    4. [Gelöst] Motioneye auf Proxmox lxc installieren
    • UHU01
      UHU01 last edited by UHU01
      ich versuche Motioneye nach dieser Anleitung in einem Proxmox lxc Container zu installieren.
      Bei der eigentlichen MotionEye Installation bekomme ich folgenden Fehler:
      uhu@MotionEye:~$  pip install motioneye
      error: externally-managed-environment
      × This environment is externally managed
      ╰─> To install Python packages system-wide, try apt install
          python3-xyz, where xyz is the package you are trying to
          install.
          If you wish to install a non-Debian-packaged Python package,
          create a virtual environment using python3 -m venv path/to/venv.
          Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
          sure you have python3-full installed.
          If you wish to install a non-Debian packaged Python application,
          it may be easiest to use pipx install xyz, which will manage a
          virtual environment for you. Make sure you have pipx installed.
          See /usr/share/doc/python3.11/README.venv for more information.
      note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
      hint: See PEP 668 for the detailed specification.
      Was ist zu tuhen?
        Thomas Braun Most Active @UHU01 last edited by
        @uhu01
        Verwende statt pip besser pipx .
        UHU01 1 Reply Last reply Reply Quote 0
        • UHU01
          UHU01 @Thomas Braun last edited by
          @thomas-braun said in Motioneye auf Proxmox lxc installieren:
          @uhu01
          -bash: pipx: command not found
            @uhu01
            Deswegen ja auch:
            sudo apt update
            sudo apt install pipx
            • UHU01
              @thomas-braun Danke dir!
              Die Anleitung war tatsächlich sehr veraltet. Mit der aktuellen ging es...
