    4. ESPhome 0.5.0. Beta 8 Fehlermeldung
    • RaspiUser
      RaspiUser last edited by
      ... wegen "Nice to have" habe ich den ESPhome Adapter (Beta Repro) installiert und bekomme nach dem connecten eines ESP8266 mini im ESPhome Dashboard diese Fehlermeldung:
      INFO ESPHome 2024.8.3
      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-6c16ca.yaml...
      Failed config
      esphome: None
        friendly_name: ESPHome Web 6c16ca
        Your ESPHome version is too old. Please update to at least 2024.11.0.
        min_version: 2024.11.0
        name_add_mac_suffix: False
        build_path: build/esphome-web-6c16ca
      Da ich nix durch try&error kaputt machen möchte (Su.fu. brachte mir keine konkreten ToDo's) frage ich hier lieber nach ...
      Hier noch die iob diag Abfrage, die wohl alle Fragen zum System beantworten sollte.
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: VM-ioBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-29-amd64
          Architecture: x86-64
       Hardware Vendor: qemu
        Hardware Model: qemu
      Firmware Version: e0d6339-dirty-20220919_024111-d528eb931742
      OS is similar to:
      model name      : Westmere E56xx/L56xx/X56xx (Nehalem-C)
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:42:33 up 4 days,  1:54,  2 users,  load average: 0.52, 0.27, 0.15
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-01-28 11:42:33 CET
                 Universal time: Tue 2025-01-28 10:42:33 UTC
                       RTC time: Tue 2025-01-28 10:42:33
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      raspiuser
      HOME=/home/raspiuser
      GROUPS=raspiuser adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.3G        2.6G        4.3G        602K        1.8G        5.7G
      Swap:           1.0G          0B        1.0G
      Total:          9.3G        2.6G        5.3G
      Active iob-Instances:   29
               7940 M total memory
               2462 M used memory
                724 M active memory
               2862 M inactive memory
               4054 M free memory
                240 M buffer memory
               1462 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 11:42:33 up 4 days,  1:54,  2 users,  load average: 0.52, 0.27, 0.15
      Tasks: 142 total,   1 running, 141 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7940.7 total,   4054.2 free,   2462.0 used,   1702.7 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   5478.7 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  588K  794M   1% /run
      /dev/sda1      ext4       48G  9.4G   37G  21% /
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     795M     0  795M   0% /run/user/1001
      [Fri Jan 24 09:48:24 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Jan 24 09:48:25 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      1.7G    /var/
      1015M   /var/log
      1001M   /var/log/journal/27bb2095ba2b41ccb088ec3ad41fc1f5
      544M    /var/cache
      Archived and active journals take up 1000.0M in the file system.
      /opt/iobroker/backups:
      20M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      882M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      46M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      VM-ioBroker         VM-ioBroker (version: 7.0.6, hostname: VM-ioBroker   , alive, uptime: 152917)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     1
      +-- iobroker.canbus@2.1.0 (git+ssh://git@github.com/crycode-de/ioBroker.canbus.git#27e0b1c58cf5ca0ff8668c10a5e34d5c6670f921)
      Adapter State
      + system.adapter.admin.0                  : admin                 : VM-ioBroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alpha-ess.0              : alpha-ess             : VM-ioBroker                              -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : VM-ioBroker                              -  enabled
        system.adapter.awtrix-light.1           : awtrix-light          : VM-ioBroker                              - disabled
      + system.adapter.backitup.0               : backitup              : VM-ioBroker                              -  enabled
      + system.adapter.canbus.0                 : canbus                : VM-ioBroker                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : VM-ioBroker                              -  enabled
      + system.adapter.discovery.0              : discovery             : VM-ioBroker                              -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: VM-ioBroker                              - disabled
      + system.adapter.esphome.0                : esphome               : VM-ioBroker                              -  enabled
        system.adapter.feiertage.0              : feiertage             : VM-ioBroker                              -  enabled
      + system.adapter.frontier_silicon.0       : frontier_silicon      : VM-ioBroker                              -  enabled
      + system.adapter.go-e.0                   : go-e                  : VM-ioBroker                              -  enabled
        system.adapter.history.0                : history               : VM-ioBroker                              - disabled
      + system.adapter.hm-rega.0                : hm-rega               : VM-ioBroker                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : VM-ioBroker                              -  enabled, port: 0
        system.adapter.influxdb.0               : influxdb              : VM-ioBroker                              - disabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : VM-ioBroker                              -  enabled
      + system.adapter.javascript.0             : javascript            : VM-ioBroker                              -  enabled
      + system.adapter.klf200.0                 : klf200                : VM-ioBroker                              -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : VM-ioBroker                              -  enabled
        system.adapter.luftdaten.0              : luftdaten             : VM-ioBroker                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : VM-ioBroker                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.onkyo.0                  : onkyo                 : VM-ioBroker                              -  enabled
        system.adapter.openweathermap.0         : openweathermap        : VM-ioBroker                              - disabled
      + system.adapter.sainlogic.0              : sainlogic             : VM-ioBroker                              -  enabled, port: 1030, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : VM-ioBroker                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : VM-ioBroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : VM-ioBroker                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : VM-ioBroker                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : VM-ioBroker                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : VM-ioBroker                              -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : VM-ioBroker                              -  enabled
      + system.adapter.web.0                    : web                   : VM-ioBroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : VM-ioBroker                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_c421aa81b69ded118718d3a5a7669f5d-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
      Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "canbus"       : 1.3.1    , installed 2.1.0
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "frontier_silicon": 0.3.0 , installed 0.3.0
      Adapter    "go-e"         : 1.0.41   , installed 1.0.41
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "klf200"       : 1.3.5    , installed 1.3.5
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "sainlogic"    : 0.11.6   , installed 0.11.6
      Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        6862
      States:         5183
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.120:42010   0.0.0.0:*               LISTEN      1000       200357     17376/io.hm-rpc.1
      tcp        0      0 192.168.178.120:42001   0.0.0.0:*               LISTEN      1000       200352     17361/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       198354     17150/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       198359     17150/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2723       531/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14540      1/init
      tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       323902     21243/python3
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       201729     17406/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       200428     17451/io.sonoff.0
      tcp        0      0 0.0.0.0:1030            0.0.0.0:*               LISTEN      1000       333928     22451/io.sainlogic.
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       202877     17574/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       198439     17171/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       200958     17589/io.simple-api
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15422      531/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2301       1/init
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       323903     21190/io.esphome.0
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       323024     21243/python3
      udp        0      0 192.168.178.120:5353    0.0.0.0:*                           1000       323023     21243/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       323019     21243/python3
      udp        0      0 0.0.0.0:20000           0.0.0.0:*                           65534      17242      594/cannelloni
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15148      384/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1505       1/init
      udp6       0      0 :::111                  :::*                                0          14128      1/init
      2025-01-28 11:41:24.837  - info: host.VM-ioBroker iobroker NPM version: 10.8.2Installing iobroker.sainlogic@0.11.6... (System call)
      2025-01-28 11:41:29.312  - info: host.VM-ioBroker iobroker changed 1 package in 4s
      2025-01-28 11:41:29.313  - info: host.VM-ioBroker iobroker
      2025-01-28 11:41:29.319  - info: host.VM-ioBroker iobroker 168 packages are looking for funding  run `npm fund` for details
      2025-01-28 11:41:29.362  - info: host.VM-ioBroker iobroker Updating objects from io-package.json for adapter "sainlogic" with version "0.11.6"
      2025-01-28 11:41:29.426  - info: host.VM-ioBroker iobroker Update "system.adapter.sainlogic.0"
      2025-01-28 11:41:29.437  - info: host.VM-ioBroker stopInstance system.adapter.sainlogic.0 (force=false, process=true)
      2025-01-28 11:41:29.442  - info: sainlogic.0 (17542) Got terminate signal TERMINATE_YOURSELF
      2025-01-28 11:41:29.445  - info: sainlogic.0 (17542) Sainlogic Adapter gracefully shut down...
      2025-01-28 11:41:29.446  - info: sainlogic.0 (17542) terminating
      2025-01-28 11:41:29.447  - info: sainlogic.0 (17542) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-01-28 11:41:29.448  - info: sainlogic.0 (17542) Listener closed.
      2025-01-28 11:41:29.494  - info: host.VM-ioBroker stopInstance system.adapter.sainlogic.0 send kill signal
      2025-01-28 11:41:29.580  - info: host.VM-ioBroker iobroker upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
      2025-01-28 11:41:29.609  - info: host.VM-ioBroker iobroker upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
      2025-01-28 11:41:29.617  - info: host.VM-ioBroker iobroker upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
      2025-01-28 11:41:29.634  - info: host.VM-ioBroker iobroker upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
      2025-01-28 11:41:29.643  - info: host.VM-ioBroker iobroker upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
      2025-01-28 11:41:29.948  - info: sainlogic.0 (17542) terminating
      2025-01-28 11:41:30.008  - info: host.VM-ioBroker instance system.adapter.sainlogic.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-01-28 11:41:30.671  - info: host.VM-ioBroker iobroker exit 0
      2025-01-28 11:41:33.345  - info: host.VM-ioBroker instance system.adapter.sainlogic.0 in version "0.11.6" started with pid 22451
      2025-01-28 11:41:34.859  - info: sainlogic.0 (22451) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.sainlogic, node: v20.18.2, js-controller: 7.0.6
      2025-01-28 11:41:34.880  - info: sainlogic.0 (22451) Starting Listener
      2025-01-28 11:42:20.366  - info: admin.0 (17171) <== Disconnect system.user.admin from ::ffff:192.168.178.95 admin
      Danke für die Hilfestellung ...
        Thomas Braun Most Active @RaspiUser last edited by
        @raspiuser sagte in ESPhome 0.5.0. Beta 8 Fehlermeldung:
        Du hast INFO ESPHome 2024.8.3 am Start.
        RaspiUser 1 Reply Last reply Reply Quote 0
        • RaspiUser
          RaspiUser @Thomas Braun last edited by
          @thomas-braun sagte in ESPhome 0.5.0. Beta 8 Fehlermeldung:
          ... das hatte ich auch gelesen.
          Aber ich finde nix, wie man "Please update to at least 2024.11.0." macht ...
          Im Adapter finde ich nix, auf esphome.io bin ich "überfordert" ...
          Ist das irgend etwas auf LINUX Ebene ?
            Von ESPHome hab ich keine Ahnung.
            Was 'überfordert' dich denn konkret?
            • RaspiUser
              ... da sind wir schon zwei ...
              Wenn ich auf esphome.io z.B. nach "2024.11.0" suchen lasse, kriege ich nix, was MIR weiterhilft (bzw. ich verstehe).
              Da derHinweis ja im Adapter auftaucht, hoffe ich auch hier in diesem Forum eine Antwort zu bekommen.
              Ich suche weiter ... es gibt ja auch ESPhome Foren ...
                Thomas Braun Most Active @RaspiUser last edited by Thomas Braun
                Mit dem Unterschied, das ich es gar nicht verwende.
                €dit:
                Ist wohl ein pip-Paket und lässt sich entsprechend dann auch per
                pipx install esphome
                installieren/updaten.
                • RaspiUser
                  RaspiUser @Thomas Braun last edited by RaspiUser
                  ... und ich es auch nur mal ausprobieren wollte ...
                  Danke für den pip-Hinweis ... schau ich mir mal an.
                  EDIT:
                  • Ich habe mal die Version Beta 10 über Gihub installiert. In den Einstellungen der Instanz wäre es möglich gewesen, die ESPhome Version (also auch 2024.11.0) aus zu wählen oder "always the latest".
                  • Bei dieser Version startete das Dasboard aber garnicht, also den Adapter gelöscht und zurück zu 8.
                  • ... und zu "pip":
                  raspiuser@VM-ioBroker:~$ python3 --version
                  Python 3.11.2
                  raspiuser@VM-ioBroker:~$ esphome version
                  -bash: esphome: Kommando nicht gefunden.
                  Also bevor ich jetzt etwas "kaputt" mache, mache ich lieber nix.
                  Wenn hier niemand die Lösung hat, gerne her damit ... ansonsten war es das mit "ESPhome ausprobieren" bzw. "nice to have".
                    AndreasE112 @RaspiUser last edited by
                    Hi, ich habe den Adapter eben installiert. Er läuft aber das Webinterface geht nicht.
                    In den Adaptereinstellungen sehe ich mein "device".
                    Hat jemand ähnliche Erfahrungen gemacht und evtl. eine Lösung ?
                    Y 1 Reply Last reply Reply Quote 0
                    • Y
                      yettiz @AndreasE112 last edited by
                      @andrease112 said in ESPhome 0.5.0. Beta 8 Fehlermeldung:
                      Hab das selbe Problem allerdings mit ESPHome 2024.10.3
                      Webinterface funktioniert, aber beim Install von dieser kommt die Meldung mit der Version.
                      Finde aber nichts wie man auf ESPHome 2025.02.0. updatet
                      Die Sourcen liegen auf Github von Esphome, aber die Beta ist immer noch bei 8.
                      Würde ESPHome gerne testen/nutzen.
                      Hab sonst Shelly und Tasmota am laufen, Shelly wegen dem EM3 Pro, sonst alles auf Tasmota.
                      Und HA installieren für ESPHome muss nicht sein, HA hatte ich bereits und das taugt mir nicht.
