', 'native', 'acl', 'from', 'user', 'ts' ]
                                      Ich möchte nicht das komplette Array in den Datenpunkt schreiben, sondern nur die Variable switch_led, die vom Wert boolean ist, so ist auch der Datenpunkt definiert.
                                      VG
                                      Krodon
                                        Ich fürchte du bist dir nicht bewusst, was das für ein Array ist, das du da speichersz.
                                        @paul53 hat es fir eben gezeigt.
                                        Ist es das wovon du redest?
                                          @krodon sagte: sondern nur die Variable switch_led
                                          Du meinst den Datenpunkt-Wert von "switch_led"? Dann so:
                                            Erst mal vielen Dank!
                                            Leider kann ich es erst kommendes WE ausprobieren.
                                            VG
                                            Krodon
                                            731
