    4. Zigbee Adapter "disconnected"
    • amg_666
      amg_666 last edited by amg_666
      Hallo, ich habe seit eingier Zeit immer wieder Probleme mit dem Zigbee Adapter, der Adapter stoppt und die Instanz ist dann "gelb".
      zigbee.2
      	2025-02-10 10:56:16.560	error	Adapter disconnected, stopping
      zigbee.2
      	2025-02-10 10:56:16.559	error	Adapter disconnected, stopping
      zigbee.2
      	2025-02-10 10:56:16.558	error	Adapter disconnected, stopping
      zigbee.2
      	2025-02-10 10:56:16.557	error	Adapter disconnected, stopping
      zigbee.2
      	2025-02-10 10:56:16.551	error	Adapter disconnected, stopping
      zigbee.2
      	2025-02-10 10:56:16.536	error	Error herdsman start
      zigbee.2
      	2025-02-10 10:56:16.536	error	Failed to start Zigbee
      zigbee.2
      	2025-02-10 10:56:16.535	error	Starting zigbee-herdsman problem : "Error while opening socket"
      admin.0
      	2025-02-10 10:56:16.276	info	==> Connected system.user.admin from ::ffff:192.168.1.226
      zigbee.2
      	2025-02-10 10:54:14.948	info	Installed Version: iobroker.zigbee@1.10.14
      zigbee.2
      	2025-02-10 10:54:14.942	info	Starting Zigbee npm ...
      zigbee.2
      	2025-02-10 10:54:14.941	info	Try to reconnect.
      zigbee.2
      	2025-02-10 10:54:04.940	error	Error herdsman start
      zigbee.2
      	2025-02-10 10:54:04.939	error	Failed to start Zigbee
      zigbee.2
      	2025-02-10 10:54:04.939	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'execute')"
      zigbee.2
      	2025-02-10 10:54:03.647	info	Installed Version: iobroker.zigbee@1.10.14
      zigbee.2
      zigbee.2
      	2025-02-10 10:54:03.635	info	Starting Zigbee npm ...
      zigbee.2
      	2025-02-10 10:54:03.634	info	Try to reconnect.
      zigbee.2
      	2025-02-10 10:54:03.634	info	Starting Zigbee npm ...
      zigbee.2
      zigbee.2
      	2025-02-10 10:53:53.606	error	Adapter disconnected, stopping
      zigbee.2
      	2025-02-10 10:53:53.597	error	Adapter disconnected, stopping
      Wenn ich im iob admin die Instanz neu starte läuft alles wieder
      zigbee.2
      	2025-02-10 10:56:27.818	info	0x04cf8cdf3c7d7c69 (addr 20132): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
      zigbee.2
      	2025-02-10 10:56:27.817	info	0x04cf8cdf3c7dcc26 (addr 29290): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
      zigbee.2
      	2025-02-10 10:56:27.816	info	0x5c0272fffe96fa2a (addr 7999): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
      zigbee.2
      	2025-02-10 10:56:27.815	info	0x00124b00234c6ba9 (addr 57249): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
      zigbee.2
      	2025-02-10 10:56:27.811	info	0x00124b00235279d6 (addr 47138): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
      zigbee.2
      	2025-02-10 10:56:27.810	info	0x00124b0023528715 (addr 35049): ZB-RGBCW - Lonsonho Zigbee 3.0 LED-bulb, RGBW LED (Router)
      zigbee.2
      	2025-02-10 10:56:27.809	info	0x54ef44100017a66e (addr 57020): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
      zigbee.2
      	2025-02-10 10:56:27.808	info	0x842e14fffe602b98 (addr 14854): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      zigbee.2
      	2025-02-10 10:56:27.807	info	0xa4c1388e4fb7d6d8 (addr 59225): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
      zigbee.2
      	2025-02-10 10:56:27.803	info	0x54ef4410001c5ee0 (addr 4247): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
      zigbee.2
      	2025-02-10 10:56:27.712	info	Currently 32 devices are joined:
      zigbee.2
      	2025-02-10 10:56:27.553	info	--> transmitPower : high+
      zigbee.2
      	2025-02-10 10:56:27.543	info	Unable to disable LED, unsupported function.
      zigbee.2
      	2025-02-10 10:56:27.542	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
      zigbee.2
      	2025-02-10 10:56:25.983	info	Installed Version: iobroker.zigbee@1.10.14
      zigbee.2
      	2025-02-10 10:56:25.759	info	Starting Zigbee npm ...
      zigbee.2
      	2025-02-10 10:56:25.756	info	delete old Backup files. keep only last 10
      zigbee.2
      	2025-02-10 10:56:25.657	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.2, js-controller: 7.0.6
      host.iobroker
      	2025-02-10 10:56:22.253	info	instance system.adapter.zigbee.2 in version "1.10.14" started with pid 453023
      iob auf proxmox container (debian 12)
      beta repository
      zigbee 1.10.14 (der Fehler trat aber auch schonn mit älteren Versionen auf),
      js-controller 7.0.6
      node-js 20.18.2
      npm 10.8.2
      Der Zigbee Stick ist ein "HamGeek CC2652P-Modul" , der direkt im LAN hängt.
      Hat hier jemand eine Idee wie/wo ich auf die Suche nach dem Fehler gehen kann?
      Asgothian Meister Mopper 2 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @amg_666 last edited by
        @amg_666 es gibt eine von 2 möglichen Ursachen
        • Netzwerkprobleme
        • Probleme im Koordinator das der Koordinator abschmiert und die Kommunikation
        A.
        amg_666 1 Reply Last reply Reply Quote 0
        • amg_666
          amg_666 @Asgothian last edited by
          @asgothian Netzwerkprobleme schließe ich eigentlioch aus, der Stick hängt an einer LAN Dose im EG und von der gehts direkt in den Router, werd ich aber trotzdem nochmal checken/messen.
          "Probleme im Koordinator": Wie kann ich das prüfen/überwachen? Oder soll ich mal eine FW neu draufziehen?
          • Asgothian
            @amg_666 sagte in Zigbee Adapter "disconnected":
            Ich wäre nicht so schnell damit Lan-Probleme auszuschliessen. Ich würde versuchen den Moment zu greifen wo der Adapter sich disconnected und genau in dem Moment per Web-Interface auf den Koordinator zuzugreifen.
            Wichtig ist erst einmal eine saubere Analyse, nicht ein "wir tauschen mal eben folgende Komponenten aus"
            A
            • Meister Mopper
              Meister Mopper @amg_666 last edited by
              Ich habe hier gerade ein ähnliches Phänomen. Der Koordinator hängt an einem POE-Switch und steigt alle paar Monate mal aus.
              Nachdem man ihn mal ne Minute stromlos macht und den Adapter neu startet, läuft die chose wieder.
              Meine Vermutung ist, dass der Koordinator zeitweise mit Strom unterversorgt ist, weiß aber noch nicht, wie ich das prüfen kann.
                20230507
                ich tippe auf die Firmware.. da läuft was über.. ich kenne den Kooridnator nicht aber gibbet da nicht was neues ?
                zigbee adapter disconnected
