    4. [influxDB] InfluxDB API unavailable after 10 [Gelöst]
    • MichaelF
      MichaelF last edited by MichaelF
      Hi, ich habe glaube ich seit ein paar Tagen das meine Influx DBnicht mehr erreichbar ist. Jemand vieleicht eine Idee woran es liegen kann.
      Installiert oder upgedatet habe ich so nichts.
      pi@Influxdb1:~ $ sudo service influxdb status
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
          Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
          Active: activating (start) since Mon 2025-02-10 12:17:03 CET; 1min 13s ago
            Docs: https://docs.influxdata.com/influxdb/
      Cntrl PID: 396 (influxd-systemd)
           Tasks: 15 (limit: 1595)
             CPU: 1min 58.700s
          CGroup: /system.slice/influxdb.service
                  ├─ 396 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                  ├─ 453 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                  └─1025 sleep 1
      Feb 10 12:18:16 Influxdb1 influxd-systemd-start.sh[396]: InfluxDB API unavailable after 68 attempts...
      Feb 10 12:18:16 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:16.871477Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:17 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:17.000972Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:17 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:17.126616Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:17 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:17.316160Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:17 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:17.540218Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:17 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:17.718894Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:17 Influxdb1 influxd-systemd-start.sh[396]: InfluxDB API unavailable after 69 attempts...
      Feb 10 12:18:18 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:18.045877Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:18 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:18.244882Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:52 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:52.067759Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:52 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:52.280740Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:52 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:52.398579Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >Feb 10 12:18:52 Influxdb1 influxd-systemd-start.sh[396]: InfluxDB API unavailable after 70 attempts...
      Feb 10 12:18:52 Influxdb1 influxd-systemd-start.sh[453]: ts=2025-02-10T11:18:52.524936Z lvl=info msg="Reading file" log_id=0ucu4a6l000 engine=tsm1 >
      pi@Influxdb1:~ $ apt policy influxdb*
      influxdb-client:
        Installiert:           (keine)
        Installationskandidat: 1.6.7~rc0-1
        Versionstabelle:
           1.6.7~rc0-1 500
      influxdb-dev:
        Installationskandidat: (keine)
        Versionstabelle:
      influxdb:
        Installiert:           1.8.10-1
        Installationskandidat: 1.8.10-1
        Versionstabelle:
       *** 1.8.10-1 500
              500 https://repos.influxdata.com/debian stable/main armhf Packages
              100 /var/lib/dpkg/status
           1.6.7~rc0-1 500
      pi@Influxdb1:~ $
      Wenn noch infos Fehlen nur schreiben. Danke schon mal und viele Gruesse.
      • Marc Berg
        Marc Berg Most Active @MichaelF last edited by
        @michaelf sagte in [influxDB] InfluxDB API unavailable after 10 attempts:
        Was sagt:
        sudo journalctl -u influxdb -n 100
        df -h
        ls -la /var/lib/influxdb
        cat /etc/influxdb/influxdb.conf
        MichaelF 1 Reply Last reply Reply Quote 0
        • MichaelF
          MichaelF @Marc Berg last edited by
          @marc-berg
          Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:04.408903Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00388.wal size=194059        Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:04.506865Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00389.wal size=193611
          Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:04.621808Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00390.wal size=194372        Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:04.745603Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00391.wal size=193853        Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:04.842707Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00392.wal size=193699        Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 50 attempts...        Feb 10 15:14:04 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:04.945822Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00393.wal size=193973        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.048821Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00394.wal size=194292        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.152176Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00395.wal size=194609        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.256002Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00396.wal size=194456        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.358288Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00397.wal size=193994        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.461019Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00398.wal size=193608        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.563770Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00399.wal size=193803        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.667321Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00400.wal size=194229        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.777526Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00401.wal size=193694        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:05.916780Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00402.wal size=194228        Feb 10 15:14:05 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 51 attempts...        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.023522Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00403.wal size=194232        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.126049Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00404.wal size=193585        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.228963Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00405.wal size=193402        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.332253Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00406.wal size=194645        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.434863Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00407.wal size=193587
          Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.546409Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00408.wal size=193788        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.650170Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00409.wal size=193868        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.755035Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00410.wal size=194303        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.858928Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00411.wal size=193975        Feb 10 15:14:06 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:06.979870Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00412.wal size=194057        Feb 10 15:14:07 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 52 attempts...        Feb 10 15:14:07 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:07.128928Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00413.wal size=193057        Feb 10 15:14:07 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:07.244535Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00414.wal size=193827        Feb 10 15:14:07 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:07.409928Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00415.wal size=193892        Feb 10 15:14:07 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:07.740491Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00416.wal size=193867        Feb 10 15:14:07 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:07.956925Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00417.wal size=193662        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 53 attempts...        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:08.200712Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00418.wal size=194050        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:08.406897Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00419.wal size=194049        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:08.556325Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00420.wal size=193442        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:08.703088Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00421.wal size=193770        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:08.818446Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00422.wal size=193974        Feb 10 15:14:08 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:08.921251Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00423.wal size=193816
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.022733Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00424.wal size=193451
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.123666Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00425.wal size=193710
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 54 attempts...
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.226569Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00426.wal size=193978
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.327883Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00427.wal size=193896
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.429515Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00428.wal size=193614
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.530891Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00429.wal size=194124
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.632725Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00430.wal size=194169
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.733992Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00431.wal size=194223
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.834885Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00432.wal size=193317
          Feb 10 15:14:09 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:09.935608Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00433.wal size=193871
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.036434Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00434.wal size=193830
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.137485Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00435.wal size=194339
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 55 attempts...
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.242110Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00436.wal size=193302
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.343542Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00437.wal size=193543
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.445129Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00438.wal size=194753
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.544827Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00439.wal size=193982
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.649931Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00440.wal size=193799
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.755390Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00441.wal size=194094
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.861658Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00442.wal size=194137
          Feb 10 15:14:10 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:10.967978Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00443.wal size=194130
          Feb 10 15:14:11 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:11.072747Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00444.wal size=193323
          Feb 10 15:14:11 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:11.178609Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00445.wal size=194131
          Feb 10 15:14:11 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 56 attempts...
          Feb 10 15:14:11 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:11.287917Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00446.wal size=194350
          Feb 10 15:14:11 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:11.393875Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00447.wal size=193873
          Feb 10 15:14:11 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:11.498260Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00448.wal size=193619
          Feb 10 15:14:12 Influxdb1 influxd-systemd-start.sh[1942]: InfluxDB API unavailable after 57 attempts...
          Feb 10 15:14:12 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:12.789154Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00449.wal size=193967
          Feb 10 15:14:12 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:12.917930Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00450.wal size=194248
          Feb 10 15:14:13 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:13.018691Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00451.wal size=194148
          Feb 10 15:14:13 Influxdb1 influxd-systemd-start.sh[1943]: ts=2025-02-10T14:14:13.149227Z lvl=info msg="Reading file" log_id=0ud39Zq0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00452.wal size=193002
          lines 1-74
          pi@Influxdb1:~ $ df -h
          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
          /dev/root       117G    9,0G  102G    9% /
          devtmpfs        333M       0  333M    0% /dev
          tmpfs           461M       0  461M    0% /dev/shm
          tmpfs           185M    980K  184M    1% /run
          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
          /dev/sda1       253M     51M  202M   20% /boot
          tmpfs            93M       0   93M    0% /run/user/1000
          pi@Influxdb1:~ $ ls -la /var/lib/influxdb
          insgesamt 24
          drwxr-xr-x  5 influxdb influxdb 4096 10. Feb 15:16 .
          drwxr-xr-x 30 root     root     4096 19. Jan 2024  ..
          drwxr-xr-x  5 influxdb influxdb 4096 19. Jan 2024  data
          -rw-r--r--  1 influxdb influxdb    5 10. Feb 15:16 influxd.pid
          drwxr-xr-x  2 influxdb influxdb 4096 10. Feb 00:36 meta
          drwx------  5 influxdb influxdb 4096 19. Jan 2024  wal
          • MichaelF
            Die config muss ich später schicken. Danke aber schonmal!
            • MichaelF
              pi@Influxdb1:~ $ cat /etc/influxdb/influxdb.conf
              ### Welcome to the InfluxDB configuration file.
              # The values in this file override the default values used by the system if
              # a config option is not specified. The commented out lines are the configuration
              # field and the default value used. Uncommenting a line and changing the value
              # will change the value used at runtime when the process is restarted.
              # Once every 24 hours InfluxDB will report usage data to usage.influxdata.com
              # The data includes a random ID, os, arch, version, the number of series and other
              # usage data. No data from user databases is ever transmitted.
              # Change this option to true to disable reporting.
              # reporting-disabled = false
              # Bind address to use for the RPC service for backup and restore.
                bind-address = ":8088"
              ### [meta]
              ### Controls the parameters for the Raft consensus group that stores metadata
              ### about the InfluxDB cluster.
              [meta]
                # Where the metadata/raft database is stored
                dir = "/var/lib/influxdb/meta"
                # Automatically create a default retention policy when creating a database.
                # retention-autocreate = true
                # If log messages are printed for the meta service
                # logging-enabled = true
              ### [data]
              ### Controls where the actual shard data for InfluxDB lives and how it is
              ### flushed from the WAL. "dir" may need to be changed to a suitable place
              ### for your system, but the WAL settings are an advanced configuration. The
              ### defaults should work for most systems.
              [data]
                # The directory where the TSM storage engine stores TSM files.
                dir = "/var/lib/influxdb/data"
                # The directory where the TSM storage engine stores WAL files.
                wal-dir = "/var/lib/influxdb/wal"
                # The amount of time that a write will wait before fsyncing.  A duration
                # greater than 0 can be used to batch up multiple fsync calls.  This is useful for slower
                # disks or when WAL write contention is seen.  A value of 0s fsyncs every write to the WAL.
                # Values in the range of 0-100ms are recommended for non-SSD disks.
                # wal-fsync-delay = "0s"
                # The type of shard index to use for new shards.  The default is an in-memory index that is
                # recreated at startup.  A value of "tsi1" will use a disk based index that supports higher
                # cardinality datasets.
                # index-version = "inmem"
                # Trace logging provides more verbose output around the tsm engine. Turning
                # this on can provide more useful output for debugging tsm engine issues.
                # trace-logging-enabled = false
                # Whether queries should be logged before execution. Very useful for troubleshooting, but will
                # log any sensitive data contained within a query.
                # query-log-enabled = true
                # Provides more error checking. For example, SELECT INTO will err out inserting an +/-Inf value
                # rather than silently failing.
                # strict-error-handling = false
                # Validates incoming writes to ensure keys only have valid unicode characters.
                # This setting will incur a small overhead because every key must be checked.
                # validate-keys = false
                # Settings for the TSM engine
                # CacheMaxMemorySize is the maximum size a shard's cache can
                # reach before it starts rejecting writes.
                # Valid size suffixes are k, m, or g (case insensitive, 1024 = 1k).
                # Values without a size suffix are in bytes.
                # cache-max-memory-size = "1g"
                # CacheSnapshotMemorySize is the size at which the engine will
                # snapshot the cache and write it to a TSM file, freeing up memory
                # cache-snapshot-memory-size = "25m"
                # CacheSnapshotWriteColdDuration is the length of time at
                # which the engine will snapshot the cache and write it to
                # a new TSM file if the shard hasn't received writes or deletes
                # cache-snapshot-write-cold-duration = "10m"
                # CompactFullWriteColdDuration is the duration at which the engine
                # will compact all TSM files in a shard if it hasn't received a
                # write or delete
                # compact-full-write-cold-duration = "4h"
                # The maximum number of concurrent full and level compactions that can run at one time.  A
                # value of 0 results in 50% of runtime.GOMAXPROCS(0) used at runtime.  Any number greater
                # than 0 limits compactions to that value.  This setting does not apply
                # to cache snapshotting.
                # max-concurrent-compactions = 0
                # CompactThroughput is the rate limit in bytes per second that we
                # will allow TSM compactions to write to disk. Note that short bursts are allowed
                # to happen at a possibly larger value, set by CompactThroughputBurst
                # compact-throughput = "48m"
                # CompactThroughputBurst is the rate limit in bytes per second that we
                # compact-throughput-burst = "48m"
                # If true, then the mmap advise value MADV_WILLNEED will be provided to the kernel with respect to
                # TSM files. This setting has been found to be problematic on some kernels, and defaults to off.
                # It might help users who have slow disks in some cases.
                # tsm-use-madv-willneed = false
                # Settings for the inmem index
                # The maximum series allowed per database before writes are dropped.  This limit can prevent
                # high cardinality issues at the database level.  This limit can be disabled by setting it to
                # 0.
                # max-series-per-database = 1000000
                # The maximum number of tag values per tag that are allowed before writes are dropped.  This limit
                # can prevent high cardinality tag values from being written to a measurement.  This limit can be
                # disabled by setting it to 0.
                # max-values-per-tag = 100000
                # Settings for the tsi1 index
                # The threshold, in bytes, when an index write-ahead log file will compact
                # into an index file. Lower sizes will cause log files to be compacted more
                # quickly and result in lower heap usage at the expense of write throughput.
                # Higher sizes will be compacted less frequently, store more series in-memory,
                # and provide higher write throughput.
                # max-index-log-file-size = "1m"
                # The size of the internal cache used in the TSI index to store previously
                # calculated series results. Cached results will be returned quickly from the cache rather
                # than needing to be recalculated when a subsequent query with a matching tag key/value
                # predicate is executed. Setting this value to 0 will disable the cache, which may
                # lead to query performance issues.
                # This value should only be increased if it is known that the set of regularly used
                # tag key/value predicates across all measurements for a database is larger than 100. An
                # increase in cache size may lead to an increase in heap usage.
                series-id-set-cache-size = 100
              ### [coordinator]
              ### Controls the clustering service configuration.
              [coordinator]
                # The default time a write request will wait until a "timeout" error is returned to the caller.
                # write-timeout = "10s"
                # The maximum number of concurrent queries allowed to be executing at one time.  If a query is
                # executed and exceeds this limit, an error is returned to the caller.  This limit can be disabled
                # by setting it to 0.
                # max-concurrent-queries = 0
                # The maximum time a query will is allowed to execute before being killed by the system.  This limit
                # can help prevent run away queries.  Setting the value to 0 disables the limit.
                # query-timeout = "0s"
                # The time threshold when a query will be logged as a slow query.  This limit can be set to help
                # discover slow or resource intensive queries.  Setting the value to 0 disables the slow query logging.
                # log-queries-after = "0s"
                # The maximum number of points a SELECT can process.  A value of 0 will make
                # the maximum point count unlimited.  This will only be checked every second so queries will not
                # be aborted immediately when hitting the limit.
                # max-select-point = 0
                # The maximum number of series a SELECT can run.  A value of 0 will make the maximum series
                # count unlimited.
                # max-select-series = 0
                # The maximum number of group by time bucket a SELECT can create.  A value of zero will max the maximum
                # number of buckets unlimited.
                # max-select-buckets = 0
              ### [retention]
              ### Controls the enforcement of retention policies for evicting old data.
              [retention]
                # Determines whether retention policy enforcement enabled.
                # enabled = true
                # The interval of time when retention policy enforcement checks run.
                # check-interval = "30m"
              ### [shard-precreation]
              ### Controls the precreation of shards, so they are available before data arrives.
              ### Only shards that, after creation, will have both a start- and end-time in the
              ### future, will ever be created. Shards are never precreated that would be wholly
              ### or partially in the past.
              [shard-precreation]
                # Determines whether shard pre-creation service is enabled.
                # enabled = true
                # The interval of time when the check to pre-create new shards runs.
                # check-interval = "10m"
                # The default period ahead of the endtime of a shard group that its successor
                # group is created.
                # advance-period = "30m"
              ### Controls the system self-monitoring, statistics and diagnostics.
              ### The internal database for monitoring data is created automatically if
              ### if it does not already exist. The target retention within this database
              ### is called 'monitor' and is also created with a retention period of 7 days
              ### and a replication factor of 1, if it does not exist. In all cases the
              ### this retention policy is configured as the default for the database.
              [monitor]
                # Whether to record statistics internally.
                # store-enabled = true
                # The destination database for recorded statistics
                # store-database = "_internal"
                # The interval at which to record statistics
                # store-interval = "10s"
              ### [http]
              ### Controls how the HTTP endpoints are configured. These are the primary
              ### mechanism for getting data into and out of InfluxDB.
              [http]
                # Determines whether HTTP endpoint is enabled.
                # enabled = true
                # Determines whether the Flux query endpoint is enabled.
                # flux-enabled = false
                # Determines whether the Flux query logging is enabled.
                # flux-log-enabled = false
                # The bind address used by the HTTP service.
                # bind-address = ":8086"
                # Determines whether user authentication is enabled over HTTP/HTTPS.
                # auth-enabled = false
                # The default realm sent back when issuing a basic auth challenge.
                # realm = "InfluxDB"
                # Determines whether HTTP request logging is enabled.
                # log-enabled = true
                # Determines whether the HTTP write request logs should be suppressed when the log is enabled.
                # suppress-write-log = false
                # When HTTP request logging is enabled, this option specifies the path where
                # log entries should be written. If unspecified, the default is to write to stderr, which
                # intermingles HTTP logs with internal InfluxDB logging.
                # If influxd is unable to access the specified path, it will log an error and fall back to writing
                # the request log to stderr.
                # access-log-path = ""
                # Filters which requests should be logged. Each filter is of the pattern NNN, NNX, or NXX where N is
                # a number and X is a wildcard for any number. To filter all 5xx responses, use the string 5xx.
                # If multiple filters are used, then only one has to match. The default is to have no filters which
                # will cause every request to be printed.
                # access-log-status-filters = []
                # Determines whether detailed write logging is enabled.
                # write-tracing = false
                # Determines whether the pprof endpoint is enabled.  This endpoint is used for
                # troubleshooting and monitoring.
                # pprof-enabled = true
                # Enables authentication on pprof endpoints. Users will need admin permissions
                # to access the pprof endpoints when this setting is enabled. This setting has
                # no effect if either auth-enabled or pprof-enabled are set to false.
                # pprof-auth-enabled = false
                # Enables a pprof endpoint that binds to localhost:6060 immediately on startup.
                # This is only needed to debug startup issues.
                # debug-pprof-enabled = false
                # Enables authentication on the /ping, /metrics, and deprecated /status
                # endpoints. This setting has no effect if auth-enabled is set to false.
                # ping-auth-enabled = false
                # Determines whether HTTPS is enabled.
                # https-enabled = false
                # The SSL certificate to use when HTTPS is enabled.
                # https-certificate = "/etc/ssl/influxdb.pem"
                # Use a separate private key location.
                # https-private-key = ""
                # The JWT auth shared secret to validate requests using JSON web tokens.
                # shared-secret = ""
                # The default chunk size for result sets that should be chunked.
                # max-row-limit = 0
                # The maximum number of HTTP connections that may be open at once.  New connections that
                # would exceed this limit are dropped.  Setting this value to 0 disables the limit.
                # max-connection-limit = 0
                # Enable http service over unix domain socket
                # unix-socket-enabled = false
                # The path of the unix domain socket.
                # bind-socket = "/var/run/influxdb.sock"
                # The maximum size of a client request body, in bytes. Setting this value to 0 disables the limit.
                # max-body-size = 25000000
                # The maximum number of writes processed concurrently.
                # Setting this to 0 disables the limit.
                # max-concurrent-write-limit = 0
                # The maximum number of writes queued for processing.
                # max-enqueued-write-limit = 0
                # The maximum duration for a write to wait in the queue to be processed.
                # Setting this to 0 or setting max-concurrent-write-limit to 0 disables the limit.
                # enqueued-write-timeout = 0
                      # User supplied HTTP response headers
                      # [http.headers]
                      #   X-Header-1 = "Header Value 1"
                      #   X-Header-2 = "Header Value 2"
              ### [logging]
              ### Controls how the logger emits logs to the output.
              [logging]
                # Determines which log encoder to use for logs. Available options
                # are auto, logfmt, and json. auto will use a more a more user-friendly
                # output format if the output terminal is a TTY, but the format is not as
                # easily machine-readable. When the output is a non-TTY, auto will use
                # logfmt.
                # format = "auto"
                # Determines which level of logs will be emitted. The available levels
                # are error, warn, info, and debug. Logs that are equal to or above the
                # specified level will be emitted.
                # level = "info"
                # Suppresses the logo output that is printed when the program is started.
                # The logo is always suppressed if STDOUT is not a TTY.
                # suppress-logo = false
              ### [subscriber]
              ### Controls the subscriptions, which can be used to fork a copy of all data
              ### received by the InfluxDB host.
              [subscriber]
                # Determines whether the subscriber service is enabled.
                # enabled = true
                # The default timeout for HTTP writes to subscribers.
                # http-timeout = "30s"
                # Allows insecure HTTPS connections to subscribers.  This is useful when testing with self-
                # signed certificates.
                # insecure-skip-verify = false
                # The path to the PEM encoded CA certs file. If the empty string, the default system certs will be used
                # ca-certs = ""
                # The number of writer goroutines processing the write channel.
                # write-concurrency = 40
                # The number of in-flight writes buffered in the write channel.
                # write-buffer-size = 1000
              ### [[graphite]]
              ### Controls one or many listeners for Graphite data.
              [[graphite]]
                # Determines whether the graphite endpoint is enabled.
                # enabled = false
                # database = "graphite"
                # retention-policy = ""
                # bind-address = ":2003"
                # protocol = "tcp"
                # consistency-level = "one"
                # These next lines control how batching works. You should have this enabled
                # otherwise you could get dropped metrics or poor performance. Batching
                # will buffer points in memory if you have many coming in.
                # Flush if this many points get buffered
                # batch-size = 5000
                # number of batches that may be pending in memory
                # batch-pending = 10
                # Flush at least this often even if we haven't hit buffer limit
                # batch-timeout = "1s"
                # UDP Read buffer size, 0 means OS default. UDP listener will fail if set above OS max.
                # udp-read-buffer = 0
                ### This string joins multiple matching 'measurement' values providing more control over the final measurement name.
                # separator = "."
                ### Default tags that will be added to all metrics.  These can be overridden at the template level
                ### or by tags extracted from metric
                # tags = ["region=us-east", "zone=1c"]
                ### Each template line requires a template pattern.  It can have an optional
                ### filter before the template and separated by spaces.  It can also have optional extra
                ### tags following the template.  Multiple tags should be separated by commas and no spaces
                ### similar to the line protocol format.  There can be only one default template.
                # templates = [
                #   "*.app env.service.resource.measurement",
                #   # Default template
                #   "server.*",
              ### [collectd]
              ### Controls one or many listeners for collectd data.
              [[collectd]]
                # enabled = false
                # bind-address = ":25826"
                # database = "collectd"
                # The collectd service supports either scanning a directory for multiple types
                # db files, or specifying a single db file.
                # typesdb = "/usr/local/share/collectd"
                # security-level = "none"
                # auth-file = "/etc/collectd/auth_file"
                # batch-size = 5000
                # Number of batches that may be pending in memory
                # batch-timeout = "10s"
                # read-buffer = 0
                # Multi-value plugins can be handled two ways.
                # "split" will parse and store the multi-value plugin data into separate measurements
                # "join" will parse and store the multi-value plugin as a single multi-value measurement.
                # "split" is the default behavior for backward compatibility with previous versions of influxdb.
                # parse-multivalue-plugin = "split"
              ### [opentsdb]
              ### Controls one or many listeners for OpenTSDB data.
              [[opentsdb]]
                # enabled = false
                # bind-address = ":4242"
                # database = "opentsdb"
                # tls-enabled = false
                # certificate= "/etc/ssl/influxdb.pem"
                # Log an error for every malformed point.
                # log-point-errors = true
                # otherwise you could get dropped metrics or poor performance. Only points
                # metrics received over the telnet protocol undergo batching.
                # batch-size = 1000
                # batch-pending = 5
              ### [[udp]]
              ### Controls the listeners for InfluxDB line protocol data via UDP.
              [[udp]]
                # enabled = false
                # bind-address = ":8089"
                # database = "udp"
                # InfluxDB precision for timestamps on received points ("" or "n", "u", "ms", "s", "m", "h")
                # precision = ""
                # batch-size = 5000
                # Will flush at least this often even if we haven't hit buffer limit
                # read-buffer = 0
              ### [continuous_queries]
              ### Controls how continuous queries are run within InfluxDB.
                # Determines whether the continuous query service is enabled.
                # enabled = true
                # Controls whether queries are logged when executed by the CQ service.
                # Controls whether queries are logged to the self-monitoring data store.
                # query-stats-enabled = false
                # interval for how often continuous queries will be checked if they need to run
                # run-interval = "1s"
              ### [tls]
              ### Global configuration settings for TLS in InfluxDB.
              [tls]
                # Determines the available set of cipher suites. See https://golang.org/pkg/crypto/tls/#pkg-constants
                # for a list of available ciphers, which depends on the version of Go (use the query
                # SHOW DIAGNOSTICS to see the version of Go used to build InfluxDB). If not specified, uses
                # the default settings from Go's crypto/tls package.
                # ciphers = [
                #   "TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305",
                #   "TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305",
                # Minimum version of the tls protocol that will be negotiated. If not specified, uses the
                # default settings from Go's crypto/tls package.
                # min-version = "tls1.2"
                # Maximum version of the tls protocol that will be negotiated. If not specified, uses the
                # max-version = "tls1.3"
              • Marc Berg
                [monitor]
                #Whether to record statistics internally.
                #store-enabled = true
                Scheint so, als ob die DB nichr mehr mit den massenhaften Monitoringdaten klarkommt. Fraglich ist, ob diese Dateien Ursache oder Folge sind.
                Auf jeden Fall würde ich das Monitoring zunächst mal abschalten:
                [monitor]
                store-enabled = false
                Danach DB neu starten. Wenn der Fehler immer noch auftritt, die WAL-Dateien zum Monitoring löschen:
                sudo systemctl stop influxdb
                sudo rm -rf /var/lib/influxdb/wal/_internal/monitor/*
                sudo systemctl start influxdb
                Nach Neustart:
                influx_inspect verify -dir /var/lib/influxdb
                • MichaelF
                  MichaelF @Marc Berg last edited by MichaelF
                  @marc-berg
                  Hi, gemacht aber leider keine Veränderung.
                  Ich sende morgen nochmal die Ergebnisse der ersten Fragen.
                  Ich glaube ich habe jetzt eine andere Fehlermeldung aber mein Handy ist zu klein um die ganze Meldung zu sehen.
                  Riesen Dank schon mal.
                  pi@Influxdb1:~ $ sudo systemctl start influxdb
                  Job for influxdb.service failed because a timeout was exceeded.
                  See "systemctl status influxdb.service" and "journalctl -xe" for details.
                  pi@Influxdb1:~ $ systemctl status influxdb.service
                       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset:>     Active: activating (start) since Mon 2025-02-10 23:19:24 CET; 56s ago
                  Cntrl PID: 5200 (influxd-systemd)
                          CPU: 1min 38.103s
                               ├─5200 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh             ├─5201 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                               └─5454 sleep 1
                  Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.1>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.2>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.3>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.4>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.5>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5200]: InfluxDB API unavailable>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.6>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.7>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.8>Feb 10 23:20:20 Influxdb1 influxd-systemd-start.sh[5201]: ts=2025-02-10T22:20:20.9>lines 1-22/22 (END)
                  • MichaelF
                    MichaelF @MichaelF last edited by MichaelF
                    Log nicht zu lesen, morgen nochmal.
                    Grüsse
                    • MichaelF
                      Journal begins at Mon 2025-02-03 06:12:12 CET, ends at Tue 2025-02-11 12:24:03 CET. --
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.602070Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/230/000000112-000000003.tsm id=0 duration=3.723ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.614121Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/239/000000114-000000002.tsm id=0 duration=7.730ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.656292Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/239 duration=55.472ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.663044Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/24/000000105-000000002.tsm id=0 duration=1.574ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.667617Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/230 duration=75.943ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.675086Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/248/000000114-000000002.tsm id=0 duration=1.660ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.685502Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/24 duration=28.951ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.693173Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/257/000000111-000000002.tsm id=0 duration=1.565ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.715310Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/248 duration=47.491ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.723450Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/266/000000111-000000002.tsm id=0 duration=2.183ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.734741Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/257 duration=49.039ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.748120Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/275/000000111-000000002.tsm id=0 duration=2.261ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.755391Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/266 duration=39.869ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.762004Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/284/000000111-000000002.tsm id=0 duration=1.762ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.774845Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/275 duration=38.971ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.786488Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/293/000000110-000000002.tsm id=0 duration=5.532ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.789566Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/284 duration=33.300ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.795554Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/302/000000112-000000002.tsm id=0 duration=1.626ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.815881Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/293 duration=40.724ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.822813Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/302 duration=33.069ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.824321Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/311/000000112-000000002.tsm id=0 duration=1.639ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.829334Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/320/000000118-000000002.tsm id=0 duration=1.611ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.848603Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/311 duration=32.385ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.855749Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/320 duration=32.603ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.857085Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/329/000000112-000000002.tsm id=0 duration=2.344ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.860734Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/33/000000106-000000002.tsm id=0 duration=1.536ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.882806Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/33 duration=26.856ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.885658Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/329 duration=36.675ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.890456Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/339/000000111-000000002.tsm id=0 duration=1.883ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.913329Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/348 duration=27.489ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.930345Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/357/000000112-000000003.tsm id=0 duration=2.966ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.942186Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/339 duration=59.053ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.954605Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/366/000000109-000000002.tsm id=0 duration=5.086ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.985502Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/357 duration=71.934ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.992987Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/375/000000107-000000002.tsm id=0 duration=1.758ms
                      Feb 11 12:23:52 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:52.998584Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/366 duration=56.073ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.006073Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/384/000000108-000000002.tsm id=0 duration=1.622ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.016788Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/375 duration=31.093ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.035517Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/393/000000108-000000002.tsm id=0 duration=2.029ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.083721Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/384 duration=84.953ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.094392Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/403/000000106-000000002.tsm id=0 duration=1.791ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.105624Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/393 duration=88.601ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.112162Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/412/000000105-000000002.tsm id=0 duration=1.832ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.120579Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/403 duration=36.681ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.138737Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/42/000000106-000000002.tsm id=0 duration=14.156ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.183967Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/412 duration=78.156ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.198668Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/420/000000109-000000002.tsm id=0 duration=6.371ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.203303Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/42 duration=82.535ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.211680Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/429/000000109-000000002.tsm id=0 duration=2.737ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.246610Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/420 duration=62.331ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2417]: InfluxDB API unavailable after 3 attempts...
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.256357Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/438/000000108-000000002.tsm id=0 duration=2.549ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.294610Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/429 duration=91.100ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.300776Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/447/000000111-000000002.tsm id=0 duration=2.068ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.336082Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/438 duration=88.521ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.348089Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/456/000000113-000000002.tsm id=0 duration=7.337ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.365775Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/447 duration=70.980ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.392680Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/465/000000114-000000002.tsm id=0 duration=3.602ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.439221Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/456 duration=102.924ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.457413Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/465 duration=74.590ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.461589Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/474/000000119-000000002.tsm id=0 duration=14.444ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.469779Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/483/000000112-000000002.tsm id=0 duration=2.310ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.547053Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/483 duration=88.606ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.554996Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/474 duration=115.486ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.558424Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000033-000000003.tsm id=0 duration=0.388ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.558572Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/502/000000096-000000003.tsm id=2 duration=0.629ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.560073Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000101-000000001.tsm id=4 duration=3.800ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.561836Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000102-000000001.tsm id=5 duration=2.279ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.563251Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000108-000000001.tsm id=9 duration=7.051ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.564942Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/502/000000032-000000003.tsm id=0 duration=0.655ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.565742Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/502/000000064-000000003.tsm id=1 duration=0.505ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.566492Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000098-000000003.tsm id=2 duration=0.478ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.567532Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000065-000000003.tsm id=1 duration=0.538ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.571363Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000103-000000001.tsm id=6 duration=11.596ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.572395Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000107-000000001.tsm id=8 duration=9.720ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.573764Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000105-000000001.tsm id=7 duration=13.359ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.596634Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/492/000000099-000000001.tsm id=3 duration=28.755ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.597700Z lvl=info msg="Reading file" log_id=0ueBrmBG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/iobroker/autogen/492/_00116.wal size=10485763
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.625962Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/502 duration=70.411ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.638019Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/51/000000106-000000002.tsm id=0 duration=4.611ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.684121Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/51 duration=57.437ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.689647Z lvl=info msg="Opened file" log_id=0ueBrmBG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/iobroker/autogen/60/000000106-000000002.tsm id=0 duration=1.563ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.725164Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/60 duration=40.860ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.780903Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/69 duration=55.517ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.869013Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/78 duration=87.918ms
                      Feb 11 12:23:53 Influxdb1 influxd-systemd-start.sh[2418]: ts=2025-02-11T11:23:53.887907Z lvl=info msg="Opened shard" log_id=0ueBrmBG000 service=store trace_id=0ueBrmaG000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/iobroker/autogen/86 duration=18.690ms
                      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                           Active: activating (start) since Tue 2025-02-11 12:25:21 CET; 1min 15s ago
                             Docs: https://docs.influxdata.com/influxdb/
                      Cntrl PID: 2754 (influxd-systemd)
                            Tasks: 14 (limit: 1595)
                              CPU: 2min 9.975s
                           CGroup: /system.slice/influxdb.service
                                   ├─2754 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                                   ├─2755 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                   └─3054 sleep 1
                      Feb 11 12:26:35 Influxdb1 influxd-systemd-start.sh[2754]: InfluxDB API unavailable after 71 attempts...
                      Feb 11 12:26:35 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:35.855577Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00577.wal size=193809
                      Feb 11 12:26:35 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:35.961077Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00578.wal size=193270
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.065864Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00579.wal size=194107
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.169997Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00580.wal size=193828
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.274682Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00581.wal size=194383
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.378973Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00582.wal size=194039
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.482300Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00583.wal size=193422
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.592391Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_internal/monitor/501/_00584.wal size=194059
                      Feb 11 12:26:36 Influxdb1 influxd-systemd-start.sh[2755]: ts=2025-02-11T11:26:36.714681Z lvl=info msg="Reading file" log_id=0ueBxId0000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/_int
                      [shard-precreation] time when the check to pre-create new shards runs.
                        # enabled = true
                        # group is created.em self-monitoring, statistics and diagnostics.
                      ### Controls the system self-monitoring, statistics and diagnostics.of 7 days
                      [monitor]estination database for recorded statistics
                      ### [http]
                      • Marc Berg
                        Marc Berg Most Active @MichaelF last edited by
                        @michaelf sagte in [influxDB] InfluxDB API unavailable after 10 attempts:
                        Steht da wirklich das "estination database for recorded statistics" hinter "[monitor]"? Das müsste dann weg. Und das Leerzeichen vor "store-enabled" zur Sicherheit auch.
                        Was bringt
                        In der Ausgabe?
                        Könnte es außerdem sein, dass ein anderer Dienst auf dem Port 8086 hört und den Start der DB verhindert?
                        MichaelF 1 Reply Last reply Reply Quote 0
                        • MichaelF
                          @marc-berg
                          So sieht es genau aus:
                          [monitor]
                          ### [http]
                          [http]
                            # enabled = true
                          War wohl ein Fehler beim Ausscheiden
                          pi@Influxdb1:~ $ sudo influx_inspect verify -dir /var/lib/influxdb
                          /var/lib/influxdb/data/_internal/monitor/493/000000039-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/494/000000037-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/496/000000037-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/497/000000037-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/498/000000038-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/499/000000038-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/500/000000037-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000024-000000002.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000025-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000026-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000027-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000028-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000029-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000030-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000031-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000032-000000001.tsm: healthy
                          /var/lib/influxdb/data/_internal/monitor/501/000000033-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/107/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/116/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/125/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/134/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/143/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/152/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/161/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/17/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/170/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/179/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/188/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/197/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/2/000000011-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/206/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/215/000000018-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/224/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/233/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/242/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/251/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/26/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/260/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/269/000000014-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/278/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/287/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/296/000000014-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/305/000000014-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/314/000000014-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/323/000000018-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/331/000000006-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/333/000000035-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/342/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/35/000000017-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/351/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/360/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/369/000000036-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/378/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/387/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/396/000000009-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/405/000000039-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/414/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/423/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/432/000000009-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/44/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/441/000000008-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/450/000000051-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/459/000000012-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/468/000000012-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/477/000000012-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/486/000000023-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/486/000000024-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000001-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000003-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000004-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000005-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000007-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000009-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/495/000000010-000000001.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/53/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/62/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/71/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/8/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/80/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/89/000000016-000000002.tsm: healthy
                          /var/lib/influxdb/data/evcc/autogen/98/000000015-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/104/000000112-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/113/000000110-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/122/000000109-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/131/000000112-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/140/000000112-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/158/000000113-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/167/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/176/000000110-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/185/000000110-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/194/000000109-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/203/000000110-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/212/000000113-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/221/000000113-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/230/000000112-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/239/000000114-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/24/000000105-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/248/000000114-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/257/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/266/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/275/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/284/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/293/000000110-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/302/000000112-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/311/000000112-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/320/000000118-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/329/000000112-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/33/000000106-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/339/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/357/000000112-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/366/000000109-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/375/000000107-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/384/000000108-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/393/000000108-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/403/000000106-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/412/000000105-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/42/000000106-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/420/000000109-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/429/000000109-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/438/000000108-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/447/000000111-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/456/000000113-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/465/000000114-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/474/000000119-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/483/000000112-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000033-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000065-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000098-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000099-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000101-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000102-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000103-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000105-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000107-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/492/000000108-000000001.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/502/000000032-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/502/000000064-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/502/000000096-000000003.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/51/000000106-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/60/000000106-000000002.tsm: healthy
                          /var/lib/influxdb/data/iobroker/autogen/95/000000107-000000002.tsm: healthy
                          Broken Blocks: 0 / 883129, in 46.761652932s
                          Auf dem Pi läuft nur die Influxdb sonst nichts. Oder isst mit dem Port was anderes gemeint ?
                          • MichaelF
                            Bin am überlegen ob ich vieleicht einfach influx neu installieren soll. Ein Backup der Datenbank hätte ich.
                            Bin mir halt auch nicht sicher ob dies Funktioniert oder machbar ist, jemand eventuell noch eine Idee dazu ?
                            • MichaelF
                              Hi, hab es gefunden........
                              Das hier war es.
                              Danke und Grüße
                              769
