    4. Gelöst: Cannot resolve adapter class
      Smartin last edited by Smartin
      Moin,
      ich hatte heute morgen einen Stromausfall, seitdem kommt ioBroker nicht mehr auf die Füße
      host.iobroker1  2025-02-03 18:22:30.037	error	instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker1  2025-02-03 18:22:30.036	error	Caught by controller[0]: Node.js v20.18.2
      host.iobroker1  2025-02-03 18:22:30.034	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
      host.iobroker1  2025-02-03 18:22:30.036	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
      host.iobroker1  2025-02-03 18:22:30.035	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:36:21)
      host.iobroker1  2025-02-03 18:22:30.035	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
      host.iobroker1  2025-02-03 18:22:30.034	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1104:12)
      host.iobroker1  2025-02-03 18:22:30.033	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32)
      host.iobroker1  2025-02-03 18:22:30.032	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
      host.iobroker1  2025-02-03 18:22:30.031	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
      host.iobroker1  2025-02-03 18:22:30.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:101:17)
      host.iobroker1  2025-02-03 18:22:30.030	error	Caught by controller[0]: at resolveAdapterConstructor (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96:9)
      host.iobroker1  2025-02-03 18:22:30.030	error	Caught by controller[0]: Error: Cannot resolve adapter class
      host.iobroker1  2025-02-03 18:22:30.029	error	Caught by controller[0]: ^
      host.iobroker1  2025-02-03 18:22:30.028	error	Caught by controller[0]: throw new Error("Cannot resolve adapter class");
      host.iobroker1  2025-02-03 18:22:30.027	error	Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96
      Stand der Installation war alles aktuell (stable)
      node v20.18.2
      npm 10.8.2
      Probiert habe ich unter /opt/iobroker :
      • iob fix
      • iob upload all
      • npm cache clean --force
      • npm install iobroker --unsafe-perm
      Lief alles ohne Fehler durch, hat aber nichts am Fehler verändert. Waren eh nur hilflose Versuche mit fehlendem Fachwissen es selbst hinzubiegen 😊
      Irgendeine Datei vermutlich zerschossen. Weiß jemand wo ich da ansetzen kann?
      Gruß aus dem hohen Norden
      • Asgothian
        Asgothian Developer last edited by
        @smartin ich fürchte du musst das Dateisystem überprüfen (lassen). Da wird beim Stromausfall was kaputt gegangen sein.
        A.
          Smartin @Asgothian last edited by
          @asgothian
          Danke für die schnelle Antwort,
          Wie überprüft man denn das Dateisystem?
            Homoran Global Moderator Administrators @Smartin last edited by
            @smartin das würde u.a. auch in iob diag enthalten sein.
              Smartin @Homoran last edited by
              Sieht für mich erst einmal ohne Fehler aus, außer die Logzeilen am Ende mit der o.a. Fehlermeldung
              Script v.2025-02-02
              *** BASE SYSTEM ***
               Static hostname: iobroker1
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 12 (bookworm)
                        Kernel: Linux 6.6.74+rpt-rpi-v7
                  Architecture: arm
              OS is similar to: debian
              Model           : Raspberry Pi 3 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : 32 bit
              Systemuptime and Load:
               19:52:59 up 19 min,  2 users,  load average: 0.23, 0.46, 0.34
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                             Local time: Mon 2025-02-03 19:53:00 CET
                         Universal time: Mon 2025-02-03 18:53:00 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              *** DISPLAY-SERVER SETUP ***
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            965M        258M        469M        5.7M        297M        707M
              Swap:           536M          0B        536M
              Total:          1.5G        258M        1.0G
              Active iob-Instances:   3
                        920 M total memory
                        246 M used memory
                        307 M active memory
                        107 M inactive memory
                        447 M free memory
                         40 M buffer memory
                        243 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              top - 19:53:00 up 19 min,  2 users,  load average: 0.23, 0.46, 0.34
              Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  9.1 us, 18.2 sy,  0.0 ni, 63.6 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :    920.9 total,    447.6 free,    246.2 used,    284.3 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.    674.7 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem              Type      Size  Used Avail Use% Mounted on
              udev                    devtmpfs  329M     0  329M   0% /dev
              tmpfs                   tmpfs      93M  1.9M   91M   3% /run
              /dev/mmcblk0p2          ext4       15G  7.9G  5.6G  59% /
              tmpfs                   tmpfs     461M  1.3M  460M   1% /dev/shm
              tmpfs                   tmpfs     5.0M     0  5.0M   0% /run/lock
              /dev/mmcblk0p1          vfat      510M   79M  432M  16% /boot/firmware
              //192.168.1.1/fritz.nas cifs      458G  254G  204G  56% /media/fritz.nas
              tmpfs                   tmpfs      93M     0   93M   0% /run/user/1000
              [Mon Feb  3 19:33:25 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6199e680-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
              [Mon Feb  3 19:33:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem bb15c8e6-d999-4838-be67-5ff200bffa46 ro with ordered data mode. Quota mode: none.
              [Mon Feb  3 19:33:33 2025] EXT4-fs (mmcblk0p2): re-mounted bb15c8e6-d999-4838-be67-5ff200bffa46 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET             SOURCE                  FSTYPE OPTIONS
              /                  /dev/mmcblk0p2          ext4   rw,noatime,commit=600
              |-/boot/firmware   /dev/mmcblk0p1          vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              `-/media/fritz.nas //192.168.1.1/fritz.nas cifs   rw,relatime,vers=3.1.1,cache=strict,username=raspi,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.1.1,file_mode=0755,dir_mode=0777,soft,nounix,mapposix,reparse=nfs,rsize=65536,wsize=65536,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
              /var:
              1.8G    /var/
              863M    /var/log
              824M    /var/log/journal/e80e6ab5978f473dbaef10c423ba5a67
              263M    /var/cache
              Journal file /var/log/journal/e80e6ab5978f473dbaef10c423ba5a67/user-1001@00062b82f9201301-c7d1c5c8c6b60dfe.journal~ is truncated, ignoring file.
              Archived and active journals take up 823.0M in the file system.
              /opt/iobroker/backups:
              70M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.1G    /opt/iobroker/iobroker-data/
              970M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.18.2
              /usr/bin/node           v20.18.2
              /usr/bin/corepack       0.29.4
              nodejs:
                Installed: 20.18.2-1nodesource1
                Candidate: 20.18.2-1nodesource1
                Version table:
               *** 20.18.2-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                      100 /var/lib/dpkg/status
                   20.18.1-1nodesource1 1001
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2+rpi1 500
                      500 http://raspbian.raspberrypi.com/raspbian bookworm/main armhf Packages
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker1           iobroker1 (version: 7.0.6, hostname: iobroker1     , alive, uptime: 1159)
              iobroker2           iobroker2 (version: 4.0.24, hostname: iobroker2     , alive, uptime: 1151)
              iobroker3           iobroker3 (version: 7.0.3, hostname: iobroker3     , dead, uptime: 51222)
              Core adapters versions
              js-controller:  7.0.6
              admin:          7.4.10
              javascript:     8.8.3
              Adapter State
                system.adapter.admin.0                  : admin                 : iobroker1                                -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.admin.2                  : admin                 : iobroker2                                -  enabled, compact enabled (group 1), port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.backitup.0               : backitup              : iobroker1                                - disabled, compact disabled
                system.adapter.backitup.1               : backitup              : iobroker3                                - disabled, compact disabled
                system.adapter.ble.0                    : ble                   : iobroker1                                - disabled
              + system.adapter.ble.1                    : ble                   : iobroker2                                -  enabled
                system.adapter.ble.2                    : ble                   : iobroker3                                - disabled
                system.adapter.devices.1                : devices               : iobroker1                                - disabled
                system.adapter.feiertage.0              : feiertage             : iobroker2                                -  enabled, compact enabled (group 5)
                system.adapter.flot.0                   : flot                  : iobroker1                                - disabled
                system.adapter.fritzdect.1              : fritzdect             : iobroker1                                - disabled, compact enabled (group 6)
                system.adapter.history.0                : history               : iobroker1                                - disabled, compact disabled
                system.adapter.iot.0                    : iot                   : iobroker1                                - disabled, compact disabled
                system.adapter.javascript.0             : javascript            : iobroker1                                - disabled, compact disabled
                system.adapter.logparser.0              : logparser             : iobroker1                                - disabled, compact enabled (group 3)
                system.adapter.luftdaten.0              : luftdaten             : iobroker1                                - disabled, compact enabled (group 3)
                system.adapter.luftdaten.1              : luftdaten             : iobroker1                                - disabled, compact enabled (group 3)
                system.adapter.parser.0                 : parser                : iobroker1                                - disabled, compact disabled
                system.adapter.ping.0                   : ping                  : iobroker1                                - disabled, compact enabled (group 3)
                system.adapter.simple-api.0             : simple-api            : iobroker1                                - disabled, compact enabled (group 0), port: 8087, bind: 0.0.0.0, run as: admin
                system.adapter.socketio.0               : socketio              : iobroker1                                - disabled, compact enabled (group 2), port: 8084, bind: 0.0.0.0, run as: admin
                system.adapter.sonoff.0                 : sonoff                : iobroker1                                - disabled, compact enabled (group 5), port: 1883, bind: 0.0.0.0
                system.adapter.telegram.0               : telegram              : iobroker1                                - disabled, compact enabled (group 3), port: 8443, bind: 0.0.0.0
                system.adapter.text2command.0           : text2command          : iobroker1                                - disabled, compact enabled (group 0)
                system.adapter.tr-064.0                 : tr-064                : iobroker1                                - disabled, compact enabled (group 6)
                system.adapter.tuya.0                   : tuya                  : iobroker1                                - disabled, compact enabled (group 6)
                system.adapter.vis.0                    : vis                   : iobroker1                                - disabled, compact disabled
                system.adapter.web.0                    : web                   : iobroker1                                - disabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.yeelight-2.0             : yeelight-2            : iobroker1                                - disabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 7.4.10   , installed 7.4.10
              Adapter    "backitup"     : 3.0.31   , installed 3.0.31
              Adapter    "ble"          : 0.14.0   , installed 0.14.0
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "logparser"    : 2.2.2    , installed 2.2.2
              Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
              Adapter    "parser"       : 2.2.4    , installed 2.2.2  [Updatable]
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
              Adapter    "telegram"     : 4.0.0    , installed 4.0.0
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
              Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
              Objects and States
              Objects:        6094
              States:         5461
              W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
              Hit:1 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
              Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6163       658/smbd
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          5827       646/lighttpd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2916       485/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        5752       582/pihole-FTL
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6162       658/smbd
              tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        5758       582/pihole-FTL
              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       868        477/iobroker.js-con
              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       875        477/iobroker.js-con
              tcp6       0      0 :::139                  :::*                    LISTEN      0          6161       658/smbd
              tcp6       0      0 :::80                   :::*                    LISTEN      0          5826       646/lighttpd
              tcp6       0      0 ::1:4711                :::*                    LISTEN      999        5759       582/pihole-FTL
              tcp6       0      0 :::22                   :::*                    LISTEN      0          2918       485/sshd: /usr/sbin
              tcp6       0      0 :::53                   :::*                    LISTEN      999        5754       582/pihole-FTL
              tcp6       0      0 :::445                  :::*                    LISTEN      0          6160       658/smbd
              udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        5751       582/pihole-FTL
              udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          776        652/nmbd
              udp        0      0 192.168.1.30:137        0.0.0.0:*                           0          775        652/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          3026       652/nmbd
              udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          778        652/nmbd
              udp        0      0 192.168.1.30:138        0.0.0.0:*                           0          777        652/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          3027       652/nmbd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2866       399/avahi-daemon: r
              udp        0      0 0.0.0.0:49089           0.0.0.0:*                           104        2868       399/avahi-daemon: r
              udp6       0      0 fe80::fbb1:bcbf:a4a:546 :::*                                0          710        447/NetworkManager
              udp6       0      0 :::53                   :::*                                999        5753       582/pihole-FTL
              udp6       0      0 :::55370                :::*                                104        2869       399/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        2867       399/avahi-daemon: r
              2025-02-03 19:53:44.128  - error: host.iobroker1 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              2025-02-03 19:53:44.129  - error: host.iobroker1 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
              2025-02-03 19:53:44.129  - error: host.iobroker1 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
              2025-02-03 19:53:44.130  - error: host.iobroker1 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
              2025-02-03 19:53:44.130  - error: host.iobroker1 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2025-02-03 19:53:44.130  - error: host.iobroker1 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:36:21)
              2025-02-03 19:53:44.131  - error: host.iobroker1 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
              2025-02-03 19:53:44.131  - error: host.iobroker1 Caught by controller[0]: Node.js v20.18.2
              2025-02-03 19:53:44.132  - error: host.iobroker1 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2025-02-03 19:54:18.870  - error: host.iobroker1 Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96
              2025-02-03 19:54:18.872  - error: host.iobroker1 Caught by controller[0]:   throw new Error("Cannot resolve adapter class");
              2025-02-03 19:54:18.873  - error: host.iobroker1 Caught by controller[0]:   ^
              2025-02-03 19:54:18.873  - error: host.iobroker1 Caught by controller[0]: Error: Cannot resolve adapter class
              2025-02-03 19:54:18.874  - error: host.iobroker1 Caught by controller[0]:     at resolveAdapterConstructor (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96:9)
              2025-02-03 19:54:18.874  - error: host.iobroker1 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:101:17)
              2025-02-03 19:54:18.882  - error: host.iobroker1 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
              2025-02-03 19:54:18.883  - error: host.iobroker1 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              2025-02-03 19:54:18.883  - error: host.iobroker1 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
              2025-02-03 19:54:18.884  - error: host.iobroker1 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
              2025-02-03 19:54:18.884  - error: host.iobroker1 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
              2025-02-03 19:54:18.884  - error: host.iobroker1 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2025-02-03 19:54:18.885  - error: host.iobroker1 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/controllerTools.js:36:21)
              2025-02-03 19:54:18.885  - error: host.iobroker1 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
              2025-02-03 19:54:18.885  - error: host.iobroker1 Caught by controller[0]: Node.js v20.18.2
              2025-02-03 19:54:18.886  - error: host.iobroker1 instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              Der RasPi selbst läuft auch, ist per SSH ansprechbar, Pi-Hole läuft auch ganz normal.
                @smartin sagte in Cannot resolve adapter class:
                ja, die befürchteten orphans sehe ich auch nicht.
                Wenn diese nicht Mittlerweile aus der logrotation verschwunden sind.
                Du kannst natürlich versuchen den Controller noch mal drüberzuinstallieren, leider fällt mir gerade der Befehl nicht ein.
                  ich kenne dafür nur
                  npm i iobroker.js-controller
                  Damit eben probiert, keine Änderung 😞
                    ich kenne dafür nur
                    nee, nicht mit npm rumhantieren!
                    war irgendwas wie iob upgrade js-controller@version und dann noch ein --Parameter
                      @homoran sagte in Cannot resolve adapter class:
                      Ich finde da tatsächlich nur
                      npm install iobroker.js-controller@version --omit=dev
                      in einem Post von @Thomas-Braun vom 29.11.2024.
                      https://forum.iobroker.net/topic/46498/test-adapter-lg-thinq/706?lang=en-GB#
                      Mit iob upgrade js-controller* finde ich nix
                        @smartin das jönnte es tatsächlich sein, aber npm Befehle müssen unbedingt im richtigen Verzeichnis ausgeführt werden.
                          Super! Das war es! 👍
                          Habe mit
                          npm install iobroker.js-controller@7.0.5 --omit=dev
                          eine Version runter, dann mit
                          npm install iobroker.js-controller@7.0.6 --omit=dev
                          wieder auf den aktuellen Stand installiert. Nach Neustart des RasPi ist das Admin-GUI wieder ansprechbar, alle Scripte wieder am Start, keine Fehler mehr.
                          Vielen Dank! You made my day!
                            Smartin @Smartin last edited by
                            Halt, doch noch Fragen dazu ... nur um für ein nächstes Mal Stromausfall vlt. besser vorbereitet zu sein ...
                            Gibt es Empfehlungen für eine kleine USV für den Raspberry?
                            Und falls ja, gibt es dafür Workarounds, dass die USV kurz den Strom des Raspberry bei einem Ausfall übernimmt und durch irgendeinen Impuls ihn sauber herunterfährt? Dafür braucht es doch sicher keine riesigen Akkus dann.
                            305
