    4. IOB Proxmox CT No Space left on device.. aber wo?
    • wendy2702
      heute abend ist mein IOB mit diesem Log Eintrag abgeschmiert:
      2025-02-04 20:27:53.864  - error: host.iobroker uncaught exception: ENOSPC: no space left on device, write
      2025-02-04 20:27:53.864  - error: host.iobroker Error: ENOSPC: no space left on device, write
      Allerdings komme ich gerade nicht dahinter wo denn das Device voll ist.
      mirko@iobroker:/opt/iobroker$ df -h
      Filesystem                        Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0   30G   15G   14G  52% /
      none                              492K  4.0K  488K   1% /dev
      udev                               16G     0   16G   0% /dev/tty
      tmpfs                              16G     0   16G   0% /dev/shm
      tmpfs                             6.3G  100K  6.3G   1% /run
      tmpfs                             5.0M     0  5.0M   0% /run/lock
      tmpfs                             3.2G     0  3.2G   0% /run/user/1001
      tmpfs                             3.2G     0  3.2G   0% /run/user/0
      NCDU (sorry für den Screenshot)
      Iob Diag:
      Script v.2025-02-02
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.12-8-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:45:37 up 3 days,  4:58,  2 users,  load average: 0.68, 1.93, 3.33
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-02-04 20:45:37 CET
                 Universal time: Tue 2025-02-04 19:45:37 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mirko
      HOME=/home/mirko
      GROUPS=mirko sudo iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:             17G        341M         15G        114K        903M         16G
      Swap:             0B          0B          0B
      Total:           17G        341M         15G
      Active iob-Instances:   1
              16384 M total memory
                326 M used memory
                195 M active memory
                695 M inactive memory
              15196 M free memory
                  0 M buffer memory
                861 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 20:45:37 up 3 days,  4:58,  2 users,  load average: 0.68, 1.93, 3.33
      Tasks:  33 total,   1 running,  32 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  16384.0 total,  15194.2 free,    327.8 used,    862.0 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.  16056.2 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
      * iobroker.service        loaded failed failed ioBroker Server
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       30G   15G   14G  52% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.3G  108K  6.3G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1001
      tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/0
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
      /var:
      1.8G    /var/
      1.4G    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
      1.4G    /var/log
      247M    /var/lib
      Archived and active journals take up 176.4M in the file system.
      /opt/iobroker/backups:
      88M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.7G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      456M    /opt/iobroker/iobroker-data/backup-objects
      194M    /opt/iobroker/iobroker-data/files/vis-2
      168M    /opt/iobroker/iobroker-data/files/vis
      38M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      28M     /opt/iobroker/iobroker-data/states.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      26M     /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
           20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
       *** 20.18.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 685)
      pi-iobroker         pi-iobroker (version: 7.0.6, hostname: pi-iobroker   , dead, uptime: 332757)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.19
      javascript:     8.9.1
      nodejs modules from github:     1
      +-- iobroker.smartstate@0.0.4 (git+ssh://git@github.com/ChriD/ioBroker.smartstate.git#aa448478fd656fff055532b33decd1138d9222e3)
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.1                  : admin                 : pi-iobroker                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
        system.adapter.enocean.0                : enocean               : pi-iobroker                              -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.frigate.0                : frigate               : iobroker                                 -  enabled
        system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
        system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
        system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
        system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
        system.adapter.history.0                : history               : iobroker                                 - disabled
        system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
        system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
        system.adapter.javascript.2             : javascript            : iobroker                                 -  enabled
        system.adapter.js2fs.0                  : js2fs                 : iobroker                                 - disabled
        system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
        system.adapter.matter.0                 : matter                : iobroker                                 - disabled
        system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.4                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.5                 : modbus                : iobroker                                 -  enabled
        system.adapter.modbus.6                 : modbus                : iobroker                                 - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
        system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobroker                                 - disabled
        system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
        system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
        system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
        system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
        system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
        system.adapter.semp.0                   : semp                  : iobroker                                 -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.18
        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8091, bind: 192.168.178.18, run as: admin
        system.adapter.smartmeter.0             : smartmeter            : pi-iobroker                              -  enabled
        system.adapter.smartstate.0             : smartstate            : iobroker                                 - disabled
        system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 192.168.178.18, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 192.168.178.18
        system.adapter.tr-064.0                 : tr-064                : pi-iobroker                              - disabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
        system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
        system.adapter.web.3                    : web                   : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
        system.adapter.yahka.2                  : yahka                 : iobroker                                 -  enabled
        system.adapter.yahka.3                  : yahka                 : iobroker                                 -  enabled
        system.adapter.yahka.4                  : yahka                 : iobroker                                 -  enabled
        system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      │ 2       │ 'Test'             │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
      Active repo(s): Beta (latest)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 7.4.19   , installed 7.4.19
      Adapter    "alarm"        : 3.6.8    , installed 3.6.8
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
      Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "frigate"      : 1.3.1    , installed 1.3.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "hue"          : 3.14.1   , installed 3.14.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "javascript"   : 8.9.1    , installed 8.9.1
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "matter"       : 0.4.13   , installed 0.4.13
      Adapter    "mercedesme"   : 0.3.4    , installed 0.3.4
      Adapter    "modbus"       : 6.4.0    , installed 6.4.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "reolink"      : 1.1.2    , installed 1.1.2
      Adapter    "roborock"     : 0.6.18   , installed 0.6.18
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "semp"         : 1.4.8    , installed 1.4.8
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.0.0    , installed 4.0.0
      Adapter    "trashschedule": 4.0.0    , installed 4.0.0
      Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
      Adapter    "vis-2-widgets-collection": 1.1.13, installed 1.1.12 [Updatable]
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.3.1    , installed 6.3.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.9    , installed 1.0.9
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Objects and States
      Objects:        42329
      States:         37044
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 9
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          10385      175/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          11276      323/master
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          11277      323/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          10387      175/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          9393       82/dhclient
      2025-02-04 20:40:00.933  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
      2025-02-04 20:40:00.974  - warn: host.iobroker instance system.adapter.hass.0 terminated due to SIGKILL
      2025-02-04 20:40:00.974  - info: host.iobroker instance system.adapter.hass.0 terminated with code null ()
      2025-02-04 20:40:01.022  - warn: host.iobroker instance system.adapter.modbus.4 terminated due to SIGKILL
      2025-02-04 20:40:01.023  - info: host.iobroker instance system.adapter.modbus.4 terminated with code null ()
      2025-02-04 20:40:01.070  - warn: host.iobroker instance system.adapter.simple-api.0 terminated due to SIGKILL
      2025-02-04 20:40:01.070  - info: host.iobroker instance system.adapter.simple-api.0 terminated with code null ()
      2025-02-04 20:40:01.118  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
      2025-02-04 20:40:01.118  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
      2025-02-04 20:40:01.162  - warn: host.iobroker instance system.adapter.linux-control.0 terminated due to SIGKILL
      2025-02-04 20:40:01.162  - info: host.iobroker instance system.adapter.linux-control.0 terminated with code null ()
      2025-02-04 20:40:01.206  - warn: host.iobroker instance system.adapter.web.1 terminated due to SIGKILL
      2025-02-04 20:40:01.206  - info: host.iobroker instance system.adapter.web.1 terminated with code null ()
      2025-02-04 20:40:01.247  - warn: host.iobroker instance system.adapter.web.2 terminated due to SIGKILL
      2025-02-04 20:40:01.247  - info: host.iobroker instance system.adapter.web.2 terminated with code null ()
      2025-02-04 20:40:01.294  - warn: host.iobroker instance system.adapter.web.3 terminated due to SIGKILL
      2025-02-04 20:40:01.294  - info: host.iobroker instance system.adapter.web.3 terminated with code null ()
      2025-02-04 20:40:01.337  - warn: host.iobroker instance system.adapter.vis-2.0 terminated due to SIGKILL
      2025-02-04 20:40:01.337  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code null ()
      2025-02-04 20:40:01.380  - warn: host.iobroker instance system.adapter.pushover.0 terminated due to SIGKILL
      2025-02-04 20:40:01.380  - info: host.iobroker instance system.adapter.pushover.0 terminated with code null ()
      2025-02-04 20:40:01.427  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2025-02-04 20:40:01.471  - info: host.iobroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
      2025-02-04 20:40:01.471  - info: host.iobroker All instances are stopped.
      2025-02-04 20:40:01.495  - info: host.iobroker terminated
      Gucke ich falsch oder wo ist die Platte voll?
      Vielleicht saß ich auch heute schon zu lange im Auto und habe jetzt Tomaten auf den Augen.
      Bitte erleuchtet mich.
      EDIT: Warum sagt das Diag script das hier:
      Obwohl der fix vorher lief und ich auf dem Server noch nie was Graphisches hatte?
      EDIT2 : habe ja noch einen Slave dran hängen aber selbst auf dem ist aus meiner Sicht noch Platz:
      pi@pi-iobroker:~ $ df -h
      /dev/root       7.1G  5.8G  939M  87% /
      devtmpfs        324M     0  324M   0% /dev
      tmpfs           454M     0  454M   0% /dev/shm
      tmpfs           182M  1.1M  181M   1% /run
      tmpfs           5.0M   12K  5.0M   1% /run/lock
      /dev/mmcblk0p1  253M   44M  209M  18% /boot/firmware
      tmpfs            91M     0   91M   0% /run/user/1000
      pi@pi-iobroker:~ $
        Thomas Braun Most Active @wendy2702 last edited by Thomas Braun
        @wendy2702 sagte in IOB Proxmox CT No Space left on device.. aber wo?:
        Der Fixer sollte dir anbieten, das Boottarget auf multi-user zu bringen.
        • wendy2702
          wendy2702 @Thomas Braun last edited by
          @thomas-braun moin,
          Der fixer lief so durch.
          Keine Abfrage oder Ähnliches.
          Hast du eventuell noch ne Idee wegen dem Hauptproblem?
            Vielleicht auf dem LXC-Host?
            • wendy2702
              @thomas-braun den hatte ich auch schon in Verdacht aber nix gesehen.
              df -h
              tmpfs                                                 3.2G  3.4M  3.1G   1% /run
              /dev/mapper/pve-root                                   94G   56G   34G  63% /
              tmpfs                                                  16G   37M   16G   1% /dev/shm
              efivarfs                                              128K   60K   64K  49% /sys/firmware/efi/efivars
              /dev/sda2                                             511M  336K  511M   1% /boot/efi
              Nextcloud                                             1.5T  128K  1.5T   1% /Nextcloud
              Nextcloud/subvol-111-disk-0                           1.8T  288G  1.5T  17% /Nextcloud/subvol-111-disk-0
              Motioneye                                             2.0T  128K  2.0T   1% /Motioneye
              Motioneye/subvol-110-disk-1                           2.0T  128K  2.0T   1% /Motioneye/subvol-110-disk-1
              Motioneye/subvol-110-disk-2                           3.6T  1.6T  2.0T  44% /Motioneye/subvol-110-disk-2
              Motioneye/subvol-110-disk-0                           2.0T  128K  2.0T   1% /Motioneye/subvol-110-disk-0
              Motioneye/subvol-109-disk-0                           8.0G  4.7G  3.4G  59% /Motioneye/subvol-109-disk-0
              /dev/fuse                                             128M   20K  128M   1% /etc/pve
              //192.168.2.1/FRITZ.NAS/ICY_DISK1/proxmox_backups_56  5.5T  1.9T  3.7T  33% /mnt/pve/NAS_1
                @wendy2702
                Swap: 0B 0B 0B
                Richte mal ein SWAP ein.
                device no space
