    4. E-INK Display OpenEPaperLink - Blockly, Java-Skripte usw.
      Beowolf last edited by
      das andere Thema
      https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie
      hat jetzt schon an die 900 Beiträge.
      Da wäre es doch etwas übersichtlicher wenn wir hier alles an Blocklys, Java-Skipte usw. posten.
      Manfred
        Beowolf last edited by Beowolf
        Ich mache mal den Anfang.
          <variables>
            <variable id="e.-?J1RG(1E03apliOsd">url</variable>
            <variable id="eMqV!m8?ZCdqN2].w`xb">TagMini1</variable>
            <variable id="*)}|9mHpKcV3YN}|a_t5">jsonMini1</variable>
          </variables>
          <block type="procedures_defcustomreturn" id="Q)=N/g,e;;C$aa#GZ/g6" x="738" y="388">
            <mutation statements="false">
              <arg name="url" varid="e.-?J1RG(1E03apliOsd"></arg>
            </mutation>
            <field name="NAME">encodeURL</field>
            <field name="SCRIPT">dXJsID0gZW5jb2RlVVJJQ29tcG9uZW50KHVybCk7DQpyZXR1cm4gdXJsOw==</field>
          <block type="on_ext" id="P$af/8byEUS#qCA]5B-P" x="738" y="413">
            <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
            <value name="OID0">
              <shadow type="field_oid" id="qKgG$O[{3RUIQEMyX@84">
                <field name="oid">hm-rpc.0.KEQ0908967.4.ACTUAL_TEMPERATURE</field>
            <value name="OID1">
              <shadow type="field_oid" id="1=$zeB_8NZ{``1IKhA@;">
                <field name="oid">hm-rpc.0.KEQ0908967.4.SET_TEMPERATURE</field>
            <value name="OID2">
              <shadow type="field_oid" id="3xv_){1%Z-Px_oc=|ee]">
                <field name="oid">hm-rpc.0.KEQ0908967.4.VALVE_STATE</field>
            <value name="OID3">
              <shadow type="field_oid" id="1%z%;+tP3g0pYuG^87_*">
                <field name="oid">hm-rpc.0.KEQ0908967.4.BATTERY_STATE</field>
              <block type="controls_if" id="?`c`Nn3U3V@~!c@vILtF">
                  <block type="time_compare" id="7~bZxST63%E#3wG~e~C$">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                    <field name="START_TIME">9:00</field>
                    <field name="END_TIME">20:00</field>
                  <block type="variables_set" id="}kvQ}B#.rViPjfKc-HTi">
                    <field name="VAR" id="eMqV!m8?ZCdqN2].w`xb">TagMini1</field>
                      <block type="text" id="AS0{YNAIOlM%S|LO,c(?">
                        <field name="TEXT">0000050CE8EFB29E</field>
                      <block type="variables_set" id="k02GjbFfyHgTN`gcO-Da">
                        <field name="VAR" id="*)}|9mHpKcV3YN}|a_t5">jsonMini1</field>
                          <block type="procedures_callcustomreturn" id="m+$OB%}5|)Pwa;Sp_8Xz">
                            <mutation name="encodeURL">
                              <arg name="url"></arg>
                            </mutation>
                            <value name="ARG0">
                              <block type="text_join" id="%7M,-4ru#q{/k6KDWMHm">
                                <mutation items="11"></mutation>
                                <value name="ADD0">
                                  <block type="text" id="KG:U*zHU9}`ZAfY=W0tK">
                                    <field name="TEXT">[    {"text": [10,10,"Arbeitszimmer","fonts/bahnschrift30",2]},</field>
                                <value name="ADD1">
                                  <block type="text" id="J8kE(`F|;UG(UnXYIXH/">
                                    <field name="TEXT">{"line": [10,35,374,35,1]},</field>
                                <value name="ADD2">
                                  <block type="text" id="n|(:Q;;@|/rl*,,eDMQ0">
                                    <field name="TEXT">{"text": [10,50,"Aktuelle Temperatur:","fonts/bahnschrift20",1]},     {"text": [240,50,"</field>
                                <value name="ADD3">
                                  <block type="get_value" id="Ivop[TTx6k8izC(a}Lh$">
                                    <field name="OID">hm-rpc.0.KEQ0908967.4.ACTUAL_TEMPERATURE</field>
                                <value name="ADD4">
                                  <block type="text" id=".;[edg]Q8Y}~9~$]`WGh">
                                    <field name="TEXT">°C","fonts/bahnschrift20",2]},     {"text": [10,80,"Eingestellte Temperatur:","fonts/bahnschrift20",1]},   {"text": [240,80,"</field>
                                <value name="ADD5">
                                  <block type="get_value" id="!vH6u](8OPQ3|j4+-R0`">
                                    <field name="OID">hm-rpc.0.KEQ0908967.4.SET_TEMPERATURE</field>
                                <value name="ADD6">
                                  <block type="text" id="10FFF9ZLy|n:h)tY)c|m">
                                    <field name="TEXT">°C","fonts/bahnschrift20",2]},     {"text": [10,110,"Aktuelle Ventilstellung:","fonts/bahnschrift20",1]},   {"text": [240,110,"</field>
                                <value name="ADD7">
                                  <block type="get_value" id="N~fNY_bADcQ(?eeOcd70">
                                    <field name="OID">hm-rpc.0.KEQ0908967.4.VALVE_STATE</field>
                                <value name="ADD8">
                                  <block type="text" id="#7e9sI0@iu:c/+?Dr@Z.">
                                    <field name="TEXT"> %","fonts/bahnschrift20",2]},     {"text": [10,140,"Batteriespannung:","fonts/bahnschrift20",1]},   {"text": [240,140,"</field>
                                <value name="ADD9">
                                  <block type="get_value" id="M=3Q06RUua?Te,a?1Ui;">
                                    <field name="OID">hm-rpc.0.KEQ0908967.4.BATTERY_STATE</field>
                                <value name="ADD10">
                                  <block type="text" id="8Mjb{3)XGWhzToz{:.]t">
                                    <field name="TEXT"> V","fonts/bahnschrift20",2]}  ]</field>
                          <block type="http_post" id="AoQ+~mSdktWzhHgxGz#C">
                            <field name="TIMEOUT">15</field>
                            <field name="TYPE">text</field>
                            <value name="URL">
                              <shadow type="text" id="qh|GfefbC0op9nMhC4nk">
                                <field name="TEXT">http://192.168.49.187/jsonupload</field>
                            <value name="DATA">
                              <block type="text_join" id="YiM(/:1NU2PK@ysCbT8$">
                                <mutation items="4"></mutation>
                                <value name="ADD0">
                                  <block type="text" id="sY#__Tq@9.DrJShh~Ant">
                                    <field name="TEXT">mac=</field>
                                <value name="ADD1">
                                  <block type="variables_get" id="^ag2u;YyTY9!dP{tJ|}c">
                                <value name="ADD2">
                                  <block type="text" id="k:I$k7w),ZmO9hEwr:$W">
                                    <field name="TEXT">&amp;json=</field>
                                <value name="ADD3">
                                  <block type="variables_get" id="MEQ/.CHU]v1WHbuc@`Ly">
        Das ist ein Blockly um eine Anzeige zu erstellen die dann die aktuelle und die eingestellte Temperatur, die Ventilestellung und die Batteriespannung von HM Heizungsstellantrieb anzeigt.
        Natürlich müssen die Datenpunkte, AP-Adresse usw. entsprechend geändert werden. Das sollte aber klar sein.
        Ob das Blockly auch noch besser geht? Kann sein. Hier läuft es ohne Probleme.
        PS
        Bei mir werden die TAGs nur in der Zeit zwischen 9 und 20 Uhr aktualisiert (kann natürlich geändert werden). Später ist keiner mehr da der auf dieTAGs schaut. Das entlastet ein wenig die Batterie in den TAGs.
        Noch was. Hatte ich leider vergessen. Ich möchte mich hier nicht mit fremden Federn schmücken.
        Das ursprüngliche Skript kommt von "ilovegym"
        Siehe:
        https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie/854?_=1739134242327
        Vielen Dank dafür
          Hier ein kleines Blockly, wenn in den TAGs angezeigt werden soll ob etwas eingeschaltet oder ausgeschaltet ist.
            <variables>
              <variable id=".N:Ev).-4-82UMj~s}jT">Uebergabe</variable>
              <variable id=":!8~[_wM)Q:b4Pev1|^x">Search</variable>
              <variable id="8f|o07jxrqx*$7Vx~oCA">Replace</variable>
            </variables>
            <block type="procedures_defcustomreturn" id="X|o`:e#4rUy{jrxDqT0Y" x="738" y="338">
                <arg name="Uebergabe" varid=".N:Ev).-4-82UMj~s}jT"></arg>
                <arg name="Search" varid=":!8~[_wM)Q:b4Pev1|^x"></arg>
                <arg name="Replace" varid="8f|o07jxrqx*$7Vx~oCA"></arg>
              </mutation>
              <field name="NAME">Replace Text</field>
              <field name="SCRIPT">bGV0IHN0cl8xID0gVWViZXJnYWJlOw0KbGV0IHN0cl8yID0gU2VhcmNoOw0KbGV0IHN0cl8zID0gUmVwbGFjZTsNCnN0cl8xID0gc3RyXzEucmVwbGFjZShTZWFyY2gsIFJlcGxhY2UpOw0KcmV0dXJuIHN0cl8xOw==</field>
              </mutation>
            <block type="on_ext" id="P$af/8byEUS#qCA]5B-P" x="738" y="438">
              <value name="OID0">
                  <field name="oid">mqtt.0.Heizung.config.HK2_Betriebsart</field>
              <value name="OID1">
                  <field name="oid">mqtt.0.Heizung.config.WW_Betriebsart</field>
              <value name="OID2">
                  <field name="oid">mqtt.0.Heizung.status.HK2_Pumpe</field>
              <value name="OID3">
                  <field name="oid">mqtt.0.Heizung.status.Brenner_Ansteuerung</field>
                <block type="controls_if" id="cfr[e6_/^LK-t[30k1HG">
                          <field name="TEXT">00007E1BD7BCB29E</field>
                              </mutation>
                              <value name="ARG0">
                                  <mutation items="7"></mutation>
                                  <value name="ADD0">
                                      <field name="TEXT">[    {"text": [10,10,"Heizung","fonts/bahnschrift30",2]},</field>
                                  <value name="ADD1">
                                  <value name="ADD2">
                                      <field name="TEXT">{"text": [10,50,"Betriebsart Heizung:","fonts/bahnschrift20",1]},     {"text": [250,50,"</field>
                                  <value name="ADD3">
                                    <block type="logic_ternary" id="yJ,9[#P7w*KD^#R7%o1p">
                                      <value name="IF">
                                        <block type="logic_compare" id="_nY8e5S_F|Uf*C2U={MR">
                                          <field name="OP">EQ</field>
                                            <block type="get_value" id="5Z^|9w~(1YmdVJQ7%v$0">
                                              <field name="OID">mqtt.0.Heizung.status.HK2_Pumpe</field>
                                            <block type="text" id="DjlkmM}:zWp9nUl1c#%w">
                                              <field name="TEXT">Tag</field>
                                      <value name="THEN">
                                          <field name="TEXT">Tag","fonts/bahnschrift20",2]},     {"text": [10,80,"Betriebsart Warmwasser:","fonts/bahnschrift20",1]},   {"text": [250,80,"</field>
                                      <value name="ELSE">
                                        <block type="text" id="qo8G;N~ktlTg~Y,fI|~L">
                                          <field name="TEXT">Nacht","fonts/bahnschrift20",2]},     {"text": [10,80,"Betriebsart Warmwasser:","fonts/bahnschrift20",1]},   {"text": [250,80,"</field>
                                  <value name="ADD4">
                                    <block type="logic_ternary" id="@@MWpXGPxtivK*HP7FQ5">
                                      <value name="IF">
                                        <block type="logic_compare" id="],Di%nSz6X0:3d?mKs`u">
                                            <block type="get_value" id="%*uWF0=YeiZ7uN[o`X|}">
                                              <field name="OID">mqtt.0.Heizung.config.WW_Betriebsart</field>
                                            <block type="text" id="hPuXlR|41/Yeo$oQ@=HH">
                                      <value name="THEN">
                                        <block type="text" id="0xLY3lrDE~(SkKt_f8DH">
                                          <field name="TEXT">Tag","fonts/bahnschrift20",2]},     {"text": [10,110,"Umwälzpumpe:","fonts/bahnschrift20",1]},   {"text": [250,110,"</field>
                                      <value name="ELSE">
                                        <block type="text" id="Mm#t/sCT:uXw`)II6s=Y">
                                          <field name="TEXT">Nacht","fonts/bahnschrift20",2]},     {"text": [10,110,"Umwälzpumpe:","fonts/bahnschrift20",1]},   {"text": [250,110,"</field>
                                  <value name="ADD5">
                                    <block type="logic_ternary" id="xu3kals`NOzfBfKf^UVC">
                                      <value name="IF">
                                        <block type="logic_compare" id="!@n,)^%^oIzm9M$zIT[,">
                                            <block type="math_number" id="K0!IMZFfNjD]w1)oD[`[">
                                              <field name="NUM">100</field>
                                      <value name="THEN">
                                        <block type="text" id=".yP]thn0Q)aA:e5!02ZK">
                                          <field name="TEXT">Eingeschaltet","fonts/bahnschrift20",2]},     {"text": [10,140,"Ölbrenner:","fonts/bahnschrift20",1]},   {"text": [250,140,"</field>
                                      <value name="ELSE">
                                        <block type="text" id="d(zc`iTQSg0r.f^FkqK:">
                                          <field name="TEXT">Ausgeschaltet","fonts/bahnschrift20",1]},     {"text": [10,140,"Ölbrenner:","fonts/bahnschrift20",1]},   {"text": [250,140,"</field>
                                  <value name="ADD6">
                                    <block type="logic_ternary" id="/+tc%%-nw4~=fQaHU,9Q">
                                      <value name="IF">
                                        <block type="logic_compare" id="kcb6qGG2z-7N*~2XYxvy">
                                            <block type="get_value" id="w52ns6N;Fk#N7x]WC6)!">
                                              <field name="OID">mqtt.0.Heizung.status.Brenner_Ansteuerung</field>
                                            <block type="math_number" id="mN;DhZ|;S1bNC5I,OH!m">
                                              <field name="NUM">1</field>
                                      <value name="THEN">
                                          <field name="TEXT">Eingeschaltet","fonts/bahnschrift20",2]}  ]</field>
                                      <value name="ELSE">
                                        <block type="text" id="$l@9YB:|C/ww3ec:AL:8">
                                          <field name="TEXT">Ausgeschaltet","fonts/bahnschrift20",1]}  ]</field>
                              <value name="URL">
                                  <field name="TEXT">http://192.168.49.185/jsonupload</field>
                              <value name="DATA">
                                  <value name="ADD0">
                                  <value name="ADD1">
                                  <value name="ADD2">
                                  <value name="ADD3">
          Siehe:
          Vielen Dank dafür
          • haselchen
            haselchen Most Active @Beowolf last edited by haselchen
            Ich mache es wahrscheinlich noch ein wenig anders als Andere hier 🙂
            Über HomeAssistant
            Dort gibt es eine Integration, die den AP und die angeschlossenen Tags erkennt.
            Über Github gibt es verschiedene Anleitungen, was man umsetzen möchte.
            https://github.com/OpenEPaperLink/Home_Assistant_Integration/wiki
            Ich hab einen Xiaomi Temperatur Sensor eingebunden und auf den Tag gebracht.
            Muss sagen, dass hat echt Spass gemacht, dass alles zurecht zu fummeln (x Daten y Daten, Datum....)
            Für die Experten hier, ist das natürlich nen Witz 😬
            Ich löse das als Automation
            ? 1 Reply Last reply Reply Quote 1
              A Former User @haselchen last edited by
              @haselchen
              Prima! Hatte das vor einem halben Jahr oder so auch mal, zur Zeit aber kein HA mehr in Betrieb.
              Du hast damit aber auch den Xiaomi Sensor in HA drin, richtig?
              • haselchen
                haselchen Most Active @Guest last edited by
                @ilovegym
                War halt mal Neugierig auf HA.
                Und tatsächlich gibt es ganz wenige Dinge , die dort besser funktionieren.
                Den Sensor habe ich da irgendwie manuell reingeklöppelt.
                Ich wollte einfach mal rumtesten und man findet immer mehr , was man ausprobieren möchte .
                  Hier mal mein Blockly für die Anzeige von drei Wechselrichtern die ich hier in meiner kleinen Solaranlage habe.
                  Anzeige auf einem 800 x 480 TAG-Display.
                    <variables>
                    </variables>
                      </mutation>
                    <block type="comment" id=":1{5ta`)D%sSjgoE=Fi!" x="738" y="413">
                      <field name="COMMENT">Solarertrag grosses Display EG</field>
                        <block type="schedule" id="|O{CP~h._+!v#c9*!LVm">
                          <field name="SCHEDULE">*/10 * * * *</field>
                            <block type="controls_if" id="+eTrP@@x*{)ZhjN2H4Jf">
                                <block type="time_compare_ex" id="$t$it-V6B2hU;#k~^cP4">
                                  <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                                  <value name="START_TIME">
                                    <shadow type="text" id="hBM#f+Gd22:2k,$_+t+,">
                                      <field name="TEXT">12:00</field>
                                    <block type="time_astro" id="((+60!hJ,hptfT?5VH.U">
                                      <field name="TYPE">sunrise</field>
                                      <field name="OFFSET">0</field>
                                  <value name="END_TIME">
                                    <shadow type="text" id="Dh8jih_mk2:;yR{u2H+n">
                                      <field name="TEXT">18:00</field>
                                    <block type="time_astro" id="LwAhrvt~a790ggE*PiZf">
                                      <field name="TYPE">sunset</field>
                                      <field name="TEXT">000005EDCEAABC9A</field>
                                          </mutation>
                                          <value name="ARG0">
                                              <mutation items="33"></mutation>
                                              <value name="ADD0">
                                                <block type="text" id="G2fL:Xxh_e)*]VxFnorb">
                                                  <field name="TEXT">[ { "rotate": 1 },  {"text": [240,10,"Solaranlage","fonts/calibrib50",2,1]}, {"line": [10,75,470,75,1]}, {"text": [10,90,"letzte Aktualisierung","fonts/bahnschrift20",1]},     {"text": [250,90,"</field>
                                              <value name="ADD1">
                                                <block type="logic_ternary" id="8{w1#^^5;dvTPL+e;YJ~">
                                                  <value name="IF">
                                                    <block type="logic_multi_and" id="}T,NvzNn/+Lg^0WvBwC]">
                                                      <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
                                                      <value name="AND0">
                                                        <block type="logic_compare" id="2=erH{%MgL5/:iIl`8T5">
                                                            <block type="get_value" id="Tpf)^`BWUL|!xG9o@^+5">
                                                              <field name="OID">opendtu.0.114190930771.producing</field>
                                                            <block type="logic_boolean" id="*$av63$R-M9D`!g~ZeWf">
                                                      <value name="AND1">
                                                        <block type="logic_compare" id="M02=NZJg8/TZ;bG=^~EK">
                                                            <block type="get_value" id="tEI3p@a`|h1#gD5ekrKU">
                                                              <field name="OID">opendtu.0.114190653534.producing</field>
                                                            <block type="logic_boolean" id="|53x*YF8cIMZ]=cN/qp3">
                                                      <value name="AND2">
                                                        <block type="logic_compare" id="Q#[Ufu%Pm9=GzdE@pFPH">
                                                            <block type="get_value" id="RdD=%=,z`:diSVyOP/!w">
                                                              <field name="OID">opendtu.0.114172609137.producing</field>
                                                            <block type="logic_boolean" id="(Eqk-Ym(20Q+_,iTt@|w">
                                                  <value name="THEN">
                                                    <block type="text" id=",QVHW_uAE@r0f!{)JmYr">
                                                      <field name="TEXT">Ausgeschaltet</field>
                                                  <value name="ELSE">
                                                    <block type="time_get" id="WDX6z]|S@u;_22cBnV?4">
                                                      <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                                      <field name="OPTION">custom</field>
                                                      <field name="FORMAT">TT.MM.JJJJ SS:mm:ss</field>
                                              <value name="ADD2">
                                                <block type="logic_ternary" id="e(0#cb7J0QP//t$A.Sqj">
                                                  <value name="IF">
                                                    <block type="logic_compare" id="/.uFC;4v~QrFr[e~l^4u">
                                                        <block type="get_value" id="z^RY8`{4;W+pqvKwa/7U">
                                                        <block type="logic_boolean" id="*wF4;WgwPbX]0kM|aRv.">
                                                  <value name="THEN">
                                                      <field name="TEXT">","fonts/bahnschrift20",2]}, {"line": [10,115,470,115,1]},  {"line": [10,117,470,117,1]},  {"text": [10,160,"WR HM800-1","fonts/bahnschrift30",2]}, {"line": [10,185,470,185,1]}, {"text": [10,200,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,200,"</field>
                                                  <value name="ELSE">
                                                    <block type="text" id="^sCuT(s]f}YnsUhyc@b4">
                                                      <field name="TEXT">","fonts/bahnschrift20",2]}, {"line": [10,115,470,115,1]},  {"line": [10,117,470,117,1]},  {"text": [10,160,"WR HM800-1  -  Ausgeschaltet","fonts/bahnschrift30",2]}, {"line": [10,185,470,185,1]}, {"text": [10,200,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,200,"</field>
                                              <value name="ADD3">
                                                  <field name="OID">pvforecast.0.plants.hm800_1.energy.today</field>
                                              <value name="ADD4">
                                                <block type="text" id="-TrP7)yat_@i@EoM![@s">
                                                  <field name="TEXT"> kWh","fonts/bahnschrift20",2]},     {"text": [10,230,"aktueller Ertrag","fonts/bahnschrift20",1]},   {"text": [250,230,"</field>
                                              <value name="ADD5">
                                                <block type="math_rndfixed" id="QAk.pcIY[:Hq@@iafttG">
                                                  <field name="n">3</field>
                                                  <value name="x">
                                                    <shadow type="math_number" id="mG[a]Hx%os@-@[KTCB6+">
                                                      <field name="NUM">3.1234</field>
                                                    <block type="math_arithmetic" id="Y4hw6Z6`8P]HU=kQv7.E">
                                                      <field name="OP">DIVIDE</field>
                                                        <shadow type="math_number" id=")F~PE4ejNz6-[9SlDD^r">
                                                        <block type="get_value" id=",q|-s|A[N!n.HVB![149">
                                                          <field name="OID">opendtu.0.114190930771.yieldday</field>
                                                        <shadow type="math_number" id="lEzFBL(5bFQIyhjrtXT2">
                                                          <field name="NUM">1000</field>
                                              <value name="ADD6">
                                                  <field name="TEXT"> kWh","fonts/bahnschrift20",2]}, {"text": [10,270,"Panel links","t0_14b_tf",1]},  {"text": [100,270,"</field>
                                              <value name="ADD7">
                                                <block type="math_rndfixed" id="6O5o-0crvmw{S]*ouu*{">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="[d|6QKY(-Y~2p1+1KXq6">
                                                        <block type="get_value" id="phgTU_Bh-tvt7%,t24y|">
                                                          <field name="OID">opendtu.0.114190930771.dc.input_1.yieldday</field>
                                                        <shadow type="math_number" id="beaX:Cp~.t27vbLSIXG/">
                                              <value name="ADD8">
                                                <block type="text" id="7nXKqp!cOTMvIDJNbSW5">
                                                  <field name="TEXT"> kWh","t0_14b_tf",2]}, {"text": [250,270,"Panel rechts","t0_14b_tf",1]},  {"text": [350,270,"</field>
                                              <value name="ADD9">
                                                <block type="math_rndfixed" id="P}gD4cnRY}-yt`}eIE|{">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="ozAT|J_|^Q$2v^@YN4Ho">
                                                        <block type="get_value" id="yKa;IXm+q5ASEgf#O+F[">
                                                          <field name="OID">opendtu.0.114190930771.dc.input_2.yieldday</field>
                                                        <shadow type="math_number" id="86CE1a5eatiL#AoR]O8m">
                                                <block type="text" id="xGp/ybNh#GE3P])v]Inw">
                                                  <field name="TEXT"> kWh","t0_14b_tf",2]},  {"line": [10,280,470,280,1]}, {"line": [10,282,470,282,1]},</field>
                                              <value name="ADD11">
                                                <block type="logic_ternary" id="@HjbASKU(HaOD^mQ,oWY">
                                                  <value name="IF">
                                                    <block type="logic_compare" id="9{#(Ck6zGJJhZ7F^p==E">
                                                        <block type="get_value" id="OSF}iUQ~rSU~5YYAin#F">
                                                        <block type="logic_boolean" id="V*Uq#xUHylKzFg-G(Q5l">
                                                  <value name="THEN">
                                                    <block type="text" id="NJ83/zw??wV}EXLpM@L-">
                                                      <field name="TEXT">{"text": [10,310,"WR HM800-2","fonts/bahnschrift30",2]}, {"line": [10,335,470,335,1]},  {"text": [10,350,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,350,"</field>
                                                  <value name="ELSE">
                                                    <block type="text" id="(,8mlBH*0JejMqRkxu^Z">
                                                      <field name="TEXT">{"text": [10,310,"WR HM800-2  -  Ausgeschaltet","fonts/bahnschrift30",2]}, {"line": [10,335,470,335,1]},  {"text": [10,350,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,350,"</field>
                                              <value name="ADD12">
                                                <block type="get_value" id="EeT5/2{=1Pjj98$#_)6X">
                                                  <field name="OID">pvforecast.0.plants.hm800_2.energy.today</field>
                                              <value name="ADD13">
                                                <block type="text" id="Lq9N4bVbA.B3?#0zbNa!">
                                                  <field name="TEXT"> kWh","fonts/bahnschrift20",2]},     {"text": [10,380,"aktueller Ertrag","fonts/bahnschrift20",1]},   {"text": [250,380,"</field>
                                              <value name="ADD14">
                                                <block type="math_rndfixed" id="Zc4Wo*jkd5VH{#}%sePK">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="TTu0Sbuj6d=$A/pZEp5i">
                                                        <block type="get_value" id="9aBLuy!78*lXpotau-h8">
                                                          <field name="OID">opendtu.0.114190653534.yieldday</field>
                                                        <shadow type="math_number" id="RuMYw9r(VN]+:RQ3X0R`">
                                              <value name="ADD15">
                                                <block type="text" id="]Y?pE{T:w[,/]BWN)Xq+">
                                                  <field name="TEXT"> kWh","fonts/bahnschrift20",2]}, {"text": [10,420,"Panel links","t0_14b_tf",1]},  {"text": [100,420,"</field>
                                              <value name="ADD16">
                                                <block type="math_rndfixed" id="Lv!##+_-},]dLvood@ZH">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="l};RW#X.f(5h_;Al3Q#F">
                                                        <block type="get_value" id="wU(`{rgH%Te%1K!gLE_.">
                                                          <field name="OID">opendtu.0.114190653534.dc.input_1.yieldday</field>
                                                        <shadow type="math_number" id="f-#~,!P7~dY_{2b]+bZw">
                                              <value name="ADD17">
                                                <block type="text" id="^^K-W;pWK,9o#[dPW~cd">
                                                  <field name="TEXT"> kWh","t0_14b_tf",2]}, {"text": [250,420,"Panel rechts","t0_14b_tf",1]},  {"text": [350,420,"</field>
                                              <value name="ADD18">
                                                <block type="math_rndfixed" id="QGt7G0Sl#@a3.5@ADHFT">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="3MtkdH74:boCXRg2pgwj">
                                                        <block type="get_value" id="U$_nYTB5?0FU){HAJE(B">
                                                          <field name="OID">opendtu.0.114190653534.dc.input_2.yieldday</field>
                                                        <shadow type="math_number" id="[NG_XNI?P4+%/Vj8==}[">
                                              <value name="ADD19">
                                                <block type="text" id="$EisYqD8XD(hY)GBpDD7">
                                                  <field name="TEXT"> kWh","t0_14b_tf",2]}, {"line": [10,430,470,430,1]}, {"line": [10,432,470,432,1]},</field>
                                              <value name="ADD20">
                                                <block type="logic_ternary" id="x~0?ARW%*1R.pa^/hko?">
                                                  <value name="IF">
                                                    <block type="logic_compare" id="o|5F4IL8N^5UDxsAGFxg">
                                                        <block type="get_value" id="GSedObh37`:,W+yov-zG">
                                                        <block type="logic_boolean" id="Y:BJ.M;?tn#S!)7%mN[;">
                                                  <value name="THEN">
                                                    <block type="text" id="KcxMy19JI6~%OX[7y7za">
                                                      <field name="TEXT">{"text": [10,460,"WR HM600","fonts/bahnschrift30",2]}, {"line": [10,485,470,485,1]},  {"text": [10,500,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,500,"</field>
                                                  <value name="ELSE">
                                                    <block type="text" id="*~KvPLC*POD+g[g1].)U">
                                                      <field name="TEXT">{"text": [10,460,"WR HM600  -  Ausgeschaltet","fonts/bahnschrift30",2]}, {"line": [10,485,470,485,1]},  {"text": [10,500,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,500,"</field>
                                              <value name="ADD21">
                                                <block type="get_value" id="?=L[IdwDuBQX=-l#f#B/">
                                                  <field name="OID">pvforecast.0.plants.hm600.energy.today</field>
                                              <value name="ADD22">
                                                <block type="text" id="@-*Ngc*K=Sp]P,1*M;CY">
                                                  <field name="TEXT"> kWh","fonts/bahnschrift20",2]},     {"text": [10,530,"aktueller Ertrag","fonts/bahnschrift20",1]},   {"text": [250,530,"</field>
                                              <value name="ADD23">
                                                <block type="math_rndfixed" id="T0-z;{D5wgX0LrH#9R[Z">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="vs^5Rb_sD8bohnEKn-fv">
                                                        <block type="get_value" id="Ob(W-,Pe~q~jy%7r^XW7">
                                                          <field name="OID">opendtu.0.114172609137.yieldday</field>
                                                        <shadow type="math_number" id="t0I3hJZuLIHM^|RLd|iv">
                                              <value name="ADD24">
                                                <block type="text" id="@A+vp)63G)$k(=[[*?-F">
                                                  <field name="TEXT"> kWh","fonts/bahnschrift20",2]}, {"text": [10,570,"Panel links","t0_14b_tf",1]},  {"text": [100,570,"</field>
                                              <value name="ADD25">
                                                <block type="math_rndfixed" id="jMe%0jtE9~k4s(pZYnc`">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="Z`G.vQb/puMf/f#NWPJ`">
                                                        <block type="get_value" id="2yCXTF1Qb84nEUUhMx8$">
                                                          <field name="OID">opendtu.0.114172609137.dc.input_1.yieldday</field>
                                                        <shadow type="math_number" id="_u/#Y9.YCwwyW}MR@j8*">
                                              <value name="ADD26">
                                                <block type="text" id="rlvNe?,x+HP[Rx$%DDjb">
                                                  <field name="TEXT"> kWh","t0_14b_tf",2]}, {"text": [250,570,"Panel rechts","t0_14b_tf",1]},  {"text": [350,570,"</field>
                                              <value name="ADD27">
                                                <block type="math_rndfixed" id="+QU2)e/xv._D]JaId@CS">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="icpgn}$s~Hp0qqP-y+pZ">
                                                        <block type="get_value" id="bf%+QR[inZJC#AAQ@u0R">
                                                          <field name="OID">opendtu.0.114172609137.dc.input_2.yieldday</field>
                                                        <shadow type="math_number" id="27Ai(Ivub(g(8@Xz~03e">
                                              <value name="ADD28">
                                                <block type="text" id="qghl?RN!Na`7!*@Rh%]!">
                                                  <field name="TEXT"> kWh","t0_14b_tf",2]}, {"line": [10,580,470,580,1]}, {"line": [10,582,470,582,1]},</field>
                                              <value name="ADD29">
                                                <block type="text" id="t4tfAp2p2KSKGOdksFV*">
                                                  <field name="TEXT">{"text": [240,600,"Gesamtertrag","fonts/calibrib50",1,1]}, {"line": [10,665,470,665,1]}, {"text": [240,690,"</field>
                                              <value name="ADD30">
                                                <block type="math_rndfixed" id="HKNDXa}YT2y6W}:;g}*x">
                                                  <value name="x">
                                                    <block type="math_arithmetic" id="$a(kOL-]3r)4dehKOE6#">
                                                        <block type="get_value" id="vA3:H]EHDmDCIp+bk3;h">
                                                          <field name="OID">opendtu.0.total.yieldday</field>
                                                        <shadow type="math_number" id="OY{OD3uwCS2W3/+FYOOz">
                                              <value name="ADD31">
                                                <block type="text" id="L[@Q+Cu-y!dxWzKzMZlL">
                                                  <field name="TEXT"> kWh","fonts/calibrib80",2,1]}, {"line": [10,780,470,780,2]}, {"line": [10,782,470,782,2]}, {"line": [10,784,470,784,2]}]</field>
                                          <value name="URL">
                                          <value name="DATA">
                                              <value name="ADD0">
                                              <value name="ADD1">
                                              <value name="ADD2">
                                              <value name="ADD3">
                  Das Display sieht so aus:
                    So,
                    ich habe die Anzeige etwas "verfeinert". Mir ging bei den Werten der Punkt anstelle eines Kommas auf die Nerven.
                      <variables>
                      </variables>
                        </mutation>
                                        <field name="TYPE">nauticalDawn</field>
                                        <field name="TYPE">nauticalDusk</field>
                                            </mutation>
                                            <value name="ARG0">
                                              <block type="text_join" id="(xI]C(qn!er+Dx3Kqd{e">
                                                <value name="ADD0">
                                                <value name="ADD1">
                                                    <value name="IF">
                                                        <value name="AND0">
                                                        <value name="AND1">
                                                        <value name="AND2">
                                                    <value name="THEN">
                                                    <value name="ELSE">
                                                <value name="ADD2">
                                                  <block type="text_replace" id="9suDhywmn0|S@k%B4tL}">
                                                    <value name="FROM">
                                                      <shadow type="text" id="R@w?w+H}pK1M|yk.4Q,7">
                                                        <field name="TEXT">.</field>
                                                    <value name="TO">
                                                      <shadow type="text" id="PO}quB08Odk-!i13EyAx">
                                                        <field name="TEXT">,</field>
                                                    <value name="TEXT">
                                                      <shadow type="text" id="Q$Af]Md*qL+5@VZ!5E+j">
                                                        <value name="ADD0">
                                                            <value name="IF">
                                                            <value name="THEN">
        <field name="TEXT">","fonts/bahnschrift20",2]}, {"line": [10,115,470,115,1]},  {"line": [10,117,470,117,1]},  {"text": [10,160,"WR1 HM1000","fonts/bahnschrift30",2]}, {"line": [10,185,470,185,1]}, {"text": [10,200,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,200,"</field>
                                                            <value name="ELSE">
        <field name="TEXT">","fonts/bahnschrift20",2]}, {"line": [10,115,470,115,1]},  {"line": [10,117,470,117,1]},  {"text": [10,160,"WR1 HM1000  -  Ausgeschaltet","fonts/bahnschrift30",2]}, {"line": [10,185,470,185,1]}, {"text": [10,200,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,200,"</field>
                                                        <value name="ADD1">
                                                            <field name="OID">pvforecast.0.plants.wr1Hm1000.energy.today</field>
                                                        <value name="ADD2">
                                                        <value name="ADD3">
                                                            <value name="x">
                                                        <value name="ADD4">
                                                        <value name="ADD5">
                                                            <field name="OID">opendtu.0.114190930771.dc.input_2.power</field>
                                                        <value name="ADD6">
                                                            <field name="TEXT"> W","t0_14b_tf",2]}, {"text": [250,270,"Panel rechts","t0_14b_tf",1]},  {"text": [350,270,"</field>
                                                        <value name="ADD7">
                                                            <field name="OID">opendtu.0.114190930771.dc.input_1.power</field>
                                                        <value name="ADD8">
                                                            <field name="TEXT"> W","t0_14b_tf",2]},  {"line": [10,280,470,280,1]}, {"line": [10,282,470,282,1]},</field>
                                                        <value name="ADD9">
                                                            <value name="IF">
                                                            <value name="THEN">
        <field name="TEXT">{"text": [10,310,"WR2 HM1000","fonts/bahnschrift30",2]}, {"line": [10,335,470,335,1]},  {"text": [10,350,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,350,"</field>
                                                            <value name="ELSE">
        <field name="TEXT">{"text": [10,310,"WR2 HM1000  -  Ausgeschaltet","fonts/bahnschrift30",2]}, {"line": [10,335,470,335,1]},  {"text": [10,350,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,350,"</field>
                                                            <field name="OID">pvforecast.0.plants.wr2Hm1000.energy.today</field>
                                                            <value name="x">
                                                            <field name="OID">opendtu.0.114190653534.dc.input_2.power</field>
                                                            <field name="TEXT"> W","t0_14b_tf",2]}, {"text": [250,420,"Panel rechts","t0_14b_tf",1]},  {"text": [350,420,"</field>
                                                            <field name="OID">opendtu.0.114190653534.dc.input_1.power</field>
                                                            <field name="TEXT"> W","t0_14b_tf",2]}, {"line": [10,430,470,430,1]}, {"line": [10,432,470,432,1]},</field>
                                                            <value name="IF">
                                                            <value name="THEN">
        <field name="TEXT">{"text": [10,460,"WR3 HM1000","fonts/bahnschrift30",2]}, {"line": [10,485,470,485,1]},  {"text": [10,500,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,500,"</field>
                                                            <value name="ELSE">
        <field name="TEXT">{"text": [10,460,"WR3 HM1000  -  Ausgeschaltet","fonts/bahnschrift30",2]}, {"line": [10,485,470,485,1]},  {"text": [10,500,"heutige Vorhersage","fonts/bahnschrift20",1]},     {"text": [250,500,"</field>
                                                            <field name="OID">pvforecast.0.plants.wr3Hm1000.energy.today</field>
                                                            <value name="x">
                                                            <field name="OID">opendtu.0.114172609137.dc.input_2.power</field>
                                                            <field name="TEXT"> W","t0_14b_tf",2]}, {"text": [250,570,"Panel rechts","t0_14b_tf",1]},  {"text": [350,570,"</field>
                                                            <field name="OID">opendtu.0.114172609137.dc.input_1.power</field>
                                                            <field name="TEXT"> W","t0_14b_tf",2]}, {"line": [10,580,470,580,1]}, {"line": [10,582,470,582,1]},{"text": [10,600,"heutige Vorhersage </field>
                                                          <block type="get_value" id="3]*vljaL09ew4$FO9xPb">
                                                            <field name="OID">pvforecast.0.summary.energy.today</field>
                                                          <block type="text" id="IUGBm6dx/gIlfNP}Yt%y">
                                                            <field name="TEXT"> kWh","t0_14b_tf",2]},{"text": [250,600,"Erreichter Ertrag </field>
                                                          <block type="math_rndfixed" id="sZUvOOMh,ha=vZpir=t[">
                                                            <field name="n">2</field>
                                                            <value name="x">
                                                              <shadow type="math_number" id="3BOwPA}*ySU8ZK0Gnl1n">
                                                              <block type="math_arithmetic" id="wmJ/[`BFPDO7D`A0RgBd">
        <shadow type="math_number" id="l1C4`dT0?s#j@S`rk4f4">
        <shadow type="math_number" id=":Xkz~uu=qr_GYw$jsfL{">
        <block type="math_arithmetic" id="!JGoF:`qR,7:r6HfEUkL">
        <shadow type="math_number" id="V+z*Pkx6V]nVqtm[{CvF">
        <block type="math_arithmetic" id="uBAX:!#=6J0*[j%6)-?y">
        <shadow type="math_number" id="zZh-~A!wYv#8/P.AW6x9">
        <block type="get_value" id=":V1;P-tCQ/Su;UfRcDj[">
        <shadow type="math_number" id="J$vn}Z+z=TXkY#,6)O%I">
        <shadow type="math_number" id="Gd_TU(AoI5gK;vD9`wR:">
        <block type="get_value" id="=[RKv}#j--V|7Tien#0#">
                                                            <field name="TEXT"> %","t0_14b_tf",2]},{"text": [240,610,"Gesamtertrag","fonts/calibrib50",1,1]}, {"line": [10,675,470,675,1]}, {"text": [240,690,"</field>
                                                            <value name="x">
                                                        <value name="ADD32">
                                            <value name="URL">
                                            <value name="DATA">
                                                <value name="ADD0">
                                                <value name="ADD1">
                                                <value name="ADD2">
                                                <value name="ADD3">
                    Sieht dann so aus.
                    Das ist ganz einfach mit dem Blockly-Baustein aus "Text" ersetze-durch-in gemacht.
                    Also ersetze "Punkt" durch "komma" und dann in das letzte Feld eben den kompletten Baustein "erstelle Text aus".
                    Die obere Datumsanzeige muß natürlich auserhalb des "ersetzen" Blocks.
                    In den Haupteinstellungen von ioBroker gibt es zwar eine Auswahl zwischen Komma und Punkt.
                    Auf Zahlenwerte in den Datenpunkten wenn sie in einem Blockly verarbeitet werden hat es leider keinen Einfluss.
                    Eisbaeeer 1 Reply Last reply Reply Quote 0
                    • Eisbaeeer
                      Eisbaeeer Developer @Beowolf last edited by
                      Java-Script um ein Display mit Puppeteer zu füttern.
                      Benötigt wird der Chrome-Headless + Puppeteer Adapter.
                      In VIS einen View erstellen und diesen hier im Script angeben.
                      Das Script wird einen Screenshot davon machen und auf das Display hochladen.
                      // Author:  Eisbaeeer
                      // Date:    20250415
                      // Version  0.2 :   Bugfix async pictures
                      // Version: 0.1 :   Convert from Blockly to js
                      // Benötigt:
                      // - Puppeteer Adapter
                      // - Chrome Headless
                      // Hier die Anpassungen vornehmen!
                      const urlOfVISView = 'http://192.168.1.200:8082/vis/?OpenEpaper#Tag2';	// Eure View oder URL vom Bild						// URL zur View
                      const targetWidth = 296;												// Breite des Displays
                      const targetHeight = 128;												// Höhe des Displays
                      const cutoutX = 0;													    // Abstand Pixel von links für Screenshot
                      const cutoutY = 0;														// Abstand Pixel von oben für Screenshot
                      const pquality = 100;	                                                // Bildqualität
                      const waitForSelector = "#w00017"										// Screenshot Qualität
                      const inputPath = "/tmp/epaperTag01.jpg";								// Screenshot temporär
                      const uploadUrl = 'http://192.168.1.180/imgupload';						// IP-Adresse Accesspoint anpassen
                      const macAddress = '0000021F7E2C3B12';									// MAC-Adresse des Displays anpassen
                      const ditherValue = 1; 												    // Setze den Dither-Wert (Farbanpassungen: 0 = View hat gleiche Farben | 1 = View hat andere Farben als das Display
                      // Hier werden die Trigger eingestellt (wann ein Screenshot erstellt werden soll)
                      // Hier im Beispiel alle 15 Minuten
                      schedule("*/15 * * * *", async () => {
                          takeScreenshots();
                      // Hier auf einen STATE im userdata.0
                      on("0_userdata.0.TESTING.STATE",function(obj) {
                          takeScreenshots();
                      // Hier auf einen STATE von Homematic Türkontakt
                      on("hm-rpc.0.LEQ9129032.1.STATE",function(obj) {
                          takeScreenshots();
                      // ENDE Anpassungen! Ab hier nichts mehr ändern!
                      // Requirements
                      const puppeteer = require('puppeteer');
                      const axios = require('axios');
                      const fs = require('fs');
                      const FormData = require('form-data');
                      async function takeScreenshots() {
                          console.log("*** function takeScreenshot");
                          sendTo('puppeteer.0', 'screenshot', {
                            url: urlOfVISView,
                              path: inputPath,
                              width: targetWidth,
                              height: targetHeight,
                              quality: pquality,
                              waitOption: {
                                  waitForSelector: waitForSelector,
                                  waitForTimeout: 20000
                              fullPage: false,
                              clip: {
                                  x: cutoutX,
                                  y: cutoutY,
                                  width: targetWidth,
                          }, obj => {
                            if (obj.error) {
                              log(`Error taking screenshot: ${obj.error.message}`, 'error');
                            } else {
                              // the binary representation of the image is contained in `obj.result`
                              log(`Successfully took screenshot: ${obj.result}`);
                              console.log("*** upload Image");
                              // uploading Screenshot
                              async function uploadImage() {
                      		try {
                      			// Prüfen, ob die Datei existiert
                      			if (!fs.existsSync(inputPath)) {
                      			throw new Error(`Datei nicht gefunden: ${inputPath}`);
                      	// FormData erstellen
                      	const form = new FormData();
                      	form.append("mac", macAddress);
                      	form.append("dither", ditherValue); // Dither-Parameter hinzufügen
                      	form.append("file", fs.createReadStream(inputPath));
                      	// POST-Anfrage senden
                      	const response = await axios.post(uploadUrl, form, {
                      	headers: {
                      		...form.getHeaders(),
                      	console.log('Upload erfolgreich:', response.data);
                      	} catch (error) {
                      	if (error.response) {
                      		console.error('Server-Antwort:', error.response.status, error.response.data);
                      	} else if (error.request) {
                      		console.error('Keine Antwort erhalten:', error.request);
                      	} else {
                      		console.error('Fehler beim Hochladen:', error.message);
                          uploadImage();
