    4. error by Controller0 nach Restart
    • G
      grazer2500 last edited by
      Guten Abend,
      Ich habe mein System geupdatet, und bekomme immer beim Neustart folgende fehlermeldungen. Habe leider bei der suche nichts darüber gefunden.
      host.iobroker 2025-01-31 19:01:04.513	error	Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
      host.iobroker 2025-01-31 19:01:04.497	error	Caught by controller[0]: (node:2204) [DEP0170] DeprecationWarning: The URL http://IP:PORT/api/events/raw is invalid. Future versions of Node.js will throw an error.
      Der iob diag:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.6.74+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       19:07:01 up 7 min,  4 users,  load average: 0.84, 1.20, 0.76
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2025-01-31 19:07:01 CET
                 Universal time: Fri 2025-01-31 18:07:01 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      daniel
      HOME=/home/daniel
      GROUPS=daniel adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.2G        1.6G        5.8G         19M        945M        6.6G
      Swap:           209M          0B        209M
      Total:          8.4G        1.6G        6.0G
      Active iob-Instances:   20
               7821 M total memory
               1523 M used memory
               1669 M active memory
                487 M inactive memory
               5501 M free memory
                 50 M buffer memory
                850 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 19:07:02 up 7 min,  4 users,  load average: 0.84, 1.20, 0.76
      Tasks: 235 total,   1 running, 234 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7821.9 total,   5500.3 free,   1524.4 used,    902.0 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6297.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     783M  1.3M  781M   1% /run
      /dev/mmcblk0p2 ext4       29G   11G   17G  39% /
      tmpfs          tmpfs     3.9G  148K  3.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
      tmpfs          tmpfs     783M   48K  783M   1% /run/user/1000
      [Fri Jan 31 18:59:23 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:91:FC:1D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=464d8fc4-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Fri Jan 31 18:59:25 2025] EXT4-fs (mmcblk0p2): mounted filesystem 12974fe2-889e-4060-b497-1d6ac3fbbb4b ro with ordered data mode. Quota mode: none.
      [Fri Jan 31 18:59:26 2025] EXT4-fs (mmcblk0p2): re-mounted 12974fe2-889e-4060-b497-1d6ac3fbbb4b r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.5G    /var/
      621M    /var/cache
      608M    /var/cache/apt
      495M    /var/cache/apt/archives
      481M    /var/log
      Archived and active journals take up 479.9M in the file system.
      /opt/iobroker/backups:
      246M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 459)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.daikin.0                 : daikin                : iobroker                                 -  enabled
      + system.adapter.daikin.1                 : daikin                : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.froeling.0               : froeling              : iobroker                                 -  enabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
      + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.0.10, run as: admin
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 192.168.0.10, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "froeling"     : 0.0.8    , installed 0.0.8
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "reolink"      : 1.1.2    , installed 1.1.2
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        14247
      States:         11988
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.0.10:8084       0.0.0.0:*               LISTEN      1001       14969      2234/io.ws.0
      tcp        0      0 192.168.0.10:8082       0.0.0.0:*               LISTEN      1001       15500      2219/io.web.0
      tcp        0      0 192.168.0.10:49293      0.0.0.0:*               LISTEN      1001       11253      2073/io.hm-rpc.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7382       751/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8804       738/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8799       738/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          5698       737/cupsd
      tcp        0      0 192.168.0.10:42010      0.0.0.0:*               LISTEN      1001       10094      2058/io.hm-rpc.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          5697       737/cupsd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12614      1289/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7384       751/sshd: /usr/sbin
      udp        0      0 0.0.0.0:42005           0.0.0.0:*                           1001       11676      1972/io.daikin.0
      udp        0      0 0.0.0.0:46118           0.0.0.0:*                           1001       12871      2039/io.hm-rega.0
      udp        0      0 0.0.0.0:58435           0.0.0.0:*                           1001       12277      2144/io.fronius-sol
      udp        0      0 0.0.0.0:37960           0.0.0.0:*                           1001       13458      2159/io.smartgarden
      udp        0      0 0.0.0.0:58444           0.0.0.0:*                           1001       14906      2189/io.vis-inventw
      udp        0      0 0.0.0.0:54358           0.0.0.0:*                           1001       13151      2133/io.froeling.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        8322       560/avahi-daemon: r
      udp        0      0 0.0.0.0:34174           0.0.0.0:*                           1001       10237      2084/io.discovery.0
      udp        0      0 0.0.0.0:46483           0.0.0.0:*                           1001       12278      2144/io.fronius-sol
      udp        0      0 0.0.0.0:42411           0.0.0.0:*                           1001       13719      738/iobroker.js-con
      udp        0      0 0.0.0.0:58815           0.0.0.0:*                           1001       12868      2039/io.hm-rega.0
      udp        0      0 0.0.0.0:54720           0.0.0.0:*                           1001       11874      2073/io.hm-rpc.1
      udp        0      0 0.0.0.0:58816           0.0.0.0:*                           1001       12902      2058/io.hm-rpc.0
      udp        0      0 0.0.0.0:42479           0.0.0.0:*                           1001       11876      2073/io.hm-rpc.1
      udp        0      0 0.0.0.0:58909           0.0.0.0:*                           1001       9488       1510/io.history.0
      udp        0      0 0.0.0.0:50788           0.0.0.0:*                           1001       12870      2039/io.hm-rega.0
      udp        0      0 0.0.0.0:50850           0.0.0.0:*                           1001       10557      1289/io.admin.0
      udp        0      0 0.0.0.0:50866           0.0.0.0:*                           1001       11674      1972/io.daikin.0
      udp        0      0 0.0.0.0:59078           0.0.0.0:*                           1001       14554      2114/io.energieflus
      udp        0      0 0.0.0.0:42766           0.0.0.0:*                           1001       10554      1289/io.admin.0
      udp        0      0 0.0.0.0:55071           0.0.0.0:*                           1001       14905      2189/io.vis-inventw
      udp        0      0 0.0.0.0:42811           0.0.0.0:*                           104        8324       560/avahi-daemon: r
      udp        0      0 0.0.0.0:59208           0.0.0.0:*                           1001       14555      2114/io.energieflus
      udp        0      0 0.0.0.0:55134           0.0.0.0:*                           1001       10234      2084/io.discovery.0
      udp        0      0 0.0.0.0:51059           0.0.0.0:*                           1001       12280      2144/io.fronius-sol
      udp        0      0 0.0.0.0:59262           0.0.0.0:*                           1001       12279      2144/io.fronius-sol
      udp        0      0 0.0.0.0:55374           0.0.0.0:*                           1001       15494      2219/io.web.0
      udp        0      0 0.0.0.0:51368           0.0.0.0:*                           1001       10977      1910/io.javascript.
      udp        0      0 0.0.0.0:51437           0.0.0.0:*                           1001       9487       1510/io.history.0
      udp        0      0 0.0.0.0:59669           0.0.0.0:*                           1001       14907      2189/io.vis-inventw
      udp        0      0 0.0.0.0:43298           0.0.0.0:*                           1001       10236      2084/io.discovery.0
      udp        0      0 0.0.0.0:59765           0.0.0.0:*                           1001       9935       1936/io.backitup.0
      udp        0      0 0.0.0.0:59801           0.0.0.0:*                           1001       13456      2159/io.smartgarden
      udp        0      0 0.0.0.0:51645           0.0.0.0:*                           1001       11877      2073/io.hm-rpc.1
      udp        0      0 0.0.0.0:55866           0.0.0.0:*                           1001       10556      1289/io.admin.0
      udp        0      0 0.0.0.0:51881           0.0.0.0:*                           1001       14962      2234/io.ws.0
      udp        0      0 0.0.0.0:47902           0.0.0.0:*                           1001       14553      2114/io.energieflus
      udp        0      0 0.0.0.0:39751           0.0.0.0:*                           1001       12903      2058/io.hm-rpc.0
      udp        0      0 0.0.0.0:35700           0.0.0.0:*                           1001       13720      738/iobroker.js-con
      udp        0      0 0.0.0.0:39802           0.0.0.0:*                           1001       16458      2174/io.vis-2.0
      udp        0      0 0.0.0.0:39828           0.0.0.0:*                           1001       10019      2009/io.daikin.1
      udp        0      0 0.0.0.0:35736           0.0.0.0:*                           1001       13152      2133/io.froeling.0
      udp        0      0 0.0.0.0:56252           0.0.0.0:*                           1001       9489       1510/io.history.0
      udp        0      0 0.0.0.0:56258           0.0.0.0:*                           1001       11095      2024/io.fronius.0
      udp        0      0 0.0.0.0:48206           0.0.0.0:*                           1001       13718      738/iobroker.js-con
      udp        0      0 0.0.0.0:60551           0.0.0.0:*                           1001       14908      2189/io.vis-inventw
      udp        0      0 0.0.0.0:48280           0.0.0.0:*                           1001       12905      2058/io.hm-rpc.0
      udp        0      0 0.0.0.0:44186           0.0.0.0:*                           1001       16456      2174/io.vis-2.0
      udp        0      0 0.0.0.0:36027           0.0.0.0:*                           1001       11875      2073/io.hm-rpc.1
      udp        0      0 0.0.0.0:36078           0.0.0.0:*                           1001       15493      2219/io.web.0
      udp        0      0 0.0.0.0:52518           0.0.0.0:*                           1001       16457      2174/io.vis-2.0
      udp        0      0 0.0.0.0:56735           0.0.0.0:*                           1001       12869      2039/io.hm-rega.0
      udp        0      0 0.0.0.0:48547           0.0.0.0:*                           1001       11098      2024/io.fronius.0
      udp        0      0 0.0.0.0:44454           0.0.0.0:*                           1001       10018      2009/io.daikin.1
      udp        0      0 0.0.0.0:40400           0.0.0.0:*                           1001       14965      2234/io.ws.0
      udp        0      0 0.0.0.0:40438           0.0.0.0:*                           1001       10976      1910/io.javascript.
      udp        0      0 0.0.0.0:36456           0.0.0.0:*                           1001       16459      2174/io.vis-2.0
      udp        0      0 0.0.0.0:44719           0.0.0.0:*                           1001       9934       1936/io.backitup.0
      udp        0      0 0.0.0.0:44830           0.0.0.0:*                           1001       11096      2024/io.fronius.0
      udp        0      0 0.0.0.0:44832           0.0.0.0:*                           1001       13459      2159/io.smartgarden
      udp        0      0 0.0.0.0:44972           0.0.0.0:*                           1001       13457      2159/io.smartgarden
      udp        0      0 0.0.0.0:53263           0.0.0.0:*                           1001       11673      1972/io.daikin.0
      udp        0      0 0.0.0.0:32817           0.0.0.0:*                           1001       13153      2133/io.froeling.0
      udp        0      0 0.0.0.0:32838           0.0.0.0:*                           1001       10555      1289/io.admin.0
      udp        0      0 0.0.0.0:57443           0.0.0.0:*                           1001       14556      2114/io.energieflus
      udp        0      0 0.0.0.0:53388           0.0.0.0:*                           1001       10974      1910/io.javascript.
      udp        0      0 0.0.0.0:32991           0.0.0.0:*                           1001       9933       1936/io.backitup.0
      udp        0      0 0.0.0.0:57586           0.0.0.0:*                           1001       13721      738/iobroker.js-con
      udp        0      0 0.0.0.0:49418           0.0.0.0:*                           1001       14963      2234/io.ws.0
      udp        0      0 0.0.0.0:33205           0.0.0.0:*                           1001       15491      2219/io.web.0
      udp        0      0 0.0.0.0:57785           0.0.0.0:*                           1001       10975      1910/io.javascript.
      udp        0      0 0.0.0.0:37472           0.0.0.0:*                           1001       12904      2058/io.hm-rpc.0
      udp        0      0 0.0.0.0:45680           0.0.0.0:*                           1001       14964      2234/io.ws.0
      udp        0      0 0.0.0.0:37510           0.0.0.0:*                           1001       11675      1972/io.daikin.0
      udp        0      0 0.0.0.0:41631           0.0.0.0:*                           1001       9486       1510/io.history.0
      udp        0      0 0.0.0.0:45817           0.0.0.0:*                           1001       15492      2219/io.web.0
      udp        0      0 0.0.0.0:54109           0.0.0.0:*                           1001       10016      2009/io.daikin.1
      udp        0      0 0.0.0.0:41823           0.0.0.0:*                           1001       10017      2009/io.daikin.1
      udp        0      0 0.0.0.0:54161           0.0.0.0:*                           1001       11097      2024/io.fronius.0
      udp        0      0 0.0.0.0:46010           0.0.0.0:*                           1001       10235      2084/io.discovery.0
      udp        0      0 0.0.0.0:41922           0.0.0.0:*                           1001       9936       1936/io.backitup.0
      udp        0      0 0.0.0.0:50129           0.0.0.0:*                           1001       13150      2133/io.froeling.0
      udp6       0      0 :::5353                 :::*                                104        8323       560/avahi-daemon: r
      udp6       0      0 :::60052                :::*                                104        8325       560/avahi-daemon: r
      udp6       0      0 fe80::74bf:2ce2:138:546 :::*                                0          5876       675/NetworkManager
      2025-01-31 19:04:44.676  - info: javascript.0 (1910) script.js.Servicemeldungen: Bitte melden: Wandthermostat Schlafzimmer (0039226994E082) --- HmIP-WTH-1 --- Batterietyp fehlt im Script
      2025-01-31 19:05:51.551  - info: smartgarden.0 (2159) 3/ on_pong: ++ pong'ed ++
      2025-01-31 19:06:14.515  - info: javascript.0 (1910) script.js.Servicemeldungen: Servicemeldung aufgehoben: Schlafzimmer INT0000007 (INT0000007) --- HmIP-HEATING--- Typ: CONFIG_PENDING_ALARM --- Status: 2 Konfigurationsdaten standen zur Übertragung an
      2025-01-31 19:06:14.534  - info: javascript.0 (1910) script.js.Servicemeldungen: Bitte melden: Außensirene (00209D899E5F28) --- HmIP-ASIR-O --- Batterietyp fehlt im Script
      2025-01-31 19:06:14.543  - info: javascript.0 (1910) script.js.Servicemeldungen: Bitte melden: Keypad (002E9F29992C85) --- HmIP-WKP --- Batterietyp fehlt im Script
      2025-01-31 19:06:14.552  - info: javascript.0 (1910) script.js.Servicemeldungen: Bitte melden: Fensterkontakt Schlafzimmer 1/0 (00365F29A5578D) --- HmIP-SWDO-2 --- Batterietyp fehlt im Script
      2025-01-31 19:06:14.564  - info: javascript.0 (1910) script.js.Servicemeldungen: Bitte melden: Wandthermostat Schlafzimmer (0039226994E082) --- HmIP-WTH-1 --- Batterietyp fehlt im Script
      Der iob diag summery:
      bash
                              v.2024-10-19
             Icon name: computer
          Architecture: arm64
      Timezone:               Europe/Vienna (CET, +0100)
      User-ID:                1000
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      Recommended versions are nodejs 20.18.2 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.2G        1.7G        5.6G         19M        1.0G        6.5G
      Swap:           209M          0B        209M
      Total:          8.4G        1.7G        5.8G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.10
      Objects type: jsonl
      States  type: jsonl
      Objects:                14247
      States:                 11988
      Size of iob-Database:
      8.4M    /opt/iobroker/iobroker-data/states.jsonl
