    4. Probleme bei Updates
      toki1973 @shellyrulestheworld last edited by toki1973
      Konnte das Node.js auch über den Terminal Zugriff durchführen. Über die iob GUI ging das nicht. Es hat sehr lange gedauert bis die GUI wieder erreichbar war.
      Ein Diag zeigt Fehler bei redis - habe ich aber gar nicht aktiviert. Allerdings habe ich schonmanchal eine langsame Event Durcheichung.
      ```bash
                              v.2025-02-02
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-28-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
      Installation:           kvm
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     1
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/corepack       0.29.4
      Recommended versions are nodejs  Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.iobroker"]
      No connection to databases possible ... and npm  Connection is closed.
      nodeJS installation is correct
      MEMORY:
      Mem:            6.3G        4.1G        1.2G        610K        1.4G        2.3G
      Swap:           1.0G          0B        1.0G
      Total:          7.4G        4.1G        2.2G
      Active iob-Instances:   0
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (node:events:633:26)
          at Socket.emit (node:events:518:28)
          at TCP.<anonymous> (node:net:343:12)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Node.js v20.18.2
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.0.23
      Objects type: jsonl
      States  type: jsonl
      Objects:                126111
      States:                 97783
      Size of iob-Database:
      93M     /opt/iobroker/iobroker-data/objects.jsonl
      25M     /opt/iobroker/iobroker-data/states.jsonl
      Operating System is the current Debian stable version codenamed 'bookworm'!
      Jedesmal nach dem Update habe ich Probleme.
      T Homoran 2 Replies Last reply Reply Quote 0
        toki1973 @toki1973 last edited by toki1973
           Checking autostart (5/5)
        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
        Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
        Authenticating as: toki,,, (toki)
        Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        toki@iobroker:~$ iob status
                throw e;
        Node.js v20.18.2
          Thomas Braun Most Active @toki1973 last edited by
          @toki1973
          Das ist aber was für einen eigenen Thread. Dein nodejs ist ja richtig installiert.
          Da dann die Ausgabe von
          iob diag
          in der Langfassung rein.
            @thomas-braun Hab 7ch mal gemacht, mir fiel aber kein passender Threadtitel ein.
            @toki1973 bitte provisorischen Threadtitel anpassen
              Homoran Global Moderator Administrators @toki1973 last edited by
              @toki1973 sagte in Probleme bei Updates:
              Wo soll man da nodejs upgraden können? 🤔
              Welcher Art?
