    4. Vis 2 Beta löschen
    Vis 2 Beta löschen
    • FragMike
      FragMike last edited by
      Hallo Leute. Ich habe mir irgendwann mal die Vis 2 beta.0 installiert. Wie werde ich diese wieder los. Taucht bei mir nicht in den Adaptern auf und ist somit über diesen Weg nicht zu deinstallieren.
      • mcm1957
        mcm1957 @FragMike last edited by
        @fragmike
        Zeig mal den Output von iob diag in der Langfassung.
        An sich sollten alle installierten Adapter ja sichtbar sein.
        FragMike 1 Reply Last reply Reply Quote 0
        • FragMike
          FragMike @mcm1957 last edited by
          @mcm1957
          /opt/iobroker$ iob diag
          TERM environment variable not set.
          *** iob diag is starting up, please wait ***
          107*** ioBroker Diagnosis ***
          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
          https://forum.iobroker.net
          Just copy and paste the Summary Page, including the ``` characters at start and end.
          It helps us to help you!
          Press any key to continue
          ========== Start marking the full check here ===========
          Script v.2025-02-02
          107*** BASE SYSTEM ***
             Static hostname: IOBROKER
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
            Operating System: Ubuntu 20.04.6 LTS
                      Kernel: Linux 6.8.12-4-pve
                Architecture: x86-64
          OS is similar to: debian
          model name    : 11th Gen Intel(R) Core(TM) i5-11500T @ 1.50GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
          16:22:00 up  7:12,  0 users,  load average: 0.21, 0.23, 0.21
          CPU threads: 10
          107*** LIFE CYCLE STATUS ***
          Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
          107*** TIME AND TIMEZONES ***
                         Local time: Sun 2025-02-23 16:22:00 CET
                     Universal time: Sun 2025-02-23 15:22:00 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          107*** Users and Groups ***
          User that called 'iob diag':
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          iobroker
          HOME=/home/iobroker
          A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
          A root login is not required in most Linux Distributions.
          Run 'iobroker fix' or use the system tools to create a user.
          107*** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          107*** MEMORY ***
          Mem:           6.3G        2.4G        1.5G        0.0K        2.4G        3.9G
          Swap:          512M          0B        512M
          Total:         6.8G        2.4G        2.0G
          Active iob-Instances:     24
                   6272 M total memory
                   2371 M used memory
                   2679 M active memory
                   1981 M inactive memory
                   1467 M free memory
                      0 M buffer memory
                   2433 M swap cache
                    512 M total swap
                      0 M used swap
                    512 M free swap
          107*** top - Table Of Processes  ***
          top - 16:22:01 up  7:12,  0 users,  load average: 0.21, 0.23, 0.21
          Tasks:  54 total,   1 running,  53 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   6272.0 total,   1466.3 free,   2371.5 used,   2434.2 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3900.3 avail Mem
          107*** FAILED SERVICES ***
            UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
          1 loaded units listed.
          107*** DMESG CRITICAL ERRORS ***
          sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
          No critical errors detected
          107*** FILESYSTEM ***
          /dev/loop0     ext4       18G   11G  6.3G  63% /
          none           tmpfs     492K  4.0K  488K   1% /dev
          efivarfs       efivarfs  192K   80K  108K  43% /sys/firmware/efi/efivars
          udev           devtmpfs  7.7G     0  7.7G   0% /dev/tty
          tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
          tmpfs          tmpfs     1.6G  120K  1.6G   1% /run
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          Show mounted filesystems:
          TARGET                    SOURCE                         FSTYPE     OPTIONS
          /                         /dev/loop0                     ext4       rw,relatime
          |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/diskstats         lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/loadavg           lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/meminfo           lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/slabinfo          lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/stat              lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/swaps             lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/uptime            lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          Archived and active journals take up 184.0M in the file system.
          /opt/iobroker/backups:
          1.3G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.3G    /opt/iobroker/iobroker-data/
          1008M    /opt/iobroker/iobroker-data/files
          796M    /opt/iobroker/iobroker-data/history
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          38M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          35M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          26M    /opt/iobroker/iobroker-data/objects.jsonl
          24M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          /dev/ttyUSB0
          107*** NodeJS-Installation ***
          /usr/bin/nodejs     v20.18.1
          /usr/bin/node         v20.18.1
          /usr/bin/npm         10.8.2
          /usr/bin/npx         10.8.2
          /usr/bin/corepack     0.29.4
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.3-1nodesource1
            Version table:
               20.18.3-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.18.2-1nodesource1 1001
          *** 20.18.1-1nodesource1 1001
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               10.19.0~dfsg-3ubuntu1.6 500
                  500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                  500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
               10.19.0~dfsg-3ubuntu1 500
                  500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
          No problems detected
          Errors in npm tree: 0
          107*** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          IOBROKER            IOBROKER (version: 7.0.6, hostname: IOBROKER      , alive, uptime: 25909)
          Core adapters versions
          js-controller:     7.0.6
          admin:         7.4.10
          javascript:     8.8.3
          nodejs modules from github:     1
          +-- iobroker.vw-connect@0.6.1 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#309769f6889c08b0789f21d327b98743f7147d3d)
          Adapter State
          + system.adapter.admin.0                  : admin                 : IOBROKER                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : IOBROKER                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : IOBROKER                                 -  enabled
          + system.adapter.backitup.0               : backitup              : IOBROKER                                 -  enabled
          + system.adapter.chromecast.0             : chromecast            : IOBROKER                                 -  enabled
            system.adapter.cloud.0                  : cloud                 : IOBROKER                                 - disabled
            system.adapter.devices.0                : devices               : IOBROKER                                 - disabled
          + system.adapter.discovery.0              : discovery             : IOBROKER                                 -  enabled
            system.adapter.firetv.0                 : firetv                : IOBROKER                                 - disabled
            system.adapter.habpanel.0               : habpanel              : IOBROKER                                 - disabled
          + system.adapter.history.0                : history               : IOBROKER                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : IOBROKER                                 -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : IOBROKER                                 -  enabled
          + system.adapter.iot.0                    : iot                   : IOBROKER                                 -  enabled
          + system.adapter.javascript.0             : javascript            : IOBROKER                                 -  enabled
            system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER                                 - disabled
            system.adapter.mqtt.0                   : mqtt                  : IOBROKER                                 - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : IOBROKER                                 -  enabled
          + system.adapter.node-red.0               : node-red              : IOBROKER                                 -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: IOBROKER                                 - disabled
          + system.adapter.pushover.0               : pushover              : IOBROKER                                 -  enabled
          + system.adapter.sayit.1                  : sayit                 : IOBROKER                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : IOBROKER                                 -  enabled
          + system.adapter.shuttercontrol.0         : shuttercontrol        : IOBROKER                                 -  enabled
          + system.adapter.smartthings.0            : smartthings           : IOBROKER                                 -  enabled
          + system.adapter.sonoff.0                 : sonoff                : IOBROKER                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.terminal.0               : terminal              : IOBROKER                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          + system.adapter.tuya.0                   : tuya                  : IOBROKER                                 -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IOBROKER                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : IOBROKER                                 - disabled
            system.adapter.vis.0                    : vis                   : IOBROKER                                 -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : IOBROKER                                 -  enabled
          + system.adapter.web.0                    : web                   : IOBROKER                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : IOBROKER                                 -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
          Adapter    "discovery"    : 5.0.0    , installed 5.0.0
          Adapter    "firetv"       : 2.1.0    , installed 2.1.0
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "panasonic-comfort-cloud": 3.0.3, installed 3.0.3
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "sayit"        : 5.0.0    , installed 5.0.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shuttercontrol": 1.8.8   , installed 1.8.5  [Updatable]
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 2.5.3  [Updatable]
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
          Objects and States
          Objects:     11217
          States:     9192
          107*** OS-Repositories and Updates ***
          W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
          W:
          Hit:1 https://apt.grafana.com stable InRelease
          Hit:2 https://repos.influxdata.com/debian stable InRelease
          Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu focal InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:6 http://archive.ubuntu.com/ubuntu focal-security InRelease
          Reading package lists...
          Pending Updates: 38
          107*** Listening Ports ***
          107*** Log File - Last 25 Lines ***
          2025-02-23 16:21:45.510  - error: smartthings.0 (1232) Error extract keys: a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value. ""
          2025-02-23 16:21:45.510  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:21:55.438  - error: smartthings.0 (1232) Cannot extract array a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap
          2025-02-23 16:21:55.438  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:21:55.447  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:21:55.447  - error: smartthings.0 (1232) Error extract keys: a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value. ""
          2025-02-23 16:21:59.344  - warn: zigbee.0 (724) Send command to 0xb40ecfd02e0d0000 failed with: Code 205 (No network route)
          2025-02-23 16:22:05.406  - error: smartthings.0 (1232) Cannot extract array a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap
          2025-02-23 16:22:05.406  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:22:05.458  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:22:05.458  - error: smartthings.0 (1232) Error extract keys: a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value. ""
          2025-02-23 16:22:15.478  - error: smartthings.0 (1232) Cannot extract array a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap
          2025-02-23 16:22:15.478  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:22:15.569  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:22:15.569  - error: smartthings.0 (1232) Error extract keys: a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value. ""
          2025-02-23 16:22:24.483  - warn: zigbee.0 (724) Send command to 0xb40ecfd02e0d0000 failed with: Code 205 (No network route)
          2025-02-23 16:22:25.466  - error: smartthings.0 (1232) Cannot extract array a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap
          2025-02-23 16:22:25.466  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModeMap.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:22:25.477  - error: smartthings.0 (1232) Error: The id "a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value." is invalid. Ids are not allowed to end in "."
          2025-02-23 16:22:25.477  - error: smartthings.0 (1232) Error extract keys: a6893adc-61bd-82a5-6daf-f1dfe07b9543.status.samsungvd.lightControl.supportedModes.value. ""
          2025-02-23 16:22:30.875  - info: tuya.0 (746) bf2972311cdc63d3e35fdz: Unknown datapoint 40 with value relay. Please resync devices
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
                      v.2025-02-02
                     Chassis: container
              Virtualization: lxc
          Installation:         lxc
          Kernel:         x86_64
          Userland:         64 bit
          Timezone:         Europe/Berlin (CET, +0100)
          User-ID:         1000
          Boot Target:         graphical.target
          Pending OS-Updates:     38
          Pending iob updates:     3
          Nodejs-Installation:
          /usr/bin/npm         10.8.2
          /usr/bin/npx         10.8.2
          Recommended versions are nodejs 20.18.3 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:           6.3G        2.5G        899M        0.0K        2.9G        3.8G
          Swap:          512M          0B        512M
          Total:         6.8G        2.5G        1.4G
          ioBroker Core:         js-controller         7.0.6
                      admin             7.4.10
          ioBroker Status:     iobroker is running on this host.
          Objects type: jsonl
          States  type: jsonl
          Objects:         11217
          States:         9192
          Size of iob-Database:
          36M    /opt/iobroker/iobroker-data/objects.jsonl
          13M    /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          • FragMike
            FragMike @FragMike last edited by FragMike
            hoffe ich habe das hier richtig gemacht. Inzwischen habe ich wohl vis2 installiert.....sehe aber nirgends eine Möglichkeit die Visu zu starten.....
            • BananaJoe
              BananaJoe Most Active @FragMike last edited by
              @fragmike was willst du da starten? Öffne die URL des Web-Adapters, dann bekommst du eine Auswahl:
              bei mir ist beides, VIS und VIS2 zur Auswahl, Editoren und die Projektseiten
              Default müsste es
              http://IP-deines-ioBrokers:8082
              sein
              • FragMike
                hier habe ich lediglich die alte vis zur Auswahl
                vis 2 ist aber installiert !?
                hier taucht sie auch nicht auf !?
                • FragMike
                  via ssh
                  cd /opt/iobroker
                  npm i iobroker.vis-2
                  iob add vis-2
                  iob upload vis-2
                  jetzt gehts 🙂
                  BananaJoe mcm1957 2 Replies Last reply Reply Quote 0
                  • BananaJoe
                    BananaJoe Most Active @FragMike last edited by BananaJoe
                    @fragmike also wenn ich eines von @thomas-braun gelernt habe, dann das man nicht mit npm im iobroker-Verzeichnis rumfuhrwerkt um Adapter zu installieren
                      Thomas Braun Most Active @BananaJoe last edited by
                      @bananajoe sagte in Vis 2 Beta löschen:
                      Zumindest nicht in flaschen Verzeichnissen.
                      Hier ist aber wohl das richtige erwischt worden.
                      Wobei
                      iob add vis-2
                      natürlich redundant ist.
                      @FragMike
                      Bring das Ding auf einen aktuellen Stand...
                      • mcm1957
                        @fragmike said in Vis 2 Beta löschen:
                        via ssh
                        cd /opt/iobroker
                        iob add vis-2
                        iob upload vis-2
                        jetzt gehts 🙂
                        NEIN NEIN NEIN
                        Keinesfalls (ohne explizite Anweisung für ganz ganz selten und letzte Reparaturversuche) irgendwas von ioBroker mittels npm direkt installieren. Einmal mit dem falschen User oder im falschen Verzeichnis und du kannst due Qualität deines Backups testen.
                        Adapter IMMER mit den vorhandenen ioBroker Befehlen installieren / deinstallieren.
                        • FragMike
                          Ok... Wieder was gelernt. Backups habe ich im Wochen Turnus auf der VM. Ich habe natürlich überall wild raumgesucht, aber für meinen Wissensstand keine zuverlässige Methode gefunden, die Vis2 auf korrekte Weise mal einfach so zu installieren. GITHUB Installation & Documentation gibt einem nicht wirklich sinnvolle Hinweise. Nun scheint es zu laufen und ich habe wohl nix kaputt gemacht😁
                          509
