    4. Fehler beim Start Javascript nach Neuinstallation
      matrose65 last edited by matrose65
      Hallo
      Ich habe mein System neu aufsetzten müssen.
      Nach dem zurückspielen des Updates sind fast alle Instanzen wieder in Ordnung.
      Nur wenn ich den Javascript Adapter starte, bekomme ich in einer Schleife folgende Fehler:
      2025-02-03 09:59:35.346 - info: host.IOB "system.adapter.javascript.0" disabled
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:135490
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: ScriptElementKijdModifier2["ambientModifier"] = "declare";
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: ^
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: ReferenceError: ScriptElementKijdModifier2 is not defined
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135490:3
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135508:3
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
      2025-02-03 09:59:40.173 - error: host.IOB Caught by controller[0]: Node.js v20.18.2
      2025-02-03 09:59:40.173 - error: host.IOB instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-02-03 09:59:40.173 - info: host.IOB Do not restart adapter system.adapter.javascript.0 because disabled or deleted
      Ich habe den Adaper auch schon neu installiert und auch den Fixer laufen lassen. Aber keine Änderung
      • Adaptername: Javascript
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: 8.8.3
      • js-controller Version: 7.0.6
      • Admin Version: 7.4.10
      • Hardwaresystem: NUC,
      • Arbeitsspeicher: 16GB
      • Festplattenart: HDD, - Betriebssystem: Linux auf Proxmox
      • Nodejs-Version: 20.18.2
      • NPM-Version: 10.8.2
      • Installationsart: Manuell
      • Image, Docker genutzt: nein
      Und hier noch die lange Diag Version
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-02-02
      *** BASE SYSTEM ***
       Static hostname: IOB
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-30-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       10:10:33 up  1:25,  2 users,  load average: 0.22, 0.07, 0.08
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-02-03 10:10:33 CET
                 Universal time: Mon 2025-02-03 09:10:33 UTC
                       RTC time: Mon 2025-02-03 09:10:33
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      uwe
      HOME=/home/uwe
      GROUPS=uwe cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        2.1G         12G        561K        2.8G         14G
      Swap:           1.0G          0B        1.0G
      Total:           17G        2.1G         13G
      Active iob-Instances:   21
              15992 M total memory
               2009 M used memory
                467 M active memory
               3484 M inactive memory
              11677 M free memory
                 89 M buffer memory
               2546 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 10:10:33 up  1:25,  2 users,  load average: 0.22, 0.07, 0.08
      Tasks: 126 total,   1 running, 125 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15992.7 total,  11677.7 free,   2009.3 used,   2635.8 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.  13983.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  556K  1.6G   1% /run
      /dev/sda1      ext4       31G  6.5G   23G  23% /
      tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Mon Feb  3 08:44:58 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Feb  3 08:44:58 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      461M    /var/
      248M    /var/cache
      241M    /var/cache/apt
      174M    /var/lib
      165M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      12M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      30M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      22M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      IOB                 IOB (version: 7.0.6, hostname: IOB           , alive, uptime: 2371)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : IOB                                      -  enabled
      + system.adapter.admin.0                  : admin                 : IOB                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : IOB                                      -  enabled
        system.adapter.bmw.0                    : bmw                   : IOB                                      - disabled
        system.adapter.daswetter.0              : daswetter             : IOB                                      -  enabled
        system.adapter.devices.0                : devices               : IOB                                      - disabled
        system.adapter.dwd.0                    : dwd                   : IOB                                      -  enabled
        system.adapter.feiertage.0              : feiertage             : IOB                                      -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : IOB                                      -  enabled
      + system.adapter.history.0                : history               : IOB                                      -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : IOB                                      -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IOB                                      -  enabled, port: 8081
        system.adapter.ical.0                   : ical                  : IOB                                      -  enabled
        system.adapter.ical.1                   : ical                  : IOB                                      -  enabled
        system.adapter.ical.2                   : ical                  : IOB                                      -  enabled
        system.adapter.ical.3                   : ical                  : IOB                                      -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : IOB                                      - disabled
        system.adapter.javascript.0             : javascript            : IOB                                      - disabled
      + system.adapter.mqtt.0                   : mqtt                  : IOB                                      -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOB                                      -  enabled
      + system.adapter.roborock.0               : roborock              : IOB                                      -  enabled
      + system.adapter.scenes.0                 : scenes                : IOB                                      -  enabled
      + system.adapter.shelly.1                 : shelly                : IOB                                      -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.2                 : shelly                : IOB                                      -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : IOB                                      -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : IOB                                      -  enabled
      + system.adapter.tr-064.0                 : tr-064                : IOB                                      -  enabled
      + system.adapter.unifi.0                  : unifi                 : IOB                                      -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IOB                                      - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IOB                                      - disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: IOB                                      - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IOB                                      - disabled
      + system.adapter.vis-2.0                  : vis-2                 : IOB                                      -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : IOB                                      - disabled
      + system.adapter.web.0                    : web                   : IOB                                      -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : IOB                                      -  enabled
        system.adapter.worx.0                   : worx                  : IOB                                      - disabled
      + system.adapter.zigbee.0                 : zigbee                : IOB                                      -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "roborock"     : 0.6.18   , installed 0.6.18
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "web"          : 6.2.5    , installed 6.3.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 3.1.1    , installed 3.1.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        7970
      States:         6912
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.1.13:8082       0.0.0.0:*               LISTEN      1001       54411      4864/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52306      4646/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       51830      4646/iobroker.js-co
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       53566      4939/io.mqtt.0
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       53567      4939/io.mqtt.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       52645      4954/io.shelly.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17857      528/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15361      1/init
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       55590      5135/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       51877      4675/io.admin.0
      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       52591      4752/io.roborock.0
      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       52590      4752/io.roborock.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17859      528/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15362      1/init
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       54525      4984/io.sonos.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       53772      5090/io.fullybrowse
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       54845      5150/io.wled.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       54496      4969/io.shelly.2
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14911      370/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14497      1/init
      udp6       0      0 :::111                  :::*                                0          14498      1/init
      2025-02-03 09:59:09.226  - info: host.IOB Restart adapter system.adapter.javascript.0 because enabled
      2025-02-03 09:59:40.173  - error: host.IOB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
      2025-02-03 09:59:40.173  - error: host.IOB Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
      2025-02-03 10:00:00.010  - info: host.IOB instance system.adapter.ical.0 in version "1.16.1" started with pid 6641
      2025-02-03 10:00:00.875  - info: ical.0 (6641) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.2, js-controller: 7.0.6
      2025-02-03 10:00:01.459  - info: ical.0 (6641) processing URL:
      2025-02-03 10:00:06.631  - info: ical.0 (6641) Terminated (NO_ERROR): Without reason
      2025-02-03 10:00:07.144  - info: host.IOB instance system.adapter.ical.0 having pid 6641 terminated with code 0 (NO_ERROR)
      2025-02-03 10:01:28.324  - error: accuweather.0 (4804) Error: Forecast cannot be retrieved. ERROR: {"Code":"ServiceUnavailable","Message":"The allowed number of requests has been exceeded.","Reference":"/currentconditions/v1/1026016?apikey=yWHAR7zDoQ5Si2Ds8SVdlNipITAtyDZp%20&language=de&metric=true&details=true"}
      • Codierknecht
        Codierknecht Developer Most Active @matrose65 last edited by
        @matrose65
        Brauchen Deine Scripte zusätzliche NPM-Module, die jetzt nicht mehr geladen werden?
          matrose65 @Codierknecht last edited by
          @codierknecht
          Es waren 4 Module installiert.
          qr-image
          Moment
          moment-parseformat
          axios
          Diese habe ich mal rausgenommen, weil ich dachte das sie stören
          • Codierknecht
            @matrose65 sagte in Fehler beim Start Javascript nach Neuinstallation:
            Da dürfte eher das Gegenteil der Fall sein.
            Wenn da benötigte Pakete fehlen (darum heißt es ja auch "required") gehen die Scripte auf die Bretter.
              @codierknecht
              Ok, das sehe ich ein aber auch mit den Modulen beginnen die Fehler wieder
              2025-02-03 10:35:20.003 - info: host.IOB "system.adapter.javascript.0" enabled
              2025-02-03 10:35:20.332 - info: host.IOB instance system.adapter.javascript.0 in version "8.8.3" started with pid 7772
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:135490
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: ScriptElementKijdModifier2["ambientModifier"] = "declare";
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: ^
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: ReferenceError: ScriptElementKijdModifier2 is not defined
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135490:3
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135508:3
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
              2025-02-03 10:35:20.928 - error: host.IOB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
              2025-02-03 10:35:20.929 - error: host.IOB Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              2025-02-03 10:35:20.929 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
              2025-02-03 10:35:20.929 - error: host.IOB Caught by controller[0]: Node.js v20.18.2
              2025-02-03 10:35:20.929 - error: host.IOB instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2025-02-03 10:35:20.929 - info: host.IOB Restart adapter system.adapter.javascript.0 because enabled
              2025-02-03 10:35:51.237 - info: host.IOB instance system.adapter.javascript.0 in version "8.8.3" started with pid 7779
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:135490
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: ScriptElementKijdModifier2["ambientModifier"] = "declare";
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: ^
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: ReferenceError: ScriptElementKijdModifier2 is not defined
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135490:3
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at /opt/iobroker/node_modules/typescript/lib/typescript.js:135508:3
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/typescript/lib/typescript.js:195004:3)
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              2025-02-03 10:35:51.830 - error: host.IOB Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
              2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
              2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
              2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptSettings.js:1:20)
              2025-02-03 10:35:51.831 - error: host.IOB Caught by controller[0]: Node.js v20.18.2
              2025-02-03 10:35:51.831 - error: host.IOB instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2025-02-03 10:35:51.831 - info: host.IOB Restart adapter system.adapter.javascript.0 because enabled
                matrose65 @matrose65 last edited by
                Hallo
                Muss jetzt leider erstmal auf Arbeit.
                Kann sicher mitlesen und antworten, aber nichts testen.
                Melde mich heute Abend nochmal
                  Hallo
                  Bin wieder am Rechner.
                  Habe jetzt alle Scripte angehalten und dann Javascript gestartet. Aber keine Änderung.
                  Versuche noch einmal zu deinstallieren, sonst weiß ich nicht weiter.
                    Guten Morgen zusammen
                    Hat keiner eine Idee was ich noch machen soll?
                    Mein Plan ist, ich werde heute alles nochmal neu aufsetzen. Mal sehen.
                    Wenn das auch nichts wird, dann besorge ich mir eine neue SSD. Irgendwie habe ich das Gefühl das von da die Probleme kommen
                    • OliverIO
                      OliverIO @matrose65 last edited by
                      @matrose65
                      Startet der Adapter auch ohne aktivierte Skripte?
                      Ich habe mal nach dieser Referenz das Internet durchsucht,
                      Leider nichts gefunden. Selbst im Repository von TypeSkript taucht das nicht auf.
                      Obwohl die Fehlermeldung dorthin zeigt.
                      Wenn der Adapter ohne Skript startet, dann liegt es wohl an einem deiner Skripte.
                      Dann musst du die der Reihe nach aktivieren und schauen, an welchem es liegt.
                        @oliverio
                        Guten Morgen
                        Ich habe gestern Abend alle Scripte gestoppt und trotzdem kamen die Fehler.
                          Jetzt habe ich die ganze Sache neu aufgesetzt.
                          Also eine VM und den IOB.
                          Beim Start habe ich nur den Haken beim installieren vom Javascript Adapter gesetzt.
                          Und schon habe ich wieder 2 Fehler
                          2025-02-04 08:31:17.335 - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
                          2025-02-04 08:31:17.337 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                          2025-02-04 08:31:17.338 - info: host.iobroker hostname: iobroker, node: v20.18.2
                          2025-02-04 08:31:17.338 - info: host.iobroker ip addresses: 192.168.1.13 fe80::be24:11ff:fe8e:f452
                          2025-02-04 08:31:17.590 - info: host.iobroker connected to Objects and States
                          2025-02-04 08:31:17.607 - info: host.iobroker Node.js version has changed from unknown to 20.18.2
                          2025-02-04 08:31:17.617 - info: host.iobroker added notifications configuration of host
                          2025-02-04 08:31:17.619 - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                          2025-02-04 08:31:17.728 - info: host.iobroker 3 instances found
                          2025-02-04 08:31:17.731 - info: host.iobroker starting 3 instances
                          2025-02-04 08:31:17.803 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11091
                          2025-02-04 08:31:18.654 - info: admin.0 (11091) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
                          2025-02-04 08:31:18.670 - info: admin.0 (11091) requesting all objects
                          2025-02-04 08:31:18.748 - info: admin.0 (11091) received all objects
                          2025-02-04 08:31:18.756 - info: admin.0 (11091) Request actual repository...
                          2025-02-04 08:31:18.768 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                          2025-02-04 08:31:18.770 - info: admin.0 (11091) socket.io server listening on port 8081
                          2025-02-04 08:31:18.772 - info: admin.0 (11091) http server listening on port 8081
                          2025-02-04 08:31:18.772 - info: admin.0 (11091) Use link "http://127.0.0.1:8081" to configure.
                          2025-02-04 08:31:18.936 - warn: admin.0 (11091) Repository cannot be read: Active repo - stable
                          2025-02-04 08:31:18.950 - warn: admin.0 (11091) Active repository "stable" cannot be read
                          2025-02-04 08:31:20.314 - info: admin.0 (11091) Repository received successfully.
                          2025-02-04 08:31:21.851 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 11136
                          2025-02-04 08:31:22.555 - info: backitup.0 (11136) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.6
                          2025-02-04 08:31:22.579 - info: backitup.0 (11136) [iobroker] backup will be activated at 02:48 every 1 day(s)
                          2025-02-04 08:31:25.870 - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 11157
                          2025-02-04 08:31:26.515 - info: discovery.0 (11157) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
                          2025-02-04 08:37:22.917 - info: admin.0 (11091) ==> Connected system.user.admin from ::ffff:192.168.1.121
                          2025-02-04 08:39:00.544 - info: host.iobroker iobroker add javascript
                          2025-02-04 08:39:01.440 - info: host.iobroker iobroker NPM version: 10.8.2
                          2025-02-04 08:39:01.441 - info: host.iobroker iobroker Installing iobroker.javascript@8.8.3... (System call)
                          2025-02-04 08:39:20.335 - error: host.iobroker iobroker npm error code ERR_SSL_CIPHER_OPERATION_FAILEDnpm error 800C2FCEF07F0000:error:1C800066:Provider routines:ossl_gcm_stream_update:cipher operation failed:../deps/openssl/openssl/providers/implementations/ciphers/ciphercommon_gcm.c:325:npm errornpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-02-04T07_39_01_538Z-debug-0.log
                          2025-02-04 08:39:20.336 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.javascript@8.8.3: 1
                          2025-02-04 08:39:21.346 - info: host.iobroker iobroker exit 25
                          2025-02-04 08:39:54.620 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                          2025-02-04 08:39:54.622 - info: admin.0 (11091) Got terminate signal TERMINATE_YOURSELF
                          2025-02-04 08:39:54.624 - info: admin.0 (11091) terminating http server on port 8081
                          2025-02-04 08:39:54.626 - info: admin.0 (11091) terminating
                          2025-02-04 08:39:54.626 - info: admin.0 (11091) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-02-04 08:39:54.663 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                          2025-02-04 08:39:55.127 - info: admin.0 (11091) terminating
                          2025-02-04 08:39:55.145 - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2025-02-04 08:39:58.295 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 11314
                          2025-02-04 08:39:59.125 - info: admin.0 (11314) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.6
                          2025-02-04 08:39:59.143 - info: admin.0 (11314) requesting all objects
                          2025-02-04 08:39:59.393 - info: admin.0 (11314) received all objects
                          2025-02-04 08:39:59.527 - info: admin.0 (11314) socket.io server listening on port 8081
                          2025-02-04 08:39:59.528 - info: admin.0 (11314) http server listening on port 8081
                          Codierknecht OliverIO Homoran 3 Replies Last reply Reply Quote 0
                          • Codierknecht
                            Wie installiert?
                            Hast Du SSL und/oder Authentication konfiguriert?
                            • OliverIO
                              @matrose65
                              Zeile 32 sieht nach einem ssl Fehler aus. Daher wird nicht oder nicht vollständig installiert.
                                @codierknecht
                                Ja habe zugriff über SSL
                                OliverIO Codierknecht 2 Replies Last reply Reply Quote 0
                                  Homoran Global Moderator Administrators @matrose65 last edited by
                                    matrose65 @Homoran last edited by
                                    Hallo
                                    Würde ich gern raussuchen, aber jetzt ist iob abgestürzt und startet auch gerade nicht neu
                                    • OliverIO
                                      OliverIO @matrose65 last edited by OliverIO
                                      @matrose65
                                      Gemäß stackoverflow mach mal folgendes
                                      npm cache clear --force
                                      Wenn das nicht funktioniert, dann mal probieren die ganzen SSL Basis Zertifikate in deinem Image aktualisieren
                                      https://manpages.debian.org/buster/ca-certificates/update-ca-certificates.8.en.html
                                      Ich weiß ja nicht wie alt das Image ist beziehungsweise wann da das letzte Mal ein Update drüber gemacht worden ist
                                      Und natürlich auch in das Detaillog einmal reinschauen, eventuell gibt es da noch Hinweise
                                        matrose65 @OliverIO last edited by
                                        @oliverio
                                        Ich habe jetzt das obere ausgeführt.
                                        Jetzt habe ich den Javascript Adapter ohne Probleme installiert und auch gestartet.
                                        Soll ich nochwas versuchen, bevor ich die Sicherung zurückspiele?
                                        • Codierknecht
                                          Nur so als Anmerkung:
                                          SSL im lokalen Netz ist eigentlich unnötig, solange das alles tatsächlich lokal bleibt. Eine Fehlerquelle weniger.
                                          Auch Authentifizierung am ioBroker in der Web-GUI kann man sich schenken, wenn nicht gerade irgendwelche Pupertisten im Haus sind die dem Vater gerne mal einen Streich spielen.
                                            @codierknecht
                                            Ok Danke Ja es soll alles lokal bleiben.
                                            Und das mit den Pupertisten hat sich schon eine Weile erledigt
                                            4021
